LC05CI
1-Line Low Capacitance Bi-directional TVS Diode
Features
450W peak pulse power (8/20μs)
Ultra low capacitance: 2pF typical
Dimensions SOD-323
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Protects one power line or data line
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 18A (8/20μs)
RoHS Compliant
Pin Configuration
Applications
USB Ports
Smart Phones
Wireless Systems
Ethernet 10/100/1000 Base T
Mechanical Characteristics
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
VESD
Value
Unit
450
W
± 30
Kv
± 30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2015
1/3
www.leiditech.com
LC05CI
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
AC
5.0
6
1
12
LC05CI
Rev : 01.06.2015
2/3
(Max)
25
(@A)
18
IR
μA
(Max)
C
(Pf)
(Typ.)
0.5
2
www.leiditech.com
LC05CI
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
4.00
Peak Power_Ppp(W)
Clamping Voltage_Vc (V)
5.00
3.00
2.00
1.00
0.00
1
0.1
0.01
2
3
4
5
Peak Pulse Current_Ipp (A)
6
0.1
Junction Capacitance vs. Reverse Voltage
100
Peak Pulse Power vs. Pulse Time
120
50.00
100
40.00
% of Rated Power
1
10
Pulse Duration_tp(uS)
30.00
20.00
10.00
80
60
40
8
12
16
Clamping Voltage vs. Peak Pulse Current
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
100
% of Peak Pulse Current
90
80
70
60
50
40
30
Time_t(uS)
60
80
ESD Clamping Voltage
8 kV Contact per IEC61000−4−2
8 X 20uS Pulse Waveform
Rev : 01.06.2015
3/4
www.leiditech.com
LC05CI
SOD-323 Package Outline & Dimensions
Millimeters
Inches
Symbol
Min.
Nom.
Max.
Min.
Nom.
Max.
A
0.80
0.90
1.00
0.031
0.035
0.040
A1
0.00
0.05
0.10
0.000
0.002
0.004
A3
Soldering Footprint
0.15 REF
0.006 REF
b
0.25
0.32
0.40
0.010
0.012
0.016
C
0.089
0.12
0.177
0.003
0.005
0.007
D
1.60
1.70
1.80
0.062
0.066
0.070
E
1.15
1.25
1.35
0.045
0.049
0.053
L
0.08
HE
2.30
0.098
0.105
0.003
2.50
2.70
0.090
Symbol
Millimeters
Inches
F
1.60
0.063
G
2.85
0.112
J
0.83
0.033
K
0.63
0.025
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
4/4
www.leiditech.com
很抱歉,暂时无法提供与“LC05CI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63360
- 200+0.40920
- 1500+0.35530
- 3000+0.31460
- 国内价格
- 10+0.63888
- 100+0.50071
- 600+0.37977
- 1200+0.37407
- 3000+0.33834
- 国内价格
- 5+0.70780
- 50+0.55260
- 150+0.47600
- 500+0.41890
- 3000+0.37320
- 6000+0.35030
- 国内价格
- 5+0.72631
- 50+0.56923
- 150+0.49064
- 500+0.43174
- 3000+0.38465
- 6000+0.36106
