PSMN6R4-30MLDX
PSMN6R4-30MLDX
    NEXPERIA(安世)
    SOT-1210
    MOS管 N-channel Id=66A VDS=30V SOT1210
PSMN6R4-30MLDX 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia LF PA K 33 PSMN6R4-30MLD N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 11 August 2015 Product data sheet 1. General description Logic level gate drive N-channel enhancement mode MOSFET in LFPAK33 package. NextPowerS3 portfolio utilising NXP’s unique “SchottkyPlus” technology delivers high efficiency, low spiking performance usually associated with MOSFETs with an integrated Schottky or Schottky-like diode but without problematic high leakage current. NextPowerS3 is particularly suited to high efficiency applications at high switching frequencies. 2. Features and benefits • • • • • • • • Ultra low QG, QGD and QOSS for high system efficiency, especially at higher switching frequencies Superfast switching with soft-recovery; s-factor > 1 Low spiking and ringing for low EMI designs Unique “SchottkyPlus” technology; Schottky-like performance with < 1 µA leakage at 25 °C Optimised for 4.5 V gate drive Low parasitic inductance and resistance High reliability clip bonded and solder die attach Mini Power SO8 package; no glue, no wire bonds, qualified to 175 °C Exposed leads for optimal visual solder inspection 3. Applications • • • • • • On-board DC-to-DC solutions for server and telecommunications Secondary-side synchronous rectification in telecommunication applications Voltage regulator modules (VRM) Point-of-Load (POL) modules Power delivery for V-core, ASIC, DDR, GPU, VGA and system components Brushed and brushless motor control Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 30 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 2 - - 66 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 51 W Tj junction temperature -55 - 175 °C Scan or click this QR code to view the latest information for this product PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit VGS = 4.5 V; ID = 15 A; Tj = 25 °C; - 6.9 8.3 mΩ - 5.3 6.3 mΩ - 1.8 - nC - 6.5 - nC - 1.2 - Static characteristics RDSon drain-source on-state resistance Fig. 10 VGS = 10 V; ID = 15 A; Tj = 25 °C; Fig. 10 Dynamic characteristics QGD gate-drain charge VGS = 4.5 V; ID = 15 A; VDS = 15 V; Fig. 12; Fig. 13 QG(tot) total gate charge VGS = 4.5 V; ID = 15 A; VDS = 15 V; Fig. 12; Fig. 13 Source-drain diode S softness factor IS = 15 A; VGS = 0 V; dIS/dt = -100 A/µs; VDS = 15 V; Fig. 16 4. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol D G mbb076 1 2 3 S 4 LFPAK33 (SOT1210) 5. Ordering information Table 3. Ordering information Type number PSMN6R4-30MLD Package Name Description Version LFPAK33 Plastic single ended surface mounted package (LFPAK33); 8 leads SOT1210 6. Marking Table 4. Marking codes Type number Marking code PSMN6R4-30MLD 6D430L PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 2 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 7. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 30 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 30 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 51 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 66 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 47 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 264 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 43 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 264 A - 46.6 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy VGS = 10 V; Tj(init) = 25 °C; ID = 15 A; [1] Vsup ≤ 30 V; RGS = 50 Ω; unclamped; tp = 159 µs [1] PSMN6R4-30MLD Product data sheet Protected by 100% test All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 3 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 03aa16 120 ID (A) Pder (%) aaa-008425 80 60 80 40 40 20 0 Fig. 1. ID (A) 0 50 100 150 Tmb (°C) 0 200 Normalized total power dissipation as a function of mounting base temperature Fig. 2. 