BUK9606-55B,118
BUK9606-55B,118
    NEXPERIA(安世)
    SOT404
    MOS管 N-channel Id=75A VDS=55V SOT404
BUK9606-55B,118 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BUK9506-55B N-channel TrenchMOS FET Rev. 04 — 23 July 2009 Product data sheet 1. Product profile 1.1 General description N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Suitable for logic level gate drive sources „ Q101 compliant „ Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications „ 12 V and 24 V loads „ General purpose power switching „ Automotive systems „ Motors, lamps and solenoids 1.4 Quick reference data Table 1. Quick reference Symbol Parameter VDS Conditions drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C [1] Min Typ Max Unit - - 55 V - - 75 A ID drain current VGS = 5 V; Tmb = 25 °C; see Figure 1 and 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 258 W ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 5 V; Tj(init) = 25 °C; unclamped - - 679 mJ VGS = 5 V; ID = 25 A; VDS = 44 V; Tj = 25 °C; see Figure 14 and 15 - 22 - nC Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Dynamic characteristics QGD gate-drain charge BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET Table 1. Quick reference …continued Symbol Parameter Conditions Min Typ Max Unit VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 11 and 12 - 4.8 5.4 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 11 and 12 - 5.1 6 mΩ Static characteristics RDSon [1] drain-source on-state resistance Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate Simplified outline 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number BUK9506-55B Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 2 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 55 V VDGR drain-gate voltage RGS = 20 kΩ VGS gate-source voltage ID drain current Tmb = 25 °C; VGS = 5 V; see Figure 1 and 3 Tmb = 100 °C; VGS = 5 V; see Figure 1 - 55 V -15 15 V [1] - 146 A [2] - 75 A [2] - 75 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 - 587 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 258 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C [1] - 146 A [2] - 75 A - 587 A - 679 mJ Source-drain diode source current IS Tmb = 25 °C; peak source current ISM tp ≤ 10 µs; pulsed; Tmb = 25 °C Avalanche ruggedness non-repetitive ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 5 V; drain-source avalanche Tj(init) = 25 °C; unclamped energy EDS(AL)S [1] Current is limited by power dissipation chip rating. [2] Continuous current is limited by package. 03nh85 150 03aa16 120 ID (A) Pder (%) 80 100 Capped at 75 A due to package 50 40 0 0 0 Fig 1. 50 100 150 Tmb ( °C) 200 0 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature BUK9506-55B_4 Product data sheet 50 © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 3 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 03nh83 103 tp = 10 μ s Limit RDSon = VDS / ID ID (A) 102 100 μ s Capped at 75 A due to package 1 ms DC 10 10 ms 100 ms 1 10-1 Fig 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 4 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 0.58 K/W Rth(j-a) thermal resistance from junction to ambient - 60 - K/W 03nh84 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10-1 0.1 0.05 0.02 δ= P 10-2 single shot tp T t tp T 10-3 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 5 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 50 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 55 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 and 10 - - 2.3 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9 and 10 1.1 1.5 2 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 9 and 10 0.5 - - V VDS = 55 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 55 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 0 V; VGS = 15 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -15 V; Tj = 25 °C - 2 100 nA VGS = 4.5 V; ID = 25 A; Tj = 25 °C; see Figure 11 and 12 - - 6.4 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 11 and 12 - 4.8 5.4 mΩ VGS = 5 V; ID = 25 A; Tj = 175 °C; see Figure 11 and 12 - - 12 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 11 and 12 - 5.1 6 mΩ ID = 25 A; VDS = 44 V; VGS = 5 V; Tj = 25 °C; see Figure 14 and 15 - 60 - nC - 11 - nC - 22 - nC Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 44 V; Tj = 25 °C; see Figure 14 and 15 - 2.4 - V Ciss input capacitance - 5674 7565 pF Coss output capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 755 906 pF Crss reverse transfer capacitance - 255 350 pF td(on) turn-on delay time - 37 - ns tr rise time - 95 - ns td(off) turn-off delay time - 117 - ns tf fall time - 106 - ns LD internal drain inductance from drain lead 6 mm from package to center of die; Tj = 25 °C - 4.5 - nH from contact screw on mounting base to center of die; Tj = 25 °C - 3.5 - nH from source lead to source bonding pad; Tj = 25 °C - 7.5 - nH LS internal source inductance VDS = 30 V; RL = 1.2 Ω; VGS = 5 V; RG(ext) = 10 Ω; Tj = 25 °C BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 6 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 13 - 0.85 1.2 V trr reverse recovery time - 64 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V; Tj = 25 °C - 79 - nC 03nj65 350 ID 10 (A) 300 6 5 3.8 14 RDSon (mΩ) 12 3.6 10 4.2 VGS (V) is 4 250 200 3.4 150 3.2 100 3 03nj66 3 3.2 VGS (V) is 3.4 4 8 5 10 6 2.8 4 50 2.6 2.4 2 0 0 Fig 5. 2 4 6 8 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 03nj62 200 0 10 Fig 6. 100 200 300 I (A) 400 D Drain-source on-state resistance as a function of drain current; typical values 03nj63 100 ID (A) gfs (S) 150 75 100 50 50 25 Tj = 175 °C Tj = 25 °C 0 0 0 Fig 7. 20 40 60 I D (A) 80 Forward transconductance as a function of drain current; typical values 0 Fig 8. 2 VGS (V) 3 Transfer characteristics: drain current as a function of gate-source voltage; typical values BUK9506-55B_4 Product data sheet 1 © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 7 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 03ng52 2.5 03ng53 10−1 ID (A) VGS(th) (V) 2.0 10−2 max min 1.5 typ 10−5 0.5 0 −60 Fig 9. max 10−4 min 1.0 typ 10−3 10−6 0 60 120 180 0 1 2 Tj (°C) Gate-source threshold voltage as a function of junction temperature Fig 10. Sub-threshold drain current as a function of gate-source voltage 03nj64 7 3 VGS (V) 03ne89 2 a RDSon (mΩ) 1.5 6 1 5 0.5 4 3 7 11 VGS (V) 15 Fig 11. Drain-source on-state resistance as a function of gate-source voltage; typical values 0 -60 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature BUK9506-55B_4 Product data sheet 0 © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 8 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 03nj60 100 03nj61 5 VGS (V) IS (A) 4 75 VDD = 14 V 3 VDD = 44 V 50 2 Tj = 175 °C 25 1 Tj = 25 °C 0 0.0 0 0.2 0.4 0.6 0.8 0 1.0 VSD (V) Fig 13. Source current as a function of source-drain voltage; typical values 20 40 60 QG (nC) Fig 14. Gate-source voltage as a function of gate charge; typical values 03nj67 8000 VDS C (pF) ID Ciss 6000 VGS(pl) VGS(th) 4000 Coss VGS QGS1 QGS2 QGS 2000 QGD QG(tot) Crss 003aaa508 Fig 15. Gate charge waveform definitions 0 10-1 1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 9 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) e c e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 17. Package outline SOT78 (TO-220AB) BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 10 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK9506-55B_4 20090723 Product data sheet - BUK95_96_9E06_55B_3 Modifications: BUK95_96_9E06_55B_3 (9397 750 13519) • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK9506-55B separated from data sheet BUK95_96_9E06_55B_3. 20041130 Product data sheet - BUK95_96_9E06_55B-02 BUK95_96_9E06_55B-02 20021010 (9397 750 10474) Product data - BUK95_96_9E06_55B-01 BUK95_96_9E06_55B-01 20020813 (9397 750 09946) Product data - - BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 11 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. TrenchMOS — is a trademark of NXP B.V. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BUK9506-55B_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 23 July 2009 12 of 13 BUK9506-55B NXP Semiconductors N-channel TrenchMOS FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 23 July 2009 Document identifier: BUK9506-55B_4
BUK9606-55B,118 价格&库存
很抱歉,暂时无法提供与“BUK9606-55B,118”相匹配的价格&库存,您可以联系我们找货
BUK9606-55B,118
    • 1+3.02400
    • 10+2.38680
    • 30+2.11680
    • 100+1.78200
    • 500+1.63080
    • 800+1.54440
