P4SMAJ5.0A
P4SMAJ5.0A
    YENJI(台湾元基)
    SMA(DO-214AC)
    ESD抑制器/TVS二极管 SMA VRWM=5V VC=9.2V
P4SMAJ5.0A 数据手册
P4SMAJ SERIES 400W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features ! Glass Passivated Die Construction ! ! ! ! ! ! 400W Peak Pulse Power Dissipation B 5.0V – 170V Standoff Voltage Uni- and Bi-Directional Versions Available Excellent Clamping Capability A Fast Response Time F Plastic Case Material has UL Flammability Classification Rating 94V-O C H G E SMA/DO-214AC Dim Min Max 2.50 2.90 A 4.00 4.60 B 1.20 1.60 C 0.152 0.305 D 4.80 5.28 E 2.00 2.44 F 0.051 0.203 G 0.76 1.52 H All Dimensions in mm Mechanical Data ! ! ! ! ! ! D Case: SMA/DO-214AC, Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band Except Bi-Directional Marking: Device Code Weight: 0.064 grams (approx.) Lead Free: For RoHS / Lead Free Version, Add “-LF” Suffix to Part Number, See Page 6 “C” Suffix Designates Bi-directional Devices “A” Suffix Designates 5% Tolerance Devices No Suffix Designates 10% Tolerance Devices Maximum Ratings and Electrical Characteristics Characteristic @TA=25°C unless otherwise specified Symbol Value Unit Peak Pulse Power Dissipation at TA = 25°C (Note 1, 2, 5) Figure 3 PPPM 400 Minimum W Peak Forward Surge Current (Note 3) IFSM 40 A Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 4 IPPM See Table 1 A PM(AV) 1.0 W Tj, TSTG -55 to +150 °C Steady State Power Dissipation (Note 4) Operating and Storage Temperature Range Note: 1. Non-repetitive current pulse per Figure 4 and derated above TA = 25°C per Figure 1. 2. Mounted on 5.0mm2 copper pad to each terminal. 3. 8.3ms single half sine-wave duty cycle = 4 pulses per minutes maximum. 4. Lead temperature at 75°C. 5. Peak pulse power waveform is 10/1000µS. www.yenji-esd.com 1/4 UNI-DIRECTIONAL 400 WATT SURFACE MOUNT TVS UNIDEVICE REVERSE DIRECTIONAL MARKING STAND-OFF PART NO. CODE VOLTAGE VRWM (V) P4SMAJ5.0 P4SMAJ5.0A P4SMAJ6.0 P4SMAJ6.0A P4SMAJ6.5 P4SMAJ6.5A P4SMAJ7.0 P4SMAJ7.0A P4SMAJ7.5 P4SMAJ7.5A P4SMAJ8.0 P4SMAJ8.0A P4SMAJ8.5 P4SMAJ8.5A P4SMAJ9.0 P4SMAJ9.0A P4SMAJ10 P4SMAJ10A P4SMAJ11 P4SMAJ11A P4SMAJ12 P4SMAJ12A P4SMAJ13 P4SMAJ13A P4SMAJ14 P4SMAJ14A P4SMAJ15 P4SMAJ15A P4SMAJ16 P4SMAJ16A P4SMAJ17 P4SMAJ17A P4SMAJ18 P4SMAJ18A P4SMAJ20 P4SMAJ20A P4SMAJ22 P4SMAJ22A P4SMAJ24 P4SMAJ24A P4SMAJ26 P4SMAJ26A P4SMAJ28 P4SMAJ28A P4SMAJ30 P4SMAJ30A P4SMAJ33 P4SMAJ33A P4SMAJ36 P4SMAJ36A P4SMAJ40 P4SMAJ40A P4SMAJ43 P4SMAJ43A P4SMAJ45 P4SMAJ45A P4SMAJ48 P4SMAJ48A P4SMAJ51 P4SMAJ51A P4SMAJ54 P4SMAJ54A P4SMAJ58 P4SMAJ58A P4SMAJ60 P4SMAJ60A P4SMAJ64 P4SMAJ64A P4SMAJ70 P4SMAJ70A P4SMAJ75 P4SMAJ75A P4SMAJ78 P4SMAJ78A P4SMAJ85 P4SMAJ85A P4SMAJ90 P4SMAJ90A