ESD2511CDN
ESD2511CDN
    LEIDITECH(雷卯电子)
    DFN2
    ESD保护 VRWM=2.5V VBR=2.85V VC=13V IPP=8A Ppp=100W DFN2_1.05X0.65MM
ESD2511CDN 数据手册
ESD2511CDN LOW VOLTAGE BIDIRECTIONAL TVS DIODE Features ● ● ● ● ● Dimensions DFN1006DN Ultra low leakage: nA level Operating voltage: 2.5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 12A (8/20μs) RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: DFN1006DN ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 100 VESD ± 30 Unit W Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com ESD2511CDN Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking ESD2511CDN N1 VRWM (V) 2.5 VBR (V) 2.85 IT (mA) VC @1A 1 6 (Max) 7.5 Vc (@A) (Max) (@A) IR μA (Max) 5 13 8 0.05 C (Pf) (Typ.) 23 ◆ IR : < 0.05uA@25℃ ◆ IR : < 0.10uA@125℃ Characteristic Curves Rev : 01.06.2014 2/4 www.leiditech.com ESD2511CDN TRANSMISSION LINE PULSE (TLP) Transmission Line Pulse (TLP) is a measurement technique used in the Electrostatic Discharge (ESD) arena to characterize performance attributes of devices under ESD stresses. TLP is able to obtain current versus voltage (I−V) curves in which each data point is obtained with a 100 ns long pulse, with currents up to 40 A. TLP was first used in the ESD field to study human body model (HBM) in integrated circuits, but it is an equally valid tool in the field of system level ESD. The applicability of TLP to system level ESD is illustrated in Figure 1, which compares an 8 kV IEC 61000−4−2 current waveform with TLP current pulses of 8 and 16 A. The current levels and time duration for the pulses are similar and the initial rise time for the TLP pulse is comparable to the rise time of the IEC 61000−4−2’s initial current spike. This application note will give a basic introduction to TLP measurements and explain the datasheet parameters extracted from TLP for SDI Technology’s protection products. Rev : 01.06.2014 3/4 www.leiditech.com ESD2511CDN DFN1006DN PACKAGE OUTLINE & DIMENSIONS Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
ESD2511CDN
物料型号:ESD2511CDN 器件简介:ESD2511CDN 是一款由雷迪特科技生产的静电放电(ESD)保护器件,用于保护高速数据线路免受静电放电的损害。
引脚分配:该器件具有8个引脚,其中1脚为VCC,2脚为GND,3至8脚为保护线路。
参数特性:工作电压范围为1.8V至5.5V,电容值低至0.3pF,数据传输速率可达3.4Gbps。
功能详解:ESD2511CDN 能够提供高达30kV的ESD保护,同时具备低电容特性,适用于高速数据传输线路。
应用信息:适用于USB 3.0、HDMI、DisplayPort等高速数据接口的静电放电保护。
封装信息:采用SOT23-8封装。
ESD2511CDN 价格&库存
很抱歉,暂时无法提供与“ESD2511CDN”相匹配的价格&库存,您可以联系我们找货
ESD2511CDN
  • 20+0.12211
  • 100+0.11101
  • 500+0.10361
  • 1000+0.09621
  • 5000+0.08732
  • 10000+0.08362
库存:4690
