BUK7660-100A,118
BUK7660-100A,118
    NEXPERIA(安世)
    SOT404
    MOS管 N-Channel Id=26A VDS=100V SOT404
BUK7660-100A,118 数据手册
BUK7660-100A N-channel TrenchMOS standard level FET Rev. 02 — 7 February 2011 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ AEC Q101 compliant „ Low conduction losses due to low on-state resistance „ Suitable for standard level gate drive sources „ Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications „ 12 V, 24 V and 42 V loads „ Motors, lamps and solenoids „ Automotive and general purpose power switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS ID drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V drain current VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3 - - 26 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 106 W VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 12; see Figure 13 - - 150 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 12; see Figure 13 - 51 60 mΩ ID = 20 A; Vsup ≤ 100 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - - 110 mJ Static characteristics RDSon drain-source on-state resistance Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Simplified outline Graphic symbol mb D G mbb076 S 2 1 3 SOT404 (D2PAK) 3. Ordering information Table 3. Ordering information Type number Package BUK7660-100A Name Description Version D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage RGS = 20 kΩ - 100 V VGS gate-source voltage ID drain current -20 20 V Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 3 - 26 A Tmb = 100 °C; VGS = 10 V; see Figure 1 - 19 A IDM peak drain current Tmb = 25 °C; pulsed; tp ≤ 10 µs; see Figure 3 - 106 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 106 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 26 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 106 A ID = 20 A; Vsup ≤ 100 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - 110 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 2 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 03aa24 120 03na19 120 Pder (%) Ider (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Fig 1. Normalized continuous drain current as a function of mounting base temperature 200 Tmb (°C) Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature 03nd04 103 ID (A) RDSon = VDS / ID 102 tp = 10 μs 100 μs 10 δ= P tp 1 ms D.C. 10 ms T 100 ms 1 t tp 10−1 T 1 10 102 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 3 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 1.4 K/W Rth(j-a) thermal resistance from junction to ambient mounted on printed-circuit board ; minimum footprint - 50 - K/W 03nd05 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10−1 δ= P 0.05 tp T 0.02 10−2 10−6 10−5 t tp Single Shot T 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 4 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 89 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11 2 3 4 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 11 - - 4.4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 11 1 - - V - - 500 µA IDSS drain leakage current VDS = 100 V; VGS = 0 V; Tj = 175 °C VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 12; see Figure 13 - - 150 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 12; see Figure 13 - 51 60 mΩ RDSon drain-source on-state resistance Dynamic characteristics Ciss input capacitance Coss output capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 14 Crss reverse transfer capacitance td(on) turn-on delay time VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω; Tj = 25 °C - 1030 1377 pF - 143 171 pF - 90 120 pF - 10 - ns tr rise time - 45 - ns td(off) turn-off delay time - 31 - ns tf fall time - 20 - ns LD internal drain inductance from upper edge of drain mounting base to centre of die ; Tj = 25 °C - 2.5 - nH from drain lead 6 mm from package to centre of die ; Tj = 25 °C - 4.5 - nH from source lead to source bond pad ; Tj = 25 °C - 7.5 - nH - 0.85 1.2 V - 59 - ns - 180 - nC LS internal source inductance Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 15 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 5 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 03nd01 80 ID (A) VGS (V) = 9 03nd00 70 RDSon (mΩ) 10 14 20 65 8.5 7.5 60 60 6.5 40 55 50 20 5.5 45 4.5 0 Fig 5. 