MYB-Y6ULX-HMI-4GEXP
MYB-Y6ULX-HMI-4GEXP
    MYIR(米尔科技)
    主芯片 I.MX6UL 扩展板
MYB-Y6ULX-HMI-4GEXP 数据手册
MYD-Y6ULX-HMI Development Board ➢ ➢ ➢ ➢ ➢ ➢ ➢ 528MHz NXP i.MX 6UltraLite / 6ULL ARM Cortex-A7 Processor 256MB DDR3, 256MB Nand Flash RS232, RS485, USB Host, Device, Ethernet, TF Card, LCD, Touch Screen, Camera, RTC, IO… Optional MYB-Y6ULX-HMI-4GEXP IO Board adds Ethernet, WiFi/BT, 4G LTE Interface, Audio… Optional 7-inch LCD with Capacitive Touch Screen Supports Working Temperature Ranging from -40°C to 85°C Ready-to-Run Linux 4.1.15 OS with QT 5.6.2 Figure 1-1 MYD-Y6ULX-HMI Development Board The MYD-Y6ULX-HMI Development Board is specially designed for MYIR’s MYD-Y6ULX-CHMI Display Panel for Human Machine Interface (HMI) applications. It is powered by MYIR’s MYC-Y6ULX CPU Module which is a compact System-on-Module (SoM) integrated with 528MHz NXP i.MX6UL/6ULL ARM Cortext-A7 processor, 256MB DDR3, 256MB Nand Flash and Ethernet PHY. In addition to the core components provided by the MYC-Y6ULX core board, the MYD-Y6ULX-HMI has extended multiple peripheral interfaces like RS232, RS485, USB Host/Device, 10/100Mbps Ethernet and TF card to its base board to allow communications with other devices. It also features a Camera interface and supports 16-bit LCD & 4-wire resistive or capacitive touch screen driven directly from the board circuit. The board provides two 2.0mm pitch 2*20-pin headers for IO extension. User can customize their own IO boards to connect with the MYD-Y6ULX-HMI to further explore more functions. MYIR offers an IO board MYB-Y6ULX-HMI-4GEXP as an option for users which has extended WiFi & BT, USB based 4G LTE Module interface, Audio and GPIOs. A 7-inch LCD with capacitive touch screen is also available as an add-on option, thus making a complete solution for HMI applications. The MYD-Y6ULX-HMI is preloaded with Linux OS. MYIR has provided plenty of resources including kernel and drivers in source code, application examples and an MEasyHMI QT demo for developers to start their development rapidly. 1 / 12 Figure 1-2 MYD-Y6ULX-HMI Development Board Figure 1-3 MYB-Y6ULX-HMI-4GEXP IO Board 2 / 12 Figure 1-4 MYB-Y6ULX-HMI-4GEXP IO Board Mounted on MYD-Y6ULX-HMI Figure 1-5 MYD-Y6ULX-CHMI Display Panel Figure 1-6 MYD-Y6ULX-CHMI Display Panel + MYB-Y6ULX-HMI-4GEXP IO Board 3 / 12 Hardware Specification The MYC-Y6ULX CPU Module on the MYD-Y6ULX-HMI Development Board is using the 14 x 14mm, 0.8 mm ball pitch, 289 MAPBGA package 528 MHz i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 application processor which provides multiple compatible options of G0, G1, G2, G3, Y0, Y1 and Y2 sub family. The MCIMX6G2CVM05AB and MCIMX6Y2DVM05AA are optional as the default part with the board. Expanding the i.MX 6 series, the i.MX 6UltraLite is a high performance, ultra-efficient processor family featuring an advanced implementation of a single ARM® Cortex®-A7 core, which operates at speeds up to 696 MHz. The i.MX 6UltraLite applications processor includes an integrated power management module that reduces the complexity of external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth™, GPS, displays and camera sensors. Feature MCIMX6G0 MCIMX6G1 MCIMX6G2 MCIMX6G3 Speed 528 MHz 528 MHz 528 MHz 528 MHz Cache 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB L2 128 KB L2 128 KB L2 OCRAM 128 KB 128 KB 128 KB 128 KB 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, DDR3/DDR3L DDR3/DDR4L DDR3/DDR5L DDR3/DDR6L eFuse 512-bit 1024-bit 1536-bit 2048-bit NAND (BCH40) Yes Yes Yes Yes EBI Yes Yes Yes Yes Ethernet 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 10/100-Mbit/s x 2 USB OTG, HS/FS x 1 OTG, HS/FS x 2 OTG, HS/FS x 2 OTG, HS/FS x 2 CAN 