P4SMAJ100 P4SMAJ100A P4SMAJ110 P4SMAJ110A P4SMAJ120 P4SMAJ120A P4SMAJ130 P4SMAJ130A P4SMAJ150 P4SMAJ150A P4SMAJ160 P4SMAJ160A P4SMAJ170 P4SMAJ170A HD HE HF HG HH HK HL HM HN HP HQ HR HS HT HU HV HW HX HY HZ ID IE IF IG IH IK IL IM IN IP IQ IR IS IT IU IV IW IX IY IZ JD JE JF JG JH JK JL JM JN JP JQ JR JS JT JU JV JW JX JY JZ RD RE RF RG RH RK RL RM RN RP RQ RR RS RT RU RV RW RX RY RZ SD SE SF SG SH SK SL SM SN SP SQ SR www.yenji-esd.com 5.00 5.00 6.00 6.00 6.50 6.50 7.00 7.00 7.50 7.50 8.00 8.00 8.50 8.50 9.00 9.00 10.00 10.00 11.00 11.00 12.00 12.00 13.00 13.00 14.00 14.00 15.00 15.00 16.00 16.00 17.00 17.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 33.00 33.00 36.00 36.00 40.00 40.00 43.00 43.00 45.00 45.00 48.00 48.00 51.00 51.00 54.00 54.00 58.00 58.00 60.00 60.00 64.00 64.00 70.00 70.00 75.00 75.00 78.00 78.00 85.00 85.00 90.00 90.00 100.00 100.00 110.00 110.00 120.00 120.00 130.00 130.00 150.00 150.00 160.00 160.00 170.00 170.00 BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.99 8.99 9.44 9.44 10.00 10.00 11.10 11.10 12.20 12.20 13.30 13.30 14.40 14.40 15.60 15.60 16.70 16.70 17.80 17.80 18.90 18.90 20.00 20.00 22.20 22.20 24.40 24.40 26.70 26.70 28.90 28.90 31.10 31.10 33.30 33.30 36.70 36.70 40.00 40.00 44.40 44.40 47.80 47.80 50.00 50.00 53.30 53.30 56.70 56.70 60.00 60.00 64.40 64.40 66.70 66.70 71.10 71.10 77.80 77.80 83.30 83.30 86.70 86.70 94.40 94.40 100.00 100.00 111.00 111.00 122.00 122.00 133.00 133.00 144.00 144.00 167.00 167.00 178.00 178.00 189.00 189.00 7.55 7.25 8.45 7.67 9.14 8.30 9.86 8.95 10.67 9.58 11.30 10.23 11.92 10.82 12.60 11.50 14.10 12.80 15.40 14.00 16.90 15.30 18.20 16.50 19.80 17.90 21.10 19.20 22.60 20.50 23.90 21.70 25.30 23.30 28.10 25.50 30.90 28.00 33.80 30.70 36.60 33.20 39.40 35.80 42.20 38.30 46.50 42.20 50.70 46.00 56.30 51.10 60.50 54.90 63.30 57.50 67.50 61.30 71.80 65.20 76.00 69.00 81.60 74.10 84.50 76.70 90.10 81.80 98.60 89.50 105.70 95.80 109.80 99.70 119.20 108.20 126.50 115.50 141.00 128.00 154.50 140.50 169.00 153.00 182.50 165.50 211.50 192.50 226.00 205.00 239.50 217.50 TEST PEAK PULSE REVERSE MAXIMUM CLAMPING CURRENT CURRENT LEAKAGE VOLTAGE @Ipp Vc (V) IT (mA) Ipp (A) @VRWM IR (uA) 10 10 10 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 59.0 53.3 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103.0 93.6 107.0 96.8 114.0 103.0 125.0 113.0 134.0 121.0 139.0 126.0 151.0 137.0 160.0 146.0 179.0 162.0 196.0 177.0 214.0 193.0 231.0 209.0 268.0 243.0 287.0 259.0 304.0 275.0 41.6 43.5 35.1 38.8 32.5 35.7 30.1 33.3 28.0 31.0 26.5 29.4 25.1 27.7 23.6 26.0 21.2 23.5 20.0 22.0 18.1 20.1 16.8 18.6 15.5 17.2 14.8 16.4 13.8 15.3 13.1 