BSP126,115
BSP126,115
    NEXPERIA(安世)
    SOT-223
    MOSFETs 250V 6.70 x 3.70mm SMT SOT223 375mA
BSP126,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET book, halfpage M3D087 BSP126 N-channel enhancement mode vertical D-MOS transistor Product specification Supersedes data of 1997 Jun 23 2002 Feb 19 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 FEATURES PINNING - SOT223 • Direct interface to C-MOS, TTL, etc. PIN DESCRIPTION • High-speed switching 1 gate • No secondary breakdown. 2 drain 3 source 4 drain APPLICATIONS • Line current interruptor in telephone sets • Relay, high-speed and line transformer drivers. d 4 handbook, halfpage DESCRIPTION N-channel enhancement mode vertical D-MOS transistor in a miniature SOT223 package. g 1 MARKING 2 TYPE NUMBER MARKING CODE BSP126 s 3 Top view MAM054 Fig.1 Simplified outline and symbol. BSP126 QUICK REFERENCE DATA SYMBOL PARAMETER CONDITIONS TYP. MAX. UNIT − 250 V − 375 mA − 1.5 W drain-source on-state resistance ID = 300 mA; VGS = 10 V 2.8 5 Ω gate-source threshold voltage − 2 V VDS drain-source voltage (DC) ID drain current (DC) Ptot total power dissipation RDSon VGSth Tamb ≤ 25 °C ID = 1 mA; VDS = VGS LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT − 250 V − ±20 V − 375 mA − 1.3 A − 1.5 W storage temperature −55 +150 °C junction temperature − 150 °C VDS drain-source voltage (DC) VGSO gate-source voltage (DC) ID drain current (DC) IDM peak drain current Ptot total power dissipation Tstg Tj open drain Tamb ≤ 25 °C; note 1 Note 1. Device mounted on a 40 × 40 × 1.5 mm epoxy printed-circuit board; mounting pad for the drain tab minimum 6 cm2. 2002 Feb 19 2 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 THERMAL CHARACTERISTICS SYMBOL Rth j-a PARAMETER VALUE UNIT 83.3 K/W thermal resistance from junction to ambient; note 1 Note 1. Device mounted on a 40 × 40 × 1.5 mm epoxy printed-circuit board; mounting pad for the drain tab minimum 6 cm2. CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT V(BR)DSS drain-source breakdown voltage ID = 10 µA; VGS = 0 250 − − V IGSS gate-source leakage current VGS = ±20 V; VDS = 0 − − ±100 nA VGSth gate-source threshold voltage ID = 1 mA; VDS = VGS 0.8 − 2 V RDSon drain-source on-state resistance ID = 20 mA; VGS = 2.4 V − − 7.5 Ω ID = 300 mA; VGS = 10 V − 2.8 5 Ω IDSS drain-source leakage current VDS = 200 V; VGS = 0 − − 1 µA  Yfs transfer admittance ID = 300 mA; VDS = 25 V 200 600 − mS Ciss input capacitance VDS = 25 V; VGS = 0; f = 1 MHz − 100 120 pF Coss output capacitance VDS = 25 V; VGS = 0; f = 1 MHz − 21 30 pF Crss feedback capacitance VDS = 25 V; VGS = 0; f = 1 MHz − 10 15 pF Switching times (see Figs 2 and 3) ton turn-on time ID = 250 mA; VDD = 50 V; VGS = 0 to 10 V − 6 10 ns toff turn-off time ID = 250 mA; VDD = 50 V; VGS = 10 to 0 V − 47 60 ns 2002 Feb 19 3 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 handbook, halfpage VDD = 50 V handbook, halfpage 90 % INPUT 10 % 90 % OUTPUT 10 V ID 0V 10 % 50 Ω ton MBB691 MBB692 Fig.2 Switching times test circuit. Fig.3 Input and output waveforms. MBB693 2 toff MGU569 1.2 handbook, halfpage handbook, halfpage Ptot (1) (2) ID (A) (W) 1.6 (3) (4) 0.8 1.2 (5) 0.8 0.4 (6) 0.4 (7) 0 0 0 50 100 200 150 Tamb (°C) 0 2 4 6 8 10 VDS (V) Tj = 25 °C. (1) VGS = 10 V. (2) VGS = 5 V. (3) VGS = 4 V. Fig.4 Power derating curve. 2002 Feb 19 Fig.5 4 (4) VGS = 3.5 V. (5) VGS = 3 V. (6) VGS = 2.5 V. (7) VGS = 2 V. Typical output characteristics. Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 MGU570 1.6 (A) MGU571 20 handbook, ID halfpage handbook, halfpage 1.4 RDSon (Ω) 1.2 15 (1) (2) 1 0.8 10 (3) 0.6 5 0.4 (4) (5) (6) 0.2 0 10−1 0 0 2 4 6 8 10 VGS (V) 1 ID (A) 10 Tj = 25 °C. (1) VGS = 2.5 V. (2) VGS = 3 V. (3) VGS = 3.5 V. (4) VGS = 4 V. (5) VGS = 5 V. (6) VGS = 10 V. VDS = 10 V; Tj = 25 °C. Fig.7 Fig.6 Typical transfer characteristics. MGU572 250 handbook, halfpage C (pF) 200 150 Ciss 100 50 Coss Crss 0 0 10 20 VDS (V) 30 VGS = 0; f = 1 MHz; Tj = 25 °C. Fig.8 Input, output and feedback capacitance as functions of drain-source voltage; typical values. 2002 Feb 19 5 Drain-source on-state resistance as a function of drain current; typical values. Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 MGU573 2 MGU574 1.25 handbook, halfpage handbook, halfpage k k (1) 1 1.5 (2) 0.75 1 0.5 0.5 0.25 0 −50 0 50 100 0 −50 150 Tj (°C) 0 50 100 Tj (°C) 150 R DSon at T j k = ---------------------------------------R DSon at 25 °C V GSth at T j k = --------------------------------------V GSth at 25 °C Typical RDSon: (1) ID = 250 mA; VGS = 10 V. (2) ID = 20 mA; VGS = 2.4 V. Fig.9 Typical VGSth at 1 mA. Temperature coefficient of drain-source on-state resistance; typical values. 2002 Feb 19 Fig.10 Temperature coefficient of gate-source threshold voltage; typical values. 6 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 PACKAGE OUTLINE Plastic surface mounted package; collector pad for good heat transfer; 4 leads D SOT223 E B A X c y HE v M A b1 4 Q A A1 1 2 3 Lp bp e1 w M B detail X e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp b1 c D E e e1 HE Lp Q v w y mm 1.8 1.5 0.10 0.01 0.80 0.60 3.1 2.9 0.32 0.22 6.7 6.3 3.7 3.3 4.6 2.3 7.3 6.7 1.1 0.7 0.95 0.85 0.2 0.1 0.1 OUTLINE VERSION SOT223 2002 Feb 19 REFERENCES IEC JEDEC EIAJ SC-73 7 EUROPEAN PROJECTION ISSUE DATE 97-02-28 99-09-13 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 DATA SHEET STATUS DATA SHEET STATUS(1) PRODUCT STATUS(2) DEFINITIONS Objective data Development This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. Product data Production This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Changes will be communicated according to the Customer Product/Process Change Notification (CPCN) procedure SNW-SQ-650A. Notes 1. Please consult the most recently issued data sheet before initiating or completing a design. 2. The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. DEFINITIONS DISCLAIMERS Short-form specification  The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support applications  These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition  Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Right to make changes  Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no licence or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Application information  Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2002 Feb 19 8 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 NOTES 2002 Feb 19 9 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 NOTES 2002 Feb 19 10 Philips Semiconductors Product specification N-channel enhancement mode vertical D-MOS transistor BSP126 NOTES 2002 Feb 19 11 Philips Semiconductors – a worldwide company Contact information For additional information please visit http://www.semiconductors.philips.com. Fax: +31 40 27 24825 For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com. SCA74 © Koninklijke Philips Electronics N.V. 2002 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613510/03/pp12 Date of release: 2002 Feb 19 Document order number: 9397 750 09311 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: BSP126,135 BSP126,115
BSP126,115 价格&库存
很抱歉,暂时无法提供与“BSP126,115”相匹配的价格&库存,您可以联系我们找货
BSP126,115
  • 1+2.18900
  • 50+1.68300
  • 1000+1.55100
库存:4
BSP126,115
  • 1000+2.473891000+0.32160
  • 3000+2.135683000+0.27764
BSP126,115
    • 1+2.08160
    库存:29
    BSP126,115
    • 1+5.45400
    • 10+4.40640
    • 30+3.88800
    • 100+3.36960
    • 500+3.06720
    • 1000+2.90520
    库存:3
