YP0403-102M
YP0403-102M
    YJYCOIN(益嘉源)
    SMD,4.5x4mm
    功率电感 1mH ±20% 15.6Ω IND_4.5X4MM_SM
YP0403-102M 数据手册
SMD Power Inductors -YP0403 Series ■ Features ● High current Type. ● Ferrite bobbin core and compact size. ● Low core loss for high frequency power application. ● Large terminal surface for good PCB bonding. ● Operating temperature:-40℃ ~ +125℃. ■ Applications ● Portable communication equipment. ● Notebook PC,digital carmera,LCD television set. ● Power supply for VTR,OA equipment. ● DC/DC converters. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷:Inductance Tolerance:N=±30%,M=±20%,L=±15%,K=±10% ■ Shapes and Dimensions (Unit:mm) TYPE A B C D1 Ref. D2 Ref. E Ref. F Ref. YP0403 4.5±0.3 4.0±0.3 3.2±0.3 1.4 1.5 5.0 4.5 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -1- SMD Power Inductors -YP0403 Series ■ YP0403 Series Part Number Inductance (uH) L Test Frequency Max.DC Resistance Max.Rated Current (KHz) (Ω) (A) YP0403-1R0□ 1.00 100 0.033 3.80 YP0403-1R5□ 1.50 100 0.038 3.30 YP0403-1R8□ 1.80 100 0.042 2.91 YP0403-2R2□ 2.20 100 0.047 2.60 YP0403-2R7□ 2.70 100 0.052 2.43 YP0403-3R3□ 3.30 100 0.058 2.15 YP0403-3R9□ 3.90 100 0.076 1.98 YP0403-4R7□ 4.70 100 0.094 1.70 YP0403-5R6□ 5.60 100 0.101 1.60 YP0403-6R8□ 6.80 100 0.117 1.41 YP0403-8R2□ 8.20 100 0.132 1.26 YP0403-100□ 10.0 100 0.182 1.15 YP0403-120□ 12.0 100 0.210 1.05 YP0403-150□ 15.0 100 0.235 0.92 YP0403-180□ 18.0 100 0.338 0.84 YP0403-220□ 22.0 100 0.378 0.76 YP0403-270□ 27.0 100 0.522 0.71 YP0403-330□ 33.0 100 0.540 0.64 YP0403-390□ 39.0 100 0.587 0.59 YP0403-470□ 47.0 100 0.844 0.54 YP0403-560□ 56.0 100 0.937 0.50 YP0403-680□ 68.0 100 1.117 0.46 YP0403-820□ 82.0 100 1.345 0.45 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -2- SMD Power Inductors -YP0403 Series ■ YP0403 Series Part Number Inductance (uH) L Test Frequency Max.DC Resistance Max.Rated Current (KHz) (Ω) (A) YP0403-101□ 100 100 1.520 0.44 YP0403-121□ 120 100 1.800 0.43 YP0403-151□ 150 100 2.000 0.42 YP0403-181□ 180 100 3.200 0.38 YP0403-221□ 220 100 3.400 0.36 YP0403-271□ 270 100 3.900 0.34 YP0403-331□ 330 100 5.300 0.28 YP0403-391□ 390 100 5.900 0.24 YP0403-471□ 470 100 6.800 0.21 YP0403-561□ 560 100 8.500 0.20 YP0403-681□ 680 100 10.000 0.18 YP0403-821□ 820 100 13.400 0.15 YP0403-102□ 1000 100 15.600 0.14 ※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 20℃) ※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at 20℃) ※ The rated current is the DC current value that satisfies both of current value saturation current value and temperature rise current value. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -3- SMD Power Inductors -YP0403 Series ■ Taping Dimensions(Unit:mm) TYPE W A B C D E P K Ref T MPQ YP0403 12±0.3 4.20±0.1 5.15±0.1 4.75 5.5±0.1 3.40±0.1 8.0±0.1 3.6 0.35±0.05 2000 ■ Reel Dimensions(Unit:mm) TYPE W W1 W2 W3 A B C D YP0403 330±2.0 12.8±1.50 18.4MAX 11.9 Min 13.0±0.50 21.0±0.80 2.0±0.50 100 Min 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -4- SMD Power Inductors -YP0403 Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com Tel:0755-27803896 Fax:0755-27803897 -5-
YP0403-102M
物料型号:YP0403系列
器件简介:YP0403系列是高电流型SMD功率电感器,具有以下特点: - 高电流型 - 采用铁氧体骨架和紧凑尺寸 - 高频电源应用的低核心损耗 - 大的端子表面,有利于PCB的良好粘接
引脚分配:文档中提供了详细的尺寸和引脚布局,例如YP0403型号的尺寸参数A、B、C、D1、D2、E、F等。
参数特性:包括电感值、测试频率、最大直流电阻和最大额定电流。例如,YP0403-1R0型号的电感值为1.00微亨,测试频率为100KHz,最大直流电阻为0.033欧姆,最大额定电流为3.80安培。
功能详解:文档中提到了YP0403系列的应用领域,包括便携式通信设备、笔记本电脑、数码相机、液晶电视、VTR电源、OA设备和DC/DC转换器。
应用信息:YP0403系列适用于多种便携式设备和电源转换器,工作温度范围为-40℃至+125℃。
封装信息:文档提供了封装的尺寸和胶带尺寸,包括卷轴尺寸和卷轴上的元件排列。
制造商信息:深圳市益嘉源电子有限公司,提供了公司网址、电话和传真信息。
YP0403-102M 价格&库存
很抱歉,暂时无法提供与“YP0403-102M”相匹配的价格&库存,您可以联系我们找货
YP0403-102M
  • 20+0.22475
  • 200+0.21025
  • 500+0.19575
  • 1000+0.18125
  • 3000+0.17400
  • 6000+0.16385
