PMV33UPE
20 V, single P-channel Trench MOSFET
Rev. 1 — 12 June 2012
Product data sheet
1. Product profile
1.1 General description
P-channel enhancement mode Field-Effect Transistor (FET) in a small SOT23
(TO-236AB) Surface-Mounted Device (SMD) plastic package using Trench MOSFET
technology.
1.2 Features and benefits
Low threshold voltage
Trench MOSFET technology
Very fast switching
2 kV ESD protected
1.3 Applications
Relay driver
High-side loadswitch
High-speed line driver
Switching circuits
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
-20
V
VGS
gate-source voltage
-8
8
V
-5.3
A
30
36
mΩ
drain current
ID
VGS = -4.5 V; Tamb = 25 °C; t ≤ 5 s
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
VGS = -4.5 V; ID = -3 A; Tj = 25 °C
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm2.
PMV33UPE
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
S
source
3
D
drain
Simplified outline
Graphic symbol
D
3
1
2
G
SOT23 (TO-236AB)
S
017aaa259
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
PMV33UPE
TO-236AB
plastic surface-mounted package; 3 leads
SOT23
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PMV33UPE
EJ%
[1]
% = placeholder for manufacturing site code
PMV33UPE
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
PMV33UPE
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
-20
V
VGS
gate-source voltage
drain current
ID
total power dissipation
Ptot
8
V
-5.3
A
[1]
-4.4
A
VGS = -4.5 V; Tamb = 100 °C
[1]
-2.8
A
Tamb = 25 °C; single pulse; tp ≤ 10 µs
peak drain current
IDM
-8
[1]
Tamb = 25 °C
-17.6
A
[2]
490
mW
[1]
980
mW
4150
mW
-55
150
°C
Tsp = 25 °C
Tj
junction temperature
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
Source-drain diode
source current
IS
Tamb = 25 °C
[1]
-1.2
A
HBM
[3]
2000
V
ESD maximum rating
electrostatic discharge voltage
VESD
[1]
[2]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
[3]
Measured between all pins.
017aaa123
120
Pder
Ider
80
80
40
40
−75
Fig 1.
017aaa124
120
−25
25
75
125
Tj (°C)
Normalized total power dissipation as a
function of junction temperature
PMV33UPE
Product data sheet
−75
175
Fig 2.
−25
25
75
125
175
Tj (°C)
Normalized continuous drain current as a
3 of 15
PMV33UPE
Nexperia
017aaa601
-102
Limit RDSon = VDS/ID
ID
(A)
-10
tp = 1 ms
tp = 10 ms
-1
tp = 100 ms
DC; Tsp = 25 °C
-10-1
DC; Tamb = 25 °C;
drain mounting pad 6 cm2
-10-2
-102
-10
VDS (V)
IDM = single pulse
Fig 3.
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drain-source
voltage
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
Min
Typ
Max
Unit
[1]
222
255
K/W
[2]
111
128
K/W
[3]
74
85
K/W
25
30
K/W
thermal resistance
from junction to solder
point
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm2.
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm2, t ≤ 5 s.
PMV33UPE
Product data sheet
4 of 15
PMV33UPE
Nexperia
017aaa602
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
102
0.33
0.25
0.2
0.1
10
0.05
0.02
0.01
10-3
10-2
10-1
1
10
102
103
tp (s)
FR4 PCB, standard footprint
Fig 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
017aaa603
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.25
0.2
0.1
10
0.05
0.02
10-3
0.01
10-2
10-1
1
10
102
103
tp (s)
FR4 PCB, mounting pad for drain 6 cm2
Fig 5.