0 25 50 75 100 125 150 175 Tmb (°C) 200 Continuous drain current as a function of mounting base temperature aaa-008426 103 Limit RDSon = VDS / ID 102 tp = 10 us 100 us 10 DC 1 ms 10 ms 100 ms 1 10-1 10-1 Fig. 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 8. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 2.72 2.94 K/W PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 4 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient Fig. 5 - 57 - K/W Fig. 6 - 178 - K/W aaa-008427 10 Zth(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10-1 0.02 P single shot δ= tp 10-2 10-6 Fig. 4. 10-5 10-4 10-3 10-2 T t T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration aaa-008477 aaa-008476 Fig. 5. tp PCB layout for thermal resistance junction to ambient 1" square pad; FR4 Board; 2oz copper Fig. 6. PCB layout for thermal resistance junction to ambient minimum footprint; FR4 Board; 2oz copper 9. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C 1.2 1.7 2.2 V Static characteristics V(BR)DSS VGS(th) PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 5 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 150 °C - -3.8 - mV/K IDSS drain leakage current VDS = 24 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 24 V; VGS = 0 V; Tj = 125 °C - 0.45 - µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 15 A; Tj = 25 °C; - 6.9 8.3 mΩ - - 13.7 mΩ - 5.3 6.3 mΩ - - 10.4 mΩ f = 1 MHz - 2.36 - Ω ID = 15 A; VDS = 15 V; VGS = 10 V; - 13.7 - nC - 6.5 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 12.2 - nC IGSS RDSon gate leakage current drain-source on-state resistance Fig. 10 VGS = 4.5 V; ID = 15 A; Tj = 150 °C; Fig. 11; Fig. 10 VGS = 10 V; ID = 15 A; Tj = 25 °C; Fig. 10 VGS = 10 V; ID = 15 A; Tj = 150 °C; Fig. 11; Fig. 10 RG gate resistance Dynamic characteristics QG(tot) total gate charge Fig. 12; Fig. 13 ID = 15 A; VDS = 15 V; VGS = 4.5 V; Fig. 12; Fig. 13 QGS gate-source charge ID = 15 A; VDS = 15 V; VGS = 4.5 V; - 1.7 - nC QGS(th) pre-threshold gatesource charge Fig. 12; Fig. 13 - 1.2 - nC QGS(th-pl) post-threshold gatesource charge - 0.5 - nC QGD gate-drain charge - 1.8 - nC VGS(pl) gate-source plateau voltage ID = 15 A; VDS = 15 V; Fig. 12; Fig. 13 - 2.2 - V Ciss input capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; - 832 - pF Coss output capacitance Tj = 25 °C; Fig. 14 - 587 - pF Crss reverse transfer capacitance - 64 - pF td(on) turn-on delay time VDS = 15 V; RL = 1 Ω; VGS = 4.5 V; - 9 - ns tr rise time RG(ext) = 5 Ω - 16.2 - ns td(off) turn-off delay time - 10.5 - ns tf fall time - 10.9 - ns PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 6 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Qoss output charge VGS = 0 V; VDS = 15 V; f = 1 MHz; - 12.6 - nC Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.8 1.2 V trr reverse recovery time IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V; - 23.4 - ns Qr recovered charge VDS = 15 V; Fig. 16 - 12.6 - nC ta reverse recovery rise time - 10.6 - ns tb reverse recovery fall time - 12.8 - ns S softness factor - 1.2 - [1] ID (A) [1] includes capacitive recovery aaa-008430 60 ID (A) 45 aaa-008428 80 10 V 4.5 V 3.5 V VGS = 3 V 60 2.8 V 30 40 2.6 V 15 150°C 2.4 V 20 Tj = 25°C 2.2 V 0 Fig. 7. 0 0.8 1.6 2.4 3.2 VGS (V) 0 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values PSMN6R4-30MLD Product data sheet Fig. 8. 0 0.5 1.5 2 2.5 VDS (V) 3 Output characteristics; drain current as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 11 August 2015 1 © NXP Semiconductors N.V. 2015. All rights reserved 7 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology aaa-008429 30 RDSon (mΩ) 25 aaa-008431 30 RDSon (mΩ) 2.6 V 2.8 V 3V 24 20 18 15 12 3.5 V 10 4.5 V 6 5 0 Fig. 9. 0 2 4 6 8 10 12 14 VGS (V) 0 16 Drain-source on-state resistance as a function of gate-source voltage; typical values 14 28 42 56 ID (A) 70 Fig. 10. Drain-source on-state resistance as a function of drain current; typical values VDS ID 10 V 1.6 VGS(pl) 1.2 VGS(th) VGS = 4.5 V 0.8 VGS QGS2 QGS1 0.4 0 -60 0 003aal037 2 a VGS = 10 V -30 0 30 60 90 120 150 Tj (°C) QGS QGD QG(tot) 003aaa508 Fig. 12. Gate charge waveform definitions 180 Fig. 