0 2 4 6 8 40 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 5 Fig 6. 03aa35 10−1 ID (A) min 10−2 typ 10 15 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values 03nc98 20 gfs (S) max 15 10−3 10 10−4 5 10−5 10−6 0 0 2 4 6 0 10 20 30 40 VGS (V) Fig 7. Sub-threshold drain current as a function of gate-source voltage BUK7660-100A Product data sheet Fig 8. ID (A) 50 Forward transconductance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 6 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 03nc99 50 ID (A) 03nc97 10 VGS (V) 40 8 30 6 VDD = 14 V 20 4 10 2 Tj = 175 °C 0 Fig 9. 0 2 Tj = 25 °C 4 6 VGS (V) 8 Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa32 5 4 10 20 30 QG (nC) 40 Fig 10. Gate-source voltage as a function of turn-on gate charge; typical values 03nd02 140 5.5 6 6.5 VGS (V) = 10 7 8 100 typ 2 80 min 1 60 40 0 60 120 180 0 20 40 60 Tj (°C) 80 ID (A) Fig 11. Gate-source threshold voltage as a function of junction temperature Product data sheet 0 120 max 3 BUK7660-100A 0 RDSon (mΩ) VGS(th) (V) 0 −60 VDD = 80 V Fig 12. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 7 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 03aa29 3 03nd03 2500 C (pF) a Ciss 2000 2 1500 Coss 1000 Crss 1 500 0 -60 0 0 60 120 Tj (°C) 180 10−2 10−1 1 102 10 VDS (V) Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature Fig 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 03nc96 60 IS (A) Tj = 175 °C Tj = 25 °C 40 20 0 0.0 0.5 1.0 VSD (V) 1.5 Fig 15. Reverse diode current as a function of reverse diode voltage; typical values BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 8 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 7. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig 16. Package outline SOT404 (D2PAK) BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 9 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK7660-100A v.2 20110207 Product data sheet - BUK7560_7660_100A v.1 Modifications: BUK7560_7660_100A v.1 BUK7660-100A Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK7660-100A separated from data sheet BUK7560_7660_100A v.1. 20010222 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 - © Nexperia B.V. 2017. All rights reserved 10 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK7660-100A Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 11 of 13 BUK7660-100A Nexperia N-channel TrenchMOS standard level FET agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BUK7660-100A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 7 February 2011 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BUK7660-100A N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 07 February 2011
BUK7660-100A,118
物料型号:BUK7660-100A
器件简介:这是一种标准级N沟道增强型场效应晶体管(FET),采用TrenchMOS技术,在塑料封装中使用。该产品已根据适当的汽车电子委员会(AEC)标准设计和认证,适用于汽车关键应用。
引脚分配:该器件有3个引脚,分别为: - G(gate):栅极 - D(drain):漏极 - S(source):源极 - mb(mounting base):安装底座,与漏极相连
参数特性: - 漏源电压(Vps):在T≥25°C至T 175 °C条件下,最大值为100V - 漏极电流(lD):在VGs= 10V条件下,最大值为26A - 总功耗(Ptot):在Tmb = 25 °C条件下,最大值为106W - 漏源导通电阻(RDSon):在VGs=10V和Ip=15A条件下,最小值为51mΩ,典型值为60mΩ,最大值为150mΩ - 非重复性漏源雪崩能量(EDS(AL)S):在Ip =20 A条件下,最大值为110mJ
功能详解: - 该器件符合AEC Q101标准,适用于标准级栅驱动源 - 由于低导通损耗(低漏源导通电阻)和175°C的高温度等级,适合热要求较高的环境 - 适用于12V、24V和42V负载,如电动机、灯具和电磁铁,以及汽车和通用电源开关
应用信息: - 适用于汽车和通用电源开关,包括电动机、灯具和电磁铁的控制
封装信息: - 采用塑料单端表面贴装封装(D2PAK),型号为SOT404,具有3个引脚(其中一个引脚被裁剪)
BUK7660-100A,118 价格&库存
很抱歉,暂时无法提供与“BUK7660-100A,118”相匹配的价格&库存,您可以联系我们找货
BUK7660-100A,118
  • 4800+3.301334800+0.42917
库存:22
BUK7660-100A,118
  • 1+14.119051+1.83543
  • 10+8.9217910+1.15981
库存:22
