YNR4030-6R8M
YNR4030-6R8M
    YJYCOIN(益嘉源)
    SMD,4x4mm
    功率电感 6.8µH ±20% 90mΩ IND_4X4MM_SM
YNR4030-6R8M 数据手册
SMD Power Inductors -YNR4030 Series ■ Features ● Low profile construction and miniature size. ● Magnetic shielded construction. ● High current saturation. ● Operating temperature:-40℃ ~ +125℃. ● RoHS compliant ■ Applications ● For small DC/DC converter(HDD,DVC,DSC,PDA,LCD display etc.). ● Car navigation systems,telecom base stations. ● VR,AR,LED lighting. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷ :Inductance Tolerance;N=±30%,M=±20%,K=±10% ■ Shapes and Dimensions (Unit:mm) TYPE A B C Max. D E Ref. F Ref. G Ref. YNR4030 4.0±0.2 4.0±0.2 3.00 0.95±0.2 3.70 1.10 1.90 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -1- SMD Power Inductors -YNR4030 Series ■ YNR4030 Series Part Number Inductance DC Resistance (Ω) Heat Rating Saturation (uH) @100KHz Typ. Max. Current (A) Current (A) YNR4030-R47□ 0.47 0.008 0.010 5.20 7.80 YNR4030-R68□ 0.68 0.010 0.013 4.56 6.80 YNR4030-R91□ 0.91 0.013 0.017 4.15 6.25 YNR4030-1R0□ 1.00 0.014 0.018 4.15 5.26 YNR4030-1R5□ 1.50 0.020 0.026 3.34 4.84 YNR4030-1R8□ 1.80 0.025 0.033 3.20 5.40 YNR4030-2R2□ 2.20 0.030 0.039 2.95 4.90 YNR4030-3R3□ 3.30 0.040 0.052 2.40 3.30 YNR4030-3R9□ 3.90 0.057 0.074 2.10 3.00 YNR4030-4R7□ 4.70 0.060 0.078 2.00 2.90 YNR4030-5R6□ 5.60 0.065 0.085 1.95 2.60 YNR4030-6R8□ 6.80 0.090 0.117 1.60 2.75 YNR4030-7R5□ 7.50 0.085 0.110 1.65 2.20 YNR4030-8R2□ 8.20 0.090 0.117 1.60 2.10 YNR4030-100□ 10.0 0.100 0.130 1.50 1.95 YNR4030-120□ 12.0 0.135 0.175 1.30 1.70 YNR4030-150□ 15.0 0.190 0.247 1.11 1.65 YNR4030-180□ 18.0 0.200 0.260 1.10 1.40 YNR4030-220□ 22.0 0.225 0.292 1.00 1.30 YNR4030-270□ 27.0 0.260 0.338 0.90 1.15 YNR4030-330□ 33.0 0.330 0.429 0.84 1.10 YNR4030-360□ 36.0 0.335 0.436 0.83 1.05 YNR4030-390□ 39.0 0.435 0.566 0.73 1.03 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -2- SMD Power Inductors -YNR4030 Series ■ YNR4030 Series Part Number Inductance DC Resistance (Ω) Heat Rating Saturation (uH) @100KHz Typ. Max. Current (A) Current (A) YNR4030-470□ 47.0 0.445 0.579 0.72 0.95 YNR4030-510□ 51.0 0.470 0.611 0.70 0.90 YNR4030-560□ 56.0 0.555 0.722 0.65 0.85 YNR4030-620□ 62.0 0.585 0.761 0.63 0.80 YNR4030-680□ 68.0 0.868 1.128 0.52 0.72 YNR4030-820□ 82.0 1.060 1.378 0.47 0.66 YNR4030-910□ 91.0 1.100 1.430 0.46 0.65 YNR4030-101□ 100 1.150 1.495 0.45 0.60 YNR4030-121□ 120 1.350 1.755 0.42 0.55 YNR4030-151□ 150 1.800 2.340 0.30 0.50 YNR4030-221□ 220 2.500 3.250 0.35 0.40 YNR4030-331□ 330 4.000 5.200 0.25 0.30 YNR4030-471□ 470 7.200 9.360 0.20 0.30 YNR4030-501□ 500 6.944 9.027 0.15 0.28 YNR4030-681□ 680 7.580 9.854 0.14 0.19 ※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 20℃) ※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at 20℃) ※ The rated current is the DC current value that satisfies both of current value saturation current value and temperature rise current value. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -3- SMD Power Inductors -YNR4030 Series ■ Taping Dimensions(Unit:mm) TYPE Chip Thickness W A B D P K Max T Max MPQ YNR4030 3.00 12.0 4.30 4.30 5.50 8.00 3.20 0.40 2000 ■ Reel Dimensions(Unit:mm) TYPE W W1 A B C D YNR4030 330±2.0 12.8±1.50 13.0±0.50 21.0±0.80 2.0±0.50 100 Min 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -4- SMD Power Inductors -YNR4030 Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -5-
YNR4030-6R8M
物料型号:YNR4030系列
器件简介:YNR4030系列是益嘉源电子有限公司生产的SMD功率电感器,具有低剖面构造和微型尺寸,磁屏蔽构造,高电流饱和,工作温度范围为-40℃至+125℃,符合RoHS标准。
引脚分配:文档中未明确提供引脚分配信息,但通常SMD电感器会有两端用于连接电路。
参数特性: - 电感值范围从0.47μH至680μH - DC电阻从0.008mΩ至7.200mΩ - 热额定电流从0.72A至5.20A - 饱和电流从0.95A至7.80A
功能详解:YNR4030系列适用于小型DC/DC转换器(硬盘驱动器、数字摄像机、数码相机、个人数字助理、液晶显示器等)、汽车导航系统、电信基站、虚拟现实/增强现实设备和LED照明。
应用信息:适用于上述提到的各种小型电子设备和系统,特别是在需要高电流和小型化解决方案的场合。
封装信息:YNR4030系列的尺寸为4.0±0.2mm x 4.0±0.2mm,最大高度为3.00mm。卷带封装的尺寸和方向也有详细说明,适用于自动化装配。
YNR4030-6R8M 价格&库存
很抱歉,暂时无法提供与“YNR4030-6R8M”相匹配的价格&库存,您可以联系我们找货
YNR4030-6R8M
  • 10+0.39445
  • 100+0.31544
  • 400+0.27594
  • 800+0.27180
  • 2000+0.24961
库存:1970
YNR4030-6R8M
  • 1+0.42900
  • 50+0.25190
  • 2000+0.22770
库存:1715