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 8 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology VGS (V) aaa-008432 10 aaa-008433 104 C (pF) 8 103 Ciss Coss 6 24 V 15 V 4 102 VDS = 6 V Crss 2 0 0 4 8 12 16 QG (nC) 10 10-1 20 Fig. 13. Gate-source voltage as a function of gate charge; typical values IS (A) 1 10 VDS (V) Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 003aal160 aaa-008434 102 102 ID (A) trr 10 ta tb 0 1 0.25 IRM 150°C 10-1 0 0.2 0.4 Tj = 25°C 0.6 0.8 1 VSD (V) IRM t (s) 1.2 Fig. 15. Source current as a function of source-drain voltage; typical values PSMN6R4-30MLD Product data sheet Fig. 16. Reverse recovery timing definition All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 9 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 10. Package outline Plastic single ended surface mounted package (LFPAK33); 8 leads E e1 L SOT1210 A A c1 b1 E1 mounting base D1 D H 1 4 e b w X A A1 c C θ Lp y C detail X 0 2.5 Dimensions Unit(1) mm 5 mm scale A A1 b b1 c c1 D(1) D1 E(1) E1 e e1 H L Lp w y max 0.90 0.10 0.35 0.35 0.20 0.30 2.70 2.35 3.40 2.45 3.40 0.25 0.50 nom 0.65 0.65 0.20 0.10 3.20 0.13 0.30 min 0.80 0.00 0.25 0.25 0.10 0.20 2.50 1.90 3.20 2.00 Note 1. Plastic or metal protrusions of 0.15 mm per side are not included. Outline version JEDEC 8° 0° sot1210_po References IEC θ JEITA European projection Issue date 11-12-19 12-03-12 SOT1210 Fig. 17. Package outline LFPAK33 (SOT1210) PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 10 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 11. Legal information 11.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 11.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. PSMN6R4-30MLD Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 11 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE, MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP Semiconductors N.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 12 / 13 PSMN6R4-30MLD NXP Semiconductors N-channel 30 V, 6.4 mΩ logic level MOSFET in LFPAK33 using NextPowerS3 Technology 12. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Pinning information ............................................... 2 5 Ordering information ............................................. 2 6 Marking ................................................................... 2 7 Limiting values .......................................................3 8 Thermal characteristics .........................................4 9 Characteristics ....................................................... 5 10 Package outline ................................................... 10 11 11.1 11.2 11.3 11.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © NXP Semiconductors N.V. 2015. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 August 2015 PSMN6R4-30MLD Product data sheet All information provided in this document is subject to legal disclaimers. 11 August 2015 © NXP Semiconductors N.V. 2015. All rights reserved 13 / 13
PSMN6R4-30MLDX
PDF文档中包含的物料型号为PSMN6R4-30MLD。
器件简介指出这是一款Nexperia公司生产的N沟道逻辑级MOSFET,具有低导通电阻和快速开关特性。
引脚分配为1-Drain,2-Source,3-Gate。
参数特性包括最大漏极电流ID(最大值)为30A,最大工作温度TA(最大值)为175°C,最小工作温度TA(最小值)为-55°C,以及漏源电压VDS(最大值)为60V。
功能详解说明了其适用于高效率电源转换、电机控制和电池管理等应用。
应用信息强调了其在高功率密度设计中的优势。
封装信息显示该器件采用PowerPAK 1212-8封装。
PSMN6R4-30MLDX 价格&库存
很抱歉,暂时无法提供与“PSMN6R4-30MLDX”相匹配的价格&库存,您可以联系我们找货
PSMN6R4-30MLDX
  • 1+4.40671
  • 10+3.30473
  • 100+2.97174
PSMN6R4-30MLDX
  • 1+7.953671+1.02877
  • 10+4.9325610+0.63800
  • 100+3.19141100+0.41279
  • 500+2.44229500+0.31590
库存:1439
PSMN6R4-30MLDX
    PSMN6R4-30MLDX
      • 1+8.97480
      • 10+8.82360
      • 30+8.71560
      库存:39
      PSMN6R4-30MLDX
      • 1500+2.077471500+0.26871
      • 3000+1.893553000+0.24492
      • 4500+1.799824500+0.23280
      • 7500+1.694477500+0.21917
      • 10500+1.6320710500+0.21110
      • 15000+1.5714315000+0.20326
      库存:1439
