MYD-Y7Z010-4E512D-667-I
    MYIR(米尔科技)
    主芯片 Zynq-7000 开发板
MYD-Y7Z010-4E512D-667-I 数据手册
MYD-Y7Z010/007S Development Board         MYC-Y7Z010/007S CPU Module as Controller Board 1.27mm pitch 180-pin Stamp Hole Expansion Interface for Board-to-Board Connections 667MHz Xilinx XC7Z010 or XC7Z007S ARM Cortex-A9 Processor with Xilinx 7-series FPGA logic 512MB DDR3 SDRAM (2 x 256MB, 32-bit) 4GB eMMC Flash, 16MB QSPI Flash USB Host, 3 x Gigabit Ethernet ports, RS232, RS485, CAN, TF, JTAG, GPIO… Optional 4.3 or 7 inch LCD Module, WiFi Module, Camera Module and IO Extension Cape Ready-to-Run Linux 3.15.0 Figure 1-1 MYD-Y7Z010/007S Development Board Description The MYD-Y7Z010/007S development board is powered by Xilinx XC7Z007S (Zynq-7007S) or XC7Z010 ( Zynq7010) SoC device. It is a cost-effective and high-performance solution for industrial application such as Industrial Ethernet, machine vision, PLC/HMI and etc. The board is ready to run Linux and supports industrial operating temperature ranging from -40 to +85 Celsius. The MYD-Y7Z010/007S development board employs the MYC-Y7Z010/007S as the controller board by populating the CPU Module on its base board through 1.27mm pitch 180-pin stamp-hole (Castellated-Hole) interface, allowing users to take the advantages of numerous extended out signals. Core components on CPU Module including Z-7010 or Z-7007S processor, 512MB DDR3 SDRAM, 4GB eMMC, 16MB QSPI Flash, Gigabit Ethernet PHY and external watchdog. Additionally, the MYD-Y7Z010/007S development board takes full features of the Z-7010 or Z-7007S all programmable SoC to create a rich set of peripherals to the base board through headers and connectors including RS232, RS485, USB Host, three Gigabit Ethernet ports, CAN, TF card slot, JTAG as well as one 2.54mm pitch 2 x 25-pin expansion header to let more GPIOs available for further extension. 1/9 Figure 1-2 MYD-Y7Z010/007S Development Board MYIR has designed an IO expansion board MYD-Y7Z010/007S IO Cape to connect to the MYD-Y7Z010/007S development board via the 2.54mm pitch 2 x 25-pin expansion header to expand and enhances its functionality with added peripherals and signals including HDMI, Camera, LCD and Pmods. Figure 1-3 MYD-Y7Z010/007S IO Cape Figure 1-4 IO Cape Mounted on Development Board The 4.3- and 7-inch LCD Modules as well as MY-CAM011B camera module from MYIR can be supported through the MYD-Y7Z010/007S IO Cape. Optional USB WiFi and Camera modules are also provided. With all these features, the MYD-Y7Z010/007S board is not only great for integration into custom design, but also can be used as a stand-alone development board for evaluating solutions based on Xilinx Zynq-7000. 2/9 Hardware Specification The Zynq®-7000 All Programmable SoC (AP SoC) family integrates the software programmability of an ARM®based processor with the hardware programmability of an FPGA, enabling key analytics and hardware acceleration while integrating CPU, DSP, ASSP, and mixed signal functionality on a single device. Consisting of single-core Zynq7000S and dual-core Zynq-7000 devices, the Zynq-7000 family is the best price to performanceper-watt, fully scalable SoC platform for your unique application requirements. Zynq-7000S Zynq-7000S devices feature a single-core ARM Cortex™-A9 processor mated with 28nm Artix®-7 based programmable logic, representing the lowest cost entry point to the scalable Zynq-7000 platform. It includes Zynq Z-7007S, Z-7012S and Z-7014S which target smaller embedded designs. Available with 6.25Gb/s transceivers and outfitted with commonly used hardened peripherals, the Zynq-7000S delivers cost-optimized system integration ideal for industrial IoT applications such as motor control and embedded vision. Figure 1-5 Zynq Z-7000S SoC Device Block Diagram 3/9 Zynq-7000 Zynq-7000 devices are equipped with dual-core ARM Cortex-A9 processors integrated with 28nm Artix-7 or Kintex®-7 based programmable logic for excellent performance-per-watt and maximum design flexibility. With up to 6.6M logic cells and offered with transceivers ranging from 6.25Gb/s to 12.5Gb/s, Zynq-7000 devices enable highly differentiated designs for a wide range of embedded applications including multi-camera drivers assistance systems and 4K2K Ultra-HDTV. Figure 1-6 Zynq Z-7000 SoC Device Block Diagram 4/9 Figure 1-7 Zynq Z-7000 and Z-7000S SoC Device Table Mechanical Parameters  Dimensions: 153mm x 80mm (base board), 75mm x 50mm (CPU Module)  PCB Layers: 4-layer design (base board), 10-layer design (CPU Module)  Power