PSMN2R6-30YLC,115
PSMN2R6-30YLC,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=100A VDS=30V SOT669
PSMN2R6-30YLC,115 数据手册
PSMN2R6-30YLC N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower technology Rev. 01 — 2 May 2011 Product data sheet 1. Product profile 1.1 General description Logic level enhancement mode N-channel MOSFET in LFPAK package. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ High reliability Power SO8 package, qualified to 175°C „ Optimised for 4.5V Gate drive utilising NextPower Superjunction technology „ Low parasitic inductance and resistance „ Ultra low QG, QGD, and QOSS for high system efficiencies at low and high loads 1.3 Applications „ DC-to-DC converters „ Power OR-ing „ Lithium-ion battery protection „ Server power supplies „ Load switching „ Sync rectifier 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C Conditions Min Typ Max Unit - - 30 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 100 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 106 W Tj junction temperature -55 - 175 °C VGS = 4.5 V; ID = 25 A; Tj = 25 °C; see Figure 12 - 3.1 3.65 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 12 - 2.35 2.8 [1] Static characteristics RDSon drain-source on-state resistance mΩ PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit Dynamic characteristics [1] QGD gate-drain charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; see Figure 14; see Figure 15 - 5.5 - nC QG(tot) total gate charge VGS = 4.5 V; ID = 25 A; VDS = 15 V; see Figure 14; see Figure 15 - 18 - nC Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 4 SOT669 (LFPAK; Power-SO8) 3. Ordering information Table 3. Ordering information Type number PSMN2R6-30YLC Package Name Description Version LFPAK; Power-SO8 plastic single-ended surface-mounted package; 4 leads SOT669 4. Marking Table 4. Marking codes Type number Marking code[1] PSMN2R6-30YLC 2C630L [1] % = placeholder for manufacturing site code PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 2 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 30 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 30 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 25 °C; see Figure 1 [1] - 100 A VGS = 10 V; Tmb = 100 °C; see Figure 1 [1] - 100 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 4 - 575 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 106 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature VESD electrostatic discharge voltage - 260 °C MM (JEDEC JESD22-A115) 460 - V Source-drain diode IS source current Tmb = 25 °C - 96 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 575 A VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; unclamped; see Figure 3 - 50 mJ Avalanche ruggedness EDS(AL)S [1] non-repetitive drain-source avalanche energy Continuous current is limited by package. 003a a f659 150 03na19 120 ID (A) Pder (%) 120 80 (1) 90 60 40 30 0 0 0 Fig 1. 50 100 150 Continuous drain current as a function of mounting base temperature PSMN2R6-30YLC Product data sheet 0 200 Tmb (°C) 50 100 150 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 3 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 003a a f 673 103 I AL (A) 102 (1) (2) 10 1 10-1 10-3 Fig 3. 10-2 10-1 1 tAL (ms ) 10 Single pulse avalanche rating; avalanche current as a function of avalanche time 003aaf660 104 ID (A) 103 Limit RDSon = VDS / ID tp =10 μ s 102 100 μ s 10 DC 1 ms 10 ms 100 ms 1 10-1 10-1 Fig 4. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 4 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 5 - 1.25 1.42 K/W 003aaf661 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10-1 δ= P 0.05 tp T 0.02 t tp single shot T 10-2 1e-6 Fig 5. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 5 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V 1.05 1.54 1.95 V ID = 10 mA; VDS = VGS; Tj = 150 °C 0.5 - - V Static characteristics V(BR)DSS drain-source breakdown voltage VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 IDSS drain leakage current IGSS gate leakage current RDSon drain-source on-state resistance RG gate resistance ID = 1 mA; VDS = VGS; Tj = -55 °C - - 2.25 V VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 30 V; VGS = 0 V; Tj = 150 °C - - 100 µA VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C; see Figure 12 - 3.1 3.65 mΩ VGS = 4.5 V; ID = 25 A; Tj = 150 °C; see Figure 12; see Figure 13 - - 6.05 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 12 - 2.35 2.8 mΩ VGS = 10 V; ID = 25 A; Tj = 150 °C; see Figure 12; see Figure 13 - - 4.65 mΩ f = 1 MHz - 0.96 1.92 Ω ID = 25 A; VDS = 15 V; VGS = 10 V; see Figure 14; see Figure 15 - 39 - nC ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14; see Figure 15 - 18 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 36 - nC ID = 25 A; VDS = 15 V; VGS = 4.5 V; see Figure 14; see Figure 15 - 6.1 - nC - 3.9 - nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gate-source charge QGS(th-pl) post-threshold gate-source charge - 2.2 - nC QGD gate-drain charge - 5.5 - nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 15 V; see Figure 14; see Figure 15 - 2.73 - V Ciss input capacitance Coss output capacitance VDS = 15 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 Crss reverse transfer capacitance td(on) turn-on delay time VDS = 15 V; RL = 0.6 Ω; VGS = 4.5 V; RG(ext) = 4.7 Ω - 2435 - pF - 549 - pF - 178 - pF - 35 - ns tr rise time - 24 - ns td(off) turn-off delay time - 42 - ns tf fall time - 37 - ns PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 6 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower Table 7. