TVS Surface Mount – 5000W > 5.0SMDJ Series
Description
The 5.0SMDJ series is designed specifically
to protect sensitive electronic equipment
from voltage transients induced by lightning
and other transient voltage events.
Features
◆ 5000W peak pulsepower capability at 10 x 1000μs waveform, repetition rate (duty cycle):
0.01%
◆ Glass Passivated chip junction
◆ For surface mounted applications to optimize board space
◆ Low profile package
◆ Built-in strain relief
◆ Low incremental surge resistance
◆ Excellent clamping capability
◆ Plastic package has UL flammability classification 94V-O
◆ Fast response time: typically less than 1.0ps from 0 Volts to BV min
◆ Typical IR less than 5uA above 22V
◆ High temperature soldering: 260°C/40 seconds at terminals
◆ IEC-61000-4-2 ESD 15KV(Air),8KV(Contact)
◆ ESD protection of data lines in accordance with IEC 61000-4-2(IEC801-2)
◆ EFT protection of data lines in accordance with IEC61000-4-4(IEC801-4)
◆ AEC - Q101 qualified.
Applications
TVS devices are ideal for the protection of I/O Interfaces, VCC bus and other
vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic
applications.
Rev : 01.06.2014
1 /8
www.leiditech.com
Maximum Ratings and Electrical Characteristics
(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
PPPM
5000
W
Power Dissipation on infinite heat sink at
TA=50℃
PD
6.5
W
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave Unidirectional
only(Note 3)
IFSM
300
A
Maximum
Instantaneous
Forward
Voltage at 100A for Unidirectional only
VF
3.5V/5.0
V
TJ, TSTG
-55 to +
150
Typical Thermal Resistance Junction to
Lead
RuJL
15
℃/W
Ambient
RuJA
75
℃/W
Peak Pulse Power Dissipation at
TA=25℃
by
10x1000μs
waveform
(Fig.2)(Note 1) (Note 2)
Operating
Junction
Temperature Range
and
Storage
Notes:
1. Non-repetitive current pulse, per Fig.3and derated above TA=25℃ per Fig. 2.
2. Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional
device only, duty cycle=4 per minute maximum.
Rev : 01.06.2014
2 /8
www.leiditech.com
BI- POLAR
UNI-POLAR
VRWM
VBR
VBR
IT
IR
Ipp
Vc
(V)
MIN(V)
MAX(V)
(mA)
(µA)
(A)
(v)
5.0SMDJ5.0CA
5.0SMDJ5.0A
5.0
6.4
7.25
50
5000
554.3
9.2
5.0SMDJ6.0CA
5.0SMDJ6.0A
6.0
6.67
7.67
50
5000
495.1
10.3
5.0SMDJ 6.5CA
5.0SMDJ 6.5A
6.5
7.22
8.30
50
2000
455.4
11.2
5.0SMDJ7.0 CA
5.0SMDJ7.0 A
7.0
7.78
8.95
50
1000
425.0
12.0
5.0SMDJ 7.5CA
5.0SMDJ 7.5A
7.5
8.33
9.58
5
250
395.3
12.9
5.0SMDJ 8.0CA
5.0SMDJ 8.0A
8.0
8.89
10.23
5
150
357.0
13.6
5.0SMDJ8.5 CA
5.0SMDJ8.5 A
8.5
9.44
10.82
5
50
354.2
14.4
5.0SMDJ9.0 CA
5.0SMDJ9.0 A
9.0
10.00
11.50
5
15.4
5.0SMDJ10CA
5.0SMDJ10A
10.0
