PSMN102-200Y,115
PSMN102-200Y,115
    NEXPERIA(安世)
    SOT669
    MOSFETs 200V 113W SMT SOT669 21.5A N-Channel
PSMN102-200Y,115 数据手册
LF PA K PSMN102-200Y N-channel TrenchMOS SiliconMAX standard level FET Rev. 03 — 16 March 2011 Product data sheet 1. Product profile 1.1 General description SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits  Higher operating power due to low thermal resistance  Suitable for high frequency applications due to fast switching characteristics 1.3 Applications  Class D amplifier  Motion control  DC-to-DC converters  Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - - 200 ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 3 - - 21.5 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 113 W VGS = 10 V; ID = 12 A; Tj = 25 °C; see Figure 9; see Figure 10 - 86 102 mΩ - 10.1 - V Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 12 A; VDS = 100 V; see Figure 11; see Figure 12 nC PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G S mbb076 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number Package Name Description PSMN102-200Y LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 Version 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - 200 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 kΩ - 200 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3 - 21.5 A VGS = 10 V; Tmb = 100 °C; see Figure 1 - 13.6 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 3 - 65 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 113 W Tstg storage temperature -55 150 °C Tj junction temperature -55 150 °C Source-drain diode IS source current Tmb = 25 °C - 52 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 208 A VGS = 10 V; Tj(init) = 25 °C; ID = 10.8 A; Vsup ≤ 200 V; unclamped; tp = 0.14 ms; RGS = 50 Ω - 202 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 2 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 003aac023 120 003aab937 120 Ider (%) Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 Tmb (°C) Fig 1. 150 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of solder point temperature 003aab740 103 ID (A) 102 Limit RDSon = VDS / ID tp = 10 μs 10 100 μs 1 ms DC 1 10 ms 100 ms 10−1 1 102 10 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 3 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Mounted on a printed-circuit board; vertical in still air; see Figure 4 - - 1.1 K/W 003aac268 10 Zth(j-mb) (K/W) 1 d = 0.5 0.2 10−1 0.1 0.05 0.02 δ= P tp T 10−2 single shot t tp 10−3 10−6 T 10−5 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 4 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit V Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 200 - - ID = 250 µA; VGS = 0 V; Tj = -55 °C 178 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 7; see Figure 8 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 150 °C; see Figure 7; see Figure 8 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 7; see Figure 8 - - 4.4 V µA IDSS drain leakage current VDS = 160 V; VGS = 0 V; Tj = 25 °C - - 1 VDS = 160 V; VGS = 0 V; Tj = 150 °C - - 100 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 20 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 20 °C - - 100 nA VGS = 10 V; ID = 12 A; Tj = 25 °C; see Figure 9; see Figure 10 - 86 102 mΩ VGS = 10 V; ID = 12 A; Tj = 150 °C; see Figure 9; see Figure 10 - 206 245 mΩ f = 1 MHz - 1.1 - Ω ID = 12 A; VDS = 100 V; VGS = 10 V; see Figure 11; see Figure 12 - 30.7 - nC - 6.3 - nC - 10.1 - nC RDSon RG drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge VGS(pl) gate-source plateau voltage ID = 12 A; VDS = 100 V; see Figure 11; see Figure 12 - 4.6 - V Ciss input capacitance - 1568 - pF Coss output capacitance VDS = 30 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 13 - 170 - pF Crss reverse transfer capacitance - 55 - pF td(on) turn-on delay time - 14.2 - ns tr rise time - 29.5 - ns td(off) turn-off