Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
Product specification
N-channel TrenchMOS transistor
Logic level FET
FEATURES
BSS123
SYMBOL
• ’Trench’ technology
• Extremely fast switching
• Logic level compatible
• Subminiature surface mounting
package
QUICK REFERENCE DATA
d
VDSS = 100 V
ID = 150 mA
g
RDS(ON) ≤ 6 Ω (VGS = 10 V)
s
GENERAL DESCRIPTION
PINNING
N-channel enhancement mode
field-effect transistor in a plastic
envelope
using
’trench’
technology.
Applications:• Relay driver
• High-speed line driver
• Telephone ringer
PIN
SOT23
DESCRIPTION
1
gate
2
source
3
drain
3
Top view
1
2
The BSS123 is supplied in the
SOT23
subminiature
surface
mounting package.
LIMITING VALUES
Limiting values in accordance with the Absolute Maximum System (IEC 134)
SYMBOL PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VDSS
VDGR
VGS
ID
IDM
PD
Tj, Tstg
Tj = 25 ˚C to 150˚C
Tj = 25 ˚C to 150˚C; RGS = 20 kΩ
- 55
100
100
± 20
150
600
0.25
150
V
V
V
mA
mA
W
˚C
CONDITIONS
TYP.
MAX.
UNIT
surface mounted on FR4 board
500
K/W
Drain-source voltage
Drain-gate voltage
Gate-source voltage
Continuous drain current
Pulsed drain current
Total power dissipation
Operating junction and
storage temperature
Ta = 25 ˚C
Ta = 25 ˚C
Ta = 25 ˚C
THERMAL RESISTANCES
SYMBOL PARAMETER
Rth j-a
Thermal resistance junction
to ambient
August 2000
1
Rev 1.000
Logic level FET
BSS123
ELECTRICAL CHARACTERISTICS
Tj= 25˚C unless otherwise specified
SYMBOL PARAMETER
V(BR)DSS
VGS(TO)
RDS(ON)
Drain-source breakdown
voltage
Gate threshold voltage
Drain-source on-state
resistance
CONDITIONS
MIN.
TYP. MAX. UNIT
VGS = 0 V; ID = 10 µA
100
130
V
VDS = VGS; ID = 1 mA
VGS = 10 V; ID = 120 mA
1
2
3.5
2.8
6
V
Ω
VDS = 25 V; ID = 120 mA
350
mS
10
100
nA
10
100
nA
3
10
ns
12
ns
23
6
4
40
25
10
pF
pF
pF
gfs
Forward transconductance
IDSS
IGSS
Zero gate voltage drain
VDS = 60 V; VGS = 0 V
current
Gate source leakage current VGS = ±20 V; VDS = 0 V
ton
Turn-on time
toff
Turn-off time
Ciss
Coss
Crss
Input capacitance
Output capacitance
Feedback capacitance
August 2000
VDD = 50 V; RD = 250 Ω; VGS = 10 V;
RG = 50 Ω; Resistive load
VGS = 0 V; VDS = 25 V; f = 1 MHz
2
Rev 1.000
Logic level FET
BSS123
MECHANICAL DATA
Plastic surface mounted package; 3 leads
SOT23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
bp
c
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
mm
1.1
0.9
OUTLINE
VERSION
A1
max.
bp
c
D
E
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
e
1.9
e1
HE
Lp
Q
v
w
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
REFERENCES
IEC
JEDEC
EIAJ
EUROPEAN
PROJECTION
ISSUE DATE
97-02-28
SOT23
Fig.1. SOT23 surface mounting package.
Notes
1. This product is supplied in anti-static packaging. The gate-source input must be protected against static
discharge during transport or handling.
2. Refer to SMD Footprint Design and Soldering Guidelines, Data Handbook SC18.
3. Epoxy meets UL94 V0 at 1/8".
August 2000
3
Rev 1.000
Logic level FET
BSS123
DEFINITIONS
Data sheet status
Objective specification
This data sheet contains target or goal specifications for product development.
Preliminary specification This data sheet contains preliminary data; supplementary data may be published later.
This data sheet contains final product specifications.
Limiting values
Limiting values are given in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one
or more of the limiting values may cause permanent damage to the device. These are stress ratings only and
operation of the device at these or at any other conditions above those given in the Characteristics sections of
this specification is not implied. Exposure to limiting values for extended periods may affect device reliability.
Application information
Where application information is given, it is advisory and does not form part of the specification.
Philips Electronics N.V. 2000
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the
copyright owner.
The information presented in this document does not form part of any quotation or contract, it is believed to be
accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any
consequence of its use. Publication thereof does not convey nor imply any license under patent or other
industrial or intellectual property rights.
LIFE SUPPORT APPLICATIONS
These products are not designed for use in life support appliances, devices or systems where malfunction of these
products can be reasonably expected to result in personal injury. Philips customers using or selling these products
for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting
from such improper use or sale.
August 2000
4
Rev 1.000
很抱歉,暂时无法提供与“BSS123,215”相匹配的价格&库存,您可以联系我们找货
