MYS-6ULY2-256N256D-50-I-IND
    MYIR(米尔科技)
    主芯片 I.MX6UL 开发板
MYS-6ULY2-256N256D-50-I-IND 数据手册
MYS-6ULX Single Board Computer        528MHz NXP i.MX 6UltraLite / 6ULL ARM Cortex-A7 Processor 256MB DDR3, 256MB Nand Flash Ethernet, WiFi, LCD, USB Host, Device, TF Card, Buttons, LED, IO… Optional MYB-6ULX Expansion Board adds Ethernet, CAN, RS485, Audio, RTC and Camera Optional 4.3 or 7 inch LCD Module and Camera Module Two Variants of MYS-6ULX Boards Respectively for Industry 4.0 and IoT Applications Support Linux 4.1.15 with Debian distribution or by Yocto Project with Ported QT Figure 1-1 MYS-6ULX-IND Figure 1-2 MYS-6ULX-IOT Description Measuring only 70mm by 55mm, the MYS-6ULX Single Board Computer is a high-performance low-cost System-on-Module (SoM) specially designed for Industry 4.0 (Industrie 4.0) and Internet of Things (IoT) applications. It is based on NXP’s i.MX 6UltraLite / 6ULL processor family which features the most efficient ARM Cortex-A7 core and can operate at speeds up to 696 MHz. The MYS-6ULX has two variants of boards which are called MYS-6ULX-IND and MYS-6ULX-IOT to meet different applications. The MYS-6ULX-IND is targeting industry 4.0 applications and based on i.MX6UL series processors while the MYS-6ULX-IOT is oriented for IOT applications and using i.MX6ULL series processors. They share the same hardware circuit design and fully compatible in software but also have their own characteristics. They have integrated 256MB DDR3 and 256MB Nand Flash as well as a set of peripherals and interfaces including Ethernet, USB Host, Device, LCD interface, TF card slot, etc. The MYS-6ULX-IOT has additionally a USB based WiFi module with antenna on the board. The MYS-6ULX-IND can support -40 to +85 Celsius extended temperature operation, which makes the board more suitable for industrial control and communication applications. MYIR has ported Linux 4.1.15 for the board with Debian distribution as well as Yocto project with ported QT. MYIR has also provided an interesting demo to enable customers to experience Amazon Alexa Voice Service. 1 / 10 Figure 1-3 MYS-6ULX-IND Figure 1-4 MYS-6ULX-IOT 2 / 10 MYIR has also designed an expansion board MYB-6ULX which is connected to the MYS-6ULX board through its onboard two 2.0mm pitch 2 x 20-pin expansion headers. The expansion board has extended one more Ethernet for MYS-6ULX and also added CAN, RS485, Audio, RTC and camera functions which has further enhanced the performance of MYS-6ULX board. MYIR will offer optional LCD modules and Camera module to help with customers’ evaluation. Figure 1-5 MYB-6ULX Expansion Board Figure 1-6 MYB-6ULX Expansion Board mounted on MYS-6ULX Board (delivered without battery) 3 / 10 Hardware Specification The MYS-6ULX-IND is based on the high performance, ultra-efficient i.MX 6UltraLite processor family featuring an advanced implementation of a single ARM® Cortex®-A7 core and can operate at speeds up to 696 MHz. It includes an integrated power management module that reduces the complexity of external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth™, GPS, displays and camera sensors. MYIR is using the 14 x 14mm, 0.8 mm ball pitch, 289 MAPBGA package i.MX6UL application processor on the MYS-6ULX-IND board which provides multiple compatible options of G0, G1, G2 and G3 sub family. The MCIMX6G2CVM05A is the default part with the board and MYIR offers optional configurations for mass customization. Feature MCIMX6G0 MCIMX6G1 