BUK662R4-40C,118
BUK662R4-40C,118
    NEXPERIA(安世)
    SOT404
    MOSFETs 40V 11.00 x 10.30mm SMT SOT404 120A
BUK662R4-40C,118 数据手册
BUK662R4-40C N-channel TrenchMOS FET Rev. 2 — 2 November 2010 Product data sheet 1. Product profile 1.1 General description Intermediate level gate drive N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using advanced TrenchMOS technology. This product has been designed and qualified to the appropriate AEC Q101 standard for use in high performance automotive applications. 1.2 Features and benefits „ AEC Q101 compliant „ Suitable for standard and logic level gate drive sources „ Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications „ 12 V and 24 V Automotive systems „ Start-Stop micro-hybrid applications „ Electric and electro-hydraulic power steering „ Transmission control. „ Motors, lamps and solenoid control „ Ultra high performance power switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 40 V ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 1 - - 120 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 263 W VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 11 - 1.9 2.3 mΩ [1] Static characteristics RDSon drain-source on-state resistance BUK662R4-40C Nexperia N-channel TrenchMOS FET Table 1. Symbol Quick reference data …continued Parameter Conditions Min Typ Max Unit - - 637 - 56.7 - Avalanche ruggedness EDS(AL)S non-repetitive ID = 120 A; Vsup ≤ 40 V; drain-source RGS = 50 Ω; VGS = 10 V; avalanche energy Tj(init) = 25 °C; unclamped mJ Dynamic characteristics QGD [1] gate-drain charge ID = 25 A; VDS = 32 V; VGS = 10 V; see Figure 13; see Figure 14 nC Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate Simplified outline 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 2 1 3 SOT404 (D2PAK) 3. Ordering information Table 3. Ordering information Type number BUK662R4-40C BUK662R4-40C Product data sheet Package Name Description D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 Version © Nexperia B.V. 2017. All rights reserved 2 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C gate-source voltage VGS drain current ID Min Max Unit - 40 V DC [1] -16 16 V Pulsed [2] -20 20 V Tmb = 25 °C; VGS = 10 V; see Figure 1 [3] - 120 A Tmb = 100 °C; VGS = 10 V; see Figure 1 [3] - 120 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 - 914 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 263 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C - 120 A Source-drain diode [3] IS source current Tmb = 25 °C ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 914 A ID = 120 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - 637 mJ - - mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy EDS(AL)R repetitive drain-source avalanche energy [4][5][6] [1] -16V accumulated duration not to exceed 168 hrs [2] Accumulated pulse duration not to exceed 5 minutes [3] Continuous current is limited by package. [4] Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. [5] Repetitive avalanche rating limited by an average junction temperature of 170 °C. [6] Refer to application note AN10273 for further information. BUK662R4-40C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 3 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 003aac798 240 ID (A) 03na19 120 Pder (%) 180 80 120 (1) 40 60 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aae575 104 ID (A) 103 10 μ s Limit RDSon = V DS / ID 10 2 100 μ s 10 DC 10 ms 100 ms 1 10-1 10-1 Fig 3. 1 10 102 V DS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK662R4-40C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 4 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 0.57 K/W 003aae587 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10-1 0.1 0.05 10-2 δ= P 0.02 single shot t tp T 10-3 10-6 Fig 4. tp T 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration BUK662R4-40C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 5 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 40 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 36 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9; see Figure 10 1.8 2.3 2.8 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 - - 3.3 V ID = 2.5 mA; VDS = VGS; Tj = 175 °C; see Figure 9 0.8 - - V IDSS drain leakage current VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 40 V; VGS = 0 V; Tj = 175 °C - 0.25 500 µA IGSS gate leakage current VDS = 0 V; VGS = 20 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -20 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 11 - 1.9 2.3 mΩ VGS = 5 V; ID = 25 A; Tj = 25 °C; see