BUK7210-55B
N-channel TrenchMOS standard level FET
Rev. 01 — 11 December 2008
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using Nexperia High-Performance Automotive (HPA) TrenchMOS technology.
This product has been designed and qualified to the appropriate AEC standard for use
in automotive critical applications.
1.2 Features and benefits
185 °C rated
Standard level compatible
Q101 compliant
Very low on-state resistance
1.3 Applications
12 V and 24 V loads
General purpose power switching
Automotive systems
Motors, lamps and solenoids
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
55
V
75
A
VGS = 10 V; ID = 25 A;
Tj = 25 °C; see Figure 10;
see Figure 9
8.5
10
mΩ
ID = 75 A; Vsup ≤ 55 V;
RGS = 50 Ω; VGS = 10 V;
Tj(init) = 25 °C; unclamped
inductive load
173
mJ
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 185 °C
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 1; see Figure 3;
[1]
Static characteristics
RDSon
drain-source
on-state resistance
Avalanche ruggedness
EDS(AL)S non-repetitive
drain-source
avalanche energy
[1]
Continuous current is limited by package.
BUK7210-55B
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
[1]
D
G
mbb076
S
2
1
3
SOT428
(SC-63; DPAK)
[1]
It is not possible to make connection to pin 2 of the SOT428 package.
3. Ordering information
Table 3.
Type number
Package
Name
Description
BUK7210-55B
SC-63;
plastic single-ended surface-mounted package (DPAK); 3 leads (one
DPAK
lead cropped)
BUK7210-55B_1
Product data sheet
Version
SOT428
Nexperia B.V. 2017. All rights reserved
2 of 14
BUK7210-55B
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
55
V
RGS = 20 kΩ; 25 °C ≤ Tj ≤ 185 °C
VDGR
drain-gate voltage
VGS
gate-source voltage
ID
drain current
Tmb = 25 °C; VGS = 10 V; see Figure 1;
see Figure 3;
[1]
Tmb = 100 °C; VGS = 10 V; see Figure 1
see Figure 3;
[2]
55
V
-20
V
89.6
A
65.5
A
75
A
335
A
IDM
peak drain current
Tmb = 25 °C; tp ≤ 10 µs; pulsed
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
167
W
Tstg
storage temperature
-55
185
°C
Tj
junction temperature
-55
185
°C
Source-drain diode
IS
ISM
source current
peak source current
Tmb = 25 °C;
[2]
75
A
Tmb = 25 °C;
[3]
89.6
A
335
A
173
mJ
tp ≤ 10 µs; pulsed; Tmb = 25 °C
EDS(AL)S
non-repetitive
ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 10 V;
drain-source avalanche Tj(init) = 25 °C; unclamped inductive load
energy
[1]
Current is limited by power dissipation chip rating.
[2]
[3]
BUK7210-55B_1
Product data sheet
3 of 14
BUK7210-55B
Nexperia
003aac284
100
ID
(A)
03no96
120
Capped at 75A due to package
Pder
75
80
50
40
25
Fig 1.
50
100
150
Tmb (°C)
Fig 2.
Normalized continuous drain current as a
function of mounting base temperature
50
100
150
200
Tmb (°C)
Normalized total power dissipation as a
003aac272
103
Limit RDSon = VDS / ID
ID
(A)
tp = 10 μ s
102
100 μ s
Capped at 75 A due to package
DC
1 ms
10
10 ms
100 ms
1
1
Fig 3.
