PSMN1R5-30YL,115
PSMN1R5-30YL,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=100A VDS=30V SOT669
PSMN1R5-30YL,115 数据手册
PSMN1R5-30YL N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK Rev. 01 — 9 April 2010 Product data sheet 1. Product profile 1.1 General description Logic level N-channel MOSFET in LFPAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits  Advanced TrenchMOS provides low RDSon and low gate charge  Improved mechanical and thermal characteristics  High efficiency gains in switching power convertors  LFPAK provides maximum power density in a Power SO8 package 1.3 Applications  DC-to-DC converters  Motor control  Lithium-ion battery protection  Server power supplies  Load switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 30 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 100 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 109 W Tj junction temperature -55 - 175 °C VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 14 - - 2.4 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C - 1.3 1.5 mΩ - 8.7 - nC [1] Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge VGS = 4.5 V; ID = 10 A; VDS = 12 V; see Figure 15; see Figure 16 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK Table 1. Quick reference data …continued Symbol Parameter Conditions Min Typ QG(tot) total gate charge VGS = 4.5 V; ID = 10 A; VDS = 12 V; see Figure 15 - 36.2 - Max Unit nC non-repetitive VGS = 10 V; Tj(init) = 25 °C; drain-source ID = 100 A; Vsup ≤ 30 V; avalanche energy RGS = 50 Ω; unclamped - - mJ Avalanche ruggedness EDS(AL)S [1] 241 Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number PSMN1R5-30YL PSMN1R5-30YL Product data sheet Package Name Description LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 Version © Nexperia B.V. 2017. All rights reserved 2 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 30 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - - 30 V VGS gate-source voltage ID drain current -20 - 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 [1] - - 100 A VGS = 10 V; Tmb = 25 °C; see Figure 1 [1] - - 100 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 4 - - 790 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 109 W Tstg storage temperature -55 - 175 °C Tj junction temperature -55 - 175 °C - - 100 A - - 790 A - - - J - - 241 mJ Source-drain diode IS source current Tmb = 25 °C ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C [1] Avalanche ruggedness EDS(AL)R repetitive drain-source avalanche energy see Figure 3 EDS(AL)S non-repetitive drain-source avalanche energy VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; unclamped [1] Continuous current is limited by package. [2] Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. [3] Repetitive avalanche rating limited by average junction temperature of 170 °C. [4] Refer to application note AN10273 for further information. PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 [2][3][4] © Nexperia B.V. 2017. All rights reserved 3 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 003aac446 120 ID (A) 100 03aa16 120 (1) Pder (%) 80 80 60 40 40 20 0 0 0 Fig 1. 50 100 150 0 200 Tmb (°C) 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aac266 103 IAL (A) 102 (1) (2) 10 (3) 1 10-1 10-3 Fig 3. 10-2 10-1 1 t (ms) 10 AL Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 4 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 003aad111 104 ID (A) Limit RDSon = VDS / ID 103 10 μs 102 100 μs (1) 1 ms 10 DC 10 ms 100 ms 1 10-1 Fig 4. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 5 - 0.5 1.1 K/W 003aac456 10 Zth(j-mb) (K/W) 1 δ = 0.5 10-1 0.2 0.1 0.05 δ= P 0.02 tp T 10-2 single shot t tp T 10-3 10-6 Fig 5. 10-5 10-4 10-3 10-2 tp (s) 10-1 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 5 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 6. Characteristics Table 6. Characteristics Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit ID = 20 A; VGS = 0 V; Tj = 25 °C; tav = 100 ns 35 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 12; see Figure 13 1.3 1.7 2.15 V ID = 1 mA; VDS = VGS; Tj = 150 °C; see Figure 13 0.65 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 13 - - 2.45 V VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 30 V; VGS = 0 V; Tj = 150 °C - - 100 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 15 A; Tj = 25 °C - 1.8 1.9 mΩ VGS = 10 V; ID = 15 A; Tj = 150 °C; see Figure 14 - - 2.8 mΩ VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 14 - - 2.4 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C - 1.3 1.5 mΩ f = 1 MHz - 0.77 1.5 Ω ID = 10 A; VDS = 12 V; VGS = 10 V; see Figure 15; see Figure 