PSMN026-80YS,115
PSMN026-80YS,115
    NEXPERIA(安世)
    SOT669
    MOSFETs 80V 74W SMT SOT669 34A N-Channel
PSMN026-80YS,115 数据手册
PSMN026-80YS N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET Rev. 01 — 25 June 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in LFPAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ Advanced TrenchMOS provides low RDSon and low gate charge „ Improved mechanical and thermal characteristics „ High efficiency gains in switching power converters „ LFPAK provides maximum power density in a Power SO8 package 1.3 Applications „ DC-to-DC converters „ Motor control „ Lithium-ion battery protection „ Server power supplies „ Load switching 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 80 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 34 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 74 W Tj junction temperature -55 - 175 °C VGS = 10 V; Tj(init) = 25 °C; ID = 31 A; Vsup ≤ 80 V; RGS = 50 Ω; unclamped - - 32 mJ VGS = 10 V; ID = 25 A; VDS = 40 V; see Figure 14; see Figure 15 - 5 - nC - 20 - nC Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET Table 1. Quick reference …continued Symbol Parameter Conditions Min Typ Max Unit VGS = 10 V; ID = 5 A; Tj = 100 °C; see Figure 12 - - 42 mΩ VGS = 10 V; ID = 5 A; Tj = 25 °C; see Figure 13 - 20 27.5 mΩ Static characteristics RDSon drain-source on-state resistance 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number PSMN026-80YS Package Name Description Version LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 2 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 80 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ VGS gate-source voltage ID drain current - 80 V -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 24 A VGS = 10 V; Tmb = 25 °C; see Figure 1 - 34 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 137 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 74 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 34 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 137 A - 32 mJ Avalanche ruggedness non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 31 A; Vsup ≤ 80 V; drain-source avalanche RGS = 50 Ω; unclamped energy EDS(AL)S 003aad282 40 ID (A) 03aa16 120 Pder (%) 30 80 20 40 10 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature © PSMN026-80YS_1 Product data sheet 50 Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 3 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 003aad313 103 ID (A) Limit RDSon = VDS / ID 10μ s 102 100μ s 10 1 1ms DC 10ms 10-1 100ms 10-2 1 Fig 3. 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 4 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - 1.4 2 K/W 003aac558 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10-1 δ= P 0.05 tp T 0.02 t tp single shot T 10-2 10-6 Fig 4. 10-5 10-4 10-3 10-2 tp (s) 10-1 1 Transient thermal impedance from junction to mounting base as a function of pulse duration © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 5 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon RG drain-source breakdown voltage gate-source threshold voltage drain leakage current gate leakage current drain-source on-state resistance ID = 250 µA; VGS = 0 V; Tj = -55 °C 73 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 80 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10; see Figure 11 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10; see Figure 11 - - 4.6 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 2 3 4 V VDS = 80 V; VGS = 0 V; Tj = 25 °C - - 1.5 µA VDS = 80 V; VGS = 0 V; Tj = 125 °C - - 10 µA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 5 A; Tj = 175 °C - - 66 mΩ VGS = 10 V; ID = 5 A; Tj = 100 °C; see Figure 12 - - 42 mΩ VGS = 10 V; ID = 5 A; Tj = 25 °C; see Figure 13 - 20 27.5 mΩ - 0.8 - Ω ID = 0 A; VDS = 0 V; VGS = 10 V - 17 - nC ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 14; see Figure 15 - 20 - nC internal gate resistance f = 1 MHz (AC) Dynamic characteristics QG(tot) total gate charge QGS gate-source charge ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 15 - 6.4 - nC QGS(th) pre-threshold gate-source charge ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 14 - 3.7 - nC QGS(th-pl) post-threshold gate-source charge - 2.7 - nC QGD gate-drain charge ID = 25 A; VDS = 40 V; VGS = 10 V; see Figure 14; see Figure 15 - 5 - nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 40 V - 5 - V Ciss input capacitance - 1200 - pF Coss output capacitance VDS = 40 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 120 - pF Crss reverse transfer capacitance - 70 - pF td(on) turn-on delay time - 15 - ns tr rise time - 6 - ns td(off) turn-off delay time - 26 - ns tf fall time - 5 - ns VDS = 40 V; RL = 1.6 Ω; VGS = 10 V; RG(ext) = 4.7 Ω © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 6 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 5 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.8 1.2 V trr reverse recovery time - 36 - ns Qr recovered charge IS = 15 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 40 V - 52 - nC [1] Tested to JEDEC standards where applicable. 003aad270 80 20 10 ID (A) C (pF) 8 6 60 003aad276 2000 Ciss 1600 5.5 40 1200 5 Crss 20 800 VGS (V) = 4.5 0 400 0 Fig 5. 1 2 3 4 VDS (V) 5 Output characteristics: drain current as a function of drain-source voltage; typical values 0 Fig 6. 003aad272 50 ID (A) 3 6 9 VGS (V) 12 Input and reverse transfer capacitances as a function of gate-source voltage; typical values 003aad278 60 RDSon (mΩ) 40 50 30 40 20 Tj = 150 °C 30 Tj = 175 °C 10 Tj = 25 °C 0 20 0 Fig 7. 2 4 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 4 Fig 8. 12 16 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values © PSMN026-80YS_1 Product data sheet 8 Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 7 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 003aad277 50 03aa35 10−1 ID (A) gfs (S) 40 10−2 30 10−3 20 10−4 10 10−5 typ max 10−6 0 0 Fig 9. min 20 40 ID (A) 60 003aad280 VGS(th) (V) 6 Fig 10. Sub-threshold drain current as a function of gate-source voltage 003aad045 2.5 max 2.0 typ 1.5 min 1.0 3 2 1 0.5 0 60 120 180 0.0 -60 -30 0 30 60 90 120 Tj (°C) Fig 11. Gate-source threshold voltage as a function of junction temperature 150 180 Tj (°C) Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature © PSMN026-80YS_1 Product data sheet 4 a 4 0 −60 2 VGS (V) Forward transconductance as a function of drain current; typical values 5 0 Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 8 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 003aad271 60 VDS RDSon (mΩ) 5.5 VGS (V) = 5 20 10 6 50 ID 20 VGS(pl) 40 VGS(th) VGS 30 QGS1 QGS2 QGS 20 QGD QG(tot) 003aaa508 10 0 20 40 60 ID (A) 80 Fig 14. Gate charge waveform definitions Fig 13. Drain-source on-state resistance as a function of drain current; typical values 003aad274 10 VGS (V) 16V 003aad275 104 C (pF) 8 64V Ciss 103 VDS = 40V 6 4 Coss 102 Crss 2 0 0 5 10 15 20 25 QG (nC) Fig 15. Gate-source voltage as a function of gate charge; typical values 10 10-1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values © PSMN026-80YS_1 Product data sheet 1 Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 9 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 003aad273 100 IS (A) 80 60 40 Tj = 150 °C Tj = 175 °C 20 Tj = 25 °C 0 0 0.3 0.6 0.9 1.2 VSD (V) Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 10 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) A UNIT A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 mm b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 18. Package outline SOT669 (LFPAK) © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 11 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN026-80YS_1 20090625 Product data sheet - - © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 12 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PSMN026-80YS_1 Product data sheet Rev. 01 — 25 June 2009 Nexperia B.V. 2017. All rights reserved 13 of 14 PSMN026-80YS Nexperia N-channel LFPAK 80 V 27.5 mΩ standard level MOSFET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 June 2009
PSMN026-80YS,115 价格&库存
很抱歉,暂时无法提供与“PSMN026-80YS,115”相匹配的价格&库存,您可以联系我们找货
PSMN026-80YS,115
  • 1+5.217291+0.67800
  • 10+4.4868710+0.58308
  • 25+4.1564425+0.54014
  • 100+3.96514100+0.51528
  • 250+3.56515250+0.46330
  • 500+3.44341500+0.44748
  • 1000+3.199941000+0.41584
  • 1500+3.130381500+0.40680
PSMN026-80YS,115
  • 1+4.85947
  • 10+4.17793
  • 25+3.87249
  • 100+3.69282
  • 250+3.32030
  • 500+3.20771
  • 1000+2.98492
  • 1500+2.91904
PSMN026-80YS,115
