MYD-J3358-256N256D-100-I
    MYIR(米尔科技)
    主芯片 AM335X 开发板
MYD-J3358-256N256D-100-I 数据手册
MYD-AM335X-J Development Board ➢ ➢ ➢ ➢ ➢ ➢ ➢ ➢ MCC-AM335X-J CPU Module as Controller Board DDR2 SO-DIMM 200-pin Connector for Board-to-Board Connections Up to 1GHz TI AM335x Series ARM Cortex-A8 Processors 256MB DDR3 SDRAM (128MB/512MB Compatible) 256MB Nand Flash (128MB/512MB Compatible) Up to 6 x Serial ports, , 1 x CAN, 2 x RS485, 2 x Gigabit Ethernet, USB, TF, Audio, LCD Optional LCD, WiFi, Camera, GPS and GPRS Modules Ready-to-Run Linux Evaluation Kit Figure 1-1 MYD-AM335X-J Development Board Description The MYD-AM335X-J development board is a complete evaluation platform for TI AM335x (AM3352, AM3354, AM3356, AM3357, AM3358 and AM3359) ARM Cortex-A8 Sitara Microprocessors (MPUs). It is designed based on the MCC-AM335X-J CPU module which integrates the core components on board including the AM335x processor, 256MB DDR3, 256MB Nand Flash, Gigabit Ethernet PHY, PMIC, etc. The MCC-AM335X-J CPU Module is mounted onto the MYD-AM335X-J base board through an SO-DIMM 200-pin gold finger interface. In addition to those main functions provided by the MCC-AM335X-J CPU module, the MYD-AM335X-J base board has extended more functions through headers and connectors, which makes the board versatile for various industrial applications. It features up to six serial ports, two Ethernet ports, USB Host, OTG, CAN, RS485, TF card slot, Audio, LCD and more other peripherals on board. It can support -40 to +85 Celsius extended temperature operation and ready to run Linux operating system. 1 / 9 Figure 1-2 MYD-AM335X-J Development Board Figure 1-3 MCC-AM335X-J CPU Module User can integrate a different MCC-AM335X-J module on the same base board, thus making six variants of evaluation boards. The differences are depending on the AM335x processor features with various options including speed grades, packages, graphics and peripherals. The image below gives a brief overview of options. 2 / 9 Figure 1-4 AM335x Devices Features The MYD-AM335X-J board comes with Linux 4.1.18 software packages, detailed documents, necessary cable accessories as well as optional 4.3- or 7-inch LCD (with touch screen) to enable your rapid development when getting the goods out-of-the-box. Figure 1-5 MYD-AM335X-J Development Board with 7-inch LCD Module 3 / 9 Hardware Specification The TI AM335x microprocessors, based on the ARM Cortex-A8, operating at up to 1GHz, are enhanced with image, graphics processing, peripherals and industrial interface options such as EtherCAT and PROFIBUS. The device supports the following high-level operating systems (HLOSs) that are available free of charge from TI: • Linux® • Android™ The AM335x microprocessor contains these subsystems: • Microprocessor unit (MPU) subsystem based on the ARM Cortex-A8 microprocessor. • POWERVR SGX™ Graphics Accelerator subsystem for 3D graphics acceleration to support display and gaming effects. • The Programmable Real-Time Unit and Industrial Communication Subsystem (PRU-ICSS) is separate from the ARM core, allowing independent operation and clocking for greater efficiency and flexibility. The PRU-ICSS enables additional peripheral interfaces and real-time protocols such as EtherCAT, PROFINET, EtherNet/IP, PROFIBUS, Ethernet Powerlink, Sercos, and others. AM335x ARM Cortex™-A8 Processors Core Feature AM3352 AM3354 AM3356 Package CPU Speed (MHz) AM3357 AM3358 AM3359 600, 800,1000 800 15x15mm, 0.8mm (ZCZ) 300, 600, 600, 800,1000 300, 600,800 300, 600,800 800, 1000 Core Internal Memory 64KB SRAM shared w/ Data 32KB Cache, Programmable 32KB Cache On-chip L2 (KB) 256 External Memory DDR2/DDR3/DDR3L/mDDR (LPDDR), 2x16-bit, NAND ECC Interface Graphics - OS Support 3D Graphics 3D Graphics Linux, Android, RTOS, Windows Embedded, no-OS Other Hardware Acceleration - Crypto Crypto Accelerator Accelerator 2 PRU-ICSS 2 PRU-ICSS 2 PRU-ICSS 2 PRU-ICSS Crypto Crypto Crypto Crypto Accelerator Accelerator + EtherCAT slave support slave support 2 port switch USB 2.0 OTG + PHY 2 6 UART, 2 SPI, 3 I2C, 2 McASP, 2 CAN, 8 Timers System EDMA, WDT, RTC, 3 eQEP, 3 eCAP, JTAG, ADC (8ch) Parallel 3 MMC/SD/SDIO, GPIO Table 1-1 AM335x Devices Key Features 4 / 9 Accelerator + EtherCAT 10/100/1000 EMAC Serial Ports Accelerator The MYD-AM335X-J development board is characterized as follows: Mechanical Parameters • Dimensions: 106mm x 177mm (base board), 67.6mm x 45mm (CPU Module) • PCB Layers: 4-layer design (base board), 8-layer design (CPU Module) • Power supply: 12V (base board), 5V, 1.8V (CPU Module) • Working temperature: 0~70 Celsius (commercial grade) or -40~85 Celsius (industrial grade) The MYD-AM335X-J Controller Board (MCC-AM335X-J