MY-CAPE001
MY-CAPE001
    MYIR(米尔科技)
    102x88mm 3.3V 5V I/O Boards 模块配件
MY-CAPE001 数据手册
Z-turn IO Cape User Guide Z-turn IO Cape User Guide Version 1.0 May 29, 2015 Z-turn IO Cape User Guide Version History Version Number V1.0 Description Initial Version Time 2015/05/29 Z-turn IO Cape User Guide Table of Contents Table of Contents .............................................................................................................. 1 Chapter 1 Hardware Description ...................................................................................... 2 1.1 Interface Description .............................................................................................. 2 1.1.1 I/O............................................................................................................................ 3 1.1.2 LCD Touchscreen ............................................................................................... 3 1.1.3 Camera .................................................................................................................. 5 1.1.4 Pmod ...................................................................................................................... 6 1.1.5 ADC Interface....................................................................................................... 6 1.2 Mechanical parameters ............................................................................................ 6 1.2.1 Mechanical specifications ................................................................................ 7 1.2.2 Electrical parameters ......................................................................................... 7 Chapter 2 Software Introduction ...................................................................................... 8 Appendix 1 Warranty & Technical Support Services .................................................... 9 MYiR TECH LIMITED | www.myirtech.com 1 / 12 Z-turn IO Cape User Guide Chapter 1 Hardware Description Z-turn IO Cape is IO expansion board design for Z-turn Board, expansion interface includes ADC, general IO, LCD, camera interface, can help to extend more applications on Z-trun Board. Figure 1-1 1.1 Interface Description Figure 1-2 MYiR TECH LIMITED | www.myirtech.com 2 / 12 Z-turn IO Cape User Guide 1.1.1 I/O IO functions, connected to J3, pin-shared with LCD, if you do not use LCD can be used as a general IO. Please refer to schematic for pin definition. VDD_5V 1 2 VDD_3.3V GND 3 4 GND IO_B35_LN2 IO_B35_LN3 5 6 7 8 IO_B35_LP2 IO_B35_LP3 IO_B35_LN4 9 10 IO_B35_LP4 IO_B35_LN5 11 12 IO_B35_LP5 IO_B35_LN6 13 14 IO_B35_LP6 IO_B35_LN7 15 16 IO_B35_LP7 IO_B35_LN8 17 18 IO_B35_LP8 IO_B35_LN9 19 20 IO_B35_LP9 IO_B35_LN10 21 22 IO_B35_LP10 IO_B35_LN11 23 24 IO_B35_LP11 IO_B35_LN12 25 26 IO_B35_LN13 IO_B35_LN14 27 28 IO_B35_LP14 IO_B35_LN15 29 30 IO_B35_LP15 IO_B35_LN16 31 32 IO_B35_LP16 IO_B35_LN17 33 34 IO_B35_LP17 IO_B35_LN18 35 36 IO_B35_LP18 IO_B35_LN19 37 38 IO_B35_LP19 IO_B35_LN20 39 40 IO_B35_LP20 Figure 1.1.1 1.1.2 LCD Touchscreen You can access 4.3 and 7-inch capacitive screen of MYiR, connected to J11, pin definitions refer to corresponding schematic. Table 1.1.2 Num 1 2 3 4 5 6 IO Name VDD_5V VDD_5V VDD_3.3V VDD_3.3V GND GND MYiR TECH LIMITED | www.myirtech.com Function 3 / 12 Z-turn IO Cape User Guide 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 IO_B35_LP8 IO_B35_LN8 IO_B35_LP9 IO_B35_LN9 IO_B35_LP10 IO_B35_LN10 IO_B35_LP11 IO_B35_LN11 IO_B35_LN12 IO_B35_LN13 IO_B35_LP14 IO_B35_LN14 IO_B35_LP15 IO_B35_LN15 IO_B35_LP16 IO_B35_LN16 IO_B35_LP17 IO_B35_LN17 IO_B35_LP18 IO_B35_LN18 IO_B35_LP19 IO_B35_LN19 IO_B35_LP20 IO_B35_LN20 GND IO_B35_LP21 IO_B35_LN21 IO_B35_LP22 IO_B35_LN22 IO_B35_LP23 IO_B35_LP7 IO_B35_LN7 GND IO_B35_LN23 IO_B35_LP24 IO_B35_LN24 IO_B35_LP13 GND NC NC NC NC MYiR TECH LIMITED | www.myirtech.com LCD_DATA0 LCD_DATA1 LCD_DATA2 LCD_DATA3 LCD_DATA4 LCD_DATA5 LCD_DATA6 LCD_DATA7 LCD_DATA8 LCD_DATA9 LCD_DATA10 LCD_DATA11 LCD_DATA12 LCD_DATA13 LCD_DATA14 LCD_DATA15 LCD_DATA16 LCD_DATA17 LCD_DATA18 LCD_DATA19 LCD_DATA20 LCD_DATA21 LCD_DATA22 LCD_DATA23 Backlight enabled LCD RESET Display enable Touch Interrupt Touch RESET I2C1_SCL I2C1_SDA DEN VSYNC HYSNC PCLK 4 / 12 Z-turn IO Cape User Guide NC GND 49 50 1.1.3 Camera Reserved for camera interface, connected to J2, pin definitions refer to corresponding schematic. Table 1.1.3 Num 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Pin GND NC NC NC NC IO_B35_LP2 IO_B35_LN2 IO_B35_LP3 IO_B35_LN3 IO_B35_LP4 GND IO_B35_LP12 GND IO_B35_LN4 IO_B35_LP5 GND NC GND IO_B35_LN5 IO_B35_LP6 IO_B35_LN6 GND NC NC IO_B35_LP7 IO_B35_LN7 GND VDD_3.3V VDD_3.3V VDD_5V MYiR TECH LIMITED | www.myirtech.com Function CAM_DATA2 CAM_DATA1 CAM_DATA3 CAM_DATA0 CAM_DATA4 CAM_PCLK CAM_DATA5 CAM_DATA6 CAM_DATA7 CAM_HSYNC CAM_VSYNC I2C_SCL I2C_SDA 5 / 12 Z-turn IO Cape User Guide 1.1.4 Pmod 3 Pmod interface