PSMN012-60YS,115
PSMN012-60YS,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=59A VDS=60V SOT669
PSMN012-60YS,115 数据手册
PSMN012-60YS N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET Rev. 01 — 5 January 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in LFPAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ Advanced TrenchMOS provides low RDSon and low gate charge „ Improved mechanical and thermal characteristics „ High efficiency gains in switching power converters „ LFPAK provides maximum power density in a Power SO8 package 1.3 Applications „ DC-to-DC converters „ Motor control „ Lithium-ion battery protection „ Server power supplies „ Load switching 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 60 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 59 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 89 W Tj junction temperature -55 - 175 °C VGS = 10 V; Tj(init) = 25 °C; ID = 59 A; Vsup ≤ 60 V; RGS = 50 Ω - - 71 mJ VGS = 10 V; ID = 30 A; VDS = 30 V; see Figure 14 and 15 - 6.4 - nC - 28.4 - nC Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET Table 1. Quick reference …continued Symbol Parameter Conditions Min Typ Max Unit VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 12 - - 17.8 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 13 - 8 11.1 mΩ Static characteristics RDSon drain-source on-state resistance 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number PSMN012-60YS PSMN012-60YS_1 Product data sheet Package Name Description Version LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 2 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 60 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ VGS gate-source voltage ID drain current - 60 V -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 42 A VGS = 10 V; Tmb = 25 °C; see Figure 1 - 59 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 236 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 89 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 59 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 236 A - 71 mJ Avalanche ruggedness non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 59 A; Vsup ≤ 60 V; drain-source avalanche RGS = 50 Ω energy EDS(AL)S 003aad856 80 ID (A) 03aa16 120 Pder (%) 60 80 40 40 20 0 0 0 Fig 1. 50 100 150 Continuous drain current as a function of mounting base temperature PSMN012-60YS_1 Product data sheet 0 200 Tmb (°C) 50 100 150 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 3 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 003aad857 103 ID (A) Limit RDSon = VDS / ID 10 2 tp = 10 μs 100 μ s 10 DC 1ms 1 10ms 100ms 10-1 1 Fig 3. 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 4 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - 0.8 1.68 K/W 003aad858 1 δ = 0.5 Zth(j-mb) (K/W) 0.2 0.1 10-1 0.05 δ= P 0.02 t tp single shot tp T T 10-2 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration; typical values PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 5 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) drain-source breakdown voltage gate-source threshold voltage VGSth ID = 250 µA; VGS = 0 V; Tj = -55 °C 54 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 60 - - V ID = 1 mA; VDS= VGS; Tj = 25 °C; see Figure 10 and 11 2 3 4 V ID = 1 mA; VDS= VGS; Tj = -55 °C; see Figure 11 - - 4.6 V ID = 1 mA; VDS= VGS; Tj = 175 °C; see Figure 11 0.95 - - V - 0.03 2 µA IDSS drain leakage current VDS = 60 V; VGS = 0 V; Tj = 25 °C VDS = 60 V; VGS = 0 V; Tj = 125 °C - - 50 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 12 - 17 25.5 mΩ VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 12 - - 17.8 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 13 - 8 11.1 mΩ f = 1 MHz - 0.66 - Ω 28.4 - nC RDSon RG drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge ID = 30 A; VDS = 30 V; VGS = 10 V; see Figure 14 and 15 - ID = 0 A; VDS = 0 V; VGS = 10 V - 23.3 - nC QGS gate-source charge ID = 30 A; VDS = 30 V; VGS = 10 V; see Figure 14 and 15 - 8.75 - nC QGS(th) pre-threshold gate-source charge ID = 30 A; VDS = 30 V; VGS = 10 V; see Figure 14 - 4.9 - nC QGS(th-pl) post-threshold gate-source charge - 3.9 - nC QGD gate-drain charge ID = 30 A; VDS = 30 V; VGS = 10 V; see Figure 14 and 15 - 6.4 - nC VGS(pl) gate-source plateau voltage VDS = 30 V; see Figure 14 and 15 - 4.8 - V Ciss input capacitance - 1685 - pF Coss output capacitance VDS = 30 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 245 - pF Crss reverse transfer capacitance - 140 - pF td(on) turn-on delay time - 15.2 - ns tr rise time - 12.6 - ns td(off) turn-off delay time - 28.7 - ns tf fall time - 8.2 - ns PSMN012-60YS_1 Product data sheet VDS = 30 V; RL = 1 Ω; VGS = 10 V; RG(ext) = 4.7 Ω All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 6 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 15 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.82 1.2 V trr reverse recovery time 35 - ns recovered charge IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V - Qr - 41 - nC 003aad859 100 7 VGS (V) = 10 ID (A) 003aad861 60 6 gfs (S) 80 5.5 40 60 5 40 20 20 4 0 0 0 Fig 5. 