BUK9214-30A
N-channel TrenchMOS logic level FET
Rev. 3 — 14 June 2012
Product data sheet
1. Product profile
1.1 General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Suitable for logic level gate drive
sources
Q101 compliant
Suitable for thermally demanding
environments due to 175 °C rating
1.3 Applications
12 V loads
Motors, lamps and solenoids
Automotive and general purpose
power switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
30
V
ID
drain current
VGS = 5 V; Tmb = 25 °C; see Figure 1;
see Figure 3
63
A
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
107
W
VGS = 4.5 V; ID = 25 A; Tj = 25 °C
15.5
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C
9
12
mΩ
VGS = 5 V; ID = 25 A; Tj = 25 °C;
see Figure 11; see Figure 12
11
14
mΩ
VGS = 5 V; ID = 25 A; VDS = 24 V;
Tj = 25 °C; see Figure 13
12.2
nC
ID = 63 A; Vsup ≤ 30 V; RGS = 50 Ω;
VGS = 5 V; Tj(init) = 25 °C; unclamped
230
mJ
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
BUK9214-30A
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
Simplified outline
Graphic symbol
mb
3
S
source
mb
D
mounting base; connected to drain
D
G
mbb076
S
2
1
3
SOT428 (DPAK)
3. Ordering information
Table 3.
Type number
BUK9214-30A
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads
(one lead cropped)
SOT428
4. Marking
Table 4.
Marking codes
Type number
Marking code
BUK9214-30A
BUK9214-30A
BUK9214-30A
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
BUK9214-30A
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
30
V
VDGR
drain-gate voltage
RGS = 20 kΩ
30
V
VGS
gate-source voltage
-15
15
V
ID
drain current
Tmb = 25 °C; VGS = 5 V; see Figure 1; see Figure 3
63
A
Tmb = 100 °C; VGS = 5 V; see Figure 1
45
A
253
A
IDM
peak drain current
Tmb = 25 °C; pulsed; tp ≤ 10 µs; see Figure 3
Ptot
107
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
63
A
ISM
peak source current
pulsed; tp ≤ 10 µs; Tmb = 25 °C
253
A
ID = 63 A; Vsup ≤ 30 V; RGS = 50 Ω; VGS = 5 V;
230
mJ
avalanche energy
EDS(AL)S
03nh79
80
03aa16
120
ID
(A)
Pder
60
80
40
40
Fig 1.
75
100
125
150
175
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
BUK9214-30A
Product data sheet
100
150
200
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
3 of 14
BUK9214-30A
Nexperia
03nh78
103
ID
(A)
tp = 10 μs
RDSon = VDS / ID
102
100 μs
1 ms
DC
10
10 ms
100 ms
1
1
Fig 3.
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK9214-30A
Product data sheet
4 of 14
BUK9214-30A
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to mounting base
see Figure 4
1.4
K/W
Rth(j-a)
thermal resistance from junction to ambient
71.4
K/W
03nh80
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
0.1
0.05
10−1
0.02
10−2
δ=
P
tp
T
Single Shot
t
tp
10−3
10−6
T
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK9214-30A
Product data sheet
5 of 14
BUK9214-30A
Nexperia
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
30
V
V(BR)DSS
drain-source breakdown
voltage
VGS(th)
gate-source threshold voltage
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
27
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10
1
1.5
2
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
2.3
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 10
0.5
V
IDSS
drain leakage current
VDS = 30 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 30 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
IGSS
gate leakage current
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
15.5
mΩ
RDSon
resistance
9
12
mΩ
VGS = 5 V; ID = 25 A; Tj = 175 °C;
26.6
mΩ
11
14
mΩ
ID = 25 A; VDS = 24 V; VGS = 5 V;
31
nC
5.3
nC
12.2
nC
1730
2317
pF
400
481
pF
260
365
pF
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
VDS = 30 V; RL = 1.2 Ω; VGS = 5 V;
RG(ext) = 10 Ω; Tj = 25 °C
10
ns
85
ns
turn-off delay time
94
ns
tf
fall time
108
ns
LD
internal drain inductance
from drain to centre of die ; Tj = 25 °C
2.5
nH
LS
internal source inductance
from source lead to source bond
pad ; Tj = 25 °C
7.5
nH
Source-drain diode
VSD
source-drain voltage
IS = 20 A; VGS = 0 V; Tj = 25 °C;
see Figure 15
0.85
1.2
V
trr
reverse recovery time
83
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
119
nC
BUK9214-30A
Product data sheet
6 of 14
BUK9214-30A
Nexperia
03nf71
300
ID
(A)
250
9
10
03nf70
18
RDSon
(mΩ)
7
8
16
VGS (V) = 6
200
14
150
5
100
4
50
3
12
2.2
4
6
8
8
10
3
5
7
9
11
13
15
VGS (V)
VDS (V)
Fig 5.
