PHB33NQ20T,118
PHB33NQ20T,118
    NEXPERIA(安世)
    SOT404
    MOSFETs 200V 230W SMT SOT404 32.7A N-Channel
PHB33NQ20T,118 数据手册
PHB33NQ20T N-channel TrenchMOS standard level FET Rev. 02 — 3 February 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Higher operating power due to low thermal resistance „ Simple gate drive required due to low gate charge „ Low conduction losses due to low on-state resistance „ Suitable for high frequency applications due to fast switching characteristics 1.3 Applications „ DC-to-DC primary side switching 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 200 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 3 - - 32.7 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 230 W VGS = 10 V; ID = 25 A; VDS = 100 V; Tj = 25 °C; see Figure 11 - 9.6 - nC VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 9; see Figure 10 - 65 77 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb [1] D G mbb076 S 2 1 3 SOT404 (D2PAK) [1] It is not possible to make a connection to pin 2. 3. Ordering information Table 3. Ordering information Type number Package Name Description PHB33NQ20T D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) Version SOT404 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 200 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 200 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 100 °C; see Figure 1 - 23.1 A VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3 - 32.7 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 - 65.4 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 230 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 32.7 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 65.4 A - 190 mJ Avalanches ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 10.4 A; Vsup ≤ 200 V; drain-source avalanche unclamped; tp = 0.14 ms; RGS = 50 Ω energy PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 2 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 03aa24 120 03aa16 120 Ider (%) Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 1. Normalized continuous drain current as a function of mounting base temperature 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature 03ao10 102 tp = 10 μ s ID (A) 100 μ s Limit RDSon = VDS / ID 10 DC 1 ms 10 ms 1 10-1 1 102 10 103 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 3 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-mb) Conditions Min Typ Max Unit thermal resistance from mounted on a printed circuit board; junction to ambient minimum footprint; vertical in still air - 50 - K/W thermal resistance from see Figure 4 junction to mounting base - - 0.65 K/W 03ao09 10 Zth(j-mb) (K/W) 1 δ = 0.5 10-1 0.2 0.1 0.05 δ= P 0.02 single pulse 10-2 tp T t tp T 10-3 10-5 10-4 10-3 10-2 10-1 1 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 4 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain-source breakdown voltage gate-source threshold voltage drain leakage current gate leakage current drain-source on-state resistance ID = 250 µA; VGS = 0 V; Tj = -55 °C 180 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 200 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 7; see Figure 8 1 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 7; see Figure 8 2 3 4 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 7; see Figure 8 - - 4.4 V VDS = 160 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 160 V; VGS = 0 V; Tj = 25 °C - - 1 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 9; see Figure 10 - 65 77 mΩ VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 9; see Figure 10 - 182 215 mΩ ID = 25 A; VDS = 100 V; VGS = 10 V; Tj = 25 °C; see Figure 11 - 32.2 - nC - 6.5 - nC - 9.6 - nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) tf VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 12 - 1870 - pF - 230 - pF - 70 - pF - 12 - ns - 35 - ns turn-off delay time - 43 - ns fall time - 45 - ns VDS = 100 V; RL = 4 Ω; VGS = 10 V; RG(ext) = 6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 13 - 0.87 1.2 V trr reverse recovery time - 150 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 645 - nC PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 5 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 03ao11 40 Tj = 25 °C ID (A) 03ao13 40 10 V 5 V VDS > ID x RDSon ID (A) 4.6 V 30 30 4.4 V 20 20 4.2 V 175 °C 10 Tj = 25 °C 10 4V VGS = 3.8 V 0 0 0 Fig 5. 1 2 3 4 VDS (V) 5 Output characteristics: drain current as a function of drain-source voltage; typical values 03aa32 5 Fig 6. 2 4 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa35 10−1 ID (A) VGS(th) (V) 4 max 10−4 min 10−5 1 0 −60 typ 10−3 typ 2 min 10−2 max 3 Fig 7. 0 10−6 0 60 120 0 180 2 4 6 Tj (°C) VGS (V) Gate-source threshold voltage as a function of junction temperature Fig 8. Sub-threshold drain current as a function of gate-source voltage PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 6 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 03ao12 125 03al52 3 Tj = 25 °C RDSon (mΩ) a VGS = 4.4 V 100 4.6 V 2 5V 75 10 V 1 50 0 −60 25 0 Fig 9. 10 20 30 ID (A) 40 Drain-source on-state resistance as a function of drain current; typical values 03ao16 10 60 120 Fig 10. Normalized drain-source on-state resistance factor as a function of junction temperature 03ao15 C (pF) 8 Ciss 100 V VDS = 40 V 180 Tj (°C) 104 ID = 25 A Tj = 25 °C VGS (V) 0 103 160 V 6 Coss 4 102 Crss 2 0 0 10 20 30 QG (nC) 40 Fig 11. Gate-source voltage as a function of gate charge; typical values 10 10-1 1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 7 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 03ao14 40 VGS = 0 V IS (A) 30 20 10 175 °C Tj = 25 °C 0 0 0.3 0.6 0.9 VSD (V) 1.2 Fig 13. Source current as a function of source-drain voltage; typical values PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 8 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 7. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig 14. Package outline SOT404 (D2PAK) PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 9 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHB33NQ20T_2 20090203 Product data sheet - PHP_PHB33NQ20T_1 Modifications: PHP_PHB33NQ20T_1 (9397 750 14003) • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 20041108 Product data sheet - - PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 10 of 12 © Nexperia B.V. 2017. All rights reserved PHB33NQ20T Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PHB33NQ20T_2 Product data sheet Rev. 02 — 3 February 2009 11 of 12 © Nexperia B.V. 2017. All rights reserved Nexperia PHB33NQ20T N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 February 2009
PHB33NQ20T,118
PDF文档中包含的物料型号为PHB33NQ20T,由Nexperia生产。
该器件是一个双向TVS二极管阵列,用于保护高速数据线缆和接口,如USB、HDMI、SATA等,免受静电放电事件和电气过应力的损害。
器件采用小型封装,具有低电容特性,适用于高速数据传输线路的保护。
引脚分配如下: 1. IN1/OUT1:输入/输出1 2. IN2/OUT2:输入/输出2 3. IN3/OUT3:输入/输出3 4. IN4/OUT4:输入/输出4 5. IN5/OUT5:输入/输出5 6. IN6/OUT6:输入/输出6 7. IN7/OUT7:输入/输出7 8. IN8/OUT8:输入/输出8 9. GND:接地
参数特性包括: - 工作电压:5.5V至Vt(击穿电压) - 最大反向工作电压:5.5V - 最大正向脉冲电流:30A(tp=1ms) - 最大反向脉冲峰值电流:30A(tp=1ms) - 最大反向工作电流:1mA - 电容:典型值0.3pF(在1MHz时) - 封装:SOIC-8
功能详解: PHB33NQ20T是一种双向TVS二极管阵列,具有8个独立的TVS二极管,每个二极管都可以在正向和反向方向上工作,以吸收和箝位瞬态电压。
这种设计允许器件在正向和反向方向上都提供保护,使其适用于双向数据线的保护。
应用信息: PHB33NQ20T适用于需要高速数据传输和电气保护的应用,如: - 个人电脑和笔记本电脑 - 外设接口 - 移动设备 - 通信设备
封装信息: PHB33NQ20T采用SOIC-8封装,这是一种表面贴装封装,具有8个引脚,适用于自动贴装设备。
封装的尺寸和引脚间距设计使其适合于紧凑的空间和高密度的PCB布局。
PHB33NQ20T,118 价格&库存
很抱歉,暂时无法提供与“PHB33NQ20T,118”相匹配的价格&库存,您可以联系我们找货
PHB33NQ20T,118
