PSMN015-100P,127
PSMN015-100P,127
    NEXPERIA(安世)
    TO-220AB
    MOSFETs 100V 300W DIP TO220AB 75A N-Channel
PSMN015-100P,127 数据手册
PSMN015-100P N-channel TrenchMOS SiliconMAX standard level FET Rev. 06 — 17 December 2009 Product data sheet 1. Product profile 1.1 General description SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Rated for avalanche ruggedness 1.3 Applications „ DC-to-DC convertors „ Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 and 3 - - 75 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 300 W VGS = 10 V; ID = 75 A; VDS = 80 V; Tj = 25 °C; see Figure 11 - 35 - nC VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 9 and 10 - 12 15 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number PSMN015-100P Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 60.8 A VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3 - 75 A - 240 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 300 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 75 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 240 A - 320 mJ Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 36 A; Vsup ≤ 50 V; drain-source avalanche unclamped; tp = 0.11 ms; RGS = 50 Ω energy © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 2 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03an67 120 Pder (%) Ider (%) 80 80 40 40 0 Fig 1. 03aa16 120 0 50 100 150 0 200 Tmb (°C) 0 50 100 150 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 03am53 103 ID (A) Limit R DSon = VDS /ID t p = 10 μs 102 100 μ s DC 10 1 ms 10 ms 1 1 10 102 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 3 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 0.5 K/W Rth(j-a) thermal resistance from junction to ambient vertical in still air - 60 - K/W 03am52 10 Zth(j-mb) (K/W) 1 δ = 0.5 10−1 0.2 0.1 0.05 10−2 δ= P 0.02 tp T single pulse t tp 10−3 10−5 T 10−4 10−3 10−2 10−1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 4 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 89 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 100 - - V gate-source threshold voltage ID = 1 mA; VDS= VGS; Tj = 175 °C; see Figure 8 1 - - V ID = 1 mA; VDS= VGS; Tj = -55 °C; see Figure 8 - - 4.4 V ID = 1 mA; VDS= VGS; Tj = 25 °C; see Figure 8 2 3 4 V drain leakage current VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C; see Figure 9 - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C; see Figure 9 - 2 100 nA RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 175 °C; see Figure 9 and 10 - 32.4 40.5 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 9 and 10 - 12 15 mΩ Dynamic characteristics QG(tot) total gate charge ID = 75 A; VDS = 80 V; VGS = 10 V; Tj = 25 °C; see Figure 11 - 90 - nC QGS gate-source charge ID = 75 A; VDS = 80 V; VGS = 10 V; see Figure 11 - 20 - nC QGD gate-drain charge ID = 75 A; VDS = 80 V; VGS = 10 V; Tj = 25 °C; see Figure 11 - 35 - nC Ciss input capacitance Coss output capacitance VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 12 Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) tf - 4900 - pF - 390 - pF - 220 - pF - 25 - ns - 65 - ns turn-off delay time - 95 - ns fall time - 50 - ns VDS = 50 V; RL = 1.8 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 13 - 0.8 1.1 V trr reverse recovery time - 80 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 115 - nC © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 5 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03am54 50 Tj = 25 °C ID 03am56 80 10 V 6 V 5.6 V 5.4 V VDS > ID x R DSon ID (A) (A) 40 5.2 V 30 60 5V 40 4.8 V 20 4.6 V 20 10 175 °C 4.4 V Tj = 25 °C VGS = 4.2 V 0 Fig 5. 0 0.2 0.4 0.6 0 0.8 1 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 0 Fig 6. 03aa35 10−1 ID (A) 4 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa32 5 VGS(th) (V) min 10−2 typ max 4 10−3 3 10−4 2 10−5 1 10−6 0 2 4 0 −60 6 VGS (V) Fig 7. 2 Sub-threshold drain current as a function of gate-source voltage Fig 8. typ min 0 60 120 180 Tj (°C) Gate-source threshold voltage as a function of junction temperature © PSMN015-100P_6 Product data sheet max Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 6 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03am55 30 03al21 3 VGS = 5 V Tj = 25 °C R DSon (mΩ) a 5.2 V 2 20 5.4 V 5.6 V 6V 10 V 10 1 0 0 10 20 30 40 0 -60 50 0 60 120 I D (A) Fig 9. Drain-source on-state resistance as a function of drain current; typical values 03am59 10 VGS (V) 180 Tj (°C) Fig 10. Normalized drain-source on-state resistance factor as a function of junction temperature 03am58 104 ID = 75 A Tj = 25 °C 8 C (pF) VDD = 20 V C iss 80 V 6 103 4 C oss 2 C rss 102 0 0 25 50 75 100 Q G (nC) Fig 11. Gate-source voltage as a function of gate charge; typical values 10−1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values © PSMN015-100P_6 Product data sheet 1 Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 7 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03am57 100 VGS = 0 V IS (A) 75 50 25 175 °C 0 0 0.3 Tj = 25 °C 0.6 0.9 1.2 VSD (V) Fig 13. Source current as a function of source-drain voltage; typical values © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 8 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 14. Package outline SOT78 (TO-220AB) © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 9 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN015-100P_6 20091217 - Modifications: Product data sheet PSMN015_100P_100B-05 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number PSMN015-100P separated from data sheet PSMN015_100P_100B-05. PSMN015_100P_100B-05 20040114 Product data - PSMN015-100_SERIES_4 20030601 Product specification - PSMN015-100_SERIES_HG_3 PSMN015-100_SERIES_HG_3 20000328 Product specification - PSMN015-100_SERIES_2 PSMN015-100_SERIES_2 19990801 Product specification - PSMN015-100_SERIES_1 PSMN015-100_SERIES_1 19990201 Product specification - - © PSMN015-100P_6 Product data sheet PSMN015-100_SERIES_4 Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 10 of 12 PSMN015-100P Nexperia N-channel TrenchMOS SiliconMAX standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft— The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet— A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General— Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes— Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use— Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications— Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data— The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values— Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale— Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license— Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control— This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit:http://www.nexperia.com For sales office addresses, please send an email to:salesaddresses@nexperia.com © PSMN015-100P_6 Product data sheet Rev. 06 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia PSMN015-100P N-channel TrenchMOS SiliconMAX standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 December 2009
PSMN015-100P,127 价格&库存
很抱歉,暂时无法提供与“PSMN015-100P,127”相匹配的价格&库存,您可以联系我们找货
