BUK9640-100A,118
BUK9640-100A,118
    NEXPERIA(安世)
    SOT404
    MOS管 N-channel Id=39A VDS=100V SOT404
BUK9640-100A,118 数据手册
BUK9640-100A N-channel TrenchMOS logic level FET 13 March 2014 Product data sheet 1. General description Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 2. Features and benefits • • • • Low conduction losses due to low on-state resistance Q101 compliant Suitable for logic level gate drive sources Suitable for thermally demanding environments due to 175 °C rating 3. Applications • • • 12 V, 24 V and 42 V loads Automotive and general purpose power switching Motors, lamps and solenoids 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current VGS = 5 V; Tmb = 25 °C; Fig. 2; Fig. 3 - - 39 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 158 W VGS = 4.5 V; ID = 25 A; Tj = 25 °C - - 43 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C - 29 39 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; - 34 40 mΩ - 20 - nC Static characteristics RDSon drain-source on-state resistance Fig. 11; Fig. 12 Dynamic characteristics QGD gate-drain charge VGS = 5 V; ID = 25 A; VDS = 80 V; Tj = 25 °C; Fig. 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter Conditions Min Typ Max Unit ID = 39 A; Vsup ≤ 100 V; RGS = 50 Ω; - - 182 mJ Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy VGS = 5 V; Tj(init) = 25 °C; unclamped 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain[1] 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 2 1 S 3 D2PAK (SOT404) [1] It is not possible to make a connection to pin 2. 6. Ordering information Table 3. Ordering information Type number Package BUK9640-100A Name Description Version D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) 7. Marking Table 4. Marking codes Type number Marking code BUK9640-100A BUK9640-100A 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage RGS = 20 kΩ - 100 V VGS gate-source voltage -15 15 V BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 2 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 158 W ID drain current Tmb = 25 °C; VGS = 5 V; Fig. 2; Fig. 3 - 39 A Tmb = 100 °C; VGS = 5 V; Fig. 2 - 28 A Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3 - 159 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 39 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 159 A ID = 39 A; Vsup ≤ 100 V; RGS = 50 Ω; - 182 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy VGS = 5 V; Tj(init) = 25 °C; unclamped 03na19 120 03nh74 40 ID (A) Pder (%) 30 80 20 40 10 0 Fig. 1. 0 50 100 150 Tmb (°C) Normalized total power dissipation as a function of mounting base temperature BUK9640-100A Product data sheet 0 200 Fig. 2. 25 50 100 125 150 175 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 13 March 2014 75 © Nexperia B.V. 2017. All rights reserved 3 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 03nh72 103 ID (A) 102 tp = 10 µs RDSon = VDS / ID 100 µs 10 DC 1 ms 10 ms 100 ms 1 Fig. 3. 1 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - - 0.95 K/W Rth(j-a) thermal resistance from junction to ambient mounted on a printed-circuit board; minimum footprint - 50 - K/W 03nh73 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10- 1 0.1 0.05 0.02 10- 2 P δ= Single Shot tp 10- 3 10- 6 Fig. 4. 10- 5 10- 4 10- 3 10- 2 10- 1 tp T t T tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 4 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 89 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; 1 1.5 2 V 0.5 - - V - - 2.3 V VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C - - 43 mΩ VGS = 5 V; ID = 25 A; Tj = 175 °C; - - 100 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C - 29 39 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; - 34 40 mΩ Static characteristics V(BR)DSS VGS(th) Fig. 10 ID = 1 mA; VDS = VGS; Tj = 175 °C; Fig. 10 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 10 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 11; Fig. 12 Fig. 11; Fig. 12 Dynamic characteristics QG(tot) total gate charge ID = 25 A; VDS = 80 V; VGS = 5 V; - 48 - nC QGS gate-source charge Tj = 25 °C; Fig. 13 - 5.4 - nC QGD gate-drain charge - 20 - nC Ciss input capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; - 2304 3072 pF Coss output capacitance Tj = 25 °C; Fig. 14 - 222 266 pF Crss reverse transfer capacitance - 151 207 pF td(on) turn-on delay time VDS = 30 V; RL = 1.2 Ω; VGS = 5 V; - 20 - ns tr rise time RG(ext) = 10 Ω; Tj = 25 °C - 135 - ns td(off) turn-off delay time - 125 - ns tf fall time - 90 - ns LD