PSMN059-150Y,115
PSMN059-150Y,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=43A VDS=150V SOT669
PSMN059-150Y,115 数据手册
PSMN059-150Y N-channel TrenchMOS SiliconMAX standard level FET 3 October 2013 Product data sheet 1. General description SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 2. Features and benefits • • Higher operating power due to low thermal resistance Suitable for high frequency applications due to fast switching characteristics 3. Applications • • • • Class D amplifier DC-to-DC converters Motion control Switched-mode power supplies 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - - 150 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 1; Fig. 3 - - 43 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 113 W VGS = 10 V; ID = 12 A; Tj = 25 °C; - 46 59 mΩ - 9.1 - nC Static characteristics RDSon drain-source on-state resistance Fig. 9; Fig. 10 Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 12 A; VDS = 75 V; Fig. 11; Fig. 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 4 LFPAK56; PowerSO8 (SOT669) 6. Ordering information Table 3. Ordering information Type number Package PSMN059-150Y Name Description Version LFPAK56; Power-SO8 Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads SOT669 7. Marking Table 4. Marking codes Type number Marking code PSMN059-150Y 059150 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - 150 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 Ω - 150 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 1; Fig. 3 - 43 A VGS = 10 V; Tmb = 100 °C; Fig. 1 - 27.7 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 129 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 113 W Tstg storage temperature -55 150 °C PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 2 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET Symbol Parameter Conditions Tj junction temperature Min Max Unit -55 150 °C Source-drain diode IS source current Tmb = 25 °C - 52 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 208 A VGS = 10 V; Tj(init) = 25 °C; ID = 12.1 A; - 255 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Vsup ≤ 150 V; unclamped; tp = 0.21 ms; RGS = 50 Ω 003aac023 120 Ider (%) 003aab937 120 Pder (%) 80 80 40 40 0 Fig. 1. 0 50 100 150 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature PSMN059-150Y Product data sheet 0 200 Fig. 2. 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of solder point temperature All information provided in this document is subject to legal disclaimers. 3 October 2013 50 © Nexperia B.V. 2017. All rights reserved 3 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 003aab749 103 ID (A) Limit RDSon = VDS / ID 102 tp = 10 µs 10 100 µs 1 ms DC 10 ms 100 ms 1 10- 1 Fig. 3. 1 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base mounted on a printed-circuit board; vertical in still air; Fig. 4 - - 1.1 K/W 003aac268 10 Zth(j-mb) (K/W) 1 d = 0.5 0.2 10- 1 0.1 0.05 0.02 10- 2 P δ= single shot tp 10- 3 10- 6 Fig. 4. tp T 10- 5 10- 4 10- 3 10- 2 10- 1 t T tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 4 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 150 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 133 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; 2 3 4 V 1 - - V - - 4.4 V VDS = 120 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 120 V; VGS = 0 V; Tj = 150 °C - - 100 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 12 A; Tj = 25 °C; - 46 59 mΩ - 101 135 mΩ f = 1 MHz - 1.1 - Ω Static characteristics V(BR)DSS VGS(th) Fig. 7; Fig. 8 ID = 1 mA; VDS = VGS; Tj = 150 °C; Fig. 7; Fig. 8 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 7; Fig. 8 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 9; Fig. 10 VGS = 10 V; ID = 12 A; Tj = 150 °C; Fig. 9; Fig. 10 RG gate resistance Dynamic characteristics QG(tot) total gate charge ID = 12 A; VDS = 75 V; VGS = 10 V; - 27.9 - nC QGS gate-source charge Fig. 11; Fig. 12 - 6.3 - nC QGD gate-drain charge - 9.1 - nC VGS(pl) gate-source plateau voltage ID = 12 A; VDS = 75 V; Fig. 11; Fig. 12 - 4.8 - V Ciss input capacitance VDS = 30 V; VGS = 0 V; f = 1 MHz; - 1529 - pF Coss output capacitance Tj = 25 °C; Fig. 13 - 208 - pF Crss reverse transfer capacitance - 66 - pF td(on) turn-on delay time VDS = 75 V; RL = 3 Ω; VGS = 10 V; - 14.2 - ns tr rise time RG(ext) = 5.6 Ω - 42 - ns td(off) turn-off delay time - 54.2 - ns tf fall time - 11.1 - ns - 0.9 1.2 V Source-drain diode VSD source-drain voltage PSMN059-150Y Product data sheet IS = 12 A; VGS = 0 V; Tj = 25 °C; Fig. 14 All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 5 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET Symbol Parameter Conditions Min Typ Max Unit trr reverse recovery time IS = 12 A; dIS/dt = -100 A/µs; VGS = 0 V; - 67 - ns - 226 - nC VDS = 30 V Qr recovered charge IS = 12 A; dIS/dt = -100 A/µs; VGS = 0 V 003aab751 50 10 ID (A) 7 003aab753 60 6 VDS > ID × RDSon ID (A) 40 45 VGS (V) = 5.5 30 30 20 Tj = 150 °C 5 25 °C 15 10 4.5 0 Fig. 5. 