delay time - 33 - ns tf fall time - 28 - ns VDS = 100 V; RL = 5.8 Ω; VGS = 10 V; RG(ext) = 5.6 Ω Source-drain diode VSD source-drain voltage IS = 12 A; VGS = 0 V; Tj = 25 °C; see Figure 14 - 0.9 1.2 V trr reverse recovery time IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V - 143 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V - 268 - nC PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 5 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 003aab742 40 VDS > ID × RDSon ID (A) VGS (V) = 10 ID (A) 003aab744 50 6 40 30 30 20 Tj = 150 °C 5 25 °C 20 4.8 10 10 4.6 4.4 4.2 0 0 1.25 2.5 3.75 0 5 0 2 4 6 8 VDS (V) VGS (V) Tj = 25 °C Fig 5. Tj = 25 °C and 150 °C; VDS > ID x RDSon Output characteristics: drain current as a function of drain-source voltage; typical values Fig 6. 003aac062 10−1 ID (A) Transfer characteristics: drain current as a function of gate-source voltage; typical values VGS(th) (V) 10−2 4 min 10−3 typ max 2 10−5 1 10−6 0 2 4 Sub-threshold drain current as a function of gate-source voltage Product data sheet typ min 0 −60 6 VGS (V) PSMN102-200Y max 3 10−4 Fig 7. 003aab852 5 Fig 8. 0 60 120 160 Tj (°C) Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 6 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 03al52 3 003aab743 200 4.5 5 RDSon (mΩ) a 160 2 VGS (V) = 6 10 120 1 0 −60 Fig 9. 80 0 60 120 0 180 10 20 30 40 ID (A) Tj (°C) Normalized drain-source on-state resistance factor as a function of junction temperature Fig 10. Drain-source on-state resistance as a function of drain current; typical values 003aab746 10 VDS ID = 12 A Tj = 25 °C VGS (V) ID 8 40 100 VGS(pl) 6 VGS(th) VDS = 160 V VGS 4 QGS1 QGS2 QGS QGD QG(tot) 2 003aaa508 0 0 10 20 30 40 QG (nC) Fig 11. Gate charge waveform definitions PSMN102-200Y Product data sheet Fig 12. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 7 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 003aab747 104 003aab745 50 IS (A) C (pF) 40 Ciss 103 30 Tj = 150 °C Coss 25 °C 20 102 Crss 10 10 10−1 1 102 10 0 0 VDS (V) Product data sheet 0.6 0.9 1.2 VSD (V) Fig 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PSMN102-200Y 0.3 Fig 14. Source current as a function of source-drain voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 8 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 15. Package outline SOT669 (LFPAK) PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 9 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN102-200Y v.3 20110316 Product data sheet - PSMN102-200Y v.2 - PSMN102-200Y v.1 Modifications: PSMN102-200Y v.2 PSMN102-200Y Product data sheet • Various changes to content. 20101220 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 10 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 9. Legal information 9.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 11 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PSMN102-200Y Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 16 March 2011 © NXP B.V. 2011. All rights reserved. 12 of 13 PSMN102-200Y NXP Semiconductors N-channel TrenchMOS SiliconMAX standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2011. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 16 March 2011 Document identifier: PSMN102-200Y
PSMN102-200Y,115 价格&库存
很抱歉,暂时无法提供与“PSMN102-200Y,115”相匹配的价格&库存,您可以联系我们找货
PSMN102-200Y,115
  • 1+7.40376
  • 10+6.71559
  • 100+6.20540
  • 500+5.54096
  • 1000+5.46977
  • 5000+4.85279
库存:15127
PSMN102-200Y,115
  • 1500+5.024971500+0.65091
  • 3000+4.651603000+0.60255
  • 4500+4.461454500+0.57792
  • 7500+4.247827500+0.55024
  • 10500+4.1213510500+0.53386
  • 15000+4.0327315000+0.52238
库存:14664
PSMN102-200Y,115
  • 1+17.111331+2.21652
  • 10+10.8599410+1.40675
  • 100+7.29397100+0.94483
  • 500+5.76654500+0.74697
库存:14664
PSMN102-200Y,115
  • 1+7.40376
  • 10+6.71559
  • 100+6.20540
  • 500+5.54096
  • 1000+5.46977
  • 5000+4.85279
库存:15127