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 6.
03aa36
10-1
ID
(A)
Drain-source on-state resistance as a function
of gate-source voltage; typical values
03nf68
50
gfs
(S)
10-2
40
10-3
30
min
typ
max
10-4
10
10-6
2
VGS (V)
3
40
50
60
70
ID (A)
Tj = 25 °C; VDS = 5 V
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
BUK9214-30A
Product data sheet
Fig 8.
Forward transconductance as a function of
drain current; typical values
7 of 14
BUK9214-30A
Nexperia
03nf69
80
03aa33
2.5
VGS(th)
(V)
ID
(A)
2
max
60
1.5
typ
1
min
40
Tj = 175 °C
Tj = 25 °C
2
3
4
5
120
VGS (V)
Fig 9.
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
RDSon
(mΩ)
25
3
3.4
3.8 4
03aa27
2
VGS (V) = 5
180
Fig 10. Gate-source threshold voltage as a function of
03nf72
30
Tj (°C)
a
1.5
15
10
0.5
5
100
150
200
ID (A)
Fig 11. Drain-source on-state resistance as a function
of drain current; typical values
BUK9214-30A
Product data sheet
−60
120
Tj (°C)
180
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
8 of 14
BUK9214-30A
Nexperia
03nf67
5
03nf73
3500
C
(pF)
3000
VGS
(V)
4
VDD = 14 V
2500
VDD = 24 V
Ciss
3
2000
Coss
1500
2
1000
Crss
1
500
10−2
10−1
1
102
10
VDS (V)
QG (nC)
Fig 13. Gate-source voltage as a function of turn-on
gate charge; typical values
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
03nf66
100
IS
(A)
80
60
40
Tj = 175 °C
Tj = 25 °C
1.0
1.5
VSD (V)
Fig 15. Reverse diode current as a function of reverse diode voltage; typical values
BUK9214-30A
Product data sheet
9 of 14
BUK9214-30A
Nexperia
8. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L
L2
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig 16. Package outline SOT428 (DPAK)
BUK9214-30A
Product data sheet
10 of 14
BUK9214-30A
Nexperia
9. Revision history
Table 8.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK9214-30A v.3
20120614
Product data sheet
BUK9214-30A v.2
BUK9214-30A v.1
Modifications:
BUK9214-30A v.2
BUK9214-30A
Product data sheet
Various changes to content.
20100615
Product data sheet
11 of 14
BUK9214-30A
Nexperia
10. Legal information
10.1 Data sheet status
Document status[1] [2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
10.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
10.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with theTerms and conditions of commercial sale of Nexperia.
BUK9214-30A
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
12 of 14
BUK9214-30A
Nexperia
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
10.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
11. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
BUK9214-30A
Product data sheet
13 of 14
Nexperia
BUK9214-30A
12. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
10.1
10.2
10.3
10.4
11
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 June 2012
很抱歉,暂时无法提供与“BUK9214-30A,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.91280
- 10+16.56720
- 30+16.34040