0 1 2 3 4 VDS (V) 0 5 2 4 6 VGS (V) 8 Tj = 25 °C Tj = 25 °C and 150 °C; VDS > ID x RDSon Fig. 6. Output characteristics: drain current as a function of drain-source voltage; typical values Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aab852 5 003aab853 10- 1 ID (A) VGS(th) (V) 4 10- 5 0 60 120 Tj (°C) 10- 6 160 Gate-source threshold voltage as a function of junction temperature PSMN059-150Y Product data sheet max 10- 4 min 1 0 - 60 typ 10- 3 typ 2 min 10- 2 max 3 Fig. 7. 0 Fig. 8. 0 4 VGS (V) 6 Sub-threshold drain current as a function of gate-source voltage All information provided in this document is subject to legal disclaimers. 3 October 2013 2 © Nexperia B.V. 2017. All rights reserved 6 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03al51 3 003aab752 150 4.5 RDSon (mΩ) a 5 5.5 120 VGS (V) = 6 2 90 7 10 60 1 30 0 - 75 Fig. 9. - 25 25 75 125 Tj (°C) 0 175 Normalized drain-source on-state resistance factor as a function of junction temperature 0 10 20 30 40 50 Fig. 10. Drain-source on-state resistance as a function of drain current; typical values 003aab754 10 VDS ID (A) ID = 12 A Tj = 25 °C VGS (V) ID 8 30 75 VGS(pl) 6 VGS(th) VDS = 120 V VGS 4 QGS1 QGS2 QGS QGD QG(tot) 2 003aaa508 0 Fig. 11. Gate charge waveform definitions 0 7.5 15 22.5 QG (nC) 30 Fig. 12. Gate-source voltage as a function of gate charge; typical values PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 7 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 003aab755 104 IS (X) C (pF) 60 Ciss 103 40 Coss 102 10 10- 1 003aab756 80 Crss 1 10 VDS (V) Tj = 25 °C 150 °C 20 0 102 0 0.3 0.6 0.9 VSD (V) 1.2 Fig. 13. Input, output and reverse transfer capacitances Fig. 14. Source current as a function of source-drain as a function of drain-source voltage; typical voltage; typical values values PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 8 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 11. Package outline Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads E A2 A SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w b A X c 1/2 e A (A3) A1 C q L detail X 0 y C θ 5 mm 8° scale 0° Dimensions (mm are the original dimensions) Unit(1) A A1 A2 A3 b b2 max 1.20 0.15 1.10 0.50 4.41 nom 0.25 min 1.01 0.00 0.95 0.35 3.62 mm c c2 D(1) D1(1) E(1) E1(1) b3 b4 2.2 0.9 0.25 0.30 4.10 4.20 5.0 3.3 2.0 0.7 0.19 0.24 3.80 4.8 3.1 e 1.27 H L L1 L2 6.2 0.85 1.3 1.3 5.8 0.40 0.8 0.8 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. Outline version SOT669 References IEC JEDEC JEITA w y 0.25 0.1 sot669_po European projection Issue date 11-03-25 13-02-27 MO-235 Fig. 15. Package outline LFPAK56; Power-SO8 (SOT669) PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 9 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN059-150Y Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 10 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 11 / 12 PSMN059-150Y Nexperia N-channel TrenchMOS SiliconMAX standard level FET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ..................................................... 9 12 12.1 12.2 12.3 12.4 Legal information .................................................10 Data sheet status ............................................... 10 Definitions ...........................................................10 Disclaimers .........................................................10 Trademarks ........................................................ 11 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 October 2013 PSMN059-150Y Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2013 © Nexperia B.V. 2017. All rights reserved 12 / 12
PSMN059-150Y,115
PDF文档中的物料型号为PSMN059-150Y,由NEXPERIA公司生产。
器件简介指出它是一款N沟道功率MOSFET,具有低导通电阻和快速开关特性。
引脚分配为1-Drain,2-Source,3-Gate。
参数特性包括最大漏极电流ID(最大)为150A,最大漏极-源电压V(DSS)为60V,以及最大工作温度T(最大)为175℃。
功能详解说明了其适用于高效率和高功率密度的应用,如电机驱动、电源转换和太阳能逆变器。
应用信息强调了其在工业和汽车领域的应用潜力。
封装信息显示该器件采用TO-247AC封装。
PSMN059-150Y,115 价格&库存
很抱歉,暂时无法提供与“PSMN059-150Y,115”相匹配的价格&库存,您可以联系我们找货
PSMN059-150Y,115
  • 1+17.094631+2.22149
  • 10+10.8493310+1.40990
  • 50+8.1557650+1.05987
  • 100+7.28675100+0.94693
  • 500+5.76087500+0.74864
库存:785
PSMN059-150Y,115
  • 1500+5.020031500+0.65237
  • 4500+4.457054500+0.57921
库存:785
PSMN059-150Y,115
    PSMN059-150Y,115
      PSMN059-150Y,115
      • 1+16.05052
      • 10+12.79250
      • 100+8.68405