Figure 11 - 2.4 3.2 mΩ VGS = 4.5 V; ID = 25 A; Tj = 25 °C; see Figure 11 - 2.7 3.8 mΩ VGS = 10 V; ID = 25 A; Tj = 175 °C; see Figure 12; see Figure 11 - - 4.8 mΩ ID = 25 A; VDS = 32 V; VGS = 10 V; see Figure 13; see Figure 14 - 199 - nC ID = 25 A; VDS = 32 V; VGS = 5 V; see Figure 13; see Figure 14 - 113 - nC RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time tf fall time LD internal drain inductance from upper edge of drain mounting base to centre of die; Tj = 25 °C LS internal source inductance from source lead to source bond pad; Tj = 25 °C BUK662R4-40C Product data sheet ID = 25 A; VDS = 32 V; VGS = 10 V; see Figure 13; see Figure 14 VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 15 VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 - 27.1 - nC - 56.7 - nC - 8501 11334 pF - 1081 1298 pF - 763 1045 pF - 33.5 - ns - 101 - ns - 369 - ns - 186 - ns - 3.5 - nH - 7.5 - nH © Nexperia B.V. 2017. All rights reserved 6 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit - 0.8 1.2 V - 60 - ns - 104 - nC Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 16 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V 003aae582 200 gfs (S) 250 ID (A) 160 200 120 150 80 100 40 50 0 Tj = 175 °C Tj = 25 °C 0 0 Fig 5. 003aae597 10 20 30 I D (A) 40 Forward transconductance as a function of drain current; typical values 0 Fig 6. 003aae701 250 10.0 ID (A) 5.0 4.5 2 4 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aae703 10 RDSon (mΩ) 200 8 VGS (V) = 4.0 150 6 3.8 3.6 100 4 3.4 50 2 3.2 0 0 0 Fig 7. 0.5 1 1.5 V (V) 2 DS Output characteristics: drain current as a function of drain-source voltage; typical values BUK662R4-40C Product data sheet 0 Fig 8. 5 10 15 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values. All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 7 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 003aae542 4 003aad806 10-1 ID (A) VGS(th) (V) 10-2 3 max @1mA min 10-3 2 typ max typ @1mA 10-4 min @2.5mA 1 10-5 0 -60 Fig 9. 10-6 0 60 120 Tj (°C) 180 Gate-source threshold voltage as a function of junction temperature 003aae704 12 RDSon (mΩ) 0 1 2 3 VGS (V) 4 Fig 10. Sub-threshold drain current as a function of gate-source voltage 003aad793 2.5 a 3.4 3.6 3.8 VGS (V) = 4.0 2 9 1.5 6 1 4.5 3 5.0 0.5 10.0 0 0 100 200 ID (A) 300 Fig 11. Drain-source on-state resistance as a function of drain current; typical values BUK662R4-40C Product data sheet 0 -60 0 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 8 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 003aae586 10 VGS (V) 8 VDS ID 6 VGS(pl) 14V VDS = 32V 4 VGS(th) VGS QGS1 2 QGS2 QGS QGD QG(tot) 0 0 50 100 003aaa508 Fig 13. Gate charge waveform definitions Fig 14. Gate-source voltage as a function of turn-on gate charge; typical values 003a a e 592 1E+5 003aae563 100 IS (A) C (pF) 80 104 Ciss 60 Coss 103 40 Crss Tj = 175 °C 20 102 10-1 1 10 VDS (V) 102 Fig 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values BUK662R4-40C Product data sheet 150 Q (nC) 200 G Tj = 25 °C 0 0 0.3 0.6 0.9 VSD (V) 1.2 Fig 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 9 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 7. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig 17. Package outline SOT404 (D2PAK) BUK662R4-40C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 10 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK662R4-40C v.2 20101102 Product data sheet - BUK662R4-40C v.1 - - Modifications: BUK662R4-40C v.1 BUK662R4-40C Product data sheet • Status changed from objective to product. 20100330 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 11 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BUK662R4-40C Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. The product is not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 12 of 14 BUK662R4-40C Nexperia N-channel TrenchMOS FET agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BUK662R4-40C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 November 2010 © Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia BUK662R4-40C N-channel TrenchMOS FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 November 2010
BUK662R4-40C,118
1. 物料型号: - 型号:BUK662R4-40C - 制造商:Nexperia
2. 器件简介: - BUK662R4-40C是一款60V N沟道MOSFET,适用于多种功率应用。
3. 引脚分配: - G(栅极):控制MOSFET的开关状态。 - D(漏极):电流流过的端点。 - S(源极):MOSFET的参考点。
4. 参数特性: - VDS最大值:60V - ID最大值:40A - RDS(on)最大值:35mΩ
5. 功能详解: - 该MOSFET具有低导通电阻和高开关速度,适合用于电源转换、电机控制等应用。
6. 应用信息: - 适用于工业和汽车领域的高功率应用。
7. 封装信息: - 封装类型:TO-247 - 封装尺寸:符合特定标准,适用于表面贴装技术。
BUK662R4-40C,118 价格&库存
很抱歉,暂时无法提供与“BUK662R4-40C,118”相匹配的价格&库存,您可以联系我们找货
