PSMN063-150D,118
PSMN063-150D,118
    NEXPERIA(安世)
    TO-252(DPAK)
    MOS管 N-channel Id=29A VDS=150V SOT428
PSMN063-150D,118 数据手册
PSMN063-150D N-channel TrenchMOS SiliconMAX standard level FET Rev. 04 — 17 December 2009 Product data sheet 1. Product profile 1.1 General description SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Higher operating power due to low thermal resistance „ Low conduction losses due to low on-state resistance „ Suitable for high frequency applications due to fast switching characteristics 1.3 Applications „ DC-to-DC convertors „ Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 150 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 and 3 - - 29 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 150 W VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 10 and 11 - 60 63 mΩ Static characteristics RDSon drain-source on-state resistance PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb [1] D G mbb076 S 2 1 3 SOT428 (DPAK) [1] It is not possible to make a connection to pin 2. 3. Ordering information Table 3. Ordering information Type number PSMN063-150D Package Name Description Version DPAK plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 150 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 150 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 100 °C; see Figure 1 and 3 - 20 A VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3 - 29 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 116 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 150 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 29 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 116 A - 502 mJ - 29 A Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 26 A; Vsup ≤ 25 V; drain-source avalanche tp = 0.2 ms; unclamped; RGS = 50 Ω energy IAS non-repetitive avalanche current Vsup ≤ 25 V; VGS = 10 V; Tj(init) = 25 °C; RGS = 50 Ω; unclamped © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 2 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03aa24 120 03aa16 120 Ider (%) Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 1. 200 Tmb (°C) Fig 2. Normalized continuous drain current as a function of mounting base temperature Normalized total power dissipation as a function of mounting base temperature 003aaa148 103 ID (A) RDSon = VDS / ID 102 tp = 10 μs 100 μs 10 1 ms DC 100 ms 10 ms 1 10−1 1 102 10 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 3 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 1 K/W Rth(j-a) thermal resistance from junction to ambient vertical in still air - 50 - K/W 003aaa149 10 Zth(j-mb) (K/W) 1 δ= 0.5 0.2 10−1 0.1 0.05 0.02 δ= P 10−2 single pulse t tp 10−3 10−6 tp T T 10−5 10−4 10−3 10−2 10−1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 4 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 133 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 150 - - V gate-source threshold voltage ID = 1 mA; VDS= VGS; Tj = 175 °C; see Figure 9 1 - - V ID = 1 mA; VDS= VGS; Tj = -55 °C; see Figure 9 - - 6 V ID = 1 mA; VDS= VGS; Tj = 25 °C; see Figure 9 2 3 4 V drain leakage current VDS = 150 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VDS = 150 V; VGS = 0 V; Tj = 175 °C - - 500 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 0.02 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 0.02 100 nA VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 10 and 11 - - 176 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 10 and 11 - 60 63 mΩ IGSS gate leakage current RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge ID = 30 A; VDS = 120 V; VGS = 10 V; Tj = 25 °C; see Figure 12 - 55 - nC QGS gate-source charge ID = 30 A; VDS = 120 V; VGS = 120 V; Tj = 25 °C; see Figure 12 - 10 - nC QGD gate-drain charge ID = 30 A; VDS = 120 V; VGS = 10 V; Tj = 25 °C; see Figure 12 - 20 27 nC Ciss input capacitance Coss output capacitance VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 13 Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) tf - 2390 - pF - 240 - pF - 98 - pF - 14 - ns - 50 - ns turn-off delay time - 48 - ns fall time - 38 - ns VDS = 75 V; RL = 2.7 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 14 - 0.9 1.2 V trr reverse recovery time - 105 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 0.55 - µC © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 5 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03aa35 10−1 ID (A) min 10−2 typ 003aaa150 30 VGS (V) = 10 ID (A) max 6.0 8.0 20 5.4 10−3 5.2 10−4 5.0 10 4.8 10−5 4.6 4.4 10−6 0 0 2 4 0 6 0.4 0.8 1.2 1.6 2.0 VDS (V) VGS (V) Fig 5. Sub-threshold drain current as a function of gate-source voltage Fig 6. 003aaa152 30 Output characteristics: drain current as a function of drain-source voltage; typical values 003aaa153 40 gfs (S) ID (A) Tj = 25 °C 30 20 Tj = 175 °C Tj = 175 °C 20 25 °C 10 10 0 0 2 4 6 0 8 0 10 20 30 VGS (V) Fig 7. Transfer characteristics: drain current as a function of gate-source voltage; typical values ID (A) Fig 8. Forward transconductance as a function of drain current; typical values © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 6 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 03aa32 5 VGS(th) (V) 003aaa151 0.20 4.4 4.6 4.8 RDSon (Ω) 4 5.0 max 0.16 typ 0.12 5.2 3 2 5.4 0.08 min 6 1 0.04 VGS (V) = 8 0 −60 Fig 9. 0 0 60 120 180 0 5 10 15 20 25 30 ID (A) Tj (°C) Gate-source threshold voltage as a function of junction temperature 03aa30 3 Fig 10. Drain-source on-state resistance as a function of drain current; typical values 003aaa155 12 VGS (V) a 2 10 VDD = 30 V 8 VDD = 120 V 1 0 -60 4 0 0 60 120 Tj (°C) 180 Fig 11. Normalized drain-source on-state resistance factor as a function of junction temperature 0 40 60 QG (nC) Fig 12. Gate-source voltage as a function of gate charge; typical values © PSMN063-150D_4 Product data sheet 20 Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 7 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 003aaa154 104 P (pF) 003aaa156 30 IS (A) Ciss Tj = 175 °C 103 20 Coss Tj = 25 °C Crss 102 10 10−1 10 1 102 10 0 0 0.4 0.8 1.2 VDS (V) VSD (V) Fig 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values Fig 14. Source current as a function of source-drain voltage; typical values © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 8 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 7. Package outline Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 y E A A A1 b2 E1 mounting base D2 D1 HD 2 L L2 1 L1 3 b1 b w M c A e e1 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 b2 c D1 D2 min E E1 min e e1 HD L L1 min L2 w y max mm 2.38 2.22 0.93 0.46 0.89 0.71 1.1 0.9 5.46 5.00 0.56 0.20 6.22 5.98 4.0 6.73 6.47 4.45 2.285 4.57 10.4 9.6 2.95 2.55 0.5 0.9 0.5 0.2 0.2 OUTLINE VERSION SOT428 REFERENCES IEC JEDEC JEITA TO-252 SC-63 EUROPEAN PROJECTION ISSUE DATE 06-02-14 06-03-16 Fig 15. Package outline SOT428 (DPAK) © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 9 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN063-150D_4 20091217 Product data sheet - PSMN063_150D-03 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. PSMN063_150D-03 (9397 750 08594) 20011031 Product data - PSMN063-150D_2 PSMN063-150D_2 19990801 Product specification - PSMN063-150D_1 PSMN063-150D_1 19990201 Objective specification - - © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 10 of 12 PSMN063-150D Nexperia N-channel TrenchMOS SiliconMAX standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft— The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet— A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General— Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes— Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use— Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications— Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data— The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values— Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale— Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license— Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control— This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit:http://www.nexperia.com For sales office addresses, please send an email to:salesaddresses@nexperia.com © PSMN063-150D_4 Product data sheet Rev. 04 — 17 December 2009 Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia PSMN063-150D N-channel TrenchMOS SiliconMAX standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 December 2009
PSMN063-150D,118 价格&库存
很抱歉,暂时无法提供与“PSMN063-150D,118”相匹配的价格&库存,您可以联系我们找货
