MYD-YA157C-V2-4E512D-65-C
    MYIR(米尔科技)
    主芯片 STM32MP157 开发板
MYD-YA157C-V2-4E512D-65-C 数据手册
MYC-YA157C CPU Module ➢ ➢ ➢ ➢ ➢ STMicroelectronics STM32MP1 MPU based on 650MHz Dual Arm Cortex-A7 and 209MHz Cortex-M4 Cores 512MB DDR3, 4GB eMMC Flash On-board Gigabit Ethernet PHY 1.0mm pitch 164-pin Stamp Hole Expansion Interface Supports Running Linux OS Figure 1-1 MYC-YA157C CPU Module Measuring only 45mm by 43mm, the MYC-YA157C CPU Module is a compact ST STM32MP1 powered System-on Module (SoM) that combines the STM32MP157 processor (STM32MP157AAC3), 512MB DDR3,4GB eMMC as well as an integrated GigE PHY chip. A number of peripherals and IO signals are brought out through 1.0 mm pitch 164-pin stamp-hole (Castellated-Hole) expansion interface to make the module an excellent embedded controller for your system integration. Typical applications are industrial control, consumer electronics, smart home, medical and more energy-efficient applications which require rich performance and low power. Figure 1-2 MYC-YA157C CPU Module The MYC-YA157C is running Linux OS. Based on Linux 4.19.9 kernel, MYIR provides abundant software resources for Yocto 2.6 based MYIR MEasy-HMI system, Yocto 2.6 based ST Weston system, Ubuntu 18.04 system and MYIR MEasy-IOT system including kernel and driver source code, STM32CubeProgrammer and STM32CubeMX tools to enable users to start their development rapidly and easily. 1 / 9 The MYD-YA157C development board is built around the MYC-YA157C CPU Module. It takes full advantages of the STM32MP157A MPU to explore a rich set of peripherals and interfaces to the base board including RS232, RS485, USB Type-C DRP, USB2.0 HOST, Gigabit Ethernet, WiFi/Bluetooth, CAN, Micro SD Card Slot, JTAG, RGB888 based LCD/HDMI, MIPI-DSI, etc. The MYD-YA157C development board is delivered with one Quick Start Guide, one Type-C cable, one USB to TTL serial cable and one WiFi/Bluetooth antenna to provide user a complete platform for evaluating and prototyping based on STM32MP1 series microprocessors. MYIR also offers MY-CAM002U Camera Module and MY-TFT070CV2 LCD Module as options for the board. Figure 1-3 MYD-YA157C Development Board Top-view Figure 1-4 MYD-YA157C Development Board Bottom-view 2 / 9 Hardware Specification The MYC-YA157C CPU Module is using STMicroelectronics STM32MP157AAC3 Microprocessor with 12 x 12 mm, 0.5 mm pitch, TFBGA361 package which is among the STM32MP1 Series. The STM32MP1 series is based on a heterogeneous single or dual Arm Cortex-A7 and Cortex-M4 cores architecture, strengthening its ability to support multiple and flexible applications, achieving the best performance and power figures at any time. The Cortex-A7 core provides access to open-source operating systems (Linux/Android) while the Cortex-M4 core leverages the STM32 MCU ecosystem. It is available in 3 different lines which are pin-to-pin compatible: • • • STM32MP157: Dual Cortex-A7 cores @ 650 MHz, Cortex-M4 core @ 209 MHz, 3D GPU, DSI display interface and CAN FD STM32MP153: Dual Cortex-A7 cores @ 650 MHz, Cortex-M4 core @ 209 MHz and CAN FD STM32MP151: Single Cortex-A7 core @ 650 MHz, Cortex-M4 core @ 209 MHz Each line comes with a security option (cryptography & secure boot) Figure 1-5 STM32MP1 Series Processors 3 / 9 Figure 1-6 STM32MP157 Block Diagram 4 / 9 Mechanical Parameters • Dimensions: 45mm x 43mm • PCB Layers: 8-layer design • Power supply: +5V/0.5A • Working temperature: 0~70 Celsius (commercial grade) or 40~85 Celsius (industrial grade) Processor • STMicroelectronics STM32MP157AAC3 Microprocessor - Up to 650MHz dual-core Arm Cortex-A7 32-bit RISC core - Up to 209MHz Arm Cortex-M4 32-bit