PSMN1R5-30BLEJ
PSMN1R5-30BLEJ
    NEXPERIA(安世)
    SOT404
    MOS管 N-channel Id=120A VDS=30V SOT404
PSMN1R5-30BLEJ 数据手册
PSMN1R5-30BLE N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 12 October 2012 Product data sheet 1. Product profile 1.1 General description Logic level N-channel MOSFET in D2PAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits • Enhanced forward biased safe operating area for superior linear mode operation • Very low Rdson for low conduction losses 1.3 Applications • Electronic fuse • Hot swap • Load switch • Soft start 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 30 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 1 - - 120 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 401 W VGS = 10 V; ID = 25 A; Tj = 25 °C; - 1.3 1.5 mΩ - 1.7 1.85 mΩ - 33.2 - nC - 228 - nC [1] Static characteristics RDSon drain-source on-state resistance Fig. 12 VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 12 Dynamic characteristics QGD gate-drain charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; Fig. 14; Fig. 15 QG(tot) total gate charge VGS = 10 V; ID = 25 A; VDS = 15 V; Fig. 14; Fig. 15 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK Symbol Parameter Conditions Min Typ Max Unit VGS = 10 V; Tj(init) = 25 °C; ID = 120 A; - - 1990 mJ Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy [1] Vsup ≤ 30 V; unclamped; RGS = 50 Ω; Fig. 3 Capped at 120A due to package 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain[1] 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 2 1 S 3 D2PAK (SOT404) [1] It is not possible to make connection to pin 2. 3. Ordering information Table 3. Ordering information Type number Package PSMN1R5-30BLE Name Description Version D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) 4. Marking Table 4. Marking codes Type number Marking code PSMN1R5-30BLE PSMN1R5-30BLE 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 30 V VDGR drain-gate voltage Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ - 30 V PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 2 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK Symbol Parameter Conditions VGS gate-source voltage ID drain current Min Max Unit -20 20 V VGS = 10 V; Tmb = 100 °C; Fig. 1 [1] - 120 A VGS = 10 V; Tmb = 25 °C; Fig. 1 [1] - 120 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 4 - 1521 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 401 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C - 120 A Source-drain diode IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 1521 A VGS = 10 V; Tj(init) = 25 °C; ID = 120 A; - 1990 mJ [1] Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Vsup ≤ 30 V; unclamped; RGS = 50 Ω; Fig. 3 [1] Capped at 120A due to package 003aaj351 400 ID (A) 03aa16 120 Pder (%) 300 80 200 40 (1) 100 0 0 50 100 150 Tmb (° C) (1) Capped at 120A due to package Fig. 1. 0 200 Fig. 2. Continuous drain current as a function of mounting base temperature PSMN1R5-30BLE Product data sheet 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 12 October 2012 50 © Nexperia B.V. 2017. All rights reserved 3 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 003aaj359 103 IAL(A) 102 (1) (2) 10 10-3 Fig. 3. 10-2 10-1 1 tAL(ms) 10 Single pulse avalanche rating; avalanche current as a function of avalanche time 003aaj352 104 ID (A) Limit RDSon = VDS / ID 103 100 µ s tp =10 µ s 102 1 ms DC 10 ms 10 100 ms 1 10-1 Fig. 4. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 5 - 0.3 0.37 K/W Rth(j-a) thermal resistance from junction to ambient minimum footprint; FR4 board - 50 - K/W PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 4 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 003aaj353 1 Zth(j-mb) (K/W) 10 δ = 0.5 -1 0.2 0.1 0.05 10 -2 P 0.02 tp single shot 10-3 10-6 Fig. 5. 