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK7210-55B_1
Product data sheet
4 of 14
BUK7210-55B
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
Rth(j-a)
Conditions
Min
Typ
Max
Unit
thermal resistance from see Figure 4
junction to mounting
base
0.95
K/W
thermal resistance from Mounted on a printed circuit board; vertical
junction to ambient
in still air.; minimum footprint
75
K/W
003aac273
1
Zth (j-mb)
(K/W)
d = 0.5
0.2
10
-1
0.1
0.05
0.02
10-2
δ=
P
single shot
tp
T
t
tp
T
10-3
1e-6
Fig 4.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7210-55B_1
Product data sheet
5 of 14
BUK7210-55B
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = 25 °C
55
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
50
V
ID = 1 mA; VDS = VGS; Tj = 175 °C; see
Figure 7
1.75
V
ID = 1 mA; VDS = VGS; Tj = 25 °C; see
Figure 7; see Figure 8
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = 185 °C; see
Figure 7
0.9
V
ID = 1 mA; VDS = VGS; Tj = -40 °C; see
Figure 7
2.8
V
ID = 1 mA; VDS = VGS; Tj = -55 °C; see
Figure 7
4.4
V
VDS = 55 V; VGS = 0 V; Tj = 175 °C
1.5
500
µA
VDS = 55 V; VGS = 0 V; Tj = 125 °C
0.1
90
µA
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.02
1
µA
VDS = 55 V; VGS = 0 V; Tj = 185 °C
3
800
µA
VDS = 0 V; VGS = 20 V; Tj = 25 °C
2
100
nA
VDS = 0 V; VGS = -20 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 185 °C; see
Figure 9
20.8
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C; see
Figure 10; see Figure 9
8.5
10
mΩ
ID = 25 A; VDS = 44 V; VGS = 10 V;
Tj = 25 °C; see Figure 12; see Figure 13
35
nC
9
nC
12
nC
1840
2453
pF
379
455
pF
165
226
pF
18
ns
91
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
48
ns
tf
fall time
45
ns
LD
internal drain
inductance
measured from drain to center of die;
Tj = 25 °C
2.5
nH
LS
internal source
inductance
measured from source lead to source
bond pad; Tj = 25 °C
7.5
nH
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
VDS = 25 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 10 Ω; Tj = 25 °C
BUK7210-55B_1
Product data sheet
6 of 14
BUK7210-55B
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IS = 18 A; VGS = 0 V; Tj = 150 °C
0.76
V
IS = 18 A; VGS = 0 V; Tj = 175 °C
0.74
V
IS = 18 A; VGS = 0 V; Tj = 100 °C
0.8
V
IS = 18 A; VGS = 0 V; Tj = 25 °C; see
Figure 11
0.85
1.2
V
IS = 18 A; VGS = 0 V; Tj = 125 °C
0.78
V
IS = 18 A; VGS = 0 V; Tj = 185 °C; see
Figure 11
0.73
V
IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V;
VDS = 30 V; Tj = 25 °C
67
ns
65
nC
Source-drain diode
source-drain voltage
VSD
trr
reverse recovery time
Qr
recovered charge
003aac279
100
003aac285
18
RDSon
(m Ω)
16
ID
(A)
75
14
50
12
10
25
Tj = 185 °C
Tj = 25 °C
8
4
6
5
8
10
15
VGS (V)
VGS (V)
Fig 5.
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
Fig 6.
Drain-source on-state resistance as a function
of gate-source voltage; typical values.
BUK7210-55B_1
Product data sheet
7 of 14
BUK7210-55B
Nexperia
003aac282
5
ID
(A)
VGS(th)
(V)
4
max
10−4
min
10−5
1
Fig 7.
typ
10−3
typ
2
min
10−2
max
3
03aa35
10−1
10−6
10
80
150
Tj (°C)
220
2
4
6
VGS (V)
Gate-source threshold voltage as a function of
003aac283
2.4
Fig 8.
Sub-threshold drain current as a function of
gate-source voltage
003aac276
25
Lable is VGS (V)
6
RDSon
(mΩ )
a
6.5 7
8
10
15
0.8
10
Fig 9.
5
10
80
150
Tj (°C)
220
Normalized drain-source on-state resistance
factor as a function of junction temperature
225
ID (A)
300
Fig 10. Drain-source on-state resistance as a function
of drain current; typical values
BUK7210-55B_1
Product data sheet
75
8 of 14
BUK7210-55B
Nexperia
003aac281
100
VDS
IS
(A)
ID
75
VGS(pl)
VGS(th)
50
VGS
QGS1
25
Tj = 185 °C
QGS2
QGS
Tj = 25 °C
QGD
QG(tot)
003aaa508
0.3
0.6
0.9
VSD (V)
1.2
Fig 12. Gate charge waveform definitions
Fig 11. Source current as a function of source-drain
003aac280
10
VGS
(V)
003aac278
3000
C (pF)
7.5
VDD = 14 V
2000
VDD = 44 V
Ciss
5
1000
2.5
Coss
Crss
QG (nC)
40
Fig 13. Gate-source voltage as a function of gate
charge; typical values
102
10
VDS (V)
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK7210-55B_1
Product data sheet
1
9 of 14
BUK7210-55B
Nexperia
003aac274
300
ID
(A)
250
20 16
Label is VGS (V)
12
10
9.5
200
9
8.5
8
150
7.5
7
100
6.5
6
50
5.5
5
4.5
4
6
8
10
VDS (V)
Fig 15. Output characteristics: drain current as a function of drain-source voltage; typical values
BUK7210-55B_1
Product data sheet
10 of 14
BUK7210-55B
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L
L2
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig 16. Package outline SOT428 (DPAK)
BUK7210-55B_1
Product data sheet
11 of 14
BUK7210-55B
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7210-55B_1
20081211
Product data sheet
BUK7210-55B_1
Product data sheet
12 of 14
BUK7210-55B
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7210-55B_1
Product data sheet
13 of 14
Nexperia
BUK7210-55B
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
Date of release: 11 December 2008
很抱歉,暂时无法提供与“BUK7210-55B,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.76462
- 10+1.39526
- 30+1.23693
- 100+1.03940
- 500+0.95138
- 1000+0.89867