RISC core with FPU/MPU - Integrated 3D GPU Memory • 512MB DDR3 (supports up to 1GB DDR3) • 4GB eMMC Flash (supports up to 64GB eMMC) • Nand Flash (alternative design with eMMC, supporting 256MB / 512MB /1GB Nand Flash) Peripherals and Signals Routed to Pins • One 10/100/1000M Ethernet PHY • 1.0mm pitch 164-pin Stamp Hole Expansion Interface - 8 x Serial ports - 6 x I2C - 6 x SPI - 1 x SAI - 1 x USB 2.0 Host and 1 x USB 2.0 OTG - 2 x SDIO - 2 x CAN - 1 x MIPI-DSI - 1 x Digital Camera Interface (DCMI) - 1 x RGB Interface (supports RGB888, resolution up to 1366 x 768 @60fps) - Up to 97 GPIOs Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet and the CPU Module pinout description file. 5 / 9 Figure 1-7 MYC-YA157C CPU Module Function Block Diagram Figure 1-8 MYC-YA157C Dimensions Chart 6 / 9 Software Features Item Features Description Source Code Bootstrap program TF-a-2.0 Arm Trusted Firmware YES Bootloader U-boot-2018.11 Kernel bootstrap YES Linux kernel Linux-4.19.94 Customized based on ST kernel_4.19.94 version for MYD-YA157C YES Nand Flash Nand Flash driver YES USB Host USB Host driver YES USB OTG USB OTG driver YES I2C I2C driver YES SPI SPI driver YES TTY TTY Serial port driver YES Ethernet 10M/100M/1000M Ethernet driver YES MMC eMMC/TF card driver YES LCD Drivers File system Tool Applications 7 / 9 LCD driver, supports MYIR’s 7-inch LCD with 800 x 480 pixels resolution YES HDMI HDMI driver YES Touch Capacitive touch screen driver YES PWM PWM driver YES RTC RTC driver YES GPIO GPIO driver YES CAN FDCAN Bus driver YES RS485 RS485 driver YES RS232 RS232 driver YES MIPI MIPI display driver YES Camera USB Camera driver (OV2659) YES ADC ADC driver YES WiFi & BT AP6212 WiFi/BT driver (SDIO) YES Watchdog Watchdog driver YES rootfs Yocto 2.6 for ST Weston system YES rootfs MEasy HMI demo system developed by MYIR YES rootfs MEasy-IOT demo system developed by MYIR YES Ubuntu core system Based on ubuntu18.04 YES SDK arm-ostl-linux-gnueabi 8.2.0 BIN Yocto2.6 System construction tool YES STM32CubeProgrammer ST programmer software BIN Win32DiskImager Creating SD card boot tool BIN SDCardUpdater Creating production burning tool YES GPIO LED LED example YES GPIO KEY KEY example YES NET TCP/IP Socket C/S example YES RTC RTC example YES RS232 RS232 example YES RS485 RS485 example YES CAN CAN example YES IDE LCD LCD Display example YES Camera Camera Display example YES stm32cube_fw_mp1 M4 core testing example YES STM32CubeIDE ST Integrated Development Environment BIN Table 1-1 MYD-YA157C Software Features The MYD-YA157C runs Linux OS and is provided with software packages. Based on Linux 4.19.9 kernel, MYIR has provided abundant software resources for Yocto 2.6 based MYIR MEasy-HMI system, Yocto 2.6 based ST Weston system, Ubuntu 18.04 system and MYIR MEasy-IOT system including kernel and driver source code, STM32CubeProgrammer and STM32CubeMX tools to enable users to start their development rapidly and easily. Figure 1-7 MEasy-HMI System Structure Figure 1-8 MEasy-IOT System Structure 8 / 9 Order Information Product Item MYC-YA157C CPU Module MYD-YA157C Development Board Part No. Packing List MYC-YA157C-V2-4E512D-65-C ➢ ➢ MYC-YA157C-V2-4E512D-65-I MYD-YA157C-V2-4E512D-65-C MYD-YA157C-V2-4E512D-65-I MY-LCD70TP-C LCD Module (with capacitive touch screen) MY-TFT070CV2 MY-CAM002U USB Camera Module MY-CAM002U MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 9 / 9 One MYC-YA157C CPU Module One Quick Start Guide Add-on Options ➢ MYD-YA157C Development Board ➢ MY-TFT070CV2 LCD Module ➢ MY-CAM002U Camera Module
MYD-YA157C-V2-4E512D-65-C 价格&库存
很抱歉,暂时无法提供与“MYD-YA157C-V2-4E512D-65-C”相匹配的价格&库存,您可以联系我们找货