11.1
12.30
5
15
300.0
17.0
5.0SMDJ11CA
5.0SMDJ11A
11.0
12.20
14.00
5
2
280.2
18.2
5.0SMDJ12CA
5.0SMDJ12A
12.0
13.30
14.70
5
2
256.3
19.9
5.0SMDJ13CA
5.0SMDJ13A
13.0
14.40
16.50
5
2
237.2
21.5
5.0SMDJ14CA
5.0SMDJ14A
14.0
15.60
17.20
5
2
219.8
23.2
5.0SMDJ15CA
5.0SMDJ15A
15.0
16.70
19.20
5
2
209.0
24.4
5.0SMDJ16CA
5.0SMDJ16A
16.0
17.80
19.70
5
2
196.2
26.0
5.0SMDJ17CA
5.0SMDJ17A
17.0
18.90
21.70
5
2
184.8
27.6
5.0SMDJ18CA
5.0SMDJ18A
18.0
20.00
23.30
5
2
174.7
29.2
5.0SMDJ20CA
5.0SMDJ20A
20.0
22.20
25.50
5
2
157.4
32.4
5.0SMDJ22CA
5.0SMDJ22A
22.0
24.40
28.00
5
2
143.7
35.5
5.0SMDJ24CA
5.0SMDJ24A
24.0
26.70
30.70
5
2
131.1
38.9
5.0SMDJ26CA
5.0SMDJ26A
26.0
28.90
33.20
5
2
121.1
42.1
5.0SMDJ28CA
5.0SMDJ28A
28.0
31.10
35.80
5
2
112.3
45.4
5.0SMDJ30CA
5.0SMDJ30A
30.0
33.30
38.30
5
2
105.4
48.4
5.0SMDJ33CA
5.0SMDJ33A
33.0
36.70
40.60
5
2
95.7
53.3
Rev : 01.06.2014
3 /8
@Ipp
VOLTAGE
CLAMPING
MAXIMUM
CURRENT
PEAK PULSE
@VRWM
LEAKAGE
REVERSE
CURRENT
TEST
T
VBR(V)MAX.@I
VOLTAGE
BREAKDOWN
VOLTAGE
STAND-OFF
PART NUMBER
REVERSE
www.leiditech.com
MIN(V)
MAX(V)
(mA)
(µA)
(A)
Vc
(v)
5.0SMDJ36CA
5.0SMDJ36A
36.0
40.00
46.00
5
2
87.8
58.1
5.0SMDJ40CA
5.0SMDJ40A
40.0
44.40
51.10
5
2
79.1
64.5
5.0SMDJ43CA
5.0SMDJ43A
43.0
47.8
52.8
5
2
73.5
69.4
5.0SMDJ45CA
5.0SMDJ45A
45.0
50.00
57.50
5
2
70.2
72.7
5.0SMDJ48CA
5.0SMDJ48A
48.0
53.30
58.90
5
2
65.9
77.4
5.0SMDJ51CA
5.0SMDJ51A
51.0
56.70
65.20
5
2
61.9
82.4
5.0SMDJ54CA
5.0SMDJ54A
54.0
60.00
69.00
5
2
58.6
87.1
5.0SMDJ58CA
5.0SMDJ58A
58.0
64.4
71.2
5
2
54.5
93.6
5.0SMDJ60CA
5.0SMDJ60A
60.0
66.7
73.7
5
2
52.7
96.8
5.0SMDJ64CA
5.0SMDJ64A
64.0
71.10
81.80
5
2
49.5
103.0
5.0SMDJ70CA
5.0SMDJ70A
70.0
77.8
95.1
5
2
45.1
113.0
5.0SMDJ75CA
5.0SMDJ75A
75.0
83.3
92.1
5
2
42.1
121.0
5.0SMDJ78CA
5.0SMDJ78A
78.0
86.70
99.70
5
2
40.5
126.0
5.0SMDJ85CA
5.0SMDJ85A
85.0
94.40
108.20
5
2
37.2
137.0
5.0SMDJ90CA
5.0SMDJ90A
90.0
100.0
111.0
5
2
34.9
146.0
5.0SMDJ100CA
5.0SMDJ100A
100.0
111.0
123.00
5
2
31.5
162.0
5.0SMDJ110CA
5.0SMDJ110A
110.0
122.0
135.00
5
2
28.8
177.0
5.0SMDJ120CA
5.0SMDJ120A
133.0
147.00
5
2
26.4
193.0
5.0SMDJ130CA
5.0SMDJ130A
130.0
144.0
159.00
5
2
24.4
209.0
5.0SMDJ150CA
5.0SMDJ150A
150.0
167.0
185.00
5
2
21.0
243.0
5.0SMDJ160CA
5.0SMDJ160A
160.0
178.0
197.00
5
2
19.7
259.0
5.0SMDJ170CA
5.0SMDJ170A
170.0
189.0
209.00
5
2
18.5
275.0
5.0SMDJ180CA
5.0SMDJ180A
180.0
201.0
222.0
5
2
17.5
292.0
5.0SMDJ190CA
5.0SMDJ190A
190.0
211.0
233.00
5
2
16.5
308.0
Rev : 01.06.2014
120.0
4 /8
@Ipp
(V)
Ipp
VOLTAGE
IR
MAXIMUM
IT
CLAMPING
VBR
CURRENT
VBR
PULSE
VRWM
PEAK
@VRWM
LEAKAGE
REVERSE
CURRENT
TEST
@IT
VBR(V)MAX.