14.5 12.4 13.7 11.1 12.3 10.1 11.2 9.3 10.3 8.6 9.5 8.0 8.8 7.5 8.3 6.8 7.5 6.2 6.9 5.6 6.2 5.2 5.7 5.0 5.5 4.7 5.2 4.4 4.9 4.2 4.6 3.9 4.3 3.7 4.1 3.5 3.9 3.2 3.5 3.0 3.3 2.9 2.2 2.6 2.9 2.5 2.7 2.2 2.5 2.0 2.3 1.9 2.0 1.7 1.9 1.5 1.6 1.4 1.5 1.3 1.4 800 800 800 800 500 500 200 200 100 100 50 50 10 10 5 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2/4 BI-DIRECTIONAL 400 WATT SURFACE MOUNT TVS BIDEVICE REVERSE DIRECTIONAL MARKING STAND-OFF PART NO. CODE VOLTAGE VRWM (V) P4SMAJ5.0C P4SMAJ5.0CA P4SMAJ6.0C P4SMAJ6.0CA P4SMAJ6.5C P4SMAJ6.5CA P4SMAJ7.0C P4SMAJ7.0CA P4SMAJ7.5C P4SMAJ7.5CA P4SMAJ8.0C P4SMAJ8.0CA P4SMAJ8.5C P4SMAJ8.5CA P4SMAJ9.0C P4SMAJ9.0CA P4SMAJ10C P4SMAJ10CA P4SMAJ11C P4SMAJ11CA P4SMAJ12C P4SMAJ12CA P4SMAJ13C P4SMAJ13CA P4SMAJ14C P4SMAJ14CA P4SMAJ15C P4SMAJ15CA P4SMAJ16C P4SMAJ16CA P4SMAJ17C P4SMAJ17CA P4SMAJ18C P4SMAJ18CA P4SMAJ20C P4SMAJ20CA P4SMAJ22C P4SMAJ22CA P4SMAJ24C P4SMAJ24CA P4SMAJ26C P4SMAJ26CA P4SMAJ28C P4SMAJ28CA P4SMAJ30C P4SMAJ30CA P4SMAJ33C P4SMAJ33CA P4SMAJ36C P4SMAJ36CA P4SMAJ40C P4SMAJ40CA P4SMAJ43C P4SMAJ43CA P4SMAJ45C P4SMAJ45CA P4SMAJ48C P4SMAJ48CA P4SMAJ51C P4SMAJ51CA P4SMAJ54C P4SMAJ54CA P4SMAJ58C P4SMAJ58CA P4SMAJ60C P4SMAJ60CA P4SMAJ64C P4SMAJ64CA P4SMAJ70C P4SMAJ70CA P4SMAJ75C P4SMAJ75CA P4SMAJ78C P4SMAJ78CA P4SMAJ85C P4SMAJ85CA P4SMAJ90C P4SMAJ90CA P4SMAJ100C P4SMAJ100CA P4SMAJ110C P4SMAJ110CA P4SMAJ120C P4SMAJ120CA P4SMAJ130C P4SMAJ130CA P4SMAJ150C P4SMAJ150CA P4SMAJ160C P4SMAJ160CA P4SMAJ170C P4SMAJ170CA TD TE TF TG TH TK TL TM TN TP TQ TR TS TT TU TV TW TX TY TZ UD UE UF UG UH UK UL UM UN UP UQ UR US UT UU UV UW UX UY UZ VD VE VF VG VH VK VL VM VN VP VQ VR VS VT VU VV VW VX VY VZ WD WE WF WG WH WK WL WM WN WP WQ WR WS WT WU WV WW WX WY WZ XD XE XF XG XH XK XL XM XN XP XQ XR www.yenji-esd.com 5.00 5.00 6.00 6.00 6.50 6.50 7.00 7.00 7.50 7.50 8.00 8.00 8.50 8.50 9.00 9.00 10.00 10.00 11.00 11.00 12.00 12.00 13.00 13.00 14.00 14.00 15.00 15.00 16.00 16.00 17.00 17.00 18.00 18.00 20.00 20.00 22.00 22.00 24.00 24.00 26.00 26.00 28.00 28.00 30.00 30.00 33.00 33.00 36.00 36.00 40.00 40.00 43.00 43.00 45.00 45.00 48.00 48.00 51.00 51.00 54.00 54.00 58.00 58.00 60.00 60.00 64.00 64.00 70.00 70.00 75.00 75.00 78.00 78.00 85.00 85.00 90.00 90.00 100.00 100.00 110.00 110.00 120.00 120.00 130.00 130.00 150.00 150.00 160.00 160.00 170.00 170.00 BREAKDOWN VOLTAGE VBR (V) MIN. @IT BREAKDOWN VOLTAGE VBR (V) MAX. @IT 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.99 8.99 9.44 9.44 10.00 10.00 11.10 11.10 12.20 12.20 13.30 13.30 14.40 14.40 15.60 15.60 16.70 16.70 17.80 17.80 18.90 18.90 20.00 20.00 22.20 22.20 24.40 24.40 26.70 26.70 28.90 28.90 31.10 31.10 33.30 