BUK7Y12-55B
N-channel TrenchMOS standard level FET
Rev. 03 — 7 April 2010
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using Nexperia High-Performance Automotive (HPA) TrenchMOS technology.
This product has been designed and qualified to the appropriate AEC standard for use
in automotive critical applications.
1.2 Features and benefits
Q101 compliant
Suitable for standard level gate drive
sources
Suitable for thermally demanding
environments due to 175 °C rating
1.3 Applications
12 V and 24 V loads
General purpose power switching
Advanced braking systems (ABS)
Motors, lamps and solenoids
Automotive systems
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source
voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
55
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 1; see Figure 4
61.8 A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
105
W
VGS = 10 V; ID = 20 A;
Tj = 25 °C; see Figure 13;
see Figure 12
8.2
12
mΩ
non-repetitive
ID = 61.8 A; Vsup ≤ 55 V;
drain-source
RGS = 50 Ω; VGS = 10 V;
avalanche energy Tj(init) = 25 °C; unclamped
129
mJ
14.8 -
V
Static characteristics
RDSon
drain-source
on-state
resistance
Avalanche ruggedness
EDS(AL)S
Dynamic characteristics
QGD
gate-drain charge ID = 20 A; VDS = 44 V;
VGS = 10 V; see Figure 14
nC
BUK7Y12-55B
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
S
1 2 3 4
SOT669 (LFPAK)
3. Ordering information
Table 3.
Type number
BUK7Y12-55B
BUK7Y12-55B
Product data sheet
Package
Name
Description
LFPAK
plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669
All information provided in this document is subject to legal disclaimers.
Version
Nexperia B.V. 2017. All rights reserved
2 of 14
BUK7Y12-55B
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
55
V
VDGR
drain-gate voltage
RGS = 20 kΩ
55
V
VGS
gate-source voltage
ID
drain current
-20
V
Tmb = 25 °C; VGS = 10 V; see Figure 1;
see Figure 4
61.8
A
Tmb = 100 °C; VGS = 10 V; see Figure 1
43.7
A
IDM
peak drain current
Tmb = 25 °C; tp ≤ 10 µs; pulsed;
see Figure 4
247
A
Ptot
total power dissipation
105
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
61.8
A
ISM
peak source current
tp ≤ 10 µs; pulsed; Tmb = 25 °C
247
A
129
mJ
J
EDS(AL)S
non-repetitive
drain-source
avalanche energy
ID = 61.8 A; Vsup ≤ 55 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
EDS(AL)R
repetitive drain-source
avalanche energy
see Figure 3
[1]
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
[2]
Repetitive avalanche rating limited by an average junction temperature of 170 °C.
[3]
Refer to application note AN10273 for further information.
BUK7Y12-55B
Product data sheet
[1][2][3]
3 of 14
BUK7Y12-55B
Nexperia
003aac507
100
03na19
120
ID
(A)
Pder
75
80
50
40
25
Fig 1.
50
100
200
Tmb (°C)
50
100
150
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
003aac486
102
IAL
(A)
(1)
10
(2)
1
(3)
10-1
10-3
Fig 3.
10-2
10-1
1
tAL (ms)
10
Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time
BUK7Y12-55B
Product data sheet
4 of 14
BUK7Y12-55B
Nexperia
003aad475
103
I D (A)
Limit RDSon = V DS / ID
102
tp = 10 μs
100 μs
10
1 ms
DC
10 ms
1
100 ms
10-1
1
Fig 4.
102
10
103
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage.
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
see Figure 5
1.42
K/W
003aac479
10
Zth (j-mb)
(K/W)
δ = 0.5
1
0.2
0.1
10-1
0.05
δ=
P
0.02
tp
T
10-2
single shot
t
tp
T
10-3
10-6
Fig 5.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration.