10-5 10-4 10-3 10-2 tp T δ= t T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; 0.5 - - V 1.3 1.7 2.15 V - - 2.45 V VDS = 30 V; VGS = 0 V; Tj = 25 °C - 0.5 10 µA VDS = 30 V; VGS = 0 V; Tj = 100 °C - - 200 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; - 1.3 1.5 mΩ - - 2.1 mΩ - 1.7 1.85 mΩ - - 2.9 mΩ Static characteristics V(BR)DSS VGS(th) drain-source breakdown voltage gate-source threshold voltage Fig. 10 ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 11; Fig. 10 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 10 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 12 VGS = 10 V; ID = 25 A; Tj = 100 °C; Fig. 12; Fig. 13 VGS = 4.5 V; ID = 25 A; Tj = 25 °C; Fig. 12 VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 12; Fig. 13 PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 5 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK Symbol Parameter Conditions Min Typ Max Unit RG internal gate resistance (AC) f = 1 MHz 0.5 1.1 2.2 Ω ID = 25 A; VDS = 15 V; VGS = 10 V; - 228 - nC - 108 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 210 - nC gate-source charge ID = 25 A; VDS = 15 V; VGS = 4.5 V; - 31.8 - nC QGS(th) pre-threshold gatesource charge Fig. 14; Fig. 15 - 21.5 - nC QGS(th-pl) post-threshold gatesource charge - 10.3 - nC QGD gate-drain charge - 33.2 - nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 15 V; Fig. 14; Fig. 15 - 2.5 - V Ciss input capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; - 14934 - pF Coss output capacitance Tj = 25 °C; Fig. 16 - 2741 - pF Crss reverse transfer capacitance - 1168 - pF td(on) turn-on delay time VDS = 15 V; RL = 0.6 Ω; VGS = 4.5 V; - 100.6 - ns tr rise time RG(ext) = 4.7 Ω; Tj = 25 °C - 156.1 - ns td(off) turn-off delay time - 191.8 - ns tf fall time - 99.2 - ns Dynamic characteristics QG(tot) total gate charge Fig. 14; Fig. 15 ID = 25 A; VDS = 15 V; VGS = 4.5 V; Fig. 14; Fig. 15 QGS Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 17 - 0.78 1.2 V trr reverse recovery time IS = 25 A; dIS/dt = 100 A/µs; VGS = 0 V; - 62.5 - ns Qr recovered charge VDS = 15 V - 96.8 - nC PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 6 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 003aaj354 75 3 3.5 ID (A) 2.8 RDSon (mΩ ) 4.5 10 60 4 45 3 2.6 30 2 15 0 Fig. 6. 1 2.4 VGS (V) = 2.2 0 0.5 1 VDS(V) 0 1.5 Output characteristics; drain current as a Fig. 7. function of drain-source voltage; typical values 003aaj356 250 gfs (S) 4 8 12 VGS (V) 16 003aaj357 250 ID (A) 200 150 150 100 100 50 50 Fig. 8. 0 Drain-source on-state resistance as a function of gate-source voltage; typical values 200 0 003aaj355 5 0 25 50 75 ID (A) 0 100 Forward transconductance as a function of drain current; typical values PSMN1R5-30BLE Product data sheet Fig. 9. Tj = 175 ° C 0 2 3 VGS (V) 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 12 October 2012 1 Tj = 25 °C © Nexperia B.V. 2017. All rights reserved 7 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 003aaj515 3 003aaj514 10-1 ID (A) VGS(th) (V) 10-2 max 2 typ min 10-3 max typ 10-4 min 1 10-5 0 -60 0 60 120 Tj (°C) 10-6 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature 20 RDSon (mΩ ) 1 2 V GS (V) 003aag820 2 2.8 3 Fig. 11. Sub-threshold drain current as a function of gate-source voltage 003aaj358 VGS GS (V) = 2.6 0 a 16 1.5 12 1 8 4 0 20 3 3.5 4.5 10 40 60 80 ID (A) 0.5 0 -60 100 Fig. 12. Drain-source on-state resistance as a function of drain current; typical values PSMN1R5-30BLE Product data sheet 0 60 120 Tj (°C) 180 Fig. 13. