PMPB12UNE
20 V, N-channel Trench MOSFET
12 April 2016
Product data sheet
1. General description
N-channel enhancement mode Field-Effect Transistor (FET) in a leadless medium power
DFN2020MD-6 (SOT1220) Surface-Mounted Device (SMD) plastic package using
Trench MOSFET technology.
2. Features and benefits
Low threshold voltage
Exposed drain pad for excellent thermal conduction
Tin-plated 100% solderable side pads for optical solder inspection
ElectroStatic Discharge (ESD) protection > 1 kV HBM
3. Applications
LED driver
Power management
Low-side loadswitch
Switching circuits
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
V
VGS
gate-source voltage
-12
12
V
ID
drain current
11.4
A
12
16
mΩ
VGS = 4.5 V; Tamb = 25 °C; t ≤ 5 s
[1]
Static characteristics
RDSon
drain-source on-state
resistance
[1]
VGS = 4.5 V; ID = 7.9 A; Tj = 25 °C
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm .
PMPB12UNE
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
D
drain
2
D
drain
3
G
gate
4
S
source
5
D
drain
6
D
drain
7
D
drain
8
S
source
Simplified outline
1
Graphic symbol
D
6
7
2
3
8
5
G
4
Transparent top view
S
017aaa255
6. Ordering information
Table 3.
Type number
Package
Name
PMPB12UNE
Description
Version
DFN2020MD-6 DFN2020MD-6: plastic thermal enhanced ultra thin
small outline package; no leads; 6 terminals
SOT1220
7. Marking
Table 4.
Marking codes
Type number
Marking code
PMPB12UNE
2Y
PMPB12UNE
Product data sheet
All information provided in this document is subject to legal disclaimers.
12 April 2016
Nexperia B.V. 2017. All rights reserved
2 / 16
PMPB12UNE
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
V
VGS
gate-source voltage
-12
12
V
ID
drain current
[1]
11.4
A
[1]
7.9
A
VGS = 4.5 V; Tamb = 100 °C
[1]
5
A
32
A
IDM
peak drain current
Tamb = 25 °C; single pulse; tp ≤ 10 µs
Ptot
total power dissipation
Tamb = 25 °C
[2]
470
mW
[1]
1.56
W
12.5
W
Tsp = 25 °C
Tj
junction temperature
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
1.5
A
Source-drain diode
IS
source current
[1]
[2]
Tamb = 25 °C
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
017aaa123
120
Pder
017aaa124
120
Ider
80
80
40
40
Fig. 1.
[1]
- 25
25
75
125
Tj (°C)
Normalized total power dissipation as a
function of junction temperature
PMPB12UNE
Product data sheet
175
Fig. 2.
- 25
75
125
Tj (°C)
175
Normalized continuous drain current as a
12 April 2016
25
3 / 16
PMPB12UNE
Nexperia
aaa-022399
102
Limit RDSon = VDS/ID
ID
(A)
tp = 10 µs
10
100 µs
1 ms
1
DC; Tsp = 25 °C
10-1
10-2
10-1
Fig. 3.
10 ms
100 ms
DC; Tamb = 25 °C;
drain mounting pad 6 cm2
1
10
102
VDS (V)
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
PMPB12UNE
Product data sheet
12 April 2016
4 / 16
PMPB12UNE
Nexperia
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
in free air; t ≤ 5 s
thermal resistance
from junction to solder
point
[1]
[2]
Min
Typ
Max
Unit
[1]
230
265
K/W
[2]
70
80
K/W
[2]
34
39
K/W
5
10
K/W
aaa-022400
103
Zth(j-a)
(K/W)
2
duty cycle = 1
0.75
102
0.33
0.20
0.50
0.25
0.10
10
0.05
0.01
0.02
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PMPB12UNE
Product data sheet
12 April 2016
5 / 16
PMPB12UNE
Nexperia
aaa-022401
102
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.33
0.20
10
0.50
0.25
0.10
0.05
0.02
0.01
10-3
10-2
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 5.