1 2 3 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 0 Fig 6. 003aad862 4000 20 40 I D (A) 60 Forward transconductance as a function of drain current; typical values 003aad865 40 RDSon (mΩ) 32 C (pF) Ciss 24 2000 Crss 16 8 0 0 0 Fig 7. 2.5 5 7.5 VGS (V) Input and reverse transfer capacitances as a function of gate-source voltage, typical values PSMN012-60YS_1 Product data sheet 4 10 Fig 8. 8 12 16 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 7 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 003aad860 50 03aa35 10−1 ID (A) ID (A) 40 10−2 30 10−3 20 10−4 typ max 10−5 10 Tj = 25 °C Tj = 175 °C 10−6 0 0 Fig 9. min 2 4 VGS (V) 2 4 6 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aad280 5 0 6 Fig 10. Sub-threshold drain current as a function of gate-source voltage 003aad696 2.4 a VGS(th) (V) 2 4 max 1.6 3 typ 1.2 2 min 0.8 1 0 −60 0.4 0 60 120 180 Fig 11. Gate-source threshold voltage as a function of junction temperature PSMN012-60YS_1 Product data sheet 0 -60 0 60 120 Tj (°C) Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature. All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 8 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 50 RDSon (mΩ) 003aad864 VDS VGS (V) = 5 4.5 ID 40 VGS(pl) 30 6 VGS(th) VGS 20 7 QGS1 QGS2 QGS 10 10 QGD QG(tot) 003aaa508 0 0 25 50 75 I D (A) 100 Fig 13. Drain-source on-state resistance as a function of drain current; typical values 003aad866 10 Fig 14. Gate charge waveform definitions 003aad863 104 VGS (V) C (pF) 8 VDS = 30 V 12 V 6 Ciss 48 V 10 3 4 2 Coss 0 0 8 16 24 QG (nC) 32 Fig 15. Gate-source voltage as a function of gate charge; typical values PSMN012-60YS_1 Product data sheet 102 10-1 Crss 1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 9 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 003aad867 50 IS (A) 40 30 20 10 Tj = 175 °C Tj = 25 °C 0 0 0.2 0.4 0.6 0.8 VSD (V) 1 Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 10 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) A UNIT A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 mm b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 18. Package outline SOT669 (LFPAK) PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 11 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN012-60YS_1 20100105 Product data sheet - - PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 12 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft— The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet— A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification— The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Suitability for use— Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications— Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data— The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Disclaimers Limited warranty and liability— Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with theTerms and conditions of commercial saleof Nexperia. Right to make changes— Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PSMN012-60YS_1 Product data sheet Limiting values— Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale— Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license— Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 13 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET Export control— This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products— Unless the data sheet of an Nexperia product expressly states that the product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit:http://www.nexperia.com For sales office addresses, please send an email to:salesaddresses@nexperia.com PSMN012-60YS_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 5 January 2010 14 of 15 © Nexperia B.V. 2017. All rights reserved PSMN012-60YS Nexperia N-channel LFPAK 60 V, 11.1 mΩ standard level MOSFET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 05 January 2010
PSMN012-60YS,115
物料型号:PSMN012-60YS
器件简介: - 这是一款标准水平的N沟道MOSFET,采用LFPAK封装,适用于175°C的环境。 - 设计用于工业、通信和家用电器的广泛应用。
引脚分配: - 引脚1、2、3:源极(S) - 引脚4:栅极(G) - 附加安装基座(mb):连接到漏极(D)
参数特性: - 漏源电压(Vps):最大60V - 漏极电流(Id):最大59A - 总功耗(Ptot):最大89W - 结温(Tj):范围-55°C至175°C - 雪崩耐量(EDs(AL)S):非重复漏源雪崩能量最大71mJ - 栅极-漏极电荷(QGD):在特定条件下典型值为6.4nC - 总栅极电荷(QG(tot)):在特定条件下典型值为28.4nC
功能详解: - 该MOSFET具有先进的TrenchMOS技术,提供低RDSon和低栅极电荷,有助于在开关电源转换器中提高效率。 - LFPAK封装提供最大的功率密度。
应用信息: - 适用于DC-DC转换器、电机控制、锂离子电池保护、服务器电源、负载开关等。
封装信息: - LFPAK是塑料单端表面贴装封装,具有4个引脚,符合SOT669标准。
PSMN012-60YS,115 价格&库存
很抱歉,暂时无法提供与“PSMN012-60YS,115”相匹配的价格&库存,您可以联系我们找货
PSMN012-60YS,115
  • 1+15.788511+2.04517
  • 10+9.9947710+1.29468
  • 100+6.68441100+0.86587
  • 500+5.26618500+0.68216
库存:1519