N VOLTAGE
VOLTAGE
BREAKDOW
UNI-POLAR
STAND-OFF
BI- POLAR
REVERSE
PART NUMBER
www.leiditech.com
(mA)
(µA)
(A)
VOLTAGE
VOLTAGE @Ipp
MAX(V)
CLAMPING
MIN(V)
Ipp
MAXIMUM
(V)
CURRENT
IR
PEAK PULSE
IT
REVERSE
VBR
VOLTAGE
VBR
BREAKDOWN
VRWM
STAND-OFF
TEST CURRENT
UNI-POLAR
VBR(V)MAX.@IT
BI- POLAR
REVERSE
PART NUMBER
LEAKAGE @VRWM
Vc
(v)
5.0SMDJ200CA
5.0SMDJ200A
200.0
224.0
247.00
5
2
15.5
324.0
5.0SMDJ210CA
5.0SMDJ220A
210.0
237.00
263.00
5
2
14.6
356.0
5.0SMDJ220CA
5.0SMDJ220A
5
2
13.7
356.0
5.0SMDJ250CA
5.0SMDJ250A
250.0
279.00
309.00
5
2
12.0
405.0
5.0SMDJ300CA
5.0SMDJ300A
300.0
335.0
371.00
5
2
9.1
486.0
5.0SMDJ350CA
5.0SMDJ350A
350.0
391.00
432.00
5
2
7.7
567.0
5.0SMDJ400CA
5.0SMDJ400A
400.0
447.00
494.00
5
2
6.72
648.0
5.0SMDJ440CA
5.0SMDJ440A
440.0
492.00
5
2
6.16
713.0
220.0
246.00
272.00
543.00
Notes:
For bidirectional type having VRWM of 20 volts and less, the IR limit is double.
For parts without A (VBR is ± 10% and VC is 5% higher than A parts
I-V Curve Characteristics
Rev : 01.06.2014
5 /8
www.leiditech.com
Ratings and Characteristic Curves
Figure 1 - Peak Pulse Power Rating Curve
Figu re 3 - Pulse Waveform
Rev : 01.06.2014
(TA=25°C unless otherwise noted)
Figure 2 - Pulse Derating Curve
Figure 4 - Typical Junction Capacitance
6 /8
www.leiditech.com
Figure 6 - Maximum Non-Repetitive
Figure 5 - Steady State Power Dissipation
Derating Curve
Forward Surge Current Uni-Directional Only
Part
5.0SMDJ
(1)
(1)
(2)
(3)
(4)
Numbering
XXX
(2)
System
C A
(3)
(4)
SERIES.
VR VOLTAGE.
BI-DIRECTIONAL.
5% VOLTAGE TOLERANCE.
Rev : 01.06.2014
7 /8
www.leiditech.com
Product Dimensions
Inches
Dime-n
Millimeters
sion
MIN
MAX
MIN
MAX
A
0.220
0.245
5.59
6.22
B
0.305
0.320
7.75
8.13
C
0.114
0.126
2.90
3.20
D
0.260
0.280
6.60
7.11
E
0.030
0.060
0.76
1.52
F
0.077
0.094
1.95
2.40
G
0.008
0.203
H
0.79
0.103
2.06
2.62
J
0.030
0.060
0.76
1.52
K
0.008
0.014
0.20
0.35
L
0.039
0.049
0.99
1.24
B
D
C
A
H
E
J
K
F
L
G
.165
(4.4)
0.129
(3.3)
.094
(2.4)
Summary of Packing Options
Package Type
Packaging Option
Packing
Quantity
Industry
Standard
Tape&Reel-16mm/13”
tape
2500PCS
EIA STD
RS-481
DO-214AB(SMC)
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
8 /8
www.leiditech.com
很抱歉,暂时无法提供与“5.0SMDJ20CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.40362
- 10+6.32016
- 30+5.77844
- 100+5.23671
- 500+4.91357
- 1000+4.74250