1
10
102
tp (s)
103
2
PMPB12UNE
Product data sheet
12 April 2016
6 / 16
PMPB12UNE
Nexperia
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
V
VGSth
gate-source threshold
voltage
ID = 250 µA; VDS=VGS; Tj = 25 °C
0.4
0.65
0.9
V
IDSS
drain leakage current
VDS = 20 V; VGS = 0 V; Tj = 25 °C
1
µA
IGSS
gate leakage current
VGS = 8 V; VDS = 0 V; Tj = 25 °C
10
µA
VGS = -8 V; VDS = 0 V; Tj = 25 °C
-10
µA
VGS = 4.5 V; VDS = 0 V; Tj = 25 °C
1
µA
VGS = -4.5 V; VDS = 0 V; Tj = 25 °C
-1
µA
VGS = 2.5 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -2.5 V; VDS = 0 V; Tj = 25 °C
-100
nA
12
16
mΩ
VGS = 4.5 V; ID = 7.9 A; Tj = 150 °C
19
25
mΩ
VGS = 2.5 V; ID = 7.1 A; Tj = 25 °C
15
mΩ
VGS = 1.8 V; ID = 1.9 A; Tj = 25 °C
mΩ
RDSon
resistance
gfs
forward
transconductance
VDS = 10 V; ID = 7.9 A; Tj = 25 °C
18
S
RG
gate resistance
f = 1 MHz
1.8
Ω
total gate charge
VDS = 10 V; ID = 6 A; VGS = 4.5 V;
10.9
17
nC
QGS
gate-source charge
Tj = 25 °C
1.3
nC
QGD
gate-drain charge
2.1
nC
Ciss
input capacitance
VDS = 10 V; f = 1 MHz; VGS = 0 V;
1220
pF
Coss
output capacitance
Tj = 25 °C
124
pF
Crss
reverse transfer
capacitance
102
pF
td(on)
turn-on delay time
10
ns
tr
rise time
RG(ext) = 6 Ω; Tj = 25 °C
24
ns
td(off)
turn-off delay time
32
ns
tf
fall time
34
ns
0.7
1.2
V
Dynamic characteristics
QG(tot)
Source-drain diode
VSD
source-drain voltage
PMPB12UNE
Product data sheet
IS = 1.5 A; VGS = 0 V; Tj = 25 °C
12 April 2016
7 / 16
PMPB12UNE
Nexperia
aaa-022402
35
ID
(A)
30
aaa-022403
10-3
4.5 V
ID
(A)
2.5 V
1.8 V
25
10-4
1.6 V
15
1.5 V
10
Fig. 6.
max
VGS = 1.4 V
5
typ
min
10-5
2
3
4
VDS (V)
10-6
5
0.4
0.6
0.8
1
VGS (V)
Tj = 25 °C
Tj = 25 °C; VDS = 5 V
Output characteristics: drain current as a
Fig. 7.
function of drain-source voltage; typical values
Sub-threshold drain current as a function of
gate-source voltage
aaa-022404
80
1.4 V 1.5 V
RDSon
(mΩ)
1.6 V
aaa-022405
70
RDSon
(mΩ)
60
1.8 V
60
50
40
2.0 V
40
Tj = 150 °C
2.5 V
VGS = 4.5 V
10
16
24
ID (A)
Tj = 25 °C
Fig. 8.
Product data sheet
2
3
4
VGS (V)
5
ID = 5.7 A
Drain-source on-state resistance as a function
of drain current; typical values
PMPB12UNE
Tj = 25 °C
Fig. 9.