CPU Module) Processor • TI AM3352, AM3354, AM3356, AM3357, AM3358, AM3359 (15x15 mm, 0.8-mm ball pitch, ZCZ package) - Up to 1GHz ARM Cortex-A8 32-bit RISC MPU - NEON™ SIMD Coprocessor - 32KB/32KB of L1 Instruction/Data Cache with Single-Error Detection (parity) - 256KB of L2 Cache with Error Correcting Code (ECC) - SGX530 Graphics Engine - Programmable Real-Time Unit Subsystem Memory • • • 256MB DDR3 SDRAM (128MB/512MB compatible) 256MB Nand Flash (128MB/512MB compatible) 32Kb EEPROM Peripherals and Signals Routed to Pins • On-board Gigabit Ethernet PHY • External Watchdog circuit • Power Management IC (TPS65217C) • One power indicator (Red LED) • One user LED (Green) • DDR2 SO-DIMM 200-pin gold finger connector (the extended signals please refer to the pinouts diagram): - 2 x Gigabit Ethernet - 2 x USB OTG - Up to 6 x Serial ports - Up to 2 x I2C - Up to 2 x SPI - Up to 2 x CAN - 8 x ADC - 2 x PWM - 3 x SDIO (One SDIO has multiplexed with Nand Flash signals) The MYD-AM335X-J Base Board • 5 / 9 Serial ports: Up to 6 x Serial ports - 1 x 3-wire RS232 - 4 x 5-wire RS232 • • • • • • • • • • • • • • 6 / 9 - 1 x USB Debug serial port - 2 x RS485 (multiplexed with UART2 and UART3, with isolation) USB - 1 x USB2.0 Host port - 1 x Mini USB2.0 OTG port 2 x 10/100/1000Mbps Ethernet interfaces 1 x CAN interface (with isolation) 1 x TF card slot 1 x LCD interface (16-bit true color, supports optional 4.3-inch TFT LCD) 1 x 4-wire resistive touch screen interface 1 x Audio input port (3.5mm jack) 1 x Stereo Audio output port (3.5mm jack) 1x 2.54mm pitch 10-pin JTAG interface 4 x Buttons (1 x Reset button, 2 x User buttons, 1 x Power button) 1 x Power indicator (Red LED) 2 x User LEDs (Green) Battery backed RTC 1 x 2.0mm pitch 20-pin and 1 x 2.0mm pitch 10-pin expansion connectors - 3 x ADC - 1 x SDIO - 1 x UART - 1 x I2C - 8 x GPIO Function Block Diagram Figure 1-6 Function Block Diagram of MYD-AM335X-J Dimension Chart of MYD-AM335X-J Figure 1-7 Dimension Chart of MYD-AM335X-J 7 / 9 Software Features MYIR’s AM335x Starter Kit MYD-AM335X-J is provided with Linux software packages. Many peripheral drivers are in source code to help accelerate customers’ designs with a stable and reliable hardware and software platform. The software features are summarized as below: Category Name Description sourc e Bootloader U-boot Responsible for system initialization and boot kernel, including TCPIP Kernel Linux 4.1.18 Designed for MYD-AM335X-J hardware USB Host USB Host driver, support OHCI and EHCI YES USB Device USB Device driver YES Ethernet Ethernet driver YES MMC/SD MMC/SD driver YES NAND Flash NAND Flash/SmartMedia driver I2C I2C driver YES SPI SPI driver YES Audio SGTL5000 driver YES LCD Controller LCD driver, for 4.3 inch, 7 inch RTC RTC clock driver YES TouchScre en 4-wire resistive touch screen driver I2C capacitive touch screen driver YES PWM PWM (Pulse Width Modulation) driver YES UART Serial driver YES CAN CAN driver YES PMU Power Management Unit river YES LED GPIO/PWM LED Driver YES GPIO LED driver and GPIO input and output YES I2c to UART/IO I2c to UART/IO Driver Drivers Filesystem Demo 8 / 9 YES YES YES YES YES rootfs rootfs-qt Base on buildroot Bin Filesystem with QT5 Bin Examples Audio, CAN, EEPROM, framebuffer, gpio, keypad, led, mtd, network, rtc, RS232, RS485 YES Order Information Product Item Part No. MYD-AM3352-J Development Board MYD-J3352-256N256D-80-I MYD-AM3358-J Development Board MYD-J3358-256N256D-100-I MCC-AM3352-J CPU Module MYC-J3352-256N256D-80-I MCC-AM3358-J CPU Module MYC-J3358-256N256D-100-I MY-LCD43TP 4.3-inch LCD Module MY-TFT043RV2 MY-LCD70TP 7-inch LCD Module MY-TFT070RV2 MY-LCD70TP-C 7-inch LCD Module MY-TFT070CV2 Packing List ➢ ➢ ➢ ➢ ➢ One MYD-AM335X-J Board One Net cable One USB cable One 12V/1.5A Power adapter One Product DVD Add-on Options ➢ MCC-AM335X-J CPU Module ➢ MY-LCD43TP 4.3-inch LCD Module ➢ MY-LCD70TP 7-inch LCD Module ➢ MY-LCD70TP-C 7-inch LCD Module Remark: 1. One MYD-AM335X-J Development Board includes one CPU module MCC-AM335X-J mounted on the base board. If you need more CPU module, you can order extra ones. 2. We deliver the board of industrial grade version with 800MHz AM3352 or 1GHz AM3358 processor, 256MB DDR3 and 256MB Nand Flash by default; if you need other CPU model or RAM/Flash configurations, please contact MYIR for availabilities. 3. For Price information, please contact MYIR. 4. We accept custom design based on the MYD-AM335X-J, whether reducing, adding or modifying the existing hardware according to customer’s requirement. MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 9 / 9
MYD-J3358-256N256D-100-I 价格&库存
很抱歉,暂时无法提供与“MYD-J3358-256N256D-100-I”相匹配的价格&库存,您可以联系我们找货
