BUK7227-100B
N-channel TrenchMOS standard level FET
Rev. 02 — 17 February 2011
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
AEC Q101 compliant
Low conduction losses due to low
on-state resistance
Suitable for standard level gate drive
sources
Suitable for thermally demanding
environments due to 185 °C rating
1.3 Applications
12 V, 24 V and 42 V loads
General purpose power switching
Automotive systems
Motors, lamps and solenoids
1.4 Quick reference data
Table 1.
Symbol
Parameter
Min
Typ
Max Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 185 °C
Conditions
100
V
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 1; see Figure 3
48
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
167
W
VGS = 10 V; ID = 25 A;
Tj = 25 °C; see Figure 11;
see Figure 12
23
27
mΩ
ID = 48 A; Vsup ≤ 100 V;
RGS = 50 Ω; VGS = 10 V;
Tj(init) = 25 °C; unclamped
145
mJ
VDS = 80 V; Tj = 25 °C;
see Figure 13
13
nC
Static characteristics
RDSon
drain-source
on-state resistance
Avalanche ruggedness
EDS(AL)S
non-repetitive
drain-source
avalanche energy
Dynamic characteristics
QGD
gate-drain charge
BUK7227-100B
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain[1]
Simplified outline
Graphic symbol
mb
3
S
source
mb
D
mounting base; connected to
drain
D
G
mbb076
S
2
1
3
SOT428 (DPAK)
[1]
It is not possible to make a connection to pin 2 of the SOT428 package.
3. Ordering information
Table 3.
Type number
BUK7227-100B
BUK7227-100B
Product data sheet
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads
(one lead cropped)
SOT428
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
BUK7227-100B
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VDGR
drain-gate voltage
RGS = 20 kΩ
100
V
VGS
gate-source voltage
ID
drain current
-20
V
Tmb = 100 °C; VGS = 10 V; see Figure 1
34
A
Tmb = 25 °C; VGS = 10 V; see Figure 1;
see Figure 3
48
A
IDM
peak drain current
Tmb = 25 °C; pulsed; tp ≤ 10 µs;
see Figure 3
196
A
Ptot
total power dissipation
167
W
Tstg
storage temperature
-55
185
°C
Tj
junction temperature
-55
185
°C
Source-drain diode
IS
source current
Tmb = 25 °C
48
A
ISM
peak source current
pulsed; tp ≤ 10 µs; Tmb = 25 °C
196
A
ID = 48 A; Vsup ≤ 100 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
145
mJ
non-repetitive drain-source
avalanche energy
EDS(AL)S
03nl33
50
ID
(A)
03no96
120
Pder
40
80
30
10
100
150
50
100
150
Tmb (°C)
Fig 1.
Continuous drain current as a function of
mounting base temperature
BUK7227-100B
Product data sheet
Fig 2.
200
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
3 of 14
BUK7227-100B
Nexperia
03nl31
103
ID
(A)
Limit RDSon = VDS / ID
102
t p = 10 μ s
100 μ s
DC
10
1 ms
10 ms
100 ms
1
1
10
102
103
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK7227-100B
Product data sheet
4 of 14
BUK7227-100B
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to mounting
base
see Figure 4
0.95
K/W
Rth(j-a)
thermal resistance from junction to ambient
71.4
K/W
03nk52
1
δ = 0.5
Zth(j-mb)
(K/W)
10−1
0.2
0.1
0.05
0.02
δ=
P
10−2
tp
T
single shot
t
tp
10−3
10−6
T
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7227-100B
Product data sheet
5 of 14
BUK7227-100B
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
100
V
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
89
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 185 °C;
see Figure 10
0.9
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
4.4
V
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.02
1
µA
VDS = 100 V; VGS = 0 V; Tj = 185 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 185 °C;
see Figure 11; see Figure 12
70
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
23
27
mΩ
ID = 25 A; VDS = 80 V; VGS = 10 V;
Tj = 25 °C; see Figure 13
37
nC
9
nC
13
nC
2092
2789
pF
241
289
pF
102
140
pF
18
ns
IDSS
drain leakage current
IGSS
gate leakage current
RDSon
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
VDS = 25 V; RL = 1.0 Ω; VGS = 10 V;
RG(ext) = 10 Ω; Tj = 25 °C
tr
rise time
99
ns
td(off)
turn-off delay time
50
ns
tf
fall time
ns
LD
internal drain
inductance
measured from drain to centre of die
2.5
nH
LS
internal source
inductance
measured from source lead to source
bond pad
7.5
nH
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 15
0.85
1.2
V
trr
reverse recovery time
94
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
114
nC
BUK7227-100B
Product data sheet
6 of 14
BUK7227-100B
Nexperia
03nl28
140
ID
(A)
9
8.5
8
7.5
10
105
03nl27
35
Label is VGS (V)
RDSon
(mΩ)
30
7
6.5
70
6
25
5.5
35
5
4.5
Fig 5.
2
4
6
8
10
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
5
Fig 6.
03aa35
10−1
ID
(A)
min
10−2
typ
10
15
VGS (V)
Drain-source on-state resistance as a function
of gate-source voltage; typical values
03nl25
40
gfs
(S)
max
30
10−3
10−4
10
10−5
10−6
4
ID (A)
VGS (V)
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
BUK7227-100B
Product data sheet
Fig 8.
60
Forward transconductance as a function of
drain current; typical values
7 of 14
BUK7227-100B
Nexperia
03nl26
100
03no98
5
VGS(th)
(V)
4
ID
(A)
75
max
3
typ
50
2
min
25
Tj = 185 °C
Tj = 25 °C
1
Fig 9.
2
4
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03nl29
60
−60
8
VGS (V)
10
80
150
220
Tj (°C)
Fig 10. Gate-source threshold voltage as a function of
03np02
2.8
Label is VGS (V)
RDSon
(mΩ)
a
50
6
6.5
7
8
10
40
1.4
30
0.7
70
105
ID (A)
140
Fig 11. Drain-source on-state resistance as a function
of drain current; typical values
BUK7227-100B
Product data sheet
-60
10
80
150
Tj (°C)
220
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
8 of 14
BUK7227-100B
Nexperia
03nl24
10
03nl30
3000
VGS
(V)
Ciss
C
(pF)
8
VDD = 14 V
2000
VDD = 80 V
6
Coss
4
1000
Crss
2
10−1
QG (nC)
40
Fig 13. Gate-source voltage as a function of gate
charge; typical values
1
10
VDS (V)
102
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
03nl23
100
IS
(A)
75
50
Tj = 185 °C
Tj = 25 °C
25
0.3
0.6
0.9
1.2
VSD (V)
Fig 15. Source current as a function of source-drain voltage; typical values
BUK7227-100B
Product data sheet
9 of 14
BUK7227-100B
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L
L2
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig 16. Package outline SOT428 (DPAK)
BUK7227-100B
Product data sheet
10 of 14
BUK7227-100B
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7227-100B v.2
20110217
Product data sheet
BUK7227_100B v.1
Modifications:
BUK7227_100B v.1
BUK7227-100B
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20040126
Product data
11 of 14
BUK7227-100B
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
BUK7227-100B
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of a Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
12 of 14
BUK7227-100B
Nexperia
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7227-100B
Product data sheet
13 of 14
Nexperia
BUK7227-100B
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
Date of release: 17 February 2011
很抱歉,暂时无法提供与“BUK9212-55B,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.70760
- 10+15.07680
- 30+14.05080
- 100+12.99240
- 500+12.52800
- 1000+12.32280
