BUK9215-55A
N-channel TrenchMOS logic level FET
7 April 2014
Product data sheet
1. General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
2. Features and benefits
AEC Q101 compliant
Low conduction losses due to low on-state resistance
Suitable for logic level gate drive sources
Suitable for thermally demanding environments due to 175 °C rating
3. Applications
12 V and 24 V loads
Automotive and general purpose power switching
Motors, lamps and solenoids
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
55
V
ID
drain current
VGS = 5 V; Tmb = 25 °C; Fig. 2; Fig. 3
62
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
115
W
VGS = 10 V; ID = 25 A; Tj = 25 °C
11
13.6
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 25 °C
16.6
mΩ
VGS = 5 V; ID = 25 A; Tj = 25 °C;
13
15
mΩ
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Fig. 11; Fig. 12
Dynamic characteristics
QGD
gate-drain charge
VGS = 5 V; ID = 25 A; VDS = 44 V;
Tj = 25 °C; Fig. 9
BUK9215-55A
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 62 A; Vsup ≤ 55 V; RGS = 50 Ω;
211
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drainsource avalanche
energy
[1]
VGS = 5 V; Tj(init) = 25 °C; unclamped
Current is limited by power dissipation chip rating.
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
D
mb
G
mbb076
2
1
S
3
DPAK (SOT428)
6. Ordering information
Table 3.
Type number
BUK9215-55A
BUK9215-55A
Product data sheet
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads
(one lead cropped)
SOT428
All information provided in this document is subject to legal disclaimers.
7 April 2014
Nexperia B.V. 2017. All rights reserved
2 / 13
BUK9215-55A
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
55
V
VDGR
drain-gate voltage
RGS = 20 kΩ
55
V
VGS
gate-source voltage
-15
15
V
Ptot
Tmb = 25 °C; Fig. 1
115
W
ID
drain current
Tmb = 25 °C; VGS = 5 V; Fig. 2; Fig. 3
[1]
62
A
[2]
55
A
[1]
44
A
248
A
Tmb = 100 °C; VGS = 5 V; Fig. 2
IDM
peak drain current
Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
[2]
55
A
[1]
62
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C
248
A
211
mJ
Source-drain diode
IS
ISM
source current
Tmb = 25 °C
peak source current
EDS(AL)S
non-repetitive drain-source
avalanche energy
[1]
[2]
BUK9215-55A
Product data sheet
Continious current is limited by bond wires.
7 April 2014
3 / 13
BUK9215-55A
Nexperia
03aa16
120
03nf79
80
ID
(A)
Pder
Capped at 55 A due to limitation of bondwires
60
80
40
40
Fig. 1.
100
150
Tmb (°C)
Fig. 2.
Normalized total power dissipation as a
function of mounting base temperature
25
50
75
100
125
150
175
200
Tmb (°C)
Continuous drain current as a function of
03nf78
103
ID
(A)
tp = 10 µs
RDSon = VDS / ID
102
100 µs
P
10
δ=
tp
T
1 ms
DC
10 ms
tp
1
Fig. 3.
1
100 ms
t
T
10
VDS (V)
102
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK9215-55A
Product data sheet
7 April 2014
4 / 13
BUK9215-55A
Nexperia
8. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 4
1.3
K/W
Rth(j-a)
thermal resistance
from junction to
ambient
71.4
K/W
03nf77
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
0.1
10- 1
0.05
0.02
10- 2
P
δ=
Single Shot
tp
10- 3
Fig. 4.
