MYS-7Z007S-C-S
MYS-7Z007S-C-S
    MYIR(米尔科技)
    Xilinx ARM Cortex A9 单板 XC7Z007S 766MHz 256MB 5V DDR3 8W
MYS-7Z007S-C-S 数据手册
Z-turn Lite        766MHz Xilinx XC7Z007S or XC7Z010 ARM Cortex-A9 Processor with Xilinx 7-series FPGA logic 512MB DDR3 SDRAM (2 x 256MB, 32-bit), 4GB eMMC Flash, 16MB QSPI Flash Micro USB2.0 OTG, 1 x 10/100/1000M Ethernet, TF, Debug UART, JTAG… Optional Camera Modules and IO Extension Cape Supports 7-inch LCD Module through Z-turn Lite IO Cape Minimal and compact system of Xilinx Zynq-7007S or Zynq-7010 SoC Ready-to-Run Linux Single Board Computer Figure 1-1 Z-turn Lite Board The Z-turn Lite is an ultra-cost-effective lite version of MYIR’s Z-turn board. It is built around Xilinx Zynq-7007S (Single-core) or Zynq-7010 (Dual-core) ARM Cortex-A9 MPCore processor and can work at up to 766MHz. It is a minimal and compact system of Xilinx Z-7007S or Z-7010 SoC and provide numerous pending configuration of PL resources. The Z-turn Lite takes full features of the Zynq-7007S or Zynq-7010 SoC which leverages the 28nm scalable optimized programmable logic used in Xilinx’s 7 series FPGAs. The board is equipped with 512MB DDR3, 4GB eMMC Flash, 16MB QSPI Flash and a set of peripherals on board including Micro USB OTG, 10/100/1000Mbps Ethernet, TF, JTAG, Debug UART, etc. Additionally, there is one 120-pin Expansion connector on the rear of the board to bring out as many as IO signals for user extensions. The Z-turn Lite is capable of running Linux operating system and provided with Linux 3.15.0 SDK, the kernel and many drivers are in source code. The Z-turn Lite Kit is delivered with complete accessories including one micro USB cable, one Ethernet cable, one 4GB TF card, one USB-to-UART cable and one 5V power adapter and product disk which enables you to start the development quickly when getting the board out-of-the-box. It is an excellent reference design and evaluation board for development based on Xilinx Zynq-7000 series SoCs. 1/7 Hardware Specification The Zynq-7000 AP SoC leverages the 28nm scalable optimized programmable logic used in Xilinx’s 7 series FPGAs. It comprises single and dual ARM Cortex-A9 equipped devices, providing processor scalability across the platform Zynq-7000S and Zynq-7000. Zynq-7000S devices are the cost optimized entry point to the Zynq-7000 SoC platform. With a single-core ARM Cortex-A9 processor mated with 28nm Artix®-7 based programmable logic, Zynq-7000S devices are ideal for industrial IoT applications such as motor control and embedded vision. Zynq-7000 devices are optimized for performance-per-watt and maximum design flexibility. Dual-core ARM Cortex-A9 processors are integrated with 7 series programmable logic to enable highly differentiated designs for a wide range of embedded applications. Figure 1-2 ZYNQ-7000 Device Family 2/7 The Z-turn Lite is based on the Xilinx Zynq-7007S or Zynq-7010 SoC and the hardware specification is listed in following table1-1: Item SoC Memory Storage Communications Input and Output Others Dimensions Power supply Temp. Power consumption OS Support Target Applications Features Xilinx XC7Z007S-1CLG400C (Zynq-7007S) or XC7Z010-1CLG400C (Zynq-7010) - ARM® Cortex™-A9 MPCore processor Up to 766MHz single-core processor (for XC7Z007S) 766MHz dual-core processor (up to 866MHz, for XC7Z010) - Integrated Artix-7 class FPGA subsystem with 23K logic cells, 14,400 LUTs, 66DSP slices (for XC7Z007S) with 28K logic cells, 17,600 LUTs, 80 DSP slices (for XC7Z010) - NEON™ & Single / Double Precision Floating Point for each processor - Supports a Variety of Static and Dynamic Memory Interfaces 512MB DDR3 SDRAM (2 x 256MB, 32-bit) 4GB eMMC Flash 16MB QSPI Flash TF card interface 1 x 10/100/1000M Ethernet 1 x Micro USB2.0 OTG 1 x 2.54mm pitch 14-pin JTAG interface 1 x 0.5mm pitch 120 Position Connector Socket for Expansion interface 1 x 2.54mm pitch 4-pin Debug UART interface 2 x Buttons (1x Reset, 1 x User) 5 x LEDs - 1 x User LED - 1 x FPGA configuration indicator - 1 x FPGA initialization indicator - 1 x Power indicator - 1 x USB overcurrent indicator 91mm x 63mm (10-layer PCB design ) DC 5V/2A 0~70 Celsius 8W Linux 3.15.0 Evaluation and Prototyping for Zynq-7000 AP SoC Multi-Axis Motor Control Machine Vision Programmable Logic Controller Industrial Automation Test & measurement Table 1-1 Z-turn Lite Hardware Specification 3/7 Figure 1-3 Z-turn Lite (Top-view) Figure 1-4 Z-turn Lite (Bottom-view) 4/7 Figure 1-5 Z-turn Lite Function Block Diagram M Figure 1-6 Z-turn Lite Dimension Chart 5/7 Software Features Item Features Description Cross compiler gcc 4.6.1 gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) Boot program BOOT.BIN First boot program including FSBL, bitstream and Source code provided u-boot Linux Kernel Linux 3.15.0 Customized kernel for Z-turn Lite USB OTG Ethernet Drivers USB OTG driver Gigabit Ethernet driver MMC/SD/TF MMC/SD/TF card driver Button Button driver LED LED driver UART GPIO Watchdog File System Ramdisk UART driver GPIO driver Watchdog driver Ramdisk system image Table 1-2 Software Features of Z-turn Lite 6/7 Remark Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Order Information Item Z-turn Lite Part No. MYS-7Z007S-C-S MYS-7Z010-L-C-S MYS-7Z007S-C Z-turn Lite Kit MYS-7Z010-L-C Packing List                   One Z-turn Lite (for Zynq-7007S) One product disk One Z-turn Lite (for Zynq-7010) One product disk One Z-turn Lite (for Zynq-7007S) One 1.5m cross Ethernet cable One 1.2m Micro USB2.0 cable One MY-UART012U USB-to-UART cable One 4GB TF card One 5V/2A Power adapter One product disk (including user manual, schematic in PDF format, datasheets and software package) One Z-turn Lite Board (for Zynq-7010) One 1.5m cross Ethernet cable One 1.2m Micro USB2.0 cable One MY-UART012U USB-to-UART cable One 4GB TF card One 5V/2A Power adapter One product disk (including user manual, schematic in PDF format, datasheets and software package) Z-turn Lite IO Cape MY-CAPE002 Optional IO Expansion Board MY-LCD70TP-C MY-TFT070CV2 7-inch LCD Module with Capacitive Touch Screen USB Camera Module MY-CAM002U Optional USB Camera Module MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 7/7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: MYIR Tech: MYS-7Z007S-C MYS-7Z010-L-C-S MYS-7Z010-L-C
MYS-7Z007S-C-S 价格&库存
很抱歉,暂时无法提供与“MYS-7Z007S-C-S”相匹配的价格&库存,您可以联系我们找货
