BUK9Y22-30B,115
BUK9Y22-30B,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=37.7A VDS=30V SOT669
BUK9Y22-30B,115 数据手册
BUK9Y22-30B N-channel TrenchMOS logic level FET Rev. 04 — 7 April 2010 Product data sheet 1. Product profile 1.1 General description Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Suitable for logic level gate drive sources „ Q101 compliant „ Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications „ 12 V loads „ General purpose power switching „ Automotive systems „ Motors, lamps and solenoids 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 30 ID drain current VGS = 5 V; Tmb = 25 °C; see Figure 1; see Figure 4 - - 37.7 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 59.4 W VGS = 5 V; ID = 20 A; Tj = 25 °C; see Figure 12; see Figure 13 - 17 22 mΩ VGS = 10 V; ID = 20 A; Tj = 25 °C - 13.5 19 mΩ V Static characteristics RDSon drain-source on-state resistance BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit - - 47 mJ - 4.5 - nC Avalanche ruggedness EDS(AL)S non-repetitive ID = 37.7 A; Vsup ≤ 30 V; drain-source RGS = 50 Ω; VGS = 5 V; avalanche energy Tj(init) = 25 °C; unclamped Dynamic characteristics QGD gate-drain charge VGS = 5 V; ID = 20 A; VDS = 24 V; see Figure 14 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source Simplified outline 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G 1 2 3 4 S1 S2 S3 mbl798 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number BUK9Y22-30B BUK9Y22-30B Product data sheet Package Name Description LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads SOT669 All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 Version © Nexperia B.V. 2017. All rights reserved 2 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 30 V VDGR drain-gate voltage RGS = 20 kΩ - - 30 V VGS gate-source voltage ID drain current -15 - 15 V Tmb = 25 °C; VGS = 5 V; see Figure 1; see Figure 4 - - 37.7 A Tmb = 100 °C; VGS = 5 V; see Figure 1 - - 26.65 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 4 - - 150.7 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 59.4 W Tstg storage temperature -55 - 175 °C Tj junction temperature -55 - 175 °C Source-drain diode IS source current Tmb = 25 °C - - 37.7 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - - 150.7 A - - 47 mJ - - - J Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy ID = 37.7 A; Vsup ≤ 30 V; RGS = 50 Ω; VGS = 5 V; Tj(init) = 25 °C; unclamped EDS(AL)R repetitive drain-source avalanche energy see Figure 3 [1] [1][2][3] [4] Maximum value not quoted. Repetitive rating defined in avalanche rating figure. [2] Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. [3] Repetitive avalanche rating limited by an average junction temperature of 170 °C. [4] Refer to application note AN10273 for further information. BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 3 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 003aac517 40 003aab844 120 ID (A) Pder (%) 30 80 20 40 10 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aac496 102 IAL (A) (1) 10 (2) 1 (3) 10-1 10-3 Fig 3. 10-2 10-1 1 tAL (ms) 10 Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 4 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 003aac617 103 Limit RDSon = VDS / ID ID (A) 102 10μ s 100μ s 10 1ms DC 10ms 100ms 1 10-1 1 Fig 4. 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 5 - - 2.53 K/W 003aac483 10 Zth (j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10-1 δ= P tp T 0.02 single shot t tp T 10-2 10-6 Fig 5. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration. BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 5 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 27 - - V Static characteristics V(BR)DSS drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 30 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 1.1 1.5 2 V VGSth gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10; see Figure 11 0.5 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10; see Figure 11 - - 2.3 V IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 30 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VDS = 0 V; VGS = 15 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -15 V; Tj = 25 °C - 2 100 nA VGS = 5 V; ID = 20 A; Tj = 25 °C; see Figure 12; see Figure 13 - 17 22 mΩ VGS = 4.5 V; ID = 20 A; Tj = 25 °C - - 24 mΩ VGS = 5 V; ID = 20 A; Tj = 175 °C; see Figure 12 - - 44 mΩ VGS = 10 V; ID = 20 A; Tj = 25 °C - 13.5 19 mΩ ID = 20 A; VDS = 24 V; VGS = 5 V; see Figure 14 - 10.5 - nC - 3.3 - nC - 4.5 - nC VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 15 - 705 940 pF - 188 226 pF - 102 140 pF - 8.7 - ns - 18.5 - ns RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 42 - ns tf fall time - 23 - ns - 0.85 1.2 V VDS = 25 V; RL = 1.25 Ω; VGS = 5 V; RG(ext) = 10 Ω Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; see Figure 16 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 - 30 - ns - 33 - nC © Nexperia B.V. 2017. All rights reserved 6 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 003aac961 120 ID (A) 003aac965 120 VGS (V) = 15 3.6 3 RDSon (mΩ) 10 80 4 5 3.4 2.6 80 5 4 40 10 40 3.6 3.4 3 2.6 2.2 0 0 Fig 6. 2 4 6 8 VGS (V) = 15 0 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values. 0 Fig 7. 003aac966 30 40 80 ID (A) 120 Drain-source on-state resistance as a function of drain current; typical values. 003aac962 20 ID (A) gfs (S) 15 20 10 10 Tj = 175 °C 5 Tj = 25 °C 0 0 0 Fig 8. 10 20 ID (A) 30 Forward transconductance as a function of drain current; typical values. BUK9Y22-30B Product data sheet 0 Fig 9. 1 2 3 VGS (V) 4 Transfer characteristics: drain current as a function of gate-source voltage; typical values. All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 7 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 003aab986 2.5 003aab987 10−1 ID (A) VGS(th) (V) 2.0 10−2 max min 1.5 min 1.0 max 10−4 10−5 0.5 0.0 −60 typ 10−3 typ 10−6 0 60 120 0 180 1 2 3 Tj (°C) VGS (V) Fig 10. Gate-source threshold voltage as a function of junction temperature 003aab851 2 Fig 11. Sub-threshold drain current as a function of gate-source voltage 003aac964 33 RDSON (mΩ) a 1.5 27 1 21 0.5 15 0 −60 9 0 60 120 Product data sheet 4 8 12 Tj (°C) Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature BUK9Y22-30B 0 180 VGS (V) 16 Fig 13. Drain-source on-state resistance as a function of gate-source voltage; typical values. All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 8 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 003aac960 5 VGS (V) C (pF) VDS = 14 V 4 003aac967 104 VDS = 24 V 103 Ciss 3 Coss 2 2 10 Crss 1 0 0 4 8 QG (nC) 10 10-1 12 Fig 14. Gate-source voltage as a function of gate charge; typical values. 1 2 VDS (V) 10 10 Fig 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values. 003aac963 100 IS (A) 80 60 40 Tj = 175 °C 20 Tj = 25 °C 0 0.2 0.6 1 VSD (V) 1.4 Fig 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values. BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 9 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 17. Package outline SOT669 (LFPAK) BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 10 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK9Y22-30B_4 20100407 Product data sheet - BUK9Y22-30B_3 Modifications: BUK9Y22-30B_3 BUK9Y22-30B Product data sheet • Status changed from objective to product. 20100216 Objective data sheet - All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 BUK9Y22-30B_2 © Nexperia B.V. 2017. All rights reserved 11 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK9Y22-30B Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 12 of 14 BUK9Y22-30B Nexperia N-channel TrenchMOS logic level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BUK9Y22-30B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 04 — 7 April 2010 © Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia BUK9Y22-30B N-channel TrenchMOS logic level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 07 April 2010
BUK9Y22-30B,115 价格&库存
很抱歉,暂时无法提供与“BUK9Y22-30B,115”相匹配的价格&库存,您可以联系我们找货
