MYC-JX8MQ6-8E1D-130-E
    MYIR(米尔科技)
    主芯片 I.MX6UL 开发板
MYC-JX8MQ6-8E1D-130-E 数据手册
MYC-JX8MX CPU Module ➢ ➢ ➢ ➢ ➢ ➢ ➢ NXP i.MX 8M Quad Application Processor based on 1.3 GHz Arm Cortex-A53 and 266MHz Cortex-M4 Cores 1GB / 2GB LPDDR4, 8GB eMMC Flash, 256Mbit QSPI Flash On-board Gigabit Ethernet PHY ROHM Power Management IC (PMIC) 0.5mm pitch 314-pin MXM 3.0 Expansion Connector Supports Working Temperature Ranging from -30°C to 80°C Supports Running Linux and Android OS Figure 1-1 MYC-JX8MX CPU Module (delivered with installed heatsink by default) Measuring 82mm by 52mm, the MYC-JX8MX CPU Module provides an outstanding embedded solution for Scanning/Imaging, Building Automation and Smart Home, Human Machine Interface (HMI), Machine Vision and more other consumer and industrial applications which requires high multi-media performance. The MYC-JX8MX is based on NXP i.MX8M Quad processor featuring 1.3GHz quad ARM Cortex-A53 cores and a real-time ARM Cortex-M4 co-processor. It is a minimum system integrated with CPU, LPDDR4, eMMC, QSPI Flash, GigE PHY and PMIC. All controller signals are brought out through one 0.5mm pitch 314-pin MXM 3.0 Expansion Connector. It is a Linux-ready ARM SoM ideal for your next embedded design and provided with Linux and Android software package for development. Figure 1-2 MYC-JX8MX CPU Module 1 / 8 A development board MYD-JX8MX is also available for evaluating the MYC-JX8MX CPU Module. It takes full features of the i.MX8M processor to provide rich peripheral interfaces and signals through connectors and headers. It is a solid reference design for users to develop their own carrier boards when using the MYC-JX8MX as their controller boards; it is also a complete evaluation platform for i.MX8M based solutions. MYIR offers MY-CAM003M MIPI Camera Module as an option for the board. Figure 1-3 MYD-JX8MX Development Board Top-view Figure 1-4 MYD-JX8MX Development Board Bottom-view 2 / 8 Hardware Specification The MYC-JX8MX CPU Module is using NXP’s 17 x 17 mm, 0.65 mm pitch, FCBGA bare die package i.MX 8M Quad Application Processor (MIMX8MQ6CVAHZAB) which is based on 1.3GHz quad Arm Cortex-A53 and 266MHz Cortex-M4 cores. The i.MX 8M family of applications processors (i.MX 8M Dual / 8M QuadLite / 8M Quad) represent NXP’s latest market of connected streaming audio/video devices, scanning/imaging devices, and various devices requiring high-performance, low-power processors. The i.MX 8M processors feature advanced implementation of a dual/quad Arm® Cortex®-A53 core, which operates at speeds of up to 1.3 GHz. A general-purpose Cortex®-M4 core processor is for low-power processing. The DRAM controller supports 32-bit/16-bit LPDDR4, DDR4, and DDR3L memory. There are a number of other interfaces for connecting peripherals, such as WLAN, Bluetooth, GPS, displays, and camera sensors. The i.MX 8M Quad and i.MX 8M Dual processors have hardware acceleration for video playback up to 4K, and can drive the video outputs up to 60 fps. Although the i.MX 8M QuadLite processor does not have hardware acceleration for video decode, it allows for video playback with software decoders if needed. Figure 1-5 i.MX 8M System Block Diagram 3 / 8 Mechanical Parameters • Dimensions: 82mm x 50mm • PCB Layers: 10-layer design • Power supply: +5V/0.5A • Working temperature: -30~80 Celsius Processor • NXP i.MX 8M Quad Processor based on 1.3GHz Quad ARM Cortex-A53 and 266MHz Cortex-M4 cores (MIMX8MQ6CVAHZAB by default) Memory • 1GB / 2 GB LPDDR4 (supports up to 4GB LPDDR4) • 8GB eMMC Flash (supports up to 64GB eMMC) • 256Mbit QSPI Flash Peripherals and Signals Routed to Pins MYC-JX8MX Pinouts Description • One 10/100/1000M Ethernet PHY • Power Management IC (ROHM BD71837MWV) • 0.5mm pitch 314-pin