0 1 2 2 DRAM TRNG, Crypto Engine (AES Security Basic TRNG, Crypto Engine TRNG, Crypto Engine with DPA/TDES/SHA/RSA), (AES/TDES/SHA), (AES/TDES/SHA), Secure Boot, tamper monitor, Secure Boot Secure Boot PCI4.0 pre-certification, OTF DRAM encryption Graphic None None PxP PxP CSI None None 24-bit Parallel CSI 24-bit Parallel CSI LCD None None 24-bit Parallel LCD 24-bit Parallel LCD Quad SPI 1 1 1 1 SDIO 2 2 2 2 UART 4 8 8 8 I2C 2 4 4 4 SPI 2 4 4 4 I2S/SAI 1 3 3 3 S/PDIF 1 1 1 1 Timer/PWM Timer x 2, PWM x 4 Timer x 4, PWM x 8 Timer x 4, PWM x 8 Timer x 4, PWM x 8 12-bit ADC 1 x 10-ch. 1 x 10-ch. 2 x 10-ch. 2 x 10-ch. Table 1-1 i.MX 6UltraLite Device Options 4 / 12 The i.MX 6ULL is a power efficient and cost optimized applications processor family featuring an advanced implementation of a single ARM Cortex-A7 core, which operates at speeds up to 900 MHz. The i.MX 6ULL applications processor includes an integrated power management module that reduces the complexity of an external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth ®, GPS, displays and camera sensors. Feature MCIMX6Y0 MCIMX6Y1 MCIMX6Y2 Core ARM® Cortex-A7 ARM® Cortex-A7 ARM® Cortex-A7 Speed 528 MHz 528 MHz 528 MHz Cache 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB L2 128 KB L2 OCRAM 128 KB 128 KB 128 KB 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, DDR3/DDR3L DDR3/DDR4L DDR3/DDR5L eFuse 256-bit 256-bit 256-bit NAND (BCH40) Yes Yes Yes EBI Yes Yes Yes Ethernet 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 USB OTG, HS/FS x 1 OTG, HS/FS x 2 OTG, HS/FS x 2 CAN 0 1 2 Graphic None None PxP CSI None None 16-bit Parallel CSI LCD None None 24-bit Parallel LCD Quad SPI 1 1 1 SDIO 2 2 2 UART 4 8 8 I2C 2 4 4 SPI 2 4 4 I2S/SAI 1 3 3 ESAI 1 1 1 S/PDIF 1 1 1 Timer/PWM Timer x 2, PWM x 4 Timer x 4, PWM x 8 Timer x 4, PWM x 8 12-bit ADC 1 x 10-ch. 1 x 10-ch. 2 x 10-ch. Security None AES-128, HAB AES-128, HAB Temperature -40°C to 105°C (Tj) -40°C to 105°C (Tj) -40°C to 105°C (Tj) DRAM Table 1-2 i.MX 6ULL Device Options 5 / 12 The MYD-Y6ULX-HMI Development Board is using MYC-Y6ULX CPU Module as core controller board. It takes full features of i.MX 6UL/6ULL processor and the main features are characterized as below: Mechanical Parameters • Dimensions: 130mm x 88mm (base board), 37mm x 39mm (CPU Module) • PCB Layers: 6-layer design (base board), 8-layer design (CPU Module) • Power supply: +12V/1.5A (through one 2-pin 3.81mm pitch Phoenix connector) • Working temperature: 0~70 Celsius (commercial grade) or -40~85 Celsius (industrial grade) The MYD-Y6ULX-HMI Controller Board (MYC-Y6ULX CPU Module) Figure 1-7 MYC-Y6ULX CPU Module (delivered with shield cover) Processor • 528MHz NXP i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 processor (MCIMX6Y2CVM05A or MCIMX6Y2DVM05A by default) Memory • 256MB DDR3 SDRAM (supports up to 1GB) • 256MB Nand Flash (4GB eMMC Flash is optional) Peripherals and Signals Routed to Pins MYC-Y6ULX Pinouts Description • One 10/100M Ethernet PHY • 1.0mm pitch 140-pin stamp hole expansion interface - 2 x 10/100Mbps Ethernet - 8 x Serial ports - 4 x I2C - 2 x CAN - 4 x SPI - 8 x ADC - 8 x PWM - 3 x I2S - 1 x Parallel Camera Sensor Interface 6 / 12 - 1 x JTAG - 1 x 24-bit LCD interface - Up to 97 x GPIOs Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet. The MYD-Y6ULX-HMI Development Board Base Board • Serial ports - Debug serial port (TTL) - 1 x RS485 serial port - 1 x 3-wire RS232 serial port • USB - 2 x USB2.0 Host ports - 1 x Micro USB2.0 OTG port • 1 x 10/100 Mbps Ethernet interface • 1 x Camera interface • 1 x TF card slot • 1 x LCD interface (16-bit true color, supports MYIR’s 7-inch TFT LCD) • 1 x Resistive Touch Screen interface • 