33.30 36.70 36.70 40.00 40.00 44.40 44.40 47.80 47.80 50.00 50.00 53.30 53.30 56.70 56.70 60.00 60.00 64.40 64.40 66.70 66.70 71.10 71.10 77.80 77.80 83.30 83.30 86.70 86.70 94.40 94.40 100.00 100.00 111.00 111.00 122.00 122.00 133.00 133.00 144.00 144.00 167.00 167.00 178.00 178.00 189.00 189.00 7.55 7.25 8.45 7.67 9.14 8.30 9.86 8.95 10.67 9.58 11.30 10.23 11.92 10.82 12.60 11.50 14.10 12.80 15.40 14.00 16.90 15.30 18.20 16.50 19.80 17.90 21.10 19.20 22.60 20.50 23.90 21.70 25.30 23.30 28.10 25.50 30.90 28.00 33.80 30.70 36.60 33.20 39.40 35.80 42.20 38.30 46.50 42.20 50.70 46.00 56.30 51.10 60.50 54.90 63.30 57.50 67.50 61.30 71.80 65.20 76.00 69.00 81.60 74.10 84.50 76.70 90.10 81.80 98.60 89.50 105.70 95.80 109.80 99.70 119.20 108.20 126.50 115.50 141.00 128.00 154.50 140.50 169.00 153.00 182.50 165.50 211.50 192.50 226.00 205.00 239.50 217.50 TEST PEAK PULSE REVERSE MAXIMUM CLAMPING CURRENT CURRENT LEAKAGE VOLTAGE @Ipp Vc (V) IT (mA) Ipp (A) @VRWM IR (uA) 10 10 10 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 59.0 53.3 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103.0 93.6 107.0 96.8 114.0 103.0 125.0 113.0 134.0 121.0 139.0 126.0 151.0 137.0 160.0 146.0 179.0 162.0 196.0 177.0 214.0 193.0 231.0 209.0 268.0 243.0 287.0 259.0 304.0 275.0 41.6 43.5 35.1 38.8 32.5 35.7 30.1 33.3 28.0 31.0 26.5 29.4 25.1 27.7 23.6 26.0 21.2 23.5 20.0 22.0 18.1 20.1 16.8 18.6 15.5 17.2 14.8 16.4 13.8 15.3 13.1 14.5 12.4 13.7 11.1 12.3 10.1 11.2 9.3 10.3 8.6 9.5 8.0 8.8 7.5 8.3 6.8 7.5 6.2 6.9 5.6 6.2 5.2 5.7 5.0 5.5 4.7 5.2 4.4 4.9 4.2 4.6 3.9 4.3 3.7 4.1 3.5 3.9 3.2 3.5 3.0 3.3 2.9 2.2 2.6 2.9 2.5 2.7 2.2 2.5 2.0 2.3 1.9 2.0 1.7 1.9 1.5 1.6 1.4 1.5 1.3 1.4 1600 1600 1600 1600 1000 1000 400 400 200 200 100 100 20 20 5 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 3/4 RATINGS AND CHARACTERISTIC CURVES (TA=25ć unless otherwise noted) 10000 CJ, JUNCTION CAPACITANCE (pF) PEAK PULSE DERATING IN % OF PEAK POWER OR CURRENT 100 75 50 25 T j = 25 °C Unidirectional 1000 Bidirectional 100 10 X 1000 Waveform as defined by REA 10 0 0 25 50 75 1 100 125 150 175 200 10 100 1000 V WM, STANDOFF VOLTAGE (V) Fig. 2 Typical Junction Capacitance TA, AMBIENT TEMPERATURE ( °C) Fig. 1 Pulse Derating Curve Pd, PEAK PULSE POWER (kW) 100 Tj = 25 °C Non Repetitive Pulse Waveform Shown in Fig. 4 10 1.0 0.1 0.1 1.0 10 100 1000 10000 IP, PEAK PULSE CURRENT (%Ipp) tp PULSE WIDTH ( ms) Fig. 3 Pulse Rating Curve t r = 10µ s 100 Peak Value Ipp Half Value Ipp/2 50 tp 10 X 1000 Waveform as defined by R.E.A. 0 0 1 2 3 t, TIME (ms) Fig. 4 Pulse Waveform www.yenji-esd.com 4/4
P4SMAJ5.0A 价格&库存
很抱歉,暂时无法提供与“P4SMAJ5.0A”相匹配的价格&库存,您可以联系我们找货