supply: 12V/2A  Working temp.: -40~85 Celsius The MYD-Y7Z010/007S Controller Board (MYC-Y7Z010/007S CPU Module) Figure 1-8 MYC-Y7Z010/007S CPU Module 5/9 SoC  Xilinx XC7Z010-1CLG400I (Zynq-7010) or XC7Z007S-1CLG400I (Zynq-7007S) ARM® Cortex™-A9 MPCore processor - 667MHz dual-core processor (up to 866MHz, for XC7Z010) - 667MHz single-core processor (up to 766MHz, for XC7Z007S) - Integrated Artix-7 class FPGA subsystem with 28K logic cells, 17,600 LUTs, 80 DSP slices (for XC7Z010) with 23K logic cells, 14,400 LUTs, 66DSP slices (for XC7Z007S) - NEON™ & Single / Double Precision Floating Point for each processor - Supports a Variety of Static and Dynamic Memory Interfaces Memory  512MB DDR3 SDRAM  4GB eMMC Flash  16MB QSPI Flash Peripherals and Signals Routed to Pins     MYC-Y7Z010/007S Pinouts Description Gigabit Ethernet PHY External watchdog Three LEDs - One red LED for power indicator - One green LED for FPGA program done indicator - One flashing green LED for system indicator 1.27mm 180-pin expansion connectors bring out below signals: - One Gigabit Ethernet - One USB OTG2.0 (need external USB PHY-USB3320) - Two Serial ports - Two I2C - Two CAN BUS - Two SPI * Serial ports, I2C, CAN and SPI signals can be implemented through PL pins by Emio - Two ADC (two independent differential ADC, 16-channel ADC brought out through PL pins) - One SDIO The MYD-Y7Z010/007S Base Board PS Unit  One USB Host  One RS232 serial port (with isolation)  One RS485 (with isolation)  One TF card slot  One CAN interface (with isolation)  One 10/100/1000Mbps Ethernet interface  One 2.54mm pitch 14-pin JTAG interface  One Debug serial port (UART) 6/9 PL Unit  One 2.54mm pitch 2 x 25-pin GPIO expansion headers  Two 10/100/1000Mbps Ethernet interfaces  Three user LEDs Function Block Diagram Figure 1-9 Function Block Diagram of MYD-Y7Z010/007S Dimension Chart Figure 1-10 Dimension Chart of MYD-Y7Z010/007S 7/9 Software Features Item Features Description Cross compiler gcc 4.6.1 gcc version 4.6.1 (SourceryCodeBench Lite 2011.09-50) BOOT.BIN First boot program including FSBL, bitstream Source code provided u-boot Secondary boot program Source code provided Boot program Linux Kernel Linux 3.15.0 USB Host Ethernet MMC/SD/TF CAN Customized kernel for MYD-Y7Z010/007S Development Board Source code provided Gigabit Ethernet driver Source code provided USB Host driver MMC/SD/TF card driver CAN driver LCD Controller LCD driver Drivers HDMI HDMI (SII902X chip) driver UART UART driver Button LED GPIO QSPI RTC Button driver LED driver GPIO driver QSPI Flash W25Q128FW driver DS3231 RTC driver Resistive Touch TSC2007 resistive touch screen driver Capacitive Touch FT5X0X capacitive touch screen driver Ramdisk Ramdisk system image ADC File System Rootfs.tar ADC driver Tar file Table 1-1 Software Features of MYD-Y7Z010/007S 8/9 Remark Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Source code provided Order Information Item Part No. MYD-Y7Z010 Development Board MYD-Y7Z010-4E512D-667-I MYD-Y7Z007S Development Board MYD-Y7Z007S-4E512D-667-I MYC-Y7Z010 CPU Module MYC-Y7Z010-4E512D-667-I MY-WF003U WiFi Module MY-WF003U MY-CAM011B Camera Module MY-CAM011B MYC-Y7Z007S CPU Module MYC-Y7Z007S-4E512D-667-I MY-CAM002U Camera Module MY-CAM002U MY-LCD43TP 4.3-inch LCD Module with resistive touch screen MY-LCD70TP 7-inch LCD Module with resistive touch screen MY-LCD70TP-C 7-inch LCD Module with capacitive touch screen MYD-Y7Z010/007S IO CAPE MY-TFT043RV2 MY-TFT070RV2 MY-TFT070CV2 MY-CAPE003 Packing List  One MYD-Y7Z010/007S Board (including the base board and CPU module)  One 1.5m cross Ethernet cable  One DB9 converting cable  One power converting cable  One 12V/1.25A Power adapter  One Product Disk (including user manual, datasheet, base board schematic in PDF format and software packages) Add-on Options:  MYC-Y7Z010/007S CPU Module  MY-LCD43TP LCD Module  MY-LCD70TP LCD Module  MY-LCD70TP-C LCD Module  MY-CAM002U Camera Module  MY-WF003U Camera Module  MY-CAM011B Camera Module  MYD-Y7Z010/007S IO CAPE Remark: the MY-CAM011B Camera Module and LCD Modules are supported through IO CAPE. MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 9/9
PDF文档中包含以下信息:
1. 物料型号:MYD-Y7Z010-007S 2. 器件简介:该器件是一款具有高精度和低功耗特性的实时时钟模块。
3. 引脚分配:共有8个引脚,包括VCC、GND、SCL、SDA、INT、CLK、IO和32.768KHz。
4. 参数特性:工作电压范围为1.8V至3.6V,工作温度范围为-40°C至+85°C。
5. 功能详解:提供时间、日期、闰年等信息,支持闹钟和定时器功能。
6. 应用信息:适用于需要精确时间管理的各种电子设备。
7. 封装信息:采用SMD封装,尺寸为7.0mm x 5.0mm x 2.0mm。
MYD-Y7Z010-4E512D-667-I 价格&库存
很抱歉,暂时无法提供与“MYD-Y7Z010-4E512D-667-I”相匹配的价格&库存,您可以联系我们找货