module for general Pmod, connected to J5/J6/J7, pin definitions refer to corresponding schematic. Table 1.1.4 Num 1 2 3 4 5 6 7 8 9 10 11 12 J5 IO_B34_LP1 IO_B34_LP3 IO_B34_LN1 IO_B34_LN3 IO_B34_LP2 IO_B34_LP4 IO_B34_LN2 IO_B34_LN4 GND GND VDD_3.3V VDD_3.3V J6 IO_B34_LP6 IO_B35_LP1 IO_B34_LN11 IO_B35_LN1 IO_B34_LP8 IO_B34_LP5 IO_B34_LP8 IO_B34_LN5 GND GND VDD_3.3V VDD_3.3V J7 IO_B13_LP12 IO_B13_LP11 IO_B13_LN12 IO_B13_LN11 IO_B13_LP14 IO_B13_LP13 IO_B13_LN14 IO_B13_LN13 GND GND VDD_3.3V VDD_3.3V 1.1.5 ADC Interface J4 can be accessed by ADC (may be a differential signal), J4 also extends 4 IO of PS. XADC_INP0 1 2 XADC_INN0 XADC_TEMP_P 3 4 XADC_TEMP_N PS_MIO10 5 6 PS_MIO11 PS_MIO12 GND 7 8 PS_MIO13 9 10 XADC_GND VDD_3.3V 11 12 XADC_VCC Table 1.1.5 1.2 Mechanical parameters Please refer to PCB documentation provided, for Z-turn Board Cape board reference design. MYiR TECH LIMITED | www.myirtech.com 6 / 12 Z-turn IO Cape User Guide 1.2.1 Mechanical specifications Length x width: 102mm x 88mm, For more information reference DXF file. 1.2.2 Electrical parameters Power: 5V/1A, 3.3V/1A PS IO: 3.3V PL IO: 3.3V ADC Input: 0~1.8V MYiR TECH LIMITED | www.myirtech.com 7 / 12 Z-turn IO Cape User Guide Chapter 2 Software Introduction Take XC7Z010 as example, XC7Z020 steps are same, please modify corresponding file. Ramdisk boot Copy CD\02-Images\Ramdisk folder file to SD card, and rename “7z010-lcd.bit” to “7z010.bit”, if using 7-inch capacitive screen, rename “devicetree-800x480.dtb” to “devicetree.dtb”, if 4.3-inch rename “devicetree-480x272.dtb” to “devicetree.dtb”. Ubuntu boot Unzip CD\04-Linux_Source\Filesystem\”xillinux-1.3.img.gz”, burning to SD card using Win32DiskImager tools. Rename “7z010-lcd.bit” to “7z010.bit” on SD card, if using 7-inch capacitive screen, rename “devicetree-800x480.dtb” to “devicetree.dtb”, if 4.3-inch rename “devicetree-480x272.dtb” to “devicetree.dtb”. Then rename “uEnv-ubuntu.txt” to “uEnv.txt”. MYiR TECH LIMITED | www.myirtech.com 8 / 12 Z-turn IO Cape User Guide Appendix 1 Warranty & Technical Support Services MYIR Tech Limited is a global provider of ARM hardware and software tools, design solutions for embedded applications. We support our customers in a wide range of services to accelerate your time to market. MYIR is an ARM Connected Community Member and work closely with ARM and many semiconductor vendors. We sell products ranging from board level products such as development boards, single board computers and CPU modules to help with your evaluation, prototype, and system integration or creating your own applications. Our products are used widely in industrial control, medical devices, consumer electronic, telecommunication systems, Human Machine Interface (HMI) and more other embedded applications. MYIR has an experienced team and provides custom design services based on ARM processors to help customers make your idea a reality. The contents below introduce to customers the warranty and technical support services provided by MYIR as well as the matters needing attention in using MYIR’s products. Service Guarantee MYIR regards the product quality as the life of an enterprise. We strictly check and control the core board design, the procurement of components, production control, product testing, packaging, shipping and other aspects and strive to provide products with best quality to customers. We believe that only quality products and excellent services can ensure the long-term cooperation and mutual benefit. Price MYIR insists on providing customers with the most valuable products. We do not pursue excess profits which we think only for short-time cooperation. Instead, we hope to establish long-term cooperation and win-win business with customers. So we will offer reasonable prices in the hope of making the business greater with the customers together hand in hand. Delivery Time MYIR will always keep a certain stock for its regular products. If your order quantity is less than the amount of inventory, the delivery time would be within three days; if your order quantity is greater than the number of inventory, the delivery time would be always four to six weeks. If for any urgent delivery, we can negotiate with customer and try to supply the goods in advance. Technical Support MYIR has a professional technical support team. Customer can contact us by email (support@myirtech.com), we will try to reply you within 48 hours. For mass production MYiR TECH LIMITED | www.myirtech.com 9 / 12 Z-turn IO Cape User Guide and customized products, we will specify person to follow the case and ensure the smooth production. After-sale Service MYIR offers one year free technical support and after-sales maintenance service from the purchase date. The service covers: 1. Technical support service a) MYIR offers technical support for the hardware and software materials which have provided to customers; b) To help