16 - 77.9 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 70 - nC ID = 10 A; VDS = 12 V; VGS = 4.5 V; see Figure 15 - 36.2 - nC ID = 10 A; VDS = 12 V; VGS = 4.5 V; see Figure 15; see Figure 16 - 11.6 - nC - 8 - nC Static characteristics V(BR)DSS VGS(th) IDSS drain-source breakdown voltage gate-source threshold voltage drain leakage current IGSS gate leakage current RDSon drain-source on-state resistance RG gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gate-source charge QGS(th-pl) post-threshold gate-source charge - 3.6 - nC QGD gate-drain charge - 8.7 - nC VGS(pl) gate-source plateau voltage VDS = 12 V; see Figure 15; see Figure 16 - 2.34 - V Ciss input capacitance - 5057 - pF Coss output capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 17 - 1082 - pF Crss reverse transfer capacitance - 398 - pF PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 6 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK Table 6. Characteristics …continued Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit td(on) turn-on delay time - 46 - ns tr rise time VDS = 12 V; RL = 0.5 Ω; VGS = 4.5 V; RG(ext) = 4.7 Ω - 72 - ns td(off) turn-off delay time - 76 - ns tf fall time - 34 - ns - 0.78 1.2 V Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 18 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 20 V 003aac449 300 ID 4 (A) 10 3.6 250 - 45 - ns - 56 - nC 003aac450 5 RDSon (mΩ) VGS (V) = 3.2 3.4 4 VGS (V) = 3.4 200 3 150 3.6 3 4 2.8 100 2 2.6 7 50 2.4 2.2 0 0 Fig 6. 2 4 6 10 1 8 VDS (V) 10 Output characteristics: drain current as a function of drain-source voltage; typical values PSMN1R5-30YL Product data sheet 0 Fig 7. 50 100 150 200 ID (A) 250 Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 7 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 003aac452 200 003aac455 8000 Ciss gfs (S) C (pF) 150 6000 100 4000 Crss 50 2000 0 0 Fig 8. 20 40 60 Forward transconductance as a function of drain current; typical values 003aac451 3.0 0 ID (A) 80 2 Fig 9. 4 6 8 VGS (V) 10 Input and reverse transfer capacitances as a function of gate-source voltage; typical values 003aad113 80 ID (A) RDSon (mΩ) 2.5 60 2.0 40 Tj = 175 °C Tj = 25 °C 1.5 20 1.0 0 2 4 6 8 VGS (V) 10 Fig 10. Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN1R5-30YL Product data sheet 0 1 2 3 VGS (V) 4 Fig 11. Transfer characteristics: drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 8 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 003aab271 10-1 003a a c982 3 ID (A) 10-2 VGS (th) (V) min typ max max 2 10-3 typ min 10-4 1 10-5 10-6 0 1 2 VGS (V) 3 Fig 12. Sub-threshold drain current as a function of gate-source voltage 0 -60 0 60 120 Tj (°C) 180 Fig 13. Gate-source threshold voltage as a function of junction temperature 03aa27 2 VDS a ID 1.5 VGS(pl) VGS(th) 1 VGS QGS1 0.5 QGS2 QGS QGD QG(tot) 003aaa508 0 −60 0 60 120 Tj (°C) 180 Fig 14. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN1R5-30YL Product data sheet Fig 15. Gate charge waveform definitions All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 9 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 003aac448 10 VGS (V) 003aac454 6000 Ciss C (pF) 8 Coss 4000 6 VDS = 12 (V) VDS = 19 (V) 4 2000 Crss 2 0 10-1 0 0 20 40 60 QG (nC) 80 Fig 16. Gate-source voltage as a function of gate charge; typical values 1 10 VDS (V) 102 Fig 17. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 003aac447 100 IS (A) 80 60 40 Tj = 150 °C 20 25 °C 0 0.0 0.2 0.4 0.6 0.8 1.0 VSD (V) Fig 18. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 10 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 mm b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 19. Package outline SOT669 (LFPAK) PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 11 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN1R5-30YL_1 20100409 Product data sheet - - PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 12 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PSMN1R5-30YL Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 13 of 15 PSMN1R5-30YL Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PSMN1R5-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 9 April 2010 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PSMN1R5-30YL N-channel 30 V 1.5 mΩ logic level MOSFET in LFPAK 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 April 2010
PSMN1R5-30YL,115 价格&库存
很抱歉,暂时无法提供与“PSMN1R5-30YL,115”相匹配的价格&库存,您可以联系我们找货
PSMN1R5-30YL,115
  • 1+12.21756
  • 5+10.64844
  • 10+9.72614
PSMN1R5-30YL,115
  • 1+19.506991+2.52312
  • 10+12.4607810+1.61173
  • 100+8.46281100+1.09462
  • 500+6.75051500+0.87314
库存:2980
PSMN1R5-30YL,115
  • 1500+6.530021500+0.84462
库存:2980