MCIMX6G2 MCIMX6G3 Speed 528 MHz 528 MHz, 696 MHz 528 MHz, 696 MHz 528 MHz 128 KB L2 128 KB L2 Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Security Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI S/PDIF Timer/PWM 12-bit ADC 4 / 10 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 512-bit 1024-bit 1536-bit 2048-bit DDR3/DDR3L Yes DDR3/DDR4L Yes Yes Yes DDR3/DDR5L Yes Yes DDR3/DDR6L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 10/100-Mbit/s x 2 0 1 2 2 OTG, HS/FS x 1 Basic OTG, HS/FS x 2 OTG, HS/FS x 2 TRNG, Crypto Engine TRNG, Crypto Engine Secure Boot Secure Boot (AES/TDES/SHA), (AES/TDES/SHA), TRNG, Crypto Engine (AES with DPA/TDES/SHA/RSA), Secure Boot, tamper monitor, PCI4.0 pre-certification, OTF DRAM encryption None None None None 24-bit Parallel LCD 24-bit Parallel LCD 2 2 2 None None 1 1 2 4 8 2 4 2 4 1 1 3 Timer x 2, PWM x 4 1 x 10-ch. 1 Timer x 4, PWM x 8 1 x 10-ch. PxP OTG, HS/FS x 2 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. Table 1-1 i.MX 6UltraLite Device Options PxP 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. The MYS-6ULX-IOT is based on i.MX 6ULL processor which is a high-performance, ultra-efficient processor family featuring an advanced implementation of a single ARM® Cortex®-A7 core and capable of operating at speeds up to 528 MHz. The i.MX 6ULL is supported by discrete component power circuitry. It is a cost down version of i.MX 6UltraLite with fewer security features and lower maximum CPU frequency, but adding ePD support. MYIR is using the 14 x 14mm, 0.8 mm ball pitch, 289 MAPBGA package i.MX6ULL application processor on the MYS-6ULX-IOT board which provides multiple compatible options of Y0, Y1 and Y2 sub family. The MCIMX6Y2DVM05A is the default part with the board and MYIR offers optional configurations for mass customization. Feature MCIMX6Y0 MCIMX6Y1 MCIMX6Y2 Core ARM® Cortex-A7 ARM® Cortex-A7 ARM® Cortex-A7 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB Speed Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI ESAI S/PDIF Timer/PWM 12-bit ADC Security Temperature 528 MHz 32 KB-I, 32 KB-D 128 KB 528 MHz 128 KB L2 5 / 10 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 256-bit 256-bit 256-bit DDR3/DDR3L Yes Yes DDR3/DDR4L Yes Yes DDR3/DDR5L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 0 1 2 OTG, HS/FS x 1 OTG, HS/FS x 2 OTG, HS/FS x 2 None None None None 24-bit Parallel LCD 2 2 None 1 2 4 2 2 1 1 1 None 1 8 4 4 3 1 1 PxP 16-bit Parallel CSI 1 8 4 4 3 1 1 Timer x 2, PWM x 4 Timer x 4, PWM x 8 Timer x 4, PWM x 8 None AES-128, HAB AES-128, HAB 1 x 10-ch. -40°C to 105°C (Tj) 1 x 10-ch. -40°C to 105°C (Tj) Table 1-2 i.MX 6ULL Device Options 2 528 MHz 2 x 10-ch. -40°C to 105°C (Tj) The MYS-6ULX Single Board Computer takes full features of the i.MX 6UltraLite / 6ULL processors. The MYB-6ULX is an expansion board which has further increased the functionality of the MYS-6ULX Board. Below table list the features of the two MYS-6ULX boards to help customers make choices according to your requirements. Features MYS-6ULX-IND Dimensions 70mm x 55mm PCB Layer 8-layer Power Supply Power Consumption Working Temp. Target Applications CPU DDR3 Nand Flash 5V/1A About 5V/0.25A (single board) About 5V/0.4A (board + 4.3” LCD) About 5V/0.8A (board + 7” LCD) -40°C~85°C Industry 4.0 MCIMX6Y2CVM05A/MCIMX6G2CVM05A Debug Connector Expansion Headers WiFi Module MCIMX6Y2DVM05A 256MB (support up to 2GB) 1 x USB Host, 1 x Micro USB Device