PMV33UPE
Product data sheet
5 of 15
PMV33UPE
Nexperia
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = -250 µA; VGS = 0 V; Tj = 25 °C
-20
V
VGSth
gate-source threshold
voltage
ID = -250 µA; VDS = VGS; Tj = 25 °C
-0.45
-0.7
-0.95
V
IDSS
drain leakage current
VDS = -20 V; VGS = 0 V; Tj = 25 °C
-1
µA
VDS = -20 V; VGS = 0 V; Tj = 150 °C
-15
µA
IGSS
gate leakage current
VGS = -8 V; VDS = 0 V; Tj = 25 °C
-10
µA
VGS = 8 V; VDS = 0 V; Tj = 25 °C
-10
µA
30
36
mΩ
RDSon
gfs
resistance
forward
transconductance
VGS = -4.5 V; ID = -3 A; Tj = 150 °C
43
51
mΩ
VGS = -2.5 V; ID = -3 A; Tj = 25 °C
38
47
mΩ
VGS = -1.8 V; ID = -3 A; Tj = 25 °C
51
65
mΩ
VDS = -10 V; ID = -4.4 A; Tj = 25 °C
16
S
VDS = -10 V; ID = -4.4 A; VGS = -4.5 V;
Tj = 25 °C
14.7
22.1
nC
2.6
nC
2.5
nC
VDS = -10 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
1820
pF
208
pF
146
pF
11
ns
30
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
83
ns
tf
fall time
39
ns
-0.7
-1.2
V
RG(ext) = 6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
PMV33UPE
Product data sheet
IS = -1.2 A; VGS = 0 V; Tj = 25 °C
6 of 15
PMV33UPE
Nexperia
017aaa604
-20
-4.5 V
ID
(A)
-2.5 V
-2.2 V
017aaa143
–10–3
VGS = -2 V
ID
(A)
-3 V
-15
–10–4
-1.8 V
(1)
(2)
(3)
-10
-1.6 V
–10–5
-5
-1.4 V
-1.2 V
-2
-3
-4
–10–6
–0.2
–0.4
–0.6
–0.8
VDS (V)
–1.0
VGS (V)
Tj = 25 °C
Tj = 25 °C; VDS = -3 V
(1) minimum values
(2) typical values
(3) maximum values
Fig 6.
Output characteristics: drain current as a
function of drain-source voltage; typical values
120
017aaa605
-1.4 V
-1.6 V
-1.8 V
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
017aaa606
120
-2.0 V
RDSon
(mΩ)
RDSon
(mΩ)
80
80
Tj = 150 °C
-2.5 V
40
40
-3.0 V
VGS = -4.5 V
Tj = 25 °C
-10
-15
-20
-4
-6
ID (A)
VGS (V)
Tj = 25 °C
Fig 8.
ID = -4.4 A
Drain-source on-state resistance as a function
of drain current; typical values
PMV33UPE
Product data sheet
Fig 9.
of gate-source voltage; typical values
7 of 15
PMV33UPE
Nexperia
017aaa607
-18
017aaa608
1.50
a
ID
(A)
1.25
-12
1.00
-6
0.75
Tj = 150 °C
Tj = 25 °C
-1.0
-1.5
-2.0
-2.5
VGS (V)
0.50
-60
120
180
Tj (°C)
VDS > ID × RDSon
Fig 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
017aaa609
-1.2
Fig 11. Normalized drain-source on-state resistance as
a function of junction temperature; typical
values
017aaa610
104
C
(pF)
VGS(th)
(V)
Ciss
max
103
-0.8
typ
Coss
-0.4
min
Crss
102
10
120
180
-102
-10
Tj (°C)
VDS (V)
ID = -0.25 mA; VDS = VGS
Fig 12. Gate-source threshold voltage as a function of
PMV33UPE
Product data sheet
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
8 of 15
PMV33UPE
Nexperia
017aaa611
-5
VDS
VGS
(V)
ID
-4
VGS(pl)
-3
VGS(th)
VGS
-2
QGS1
QGS2
QGS
-1
QGD
QG(tot)
017aaa137
10
15
QG (nC)
ID = −4.4 A; VDS = −10 V; Tamb = 25 °C
Fig 14. Gate-source voltage as a function of gate
charge; typical values
Fig 15. Gate charge waveform definitions
017aaa612
-5
IS
(A)
-4
-3
-2
Tj = 150 °C
-1
Tj = 25 °C
-0.4
-0.6
-0.8
-1.0
VSD (V)
VGS = 0 V
Fig 16. Source current as a function of source-drain voltage; typical values
PMV33UPE
Product data sheet
9 of 15
PMV33UPE
Nexperia
8. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig 17. Duty cycle definition
9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
0.15
0.09
04-11-04
Fig 18. Package outline SOT23 (TO-236AB)
PMV33UPE
Product data sheet
10 of 15
PMV33UPE
Nexperia
10. Soldering
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig 19. Reflow soldering footprint for SOT23 (TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig 20. Wave soldering footprint for SOT23 (TO-236AB)
PMV33UPE
Product data sheet
11 of 15
PMV33UPE
Nexperia
11. Revision history
Table 8.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMV33UPE v.1
20120612
Product data sheet
PMV33UPE
Product data sheet
12 of 15
PMV33UPE
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1] [2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with theTerms and conditions of commercial sale of Nexperia.
PMV33UPE
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
13 of 15
PMV33UPE
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
13. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PMV33UPE
Product data sheet
14 of 15
Nexperia
PMV33UPE
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Test information . . . . . . . . . . . . . . . . . . . . . . . . .10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 June 2012