of gate-source voltage; typical values
12 April 2016
8 / 16
PMPB12UNE
Nexperia
aaa-022406
30
aaa-022407
2.0
a
ID
(A)
1.5
Tj = 150 °C
10
0.5
Tj = 25 °C
2
VGS (V)
3
VDS > ID × RDSon
Fig. 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
VGS(th)
(V)
0.8
60
120
180
aaa-022409
104
max
Tj (°C)
Fig. 11. Normalized drain-source on-state resistance
as a function of junction temperature; typical
values
aaa-022408
1.2
C
(pF)
typ
Ciss
103
min
120
Tj (°C)
10
10-1
180
ID = 0.25 mA; VDS = VGS
Product data sheet
Crss
1
10
VDS (V)
102
Fig. 12. Gate-source threshold voltage as a function of
PMPB12UNE
Coss
102
0.4
Fig. 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
12 April 2016
9 / 16
PMPB12UNE
Nexperia
aaa-022410
5
VDS
VGS
(V)
ID
4
VGS(pl)
3
VGS(th)
VGS
2
QGS1
1
QGS2
4
6
8
QGS
QGD
QG(tot)
003aaa508
Fig. 15. Gate charge waveform definitions
10
QG (nC)
ID = 6 A; VDS = 10 V; Tamb = 25 °C
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
aaa-022411
6
IS
(A)
4
Tj = 150 °C
2
Tj = 25 °C
8
VSD (V)
1.2
VGS = 0 V
Fig. 16. Source current as a function of source-drain voltage; typical values
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 17. Duty cycle definition
PMPB12UNE
Product data sheet
12 April 2016
10 / 16
PMPB12UNE
Nexperia
12. Package outline
DFN2020MD-6: plastic thermal enhanced ultra thin small outline package; no leads;
6 terminals; body 2 x 2 x 0.65 mm
SOT1220
(8×)
pin 1
index area
B
E
A
X
D
A
A1
detail X
solderable lead
end protrusion
max. 0.02 mm (6×)
C
Lp
E2
J1
D2 3
4
2
5
e
J
D1
bp (6×)
e
1
v
E1
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
A
A1
bp
min
0.25
nom
max 0.65 0.04 0.35
D
D1
D2
E
E1
E2
1.9
1.0
0.2
1.9
1.1
0.51
2.1
1.2
0.3
2.1
1.3
0.61
e
J
J1
0.65 0.27 0.64
Lp
0.2
0.3
v
y
y1
0.1
0.05
0.1
Note
1. Dimension A is including plating thickness.
Outline
version
A B
6
pin 1
index area
mm
y
y1 C
sot1220_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
12-04-23
12-04-30
SOT1220
Fig. 18. Package outline DFN2020MD-6 (SOT1220)
PMPB12UNE
Product data sheet
12 April 2016
11 / 16
PMPB12UNE
Nexperia
13. Soldering
Footprint information for reflow soldering of DFN2020MD-6 package
0.33 (6×)
SOT1220
0.76
0.43 (6×)
0.66
0.53 (6×)
0.56
0.25 0.35 0.45
0.775
0.65
2.06
0.285
1.25
1.35
0.35 (6×)
1.05
0.25 (6×)
0.65
0.45 (6×)
0.9
1.1
1.2
0.935
0.935
2.5
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sot1220_fr
Fig. 19. Reflow soldering footprint for DFN2020MD-6 (SOT1220)
PMPB12UNE
Product data sheet
12 April 2016
12 / 16
PMPB12UNE
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMPB12UNE v.1
20160412
Product data sheet
PMPB12UNE
Product data sheet
12 April 2016
13 / 16
PMPB12UNE
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PMPB12UNE
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
12 April 2016
14 / 16
PMPB12UNE
Nexperia
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PMPB12UNE
Product data sheet
12 April 2016
15 / 16
PMPB12UNE
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Thermal characteristics .........................................5
10
Characteristics ....................................................... 7
11
Test information ................................................... 10
12
Package outline ................................................... 11
13
Soldering .............................................................. 12
14
Revision history ................................................... 13
15
15.1
15.2
15.3
15.4
Legal information .................................................14
Data sheet status ............................................... 14
Definitions ...........................................................14
Disclaimers .........................................................14
Trademarks ........................................................ 15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 April 2016
PMPB12UNE
Product data sheet
12 April 2016
16 / 16
