SS22A thru SS210A
SURFACE MOUNT
SCHOTTKY BARRIER RECTIFIERS
FORWARD CURRENT - 2.0 Amperes
FEATURES
● For
SMA
surface mounted applications
● Metal-Semiconductor
● Epitaxial
- 20 to 100 Volts
REVERSE VOLTAGE
junction with guarding
construction
● Very
low forward voltage drop
● High
current capability
.062(1.60)
.055(1.40)
.114(2.90)
.098(2.50)
● Plastic material has UL flammability
classification 94V-0
● For
.181(4.60)
.157(4.00)
use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications.
.012(.305)
.006(.152)
.103(2.62)
.079(2.00)
MECHANICAL DATA
● Case:
Molded Plastic
● Polarity:
lndicated by cathode band
● Weight:
0.002 ounces,0.064 grams
.060(1.52)
.030(0.76)
.008(.203)
.002(.051)
.208(5.28)
.188(4.80)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave ,60Hz, resistive or inductive load.
For capacitive load, derate current by 20%
CHARACTERISTICS
SYMBOL
SS22A
SS23A
SS24A
SS25A
SS26A
SS28A
SS210A
UNIT
Maximum Recurrent Peak Reverse Voltage
VRRM
40
50
60
80
100
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
V
Maximum Average Forward
Rectified Current
Peak Forward Surage Current
@TL=100 ℃
8.3ms Single Half Sine-Wave
Super Imposed On Rated Load (JEDEC Method)
Maximum Forward Voltage at 2.0A DC
Maximum DCReverse Current
@TJ=25℃
at Rated DC BlockingVoltage
@TJ=100℃
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Operating Temperature Range
Storage Temperature Range
I(AV)
2.0
A
IFSM
60
A
VF
0.45
0.55
0.7
0.6
1.0
IR
V
mA
200
pF
RθJL
15
℃/W
TJ
-55 to +150
TSTG
-55 to + 150
CJ
NOTES:1.Measured at 1.0 MHz and applied reverse voltage of 4.0V DC.
2.Thermal resistance junction to lead.
~ 157
RATING AND CHARACTERTIC CURVES
SS22A thru SS210A
FIG.2 - MAXIMUM NON-REPETITIVE
SURGE CURRENT
PEAK FORWARD SURGECURRENT,
AMPERES
AVERAGE FORWARD CURRENT
AMPERES
FIG. 1 - FORWARD CURRENT DERATING CURVE
2.0
1.0
SINGLE PHASE HALF WAVE 60Hz
RESIST IVE OR INDUCTIVE LOAD
50
75
100
125
150
175
60
50
40
30
PULSE WIDTH 8.3ms
SINGLE HALF-SINE-W AVE
(JEDEC METHOD)
10
2
5
FIG.4-TYPICAL FORWARD CHARACTERISTICS
SS23A
CAPACITANCE,(pF )
SS25A -SS26A
SS28A -SS210A
1.0
100
TJ = 25°C
PULSE WIDTH 300us
1% DUTY CYCLE
0.5
0.7
0.9
1.1
TJ=25
℃ f=1MHZ
10
1.3 1.5
1.0
0.1
1.7
4.0
FIG.5-TYPICAL REVERSE CHARACTERISTICS
100
TJ=125℃
10
TJ=100 ℃
1.0
0.1
0.01
TJ=25℃
0.001
10.0
REVERSE VOLTAGE,VOLTS
INSTANTANEOUS FORWARD VOLTAGE, (VOLTS)
INSTANTANEOUS REVERSE CURRENT, (mA )
INSTANTANEOUS FORWARDCURRENT,
(A)
100
1000
SS24A
0.1
50
FIG.4-TYPICAL JUNCTION CAPACITANCE
SS22A
10
NUMBER OF CYCLES AT 60Hz
LEAD TEMPERATURE ℃
60
80
100
120
PERCENT RATED PEAK REVERSE VOLTAGE,(%)
~ 158
140
100
很抱歉,暂时无法提供与“SS26A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.08640
- 200+0.08100
- 500+0.07560
- 2000+0.06480
- 国内价格
- 20+0.21074
- 200+0.17084
- 600+0.14867
- 2000+0.13174
- 10000+0.12025
- 20000+0.11399
- 国内价格
- 1+0.17380
- 50+0.08712
- 2000+0.06600
- 国内价格
- 1+0.13362
- 100+0.12471
- 300+0.11580
- 500+0.10690
- 2000+0.10244
- 5000+0.09977
