PHB191NQ06LT,118
PHB191NQ06LT,118
    NEXPERIA(安世)
    SOT404
    MOSFETs 55V 300W SMT SOT404 75A N-Channel
PHB191NQ06LT,118 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PHB191NQ06LT N-channel TrenchMOS logic level FET Rev. 02 — 13 January 2010 Product data sheet 1. Product profile 1.1 General description Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Suitable for logic level gate drive sources 1.3 Applications „ DC-to-DC convertors „ Motors, lamps and solenoids „ General industrial applications „ Uninterruptible power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 55 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 and 3 - - 75 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 300 W VGS = 5 V; ID = 25 A; VDS = 44 V; Tj = 25 °C; see Figure 11 - 37.6 - nC VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 10 and 9 - 3.1 3.7 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb [1] G mbb076 S 2 1 3 SOT404 (D2PAK) [1] It is not possible to make connection to pin 2. 3. Ordering information Table 3. Ordering information Type number PHB191NQ06LT Package Name Description Version D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) SOT404 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 55 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 55 V VGS gate-source voltage ID drain current -15 15 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 75 A VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3 - 75 A - 240 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 300 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 75 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 240 A - 560 mJ Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 75 A; Vsup ≤ 55 V; drain-source avalanche unclamped; RGS = 50 Ω; tp ≤ 0.21 ms energy PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 2 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 03aq99 120 Ider (%) Pder (%) 80 80 40 40 0 Fig 1. 03aa16 120 0 50 100 150 0 200 Tmb (°C) 0 50 100 150 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 03ar01 103 Limit R DSon = VDS /I D ID (A) t p = 10 μs 102 100 μs 1 ms DC 10 ms 10 100 ms 1 1 102 10 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 3 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) Rth(j-a) Conditions Min Typ Max Unit thermal resistance from see Figure 4 junction to mounting base - - 0.5 K/W thermal resistance from mounted on a printed-circuit board; junction to ambient vertical in still air; minimum footprint - 50 - K/W 03ar00 1 Zth(j-mb) (K/W) 10−1 δ = 0.5 0.2 0.1 0.05 0.02 δ= P single pulse t tp 10−2 10−4 tp T T 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 4 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 50 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 55 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 7 and 8 - - 2.2 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 7 and 8 0.5 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 7 and 8 1 1.5 2 V VDS = 55 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 55 V; VGS = 0 V; Tj = 175 °C - - 500 µA VGS = 15 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -15 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C; see Figure 9 - - 4.4 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 10 and 9 - 3.5 4.2 mΩ VGS = 10 V; ID = 25 A; Tj = 175 °C; see Figure 10 and 9 - - 7.4 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 10 and 9 - 3.1 3.7 mΩ ID = 25 A; VDS = 44 V; VGS = 5 V; Tj = 25 °C; see Figure 11 - 95.6 - nC - 17.2 - nC - 37.6 - nC Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) tf VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 12 VDS = 30 V; RL = 1.2 Ω; VGS = 5 V; RG(ext) = 10 Ω; Tj = 25 °C - 7665 - pF - 1045 - pF - 465 - pF - 63 - ns - 232 - ns turn-off delay time - 273 - ns fall time - 178 - ns Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 13 - 0.79 1.2 V trr reverse recovery time - 78 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 171 - nC PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 5 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 03ar02 240 10 V Tj = 25 °C ID (A) 03ar04 80 4 V 3.6 V VDS > ID x R DSon ID (A) 3.2 V 5V 60 160 40 2.8 V 80 20 Tj = 175 °C 25 °C VGS = 2.4 V 0 0 0 0.5 1 1.5 2 0 VDS (V) Fig 5. Output characteristics: drain current as a function of drain-source voltage; typical values 03aa33 2.5 1.5 max 10-2 typ 10-3 Fig 7. 03aa36 Product data sheet typ max 10-5 10-6 0 60 120 Tj (°C) 180 Gate-source threshold voltage as a function of junction temperature PHB191NQ06LT_2 3 10-4 min 0.5 0 -60 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values min 1 2 10-1 ID (A) VGS(th) (V) 2 Fig 6. 1 0 Fig 8. 1 2 VGS (V) 3 Sub-threshold drain current as a function of gate-source voltage All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 6 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 03ne89 2 03ar03 10 Tj = 25 °C R DSon (mΩ) 8 a VGS = 3.2 V 1.5 6 3.6 V 1 4V 5V 10 V 4 0.5 2 0 -60 Fig 9. 0 60 120 Tj (°C) 180 Normalized drain-source on-state resistance factor as a function of junction temperature 03ar07 10 VGS ID = 25 A (V) 0 80 160 ID (A) 240 Fig 10. Drain-source on-state resistance as a function of drain current; typical values 03ar06 105 C (pF) Tj = 25 °C 8 0 104 C iss 6 14 V VDD = 44 V 4 103 C oss C rss 2 0 102 0 50 100 150 200 Q G (nC) Fig 11. Gate-source voltage as a function of gate charge; typical values PHB191NQ06LT_2 Product data sheet 10−1 1 10 VDS (V) 102 Fig 12. Sub-threshold drain current as a function of gate-source voltage All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 7 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 03ar05 80 VGS = 0 V IS (A) 60 40 175 °C Tj = 25 °C 20 0 0 0.3 0.6 0.9 1.2 VSD (V) Fig 13. Source current as a function of source-drain voltage; typical values PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 8 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 7. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig 14. Package outline SOT404 (D2PAK) PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 9 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHB191NQ06LT_2 20100113 Product data sheet - PHP_PHB191NQ06LT-01 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number PHB191NQ06LT separated from data sheet PHP_PHB191NQ06LT-01. PHP_PHB191NQ06LT-01 20040505 (9397 750 13168) PHB191NQ06LT_2 Product data sheet Product data - All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 - © NXP B.V. 2010. All rights reserved. 10 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the NXP Semiconductors product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. NXP Semiconductors does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PHB191NQ06LT_2 Product data sheet Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 11 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless the data sheet of an NXP Semiconductors product expressly states that the product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. TrenchMOS — is a trademark of NXP B.V. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PHB191NQ06LT_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 13 January 2010 © NXP B.V. 2010. All rights reserved. 12 of 13 PHB191NQ06LT NXP Semiconductors N-channel TrenchMOS logic level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 13 January 2010 Document identifier: PHB191NQ06LT_2
PHB191NQ06LT,118 价格&库存
很抱歉,暂时无法提供与“PHB191NQ06LT,118”相匹配的价格&库存,您可以联系我们找货