BUK7Y12-55B
Product data sheet
5 of 14
BUK7Y12-55B
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
55
ID = 250 µA; VGS = 0 V; Tj = -55 °C
50
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10; see Figure 11
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
4.4
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 10
1
V
IDSS
drain leakage current
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.02
1
µA
VDS = 55 V; VGS = 0 V; Tj = 175 °C
500
µA
IGSS
gate leakage current
VDS = 0 V; VGS = 20 V; Tj = 25 °C
2
100
nA
VDS = 0 V; VGS = -20 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 20 A; Tj = 175 °C;
see Figure 12; see Figure 13
27.6
mΩ
VGS = 10 V; ID = 20 A; Tj = 25 °C;
see Figure 13; see Figure 12
8.2
12
mΩ
ID = 20 A; VDS = 44 V; VGS = 10 V;
see Figure 14
35.2
nC
9.24
nC
14.8
nC
1550
2067
pF
328
394
pF
153
210
pF
19.3
ns
RDSon
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 15
VDS = 30 V; RL = 1.5 Ω; VGS = 10 V;
RG(ext) = 10 Ω
tr
rise time
29.4
ns
td(off)
turn-off delay time
43.2
ns
tf
fall time
22
ns
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 25 V; Tj = 25 °C;
see Figure 16
0.85
1.2
V
trr
reverse recovery time
45
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 30 V
84
nC
BUK7Y12-55B
Product data sheet
6 of 14
BUK7Y12-55B
Nexperia
003aad467
60
20 10
003aad468
40
6.2
5
RDS on
(mΩ)
VGS (V) = 6
ID
(A)
5.4
6
VGS (V) = 5.7
6.2
30
40
5.7
10
5
Fig 6.
1
2
3
4
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values.
Fig 7.
003aad469
56
60
Drain-source on-state resistance as a function
of drain current; typical values.
003aad470
60
gfs
(S)
ID
(A)
44
40
32
Tj = 175 °C
25 °C
Fig 8.
I D (A)
I D (A)
60
Forward transconductance as a function of
BUK7Y12-55B
Product data sheet
Fig 9.
2
4
6
VGS (V)
8
Transfer characteristics: drain current as a
function of gate-source voltage; typical values.
7 of 14
BUK7Y12-55B
Nexperia
03aa32
5
03aa35
10−1
ID
(A)
VGS(th)
(V)
4
3
typ
max
10−3
typ
2
min
10−2
max
10−4
min
10−5
1
−60
10−6
120
2
4
6
Tj (°C)
VGS (V)
Fig 10. Gate-source threshold voltage as a function of
003aad618
35
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
003aad696
2.4
a
RDSON
(mΩ)
28
2
1.6
21
1.2
14
0.8
7
0.4
8
12
16
VGS (V)
Fig 12. Drain-source on-state resistance as a function
BUK7Y12-55B
Product data sheet
120
Tj (°C)
180
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature.
8 of 14
BUK7Y12-55B
Nexperia
003aad472
10
VGS
(V)
003aad473
104
VDS = 14 V
C
(pF)
8
VDS = 44 V
6
Ciss
10
3
4
Coss
2
Crss
102
10-1
QG (nC)
40
Fig 14. Gate-source voltage as a function of gate
charge; typical values.
1
10
VDS (V)
102
Fig 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values.
003aad471
60
IS
(A)
40
Tj = 175 °C
0.4
25°C
0.6
0.8
VSD (V)
1
Fig 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values.
BUK7Y12-55B
Product data sheet
9 of 14
BUK7Y12-55B
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (LFPAK); 4 leads
A2
A
E
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w M A
b
1/2
X
c
e
A
(A 3)
A1
C
θ
L
detail X
y C
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
mm
A
A1
A2
A3
b
b2
1.20 0.15 1.10
0.50 4.41
0.25
1.01 0.00 0.95
0.35 3.62
b3
b4
2.2
2.0
0.9
0.7
c
D (1)
c2
D1(1)
E(1) E1(1)
max
0.25 0.30 4.10
4.20
0.19 0.24 3.80
5.0
4.8
3.3
3.1
e
H
L
L1
L2
w
y
θ
1.27
6.2
5.8
0.85
0.40
1.3
0.8
1.3
0.8
0.25
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT669
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-10-13
06-03-16
MO-235
Fig 17. Package outline SOT669 (LFPAK)
BUK7Y12-55B
Product data sheet
10 of 14
BUK7Y12-55B
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7Y12-55B_3
20100407
Product data sheet
BUK7Y12-55B_2
Modifications:
BUK7Y12-55B_2
BUK7Y12-55B
Product data sheet
Status changed from objective to product.
20100218
Objective data sheet
BUK7Y12-55B_1
11 of 14
BUK7Y12-55B
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
BUK7Y12-55B
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of a Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in the
Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
12 of 14
BUK7Y12-55B
Nexperia
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7Y12-55B
Product data sheet
13 of 14
Nexperia
BUK7Y12-55B
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
Date of release: 07 April 2010
很抱歉,暂时无法提供与“BUK7Y12-55B,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.869321+1.67240
- 10+8.0868010+1.05090
- 25+7.3911625+0.96050
- 国内价格
- 1000+9.05163
- 10000+8.09040
- 100000+6.72865