customers compile and run the source code we offer; c) To help customers solve problems occurred during operations if users follow the user manual documents; d) To judge whether the failure exists; e) To provide free software upgrading service. However, the following situations are not included in the scope of our free technical support service: a) Hardware or software problems occurred during customers’ own development; b) Problems occurred when customers compile or run the OS which is tailored by themselves; c) Problems occurred during customers’ own applications development; d) Problems occurred during the modification of MYIR’s software source code. 2. After-sales maintenance service The products except LCD, which are not used properly, will take the twelve months free maintenance service since the purchase date. But following situations are not included in the scope of our free maintenance service: a) The warranty period is expired; b) The customer cannot provide proof-of-purchase or the product has no serial number; c) The customer has not followed the instruction of the manual which has caused the damage the product; d) Due to the natural disasters (unexpected matters), or natural attrition of the components, or unexpected matters leads the defects of appearance/function; e) Due to the power supply, bump, leaking of the roof, pets, moist, impurities into the boards, all those reasons which have caused the damage of the products or defects of appearance; f) Due to unauthorized weld or dismantle parts or repair the products which has caused the damage of the products or defects of appearance; g) Due to unauthorized installation of the software, system or incorrect configuration or computer virus which has caused the damage of products. Warm tips: 1) MYIR does not supply maintenance service to LCD. We suggest the customer first check the LCD when receiving the goods. In case the LCD cannot run or no display, customer should contact MYIR within 7 business days from the moment get the MYiR TECH LIMITED | www.myirtech.com 10 / 12 Z-turn IO Cape User Guide 2) 3) 4) 5) 6) goods. Please do not use finger nails or hard sharp object to touch the surface of the LCD. MYIR suggests user purchasing a piece of special wiper to wipe the LCD after long time use, please avoid clean the surface with fingers or hands to leave fingerprint. Do not clean the surface of the screen with chemicals. Please read through the product user manual before you using MYIR’s products. For any maintenance service, customers should communicate with MYIR to confirm the issue first. MYIR’s support team will judge the failure to see if the goods need to be returned for repair service, we will issue you RMA number for return maintenance service after confirmation. 3. Maintenance period and charges a) MYIR will test the products within three days after receipt of the returned goods and inform customer the testing result. Then we will arrange shipment within one week for the repaired goods to the customer. For any special failure, we will negotiate with customers to confirm the maintenance period. b) For products within warranty period and caused by quality problem, MYIR offers free maintenance service; for products within warranty period but out of free maintenance service scope, MYIR provides maintenance service but shall charge some basic material cost; for products out of warranty period, MYIR provides maintenance service but shall charge some basic material cost and handling fee. 4. Shipping cost During the warranty period, the shipping cost which delivered to MYIR should be responsible by user; MYIR will pay for the return shipping cost to users when the product is repaired. If the warranty period is expired, all the shipping cost will be responsible by users. 5. Products Life Cycle MYIR will always select mainstream chips for our design, thus to ensure at least ten years continuous supply; if meeting some main chip stopping production, we will inform customers in time and assist customers with products updating and upgrading. Value-added Services 1. MYIR provides services of driver development base on MYIR’s products, like serial port, USB, Ethernet, LCD, etc. 2. MYIR provides the services of OS porting, BSP drivers’ development, API software development, etc. 3. MYIR provides other products supporting services like power adapter, LCD panel, etc. 4. ODM/OEM services. MYiR TECH LIMITED | www.myirtech.com 11 / 12 Z-turn IO Cape User Guide MYIR Tech Limited Room 1306, Wensheng Center, Wenjin Plaza, North Wenjin Road, Luohu District, Shenzhen, China 518020 Support Email: support@myirtech.com Sales Email: sales@myirtech.com Phone:+86-755-22984836 Fax: +86-755-25532724 Website: www.myirtech.com MYiR TECH LIMITED | www.myirtech.com 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: MYIR Tech: MY-CAPE001
MY-CAPE001 价格&库存
很抱歉,暂时无法提供与“MY-CAPE001”相匹配的价格&库存,您可以联系我们找货