MXM 3.0 Expansion Connector - 1 x 10/100/1000Mbps Ethernet - 3 x Serial ports - 3 x I2C - 2 x SPI - 4 x PWM - 3 x USB 3.0 - 2 x PCIe - 6 x I2S / SAI - 2 x MIPI Camera Sensor Interface - 1 x JTAG - 1 x HDMI 2.0a output - Up to 108 GPIOs Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet. 4 / 8 Figure 1-6 MYC-JX8MX CPU Module Function Block Diagram Figure 1-7 MYC-JX8MX Dimensions Chart 5 / 8 Software Features MYIR’s MYC-JX8MX CPU module is ready to run Linux OS and is provided with both Linux and Android software packages for user development. Many peripheral drivers are in source code to help accelerate customers’ designs. The software packages provided are characterized as following: Item Features Description Source Code Provided Bootstrap program U-boot The primary bootstrap YES Linux kernel Image Based on NXP official imx_4.9.88_2.0.0_ga version YES PMIC BD71873PMIC driver YES USB Host USB Host driver YES USB OTG USB OTG driver YES I2C I2C Bus driver YES SPI SPI Bus driver YES Ethernet 10/100/1000M Ethernet driver YES MMC MMC/eMMC/TF card driver YES HDMI HDMI Display driver YES LCD MIPI-LVDS driver YES PWM PWM driver YES RTC RTC driver YES IO GPIO driver YES Touch Capacitive touch screen driver YES Audio WM8904 driver YES Camera Ov5640 driver YES WiFi & BT QCA6174/RTK8822 driver NO Watchdog Watchdog driver YES 4G LTE Module Supports Quectel’s EC20 using USB driver YES M.2 NVME driver YES Yocto rootfs Including QT5.9 YES Common file system for terminal YES GPIO KEY Key example YES GPIO LED LED example YES NET TCP/IP Sokect C/S example YES RTC RTC example YES UART UART example YES Audio Audio example YES LCD LCD example YES Camera Dual camera display example YES Cross compiler Yocto GCC 7.3.0 Hardfloat BINARY Drivers File System Application Programs Compiler Tool Chain Table 1-1 Linux Software Features 6 / 8 Item Features Description Source Code Provided Bootstrap program U-boot The primary bootstrap YES Linux kernel Image Based on NXP official Android 9.0.0 version YES PMIC BD71873PMIC driver YES USB Host USB Host driver YES USB OTG USB OTG driver YES I2C I2C Bus driver YES SPI SPI Bus driver YES Ethernet 10/100/1000M Ethernet driver YES MMC MMC/eMMC/TF card driver YES HDMI HDMI Display driver YES PWM PWM driver YES RTC RTC driver YES IO GPIO driver YES Audio WM8904 driver YES Camera Ov5640 driver YES WiFi & BT QCA6174/RTK8822 driver NO Watchdog Watchdog driver YES 4G LTE Module Supports Quectel’s EC20 using USB driver YES M.2 NVME driver YES Ramdisk android ramdisk YES GPIO KEY Key example YES GPIO LED LED example YES NET TCP/IP Sokect C/S example YES RTC RTC example YES UART UART example YES Audio Primary recorder apk based on Android YES Camera Primary camera apk based on Android YES WiFi Primary settings apk based on Android YES BT Primary settings apk based on Android YES Video Primary Cactus player based on Android YES Cross compiler 4.9.x 20150123 BINARY Drivers File System Application Programs Compiler Tool Chain Table 1-2 Android Software Features 7 / 8 Order Information Product Item Part No. MYC-JX8MQ6-8E1D-130-E MYC-JX8MX CPU Module MYC-JX8MQ6-8E2D-130-E MYD-JX8MQ6-8E1D-130-E MYD-JX8MX Development Board Packing List ➢ One MYC-JX8MX CPU Module (Product resources provided include user manual, datasheet, base board schematic pdf format, CPU Module pinout description and software packages.) MYD-JX8MQ6-8E2D-130-E MY-CAM003M Camera Module MY-CAM003M MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 8 / 8 Add-on Options ➢ MYD-JX8MX Development Board ➢ MY-CAM003M Camera Module Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: MYIR Tech: MYC-JX8MQ6-8E2D-130-E MYC-JX8MQ6-8E1D-130-E
MYC-JX8MQ6-8E1D-130-E 价格&库存
很抱歉,暂时无法提供与“MYC-JX8MQ6-8E1D-130-E”相匹配的价格&库存,您可以联系我们找货