tp
T
10- 6
10- 5
10- 4
10- 3
10- 2
t
T
10- 1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK9215-55A
Product data sheet
7 April 2014
5 / 13
BUK9215-55A
Nexperia
9. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
55
V
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
50
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = -55 °C;
2.3
V
0.5
V
1
1.5
2
V
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VDS = 55 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
11
13.6
mΩ
16.6
mΩ
VGS = 5 V; ID = 25 A; Tj = 175 °C;
30
mΩ
13
15
mΩ
V(BR)DSS
VGS(th)
Fig. 10
ID = 1 mA; VDS = VGS; Tj = 175 °C;
Fig. 10
ID = 1 mA; VDS = VGS; Tj = 25 °C;
Fig. 10
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
Fig. 11; Fig. 12
Fig. 11; Fig. 12
QG(tot)
total gate charge
ID = 25 A; VDS = 44 V; VGS = 5 V;
48
nC
QGS
gate-source charge
Tj = 25 °C; Fig. 9
6
nC
QGD
gate-drain charge
nC
Ciss
input capacitance
VGS = 0 V; VDS = 25 V; f = 1 MHz;
2190
2916
pF
Coss
output capacitance
Tj = 25 °C; Fig. 13
380
450
pF
Crss
reverse transfer
capacitance
250
344
pF
td(on)
turn-on delay time
VDS = 30 V; RL = 1.2 Ω; VGS = 5 V;
19
ns
tr
rise time
RG(ext) = 10 Ω; Tj = 25 °C
161
ns
td(off)
turn-off delay time
138
ns
tf
fall time
165
ns
LD
internal drain
inductance
2.5
nH
BUK9215-55A
Product data sheet
measured from drain to centre of die
7 April 2014
6 / 13
BUK9215-55A
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
LS
internal source
inductance
measured from source lead to source
bond pad
7.5
nH
IS = 20 A; VGS = 0 V; Tj = 25 °C; Fig. 14
0.85
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs;
51
ns
recovered charge
VGS = -10 V; VDS = 30 V; Tj = 25 °C
102
nC
Qr
ID
(A)
03nb61
300
VGS (V) = 10
9
250
8
17
7
200
16
6
5
150
15
14
13
100
3
12
50
11
2.2
Fig. 5.
03nf85
19
RDSon
(mΩ)
18
4
6
8
VDS (V)
10
10
Output characteristics: drain current as a
Fig. 6.
function of drain-source voltage; typical values
03aa35
10- 1
ID
(A)
min
10- 2
typ
3
6
9
12
VGS (V)
15
Drain-source on-state resistance as a function
of gate-source voltage; typical values
03nb58
60
gfs
(S)
max
40
10- 3
10- 4
10- 6
Fig. 7.
4
VGS (V)
Sub-threshold drain current as a function of
gate-source voltage
BUK9215-55A
Product data sheet
Fig. 8.
80
ID (A)
100
Forward transconductance as a function of
drain current; typical values
7 April 2014
40
7 / 13
BUK9215-55A
Nexperia
03nb57
5
VGS
(V)
VDD = 14 V
VGS(th)
(V)
VDD = 44 V
4
03aa33
2.5
2
max
3
1.5
typ
2
1
min
1
0.5
Fig. 9.
60
QG (nC)
Gate-source voltage as a function of turn-on
gate charge; typical values
Tj (° C)
180
03ne89
a
3.6
1.5
4.0
18
120
2
VGS (V) = 3.4
Fig. 10. Gate-source threshold voltage as a function of
03nb62
22
RDSon
(mΩ)
16
1
4.6
5.0
14
0.5
12
10
60
80
ID (A)
100
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
BUK9215-55A
Product data sheet
120
Tj (°C)
180
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
7 April 2014
8 / 13
BUK9215-55A
Nexperia
03nb63
6000
C
Ciss
(pF)
5000
4000
03nb56
100
IS
(A)
80
Coss
Tj = 175 °C
60
Tj = 25 °C
3000 Crss
40
2000
10- 1
1
10
VDS (V)
0.0
0.5
1.0
VSD (V)
1.5
Fig. 13. Input, output and reverse transfer capacitances Fig. 14. Reverse diode current; typical value
as a function of drain-source voltage; typical
values
BUK9215-55A
Product data sheet
7 April 2014
9 / 13
BUK9215-55A
Nexperia
10. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L2
L
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig. 15. Package outline DPAK (SOT428)
BUK9215-55A
Product data sheet
7 April 2014
10 / 13
BUK9215-55A
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
11. Legal information
11.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
11.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
11.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
BUK9215-55A
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
7 April 2014
11 / 13
BUK9215-55A
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
11.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BUK9215-55A
Product data sheet
7 April 2014
12 / 13
BUK9215-55A
Nexperia
12. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Limiting values .......................................................3
8
Thermal characteristics .........................................5
9
Characteristics ....................................................... 6
10
Package outline ................................................... 10
11
11.1
11.2
11.3
11.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 07 April 2014
BUK9215-55A
Product data sheet
7 April 2014
13 / 13
很抱歉,暂时无法提供与“BUK9215-55A,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.83200
- 10+4.71960
- 30+4.16880
- 100+3.61800
- 500+3.29400
- 1000+3.12120
