MYC-Y6ULG2-256N256D-50-I
    MYIR(米尔科技)
    主芯片 I.MX6UL 核心板
MYC-Y6ULG2-256N256D-50-I 数据手册
MYC-Y6ULX CPU Module - 528MHz NXP i.MX 6UL/6ULL ARM Cortex-A7 Processors - 256MB DDR3 SDRAM - 256MB Nand Flash (4GB eMMC Flash is optional) - On-board 10/100M Ethernet PHY - 1.0mm pitch 140-pin Stamp Hole Expansion Interface - Ready-to-Run Linux 4.1.15 Figure 1-1 MYC-Y6ULX CPU Module (delivered with shield cover) Measuring only 37mm by 39mm, the MYC-Y6ULX CPU Module is covered with shield and powered by NXP i.MX 6UltraLite/6ULL processor based on the ARM Cortex-A7 architecture. With a choice of G2 and Y2 sub family processors running at 528MHz and integrated with 256MB DDR3 and 256MB Nand Flash (4GB eMMC Flash is optional), the MYC-Y6ULX module delivers high performance with ultra-efficient power that targets Industry Control, Communications, HMI, Smart Healthcare and Internet of Things (IoT) applications. It carries out as many as peripheral signals and IOs through 1.0mm pitch 140-pin stamp hole expansion interface to allow customer’s extension for their next embedded design. The module is ready to run Linux and can support industrial operating temperature range from -40 to +85 Celsius. MYIR also offers a development board MYD-Y6ULX which is built around the MYC-Y6ULX CPU Module with a specially designed base board. A variety of peripheral interfaces have been brought out to the base board through headers and connectors including serial ports, two USB Host, one USB OTG, two 10/100Mbps Ethernet, CAN, Camera, LCD, Audio, TF card as well as a Mini PCIe interface for 4G LTE Module. The board also has an integrated WiFi Module with external antenna to allow wireless communications. Along with some cable accessories, the MYD-Y6ULX is a complete evaluation platform and reference design for development based on i.MX 6UL/6ULL processors. 1/8 Figure 1-2 MYD-Y6ULX Development Board MYIR provides three models of MYC-Y6ULX CPU Module with mainly different features as shown in below table. User can select model according to their own requirement. Part No. MYC-Y6ULG2-256N256D-50-I MYC-Y6ULY2-256N256D-50-C MYC-Y6ULY2-4E512D-50-C RAM 256MB DDR3 256MB DDR3 512MB DDR3 Processor Flash Working Temp. 2/8 MCIMX6G2CVM05AB 256MB Nand Flash -40 to +85 Celsius MCIMX6Y2DVM05AA 256MB Nand Flash 0 to +70 Celsius MCIMX6Y2DVM05AA 4GB eMMC 0 to +70 Celsius Table 1-1 Three Models of MYC-Y6ULX (default configurations) Hardware Specification The MYC-Y6ULX CPU Module is using the 14 x 14mm, 0.8 mm ball pitch, 289 MAPBGA package 528 MHz i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 application processor which provides multiple compatible options of G0, G1, G2, G3, Y0, Y1 and Y2 sub family. The MCIMX6G2CVM05AB and MCIMX6Y2DVM05AA are optional as the default part with the board. Expanding the i.MX 6 series, the i.MX 6UltraLite is a high performance, ultra-efficient processor family featuring an advanced implementation of a single ARM® Cortex®-A7 core, which operates at speed up to 696 MHz. The i.MX 6UltraLite applications processor includes an integrated power management module that reduces the complexity of external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth™, GPS, displays and camera sensors. Feature MCIMX6G0 MCIMX6G1 MCIMX6G2 MCIMX6G3 Speed 528 MHz 528 MHz, 696 MHz 528 MHz, 696 MHz 528 MHz 128 KB L2 128 KB L2 Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Security Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI S/PDIF Timer/PWM 12-bit ADC 3/8 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 512-bit 1024-bit 1536-bit 2048-bit DDR3/DDR3L Yes DDR3/DDR4L Yes Yes Yes DDR3/DDR5L Yes Yes DDR3/DDR6L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 10/100-Mbit/s x 2 0 1 2 2 OTG, HS/FS x 1 Basic OTG, HS/FS x 2 OTG, HS/FS x 2 TRNG, Crypto Engine TRNG, Crypto Engine Secure Boot Secure Boot (AES/TDES/SHA), (AES/TDES/SHA), TRNG, Crypto Engine (AES with DPA/TDES/SHA/RSA), Secure Boot, tamper monitor, PCI4.0 pre-certification, OTF DRAM encryption None None None None 24-bit Parallel LCD 24-bit Parallel LCD 2 2 2 None None 1 1 2 4 8 2 4 2 4 1 1 3 Timer x 2, PWM x 4 1 x 10-ch. 1 Timer x 4, PWM x 8 1 x 10-ch. PxP OTG, HS/FS x 2 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. Table 1-2 i.MX 6UltraLite Device Options PxP 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. The i.MX 6ULL is a power efficient and cost optimized application processor family featuring an advanced implementation of a single ARM Cortex-A7 core, which