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 8 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 003aai322 10 VDS VGS (V) ID 7.5 6V VGS(pl) 24 V VGS(th) 5 VGS QGS1 QGS2 QGS VDS = 15V 2.5 QGD QG(tot) 003aaa508 0 Fig. 14. Gate charge waveform definitions 0 60 120 180 Q (nC) 240 G Fig. 15. Gate-source voltage as a function of gate charge; typical values 003aai323 105 C (pF) 003aaj361 120 IS (A) 100 80 Ciss 104 60 40 Coss Tj = 150° C Tj = 25 ° C 20 C rss 10 3 10-1 1 10 VDS (V) 0 102 0 0.3 0.6 0.9 VSD (V) 1.2 Fig. 16. Input, output and reverse transfer capacitances Fig. 17. Source current as a function of source-drain as a function of drain-source voltage; typical voltage; typical values values PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 9 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 8. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 1 Lp 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig. 18. Package outline D2PAK (SOT404) PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 10 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 9. Legal information 9.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN1R5-30BLE Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 11 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 12 / 13 PSMN1R5-30BLE Nexperia N-channel 30 V 1.5 mΩ logic level MOSFET in D2PAK 10. Contents 1 1.1 1.2 1.3 1.4 Product profile ....................................................... 1 General description .............................................. 1 Features and benefits ...........................................1 Applications .......................................................... 1 Quick reference data ............................................ 1 2 Pinning information ............................................... 2 3 Ordering information ............................................. 2 4 Marking ................................................................... 2 5 Limiting values .......................................................2 6 Thermal characteristics .........................................4 7 Characteristics ....................................................... 5 8 Package outline ................................................... 10 9 9.1 9.2 9.3 9.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 October 2012 PSMN1R5-30BLE Product data sheet All information provided in this document is subject to legal disclaimers. 12 October 2012 © Nexperia B.V. 2017. All rights reserved 13 / 13
PSMN1R5-30BLEJ
物料型号:PSMN1R5-30BLE
器件简介: - 这是一款逻辑电平N沟道MOSFET,封装在D2PAK中,适用于工业、通信和家用电器的广泛应用。
引脚分配: - 1G:栅极 - 2D:漏极[1] - 3S:源极 - mb:安装底座;连接到漏极
参数特性: - 漏源电压(VDS):最高30V - 漏极电流(ID):最大120A - 总功耗(Ptot):最高401W - 栅源电压(VGS):-20V至20V - 存储温度(Tstg):-55°C至175°C - 结温(Tj):-55°C至175°C - 峰值焊接温度(Tsld(M)):-260°C
功能详解: - 增强的正向偏置安全工作区,提供优越的线性模式操作。 - 极低的导通电阻(Rdson),降低导通损耗。
应用信息: - 电子保险丝 - 热插拔 - 负载开关 - 软启动
封装信息: - D2PAK (SOT404)塑料单端表面贴装封装;3个引脚(一个引脚被裁剪)。
PSMN1R5-30BLEJ 价格&库存
很抱歉,暂时无法提供与“PSMN1R5-30BLEJ”相匹配的价格&库存,您可以联系我们找货
PSMN1R5-30BLEJ
  • 1+41.59287
  • 10+37.42733
  • 100+34.51146
库存:800
PSMN1R5-30BLEJ
  • 1+46.567051+6.05357
  • 10+30.8701410+4.01302
  • 50+24.1459750+3.13890
  • 100+21.97974100+2.85730
库存:11271
PSMN1R5-30BLEJ
  • 800+17.33742800+2.25381
  • 2400+15.850892400+2.06057
库存:11271
PSMN1R5-30BLEJ
    PSMN1R5-30BLEJ
    • 1+33.41862
    • 5+30.81939
    • 10+28.67533
    PSMN1R5-30BLEJ
      • 1+12.85200
      • 10+11.76120
      • 30+11.09160
      • 100+10.38960
      • 500+10.07640
      • 800+9.93600
      库存:154
      PSMN1R5-30BLEJ
      • 1+35.987051+4.67820
      • 5+33.118525+4.30530
      • 10+30.8584610+4.01150