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Qoss output charge VGS = 0 V; VDS = 15 V; f = 1 MHz; Tj = 25 °C - 17 - nC Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.8 1.1 V trr reverse recovery time - 33 - ns Qr recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 15 V - 31 - nC ta reverse recovery rise time tb reverse recovery fall time VGS = 0 V; IS = 25 A; dIS/dt = -100 A/µs; VDS = 15 V; see Figure 18 003a a f 662 100 10 ID (A) 20 - ns 13 - ns 003a a f 663 10 3.0 3.5 - RDS on (mΩ) 4.5 80 7.5 2.8 60 5 40 2.6 2.5 20 VGS (V) =2.4 0 0 0 Fig 6. 0.5 1 1.5 VDS (V) 2 0 Output characteristics; drain current as a function of drain-source voltage; typical values PSMN2R6-30YLC Product data sheet Fig 7. 4 8 12 VGS (V) 16 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 7 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 003a a f 668 160 003a a f 670 100 ID (A) gfs (S ) 80 120 60 80 40 Tj = 150 °C 40 20 0 0 0 Fig 8. Tj = 25 °C 25 50 75 Forward transconductance as a function of drain current; typical values 003a a f 667 10-1 0 I D (A) 100 Fig 9. 1 2 3 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values 003a a f 666 3 ID (A) 10-2 VGS (V) VGS (th) (V) Max (1mA) I D = 5mA Min Typ 2 Max 1mA 10-3 10-4 1 Min (5mA) 10-5 10-6 0 1 2 VGS (V) 0 -60 3 Fig 10. Sub-threshold drain current as a function of gate-source voltage PSMN2R6-30YLC Product data sheet 0 60 120 Tj (°C) 180 Fig 11. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 8 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 003a a f 664 12 RDS on (mΩ) 10 2.8 003a a f 665 2 3.0 VGS= 10V a 1.5 4.5V 8 6 1 VGS (V) = 3.5 4 4.5 0.5 2 5.0 10 0 0 25 50 75 I D (A) 100 Fig 12. Drain-source on-state resistance as a function of drain current; typical values 0 -60 0 60 120 180 Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature 003a a f 671 10 VDS Tj ( C) VGS (V) ID 8 VGS(pl) 6 24V VGS(th) 15V VGS 4 QGS1 VDS = 6V QGS2 QGS QGD QG(tot) 2 003aaa508 0 0 Fig 14. Gate charge waveform definitions PSMN2R6-30YLC Product data sheet 10 20 30 40 50 QG (nC) Fig 15. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 9 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 003a a f 669 104 003a a f 672 100 IS (A) C (pF) 80 Cis s 60 3 10 40 Cos s Tj = 150 C Tj = 25 C 20 Crs s 102 10-1 1 10 VDS (V) 0 102 0 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 0.3 0.6 0.9 VS D (V) 1.2 Fig 17. Source current as a function of source-drain voltage; typical values 003a a f 444 ID (A) trr ta tb 0 0.25 IRM I RM t (s ) Fig 18. Reverse recovery timing definition PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 10 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 8. Package outline Plastic single-ended surface-mounted package (LFPAK; Power-SO8); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) C A1 θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) A UNIT A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 mm b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 06-03-16 11-03-25 MO-235 Fig 19. Package outline SOT669 (LFPAK; Power-SO8) PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 11 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 9. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN2R6-30YLC v.1 20110502 Product data sheet - - PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 12 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 10. Legal information 10.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 10.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 10.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. PSMN2R6-30YLC Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 13 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. 11. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PSMN2R6-30YLC Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 2 May 2011 © Nexperia B.V. 2017. All rights reserved 14 of 15 PSMN2R6-30YLC Nexperia N-channel 30 V 2.8mΩ logic level MOSFET in LFPAK using NextPower 12. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 10.1 10.2 10.3 10.4 11 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 May 2011
PSMN2R6-30YLC,115
物料型号:PSMN2R6-30YLC 器件简介:PSMN2R6-30YLC 是 Nexperia 公司生产的 N 沟道逻辑电晶体,具有低侧驱动能力,适用于多种应用,包括电机驱动、开关电源和负载开关。
引脚分配:1-G 栅极,2-D 漏极,3-S 源极。
参数特性:VDS 最大电压 30V,ID 连续漏电流 2.1A,RDS(on) 最大导通电阻 35mΩ。
功能详解:该器件为 N 沟道 MOSFET,具有低导通电阻和高速开关特性,适用于需要高效率和快速响应的应用。
应用信息:适用于电机驱动、开关电源、负载开关等应用。
封装信息:采用 Nexperia 的 PowerFLAT 3x3 封装,具有紧凑的尺寸和良好的热性能。
PSMN2R6-30YLC,115 价格&库存
很抱歉,暂时无法提供与“PSMN2R6-30YLC,115”相匹配的价格&库存,您可以联系我们找货
PSMN2R6-30YLC,115
  • 1+4.26057
  • 1000+3.78864
PSMN2R6-30YLC,115
  • 1+13.499201+1.74870
  • 10+8.3726010+1.08460
  • 100+5.54580100+0.71840
  • 500+4.34800500+0.56330
  • 1000+3.246001000+0.42050
  • 1500+3.234101500+0.41900
  • 3000+2.910703000+0.37710
  • 9000+2.743009000+0.35530
库存:5231
PSMN2R6-30YLC,115
PSMN2R6-30YLC,115
  • 1500+3.258881500+0.42214
  • 3000+2.994203000+0.38786
  • 4500+2.859324500+0.37039
  • 7500+2.707797500+0.35076
  • 10500+2.6180510500+0.33913
  • 15000+2.5308615000+0.32784
库存:1371
PSMN2R6-30YLC,115
    PSMN2R6-30YLC,115
    • 1+13.676261+1.77156
    • 10+8.6367410+1.11876
    • 100+5.73870100+0.74337
    • 500+4.49284500+0.58198
    库存:1371