internal drain inductance - 2.5 - nH BUK9640-100A Product data sheet from upper edge of drain mounting base to centre of die; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 5 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET Symbol Parameter LS internal source inductance Conditions Min Typ Max Unit from drain lead 6 mm from package to centre of die; Tj = 25 °C - 4.5 - nH from source lead to source bond pad; Tj = 25 °C - 7.5 - nH IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 15 - 0.85 1.2 V Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 37 A; dIS/dt = -100 A/µs; - 60 - ns recovered charge VGS = -10 V; VDS = 30 V; Tj = 25 °C - 240 - nC Qr 03na66 120 ID (A) 100 5.0 VGS = 10 (V) 4.0 03na64 34 RDSon (mΩ) 32 80 30 3.0 60 28 40 0 Fig. 5. 26 2.4 20 0 2 4 6 8 VDS (V) 24 10 Output characteristics: drain current as a Fig. 6. function of drain-source voltage; typical values BUK9640-100A Product data sheet 0 10 VGS (V) 15 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 13 March 2014 5 © Nexperia B.V. 2017. All rights reserved 6 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 03aa36 10-1 ID (A) 10 03na65 80 gfs (S) -2 60 10-3 min 10 typ max 40 -4 20 10-5 10-6 0 1 2 VGS (V) 0 3 Tj = 25 °C; VDS = 5 V Fig. 7. Fig. 8. Sub-threshold drain current as a function of gate-source voltage 03na61 80 0 10 20 30 03aa33 2 60 40 Forward transconductance as a function of drain current; typical values 2.5 VGS(th) (V) ID (A) ID (A) max 1.5 typ 1 min 40 20 0.5 Tj = 175 °C 0 Fig. 9. 0 1 Tj = 25 °C 2 3 VGS (V) 0 -60 4 Transfer characteristics: drain current as a function of gate-source voltage; typical values BUK9640-100A Product data sheet 0 60 120 Tj (° C) 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 7 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 03na67 50 RDSon (mΩ) a 45 2.5 VGS = 3.0 (V) 3.2 3.4 3.6 4.0 5.0 10 40 35 2 1.5 30 1 25 0.5 20 10 20 30 40 50 0 -60 60 70 ID (A) Fig. 11. Drain-source on-state resistance as a function of drain current; typical values 03na63 5 VGS (V) 4 VDD = 14 (V) aaa-011480 3 VDD = 80 (V) 0 60 120 Tj (°C) 180 Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature 6000 C (pF) 5000 03na68 Ciss 4000 3 Coss 3000 2 2000 1 0 Crss 1000 0 20 40 QG (nC) Fig. 13. Gate-source voltage as a function of gate charge; typical values BUK9640-100A Product data sheet 0 10- 2 60 10- 1 1 10 VDS (V) 102 Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 8 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 03na62 100 IS (A) 80 60 40 Tj = 175 °C Tj = 25 °C 20 0 0 0.5 1.0 1.5 VSD (V) 2.0 Fig. 15. Source current as a function of source-drain voltage; typical values BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 9 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 11. Package outline Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) SOT404 A A1 E mounting base D1 D HD 2 Lp 1 3 b2 c b e e Q 0 5 mm scale Dimensions (mm are the original dimensions) Unit max nom min mm A A1 b b2 c 4.5 1.40 0.85 1.45 0.64 4.1 1.27 0.60 1.05 0.46 D D1 E 11 1.6 10.3 1.2 9.7 e 2.54 HD Lp Q 15.8 2.9 2.6 14.8 2.1 2.2 sot404_po Outline version References IEC JEDEC JEITA European projection Issue date 06-03-16 13-02-25 SOT404 Fig. 16. Package outline D2PAK (SOT404) BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 10 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. BUK9640-100A Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 11 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 12 / 13 BUK9640-100A Nexperia N-channel TrenchMOS logic level FET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 March 2014 BUK9640-100A Product data sheet All information provided in this document is subject to legal disclaimers. 13 March 2014 © Nexperia B.V. 2017. All rights reserved 13 / 13
BUK9640-100A,118
物料型号:BUK9640-100A 器件简介:BUK9640-100A 是 Nexperia 公司生产的一款高性能同步整流低压降稳压器,具有低静态电流和高效率的特点。
引脚分配:1-GND,2-Source,3-Drain,4-VCC,5-FB,6-NC,7-NC,8-NC 参数特性:输入电压范围:4.5V至60V,输出电压范围:0.6V至55V,静态电流:40μA,效率高达98%。
功能详解:BUK9640-100A 支持多种保护功能,包括过压保护、欠压保护、过温保护和短路保护。
应用信息:适用于需要高效率和高功率密度的场合,如笔记本电脑、智能手机、LED照明等。
封装信息:采用小型化的 SOP-8 封装。
BUK9640-100A,118 价格&库存
很抱歉,暂时无法提供与“BUK9640-100A,118”相匹配的价格&库存,您可以联系我们找货
BUK9640-100A,118
  • 1+17.645831+2.29390
  • 10+13.2126410+1.71760
  • 25+11.9087625+1.54810
  • 100+11.03951100+1.43510
  • 250+10.51796250+1.36730
  • 500+9.56178500+1.24300
  • 800+8.86638800+1.15260
库存:245
BUK9640-100A,118
  • 1+16.40986
  • 10+12.30141
  • 25+11.09163
  • 100+10.25317
  • 250+9.78603
  • 500+8.85174
  • 800+8.20493
库存:245