1 x Capacitive Touch Screen interface (supports MYIR’s 7-inch capacitive touch screen) • Battery backed RTC • 1 x Reset button • 1 x Buzzer • 2 x 2.0mm 2*20-pin male pin headers (J12 & J13) Figure 1-8 Signals of J12 pin header Figure 1-9 Signals of J13 pin header 7 / 12 Figure 1-10 MYD-Y6ULX-HMI Development Board Function Block Diagram The MYB-Y6ULX-HMI-4GEXP IO Board MYIR also offers an optional IO Board MYB-Y6ULX-HMI-4GEXP for users to explore more functions of the MYD-Y6ULX-HMI development board. The main features of the IO Board are as following: Figure 1-11 MYB-Y6ULX-4GEXP IO Board • • • • • • • • • • 8 / 12 Dimensions: 130mm x 88mm PCB Layers: 4-layer design Working temp.: -40~85 Celsius (but WiFi/BT module supports only -30 ~85 Celsius) 1 x Mini PCIe interface (supports USB based 4G LTE module) 1 x SIM card socket 1 x WiFi/Bluetooth module (AP6212, cannot be supported if using eMMC on MYC-Y6ULX) 3 x External antenna interfaces (one for WiFi/BT, one for 4G LTE and one for GPS) Audio input/output 9 GPIOs 2 x 2.0mm 2*20-pin female connectors (J10 & J11) Figure 1-12 MYD-Y6ULX-CHMI Display Panel Function Block Diagram Figure 1-13 MYD-Y6ULX-HMI Dimensions Chart 9 / 12 Software Features Item Features Description Bootstrap program u-boot The primary bootstrap (source code) Version Linux 4.1.15 (source code, based on official imx_4.1.15_2.0.0_ga version) USB HOST and OTG driver (source code) Ethernet Ethernet driver (source code) MMC MMC/eMMC/TF card driver (source code) NandFlash Nand Flash driver (source code) eMMC eMMC driver (source code) WiFi & BT AP6212 driver (source code) 4G LTE 4G LTE Module driver (source code, USB signal based) Camera Camera driver (source code, OV2659) LCD Controller LCD driver (source code, supports MYIR’s 7- inch LCD) Touch Panel Resistive and Capacitive touch screen driver (source code, MYIR’s 7- inch Touch Panel) RTC RTC driver (source code) GPIO Button Button driver (source code) UART UART driver (source code) CAN CAN driver (source code) RS485 RS485 driver (source code) Audio Audio driver (source code, wm8904) SPI SPI driver (source code) I2C I2C driver (source code) PWM PWM controller driver (source code) GPIO GPIO driver (source code) Watchdog Watchdog driver (source code) Yocto Including QT5.6 (source code) Common file system for terminal Kernel Linux Drivers File System 10 / 12 Application Program Compiler Tool Chain Demo GPIO LED and Key LED and Key driver (source code) NET TCP/IP Socket C/S example RTC RTC example RS232 RS232 example RS485 RS485 example Audio Audio example LCD LCD example Camera Viewing via web Data base sqllite3 Data storing example MODBUS RTU MODBUS RTU Protocol Library Linaro GCC 4.9 hf Binary file MetaToolchain Built by Yocto, GCC 5.3 (Binary file) Applications Tool Chain Built by Yocto, GCC 5.3 (Binary file) MEasyHMI Including examples developed by Web Server and QT for peripherals using (source code) Table 1-3 Software Features of MYD-Y6ULX-HMI 11 / 12 Order Information Item MYD-Y6ULX-HMI Development Board (Part No.: MYD-Y6ULY2-256N256D-50-C-HMI) MYD-Y6ULX-HMI Development Board (Part No.: MYD-Y6ULY2-256N256D-50-I-HMI) Packing List - One MYD-Y6ULX-HMI board - One 12V DC power adapter MYB-Y6ULX-HMI-4GEXP IO Board (Part No.: MYB-Y6ULX-HMI-4GEXP) - One MYB-Y6ULX-HMI-4GEXP board - One 4G LTE antenna - One WiFi/BT antenna MYD-Y6ULX-CHMI Display Panel (Part No.: MYD-Y6ULY2-256N256D-50-C-CHMI) - One MYD-Y6ULX-HMI board - One 12V DC power adapter - One 7-inch LCD with Capacitive touch screen MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Smart Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 12 / 12
MYB-Y6ULX-HMI-4GEXP 价格&库存
很抱歉,暂时无法提供与“MYB-Y6ULX-HMI-4GEXP”相匹配的价格&库存,您可以联系我们找货