TF Card LCD Connector IoT 1 x 10/100Mbps USB LED 0°C~70°C 256MB (support 512MB/1GB) Ethernet Button MYS-6ULX-IOT 1 x Micro SD card slot 1 x Reset Button, 1 x User Button 1 x Power Indicator, 2 x User LEDs 24-bit RGB LCD & Touch Screen (50-pin FPC connector) 2.5mm pitch 3-pin Headers, TTL Two 2.0mm pitch 2x20-pin male Headers (1 x Ethernet, 8 x UARTs, 4 x I2C, 2 x CAN, 4 x SPI, 8 x ADC, 4 x PWM, 2 x I2S, 1 x 8-bit Camera, 1 x JTAG, up to 46 x GPIOs) - 2.4GHz, IEEE 802.11b/g/n standards 70mm x 55mm, 4-layer PCB, 5V/1A USB Power Supply Supports -40°C~85°C Working Temperature 1 x 10/100Mbps MYB-6ULX Expansion Board 1 x CAN 1 x RS485 1 x Micro USB Debug port 1 x Microphone, 1 x Headphone, 1 x Line In 1 x Camera Interface (30-pin FPC connector) 1 x RTC Battery Socket 1 x IO Expansion Header (2.0mm pitch 2 x 7-pin headers) 2 x 2.0mm pitch 2 x 20-pin female Header Connectors (connect with MYS-6ULX) Note: the peripheral signals brought out to the expansion headers are listed in maximum number. Some signals are reused. Please refer to the processor datasheet. Table 1-3 Hardware Features of MYS-6ULX Single Board Computer 6 / 10 Function Block Diagram Figure 1-7 Function Block Diagram of MYS-6ULX-IND Figure 1-8 Function Block Diagram of MYS-6ULX-IOT 7 / 10 Dimension Charts Figure 1-9 Dimension Chart of MYS-6ULX Single Board Computer Figure 1-10 Dimension Chart of MYB-6ULX Expansion Board 8 / 10 Software Features The MYS-6ULX Single Board Computer is ready to run Linux with Debian distribution or by Yocto project with QT. Many peripheral drivers are in source code to help accelerate customers’ designs with a stable and reliable hardware and software platform. The software features are summarized as below: Item Bootstrap program Linux Kernel Features Description USB HOST and Device drivers (source code) u-boot Version Ethernet MMC/SD NandFlash UART Linux Drivers LCD Controller Touch Panel CAN Camera Audio RTC Button File System Compiler Tool Chain 9 / 10 LED Yocto Debian Linaro GCC 4.9 hf The primary bootstrap (source code) Linux 4.1.15 (source code) Ethernet driver (source code) MMC/SD card driver (source code) Nand Flash driver (source code) UART driver (source code) LCD driver (source code), supporting MYIR’s 4.3- and 7- inch LCD module Touch screen driver (source code), supporting 4-wire capacitive and resistive touch screen CAN driver (source code) Camera driver (source code), Supporting MYIR’s MY-CAM011B Camera module Audio driver (source code) RTC driver (source code) Button driver (source code) LED driver (source code) Including QT 5.0 (source code) Binary file and Building Instructions Binary file Table 1-4 Software Features of MYS-6ULX Single Board Computer Order Information Item MYS-6ULX Single Board Computer MYB-6ULX Expansion Board MY-LCD43TP 4.3-inch LCD Module with Resistive Touch Screen MY-LCD70TP 7-inch LCD Module with Resistive Touch Screen MY-LCD70TP-C 7-inch LCD Module with Capacitive Touch Screen MY-CAM011B Camera Module MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 10 / 10 Part No. MYS-6ULX-IND (MYS-6ULG2-256N256D-50-I-IND) MYS-6ULY2-256N256D-50-I-IND MYS-6ULX-IOT (MYS-6ULY2-256N256D-50-C-IOT) MYB-6ULX MY-TFT043RV2 MY-TFT070RV2 MY-TFT070CV2 MY-CAM011B Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: MYIR Tech: MYS-6ULX-IND MYS-6ULX-IOT MYS-6ULY2-256N256D-50-I-IND MYS-6ULY2-256N256D-50-C-IOT
MYS-6ULY2-256N256D-50-I-IND 价格&库存
很抱歉,暂时无法提供与“MYS-6ULY2-256N256D-50-I-IND”相匹配的价格&库存,您可以联系我们找货