operates at speeds up to 900 MHz. The i.MX 6ULL applications processor includes an integrated power management module that reduces the complexity of an external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth®, GPS, displays and camera sensors. Feature MCIMX6Y0 MCIMX6Y1 MCIMX6Y2 Core ARM® Cortex-A7 ARM® Cortex-A7 ARM® Cortex-A7 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB Speed Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI ESAI S/PDIF Timer/PWM 12-bit ADC Security Temperature 528 MHz 32 KB-I, 32 KB-D 128 KB 528 MHz 128 KB L2 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 256-bit 256-bit 256-bit DDR3/DDR3L Yes Yes DDR3/DDR4L Yes Yes DDR3/DDR5L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 0 1 2 OTG, HS/FS x 1 OTG, HS/FS x 2 OTG, HS/FS x 2 None None None None 24-bit Parallel LCD 2 2 None 1 2 4 2 2 1 1 1 None 1 8 4 4 3 1 1 PxP 16-bit Parallel CSI 1 8 4 4 3 1 1 Timer x 2, PWM x 4 Timer x 4, PWM x 8 Timer x 4, PWM x 8 None AES-128, HAB AES-128, HAB 1 x 10-ch. -40°C to 105°C (Tj) 1 x 10-ch. -40°C to 105°C (Tj) Table 1-3 i.MX 6ULL Device Options 4/8 528 MHz 2 x 10-ch. 0°C to 90°C (Tj) Mechanical Parameters • • • • Dimensions: 37mm x 39mm PCB Layers: 8-layer design Power supply: 3.3V/0.3A Working temperature: 0~70 Celsius (commercial grade) or -40~85 Celsius (industrial grade) Processor • 528MHz NXP i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 processor (MCIMX6G2CVM05AB or MCIMX6Y2DVM05AA by default) Memory • • 256MB DDR3 SDRAM (supports up to 1GB) 256MB Nand Flash (4GB eMMC Flash is optional) Peripherals and Signals Routed to Pins MYC-Y6ULX Pinouts Description • One 10/100M Ethernet PHY • 1.0mm pitch 140-pin stamp hole expansion interface - 2 x 10/100Mbps Ethernet - 8 x Serial ports - 4 x I2C - 2 x CAN - 4 x SPI - 8 x ADC - 8 x PWM - 3 x I2S - 1 x Parallel Camera Sensor Interface - 1 x JTAG - 1 x 24-bit LCD interface - Up to 97 x GPIOs Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet. 5/8 Function Block Diagram Figure 1-3 MYC-Y6ULX Function Block Diagram Dimension Chart of MYC-Y6ULX Figure 1-4 MYC-Y6ULX Dimension Chart 6/8 Software Features MYIR’s MYC-Y6ULX CPU module supports for Linux and is provided with software packages. Many peripheral drivers are in source code to help accelerate customers’ designs with a stable and reliable hardware and software platform. The software features are summarized as below: Item Bootstrap program Kernel Features Description u-boot The primary bootstrap (source code) Ethernet Ethernet driver (source code) Version Linux 4.1.15 (source code) USB HOST and OTG driver (source code) MMC/SD MMC/SD card driver (source code) NandFlash Nand Flash driver (source code) eMMC UART LCD Controller Linux Drivers RTC Touch Panel GPIO Button GPIO LED CAN RS485 LCD driver (source code, supports MYIR’s 4.3- and 7- inch LCD) RTC driver (source code) Resistive and Capacitive touch screen driver (source code) Button driver (source code) LED driver (source code) CAN driver (source code) WiFi Module driver (SDIO signal, source code) 4G LTE 4G LTE Module driver (USB signal, source code) Camera Compiler Tool Chain UART driver (source code) RS485 driver (source code) WiFi File System eMMC driver (source code) Camera driver (source code, supports MYIR’s MY-CAM011B) Audio Audio (wm8904) driver (source code) SPI Yocto Linaro GCC 4.9 hf MetaToolchain Applications Tool Chain SPI driver (source code) Including QT5.6 (source code) Binary file Built by Yocto, GCC 5.3 (Binary file) Built by Yocto, GCC 5.3 (Binary file) Table 1-4 Software Features of MYC-Y6ULX 7/8 Order Information Product Item MYC-Y6ULX CPU Module MYD-Y6ULX Development Board MY-LCD43TP 4.3-inch LCD Module with resistive touch screen MY-LCD70TP 7-inch LCD Module with resistive touch screen MY-LCD70TP-C 7-inch LCD Module with capacitive touch screen MY-CAM011B Camera Module Part No. Packing List MYC-Y6ULG2-256N256D-50-I  One MYC-Y6ULX CPU Module  One Product Disk (including user manual, datasheet, and software packages) MYC-Y6ULY2-256N256D-50-C MYC-Y6ULY2-4E512D-50-C MYD-Y6ULG2-256N256D-50-I MYD-Y6ULY2-256N256D-50-C MYD-Y6ULY2-4E512D-50-C MY-TFT043RV2 MY-TFT070RV2 MY-TFT070CV2 MY-CAM011B MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 8/8 Add-on Options  MYD-Y6ULX Development Board  MY-LCD43TP 4.3-inch LCD Module  MY-LCD70TP 7-inch LCD Module  MY-LCD70TP-C 7-inch LCD Module  MY-CAM011B Camera Module
MYC-Y6ULG2-256N256D-50-I 价格&库存
很抱歉,暂时无法提供与“MYC-Y6ULG2-256N256D-50-I”相匹配的价格&库存,您可以联系我们找货
