PSMN034-100PS,127
PSMN034-100PS,127
    NEXPERIA(安世)
    TO-220AB
    MOSFETs 100V 86W DIP TO220AB 32A N-Channel
PSMN034-100PS,127 数据手册
PSMN034-100PS N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. Rev. 02 — 1 March 2010 Objective data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in TO220 package qualified to 175C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits „ High efficiency due to low switching and conduction losses „ Suitable for standard level gate drive 1.3 Applications „ DC-to-DC converters „ Motor control „ Load switching „ Server power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 - - 32 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 86 W Tj junction temperature -55 - 175 °C VGS = 10 V; Tj(init) = 25 °C; ID = 32 A; Vsup ≤ 100 V; unclamped; RGS = 50 Ω - - 42 mJ VGS = 10 V; ID = 15 A; VDS = 50 V; see Figure 12 and 13 - 6.9 - nC - 23.8 - nC VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 11 - - 62 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 16 - 29.3 34.5 mΩ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge Static characteristics RDSon drain-source on-state resistance PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain Simplified outline Graphic symbol mb 3 S source mb D mounting base; connected to drain D G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number PSMN034-100PS PSMN034-100PS_2 Objective data sheet Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 22 A VGS = 10 V; Tmb = 25 °C; see Figure 1 - 32 A - 127 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 86 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 32 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 127 A - 42 mJ Avalanche ruggedness non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 32 A; Vsup ≤ 100 V; drain-source avalanche unclamped; RGS = 50 Ω energy EDS(AL)S 003aae103 40 ID (A) 03aa16 120 Pder (%) 30 80 20 40 10 0 0 0 Fig 1. 50 100 150 T mb( ° C) 200 Objective data sheet 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature PSMN034-100PS_2 0 Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 003aae104 103 ID (A) Limit RDSon = VDS / ID 102 tp =10 μ s 10 100 μ s 1 1 ms 10 ms 100 ms DC 10-1 1 102 10 103 V DS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN034-100PS_2 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - 0.9 1.7 K/W Rth(j-a) thermal resistance from junction to ambient vertical in free air - 50 - K/W 003aae105 1 d = 0.5 Z th(j-mb) (K/W) 0.2 0.1 10-1 0.05 P = 0.02 tp T single shot t tp T 10-2 1e-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 t p (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration; typical values PSMN034-100PS_2 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 90 - - V ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 9 1 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10 and 9 2 3 4 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 and 10 - - 4.8 V VDS = 100 V; VGS = 0 V; Tj = 125 °C - - 50 µA VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA Static characteristics V(BR)DSS drain-source breakdown voltage VGS(th) gate-source threshold voltage IDSS IGSS RDSon RG drain leakage current gate leakage current drain-source on-state resistance VGS = 20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 11 - - 62 mΩ VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 11 - 82.1 96 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 16 - 29.3 34.5 mΩ - 1 - Ω internal gate resistance f = 1 MHz (AC) Dynamic characteristics QG(tot) total gate charge ID = 15 A; VDS = 50 V; VGS = 10 V; see Figure 12 and 13 - 23.8 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 19 - nC QGS gate-source charge ID = 15 A; VDS = 50 V; VGS = 10 V; see Figure 12 and 13 - 5.5 - nC QGS(th) pre-threshold gate-source charge ID = 15 A; VDS = 50 V; VGS = 10 V; see Figure 12 - 3.6 - nC QGS(th-pl) post-threshold gate-source charge - 1.9 - nC QGD gate-drain charge ID = 15 A; VDS = 50 V; VGS = 10 V; see Figure 12 and 13 - 6.9 - nC VGS(pl) gate-source plateau voltage VDS = 50 V; see Figure 12 and 13 - 4.4 - V Ciss input capacitance - 1201 - pF Coss output capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 14 - 94 - pF Crss reverse transfer capacitance - 61 - pF td(on) turn-on delay time - 12 - ns tr rise time - 10 - ns td(off) turn-off delay time - 28 - ns tf fall time - 9 - ns PSMN034-100PS_2 Objective data sheet VDS = 50 V; RL = 3.3 Ω; VGS = 10 V; RG(ext) = 4.7 Ω; Tj = 25 °C All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 15 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.85 1.2 V trr reverse recovery time - 38 - ns Qr recovered charge IS = 5 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 50 V - 59 - nC 003aae110 50 g fs (S) 003aae109 2000 Ciss C (pF) 40 1500 Crss 30 1000 20 500 10 0 0 0 10 20 30 40 0 I D (A) Fig 5. Forward transconductance as a function of drain current; typical values Fig 6. 003aae111 100 R DSon (mΩ) 4 8 Input and reverse capacitances as a function of gate-source voltage; typical values 003aae106 40 I D (A) 10.0 30 80 12 V GS(V) 6.5 5.5 5.0 4.7 20 60 4.5 10 40 VGS (V) = 4 0 20 0 5 10 15 0 20 1 2 3 4 V GS(V) Fig 7. Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN034-100PS_2 Objective data sheet 5 V DS(V) Fig 8. Output characteristics: drain current as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 003aad280 5 ID (A) VGS(th) (V) 4 max 10−4 min 10−5 1 0 −60 typ 10−3 typ 2 min 10−2 max 3 Fig 9. 03aa35 10−1 10−6 0 60 120 180 0 2 4 6 Tj (°C) VGS (V) Gate-source threshold voltage as a function of junction temperature Fig 10. Sub-threshold drain current as a function of gate-source voltage 003aad774 3.2 VDS a ID 2.4 VGS(pl) VGS(th) 1.6 VGS QGS1 0.8 QGS2 QGS QGD QG(tot) 003aaa508 0 -60 0 60 120 Tj (°C) 180 Fig 11. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN034-100PS_2 Objective data sheet Fig 12. Gate charge waveform definitions All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 003aae113 12 003aae112 104 V GS (V) C (pF) 10 8 Ciss 103 20 V 6 VDS = 50 V 102 4 Coss Crss 2 0 0 10 20 30 10 10-1 1 102 10 Q G (nC) V DS(V) Fig 13. Gate-source voltage as a function of gate charge; typical values 003aae107 Fig 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 25 140 RDSon (m ) 120 20 100 15 80 10 60 30 I D (A) 003aae108 VGS (V) = 4.5 4.7 5.0 5 40 Tj = 175 C 5.5 6.5 10.0 Tj = 25 C 0 0 1 2 3 4 VGS(V) 5 Fig 15. Transfer characteristics: drain current as a function of gate-source voltage; typical values PSMN034-100PS_2 Objective data sheet 20 0 10 20 30 ID (A) 40 Fig 16. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 9 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 003aae114 40 IS (A) 30 20 10 Tj = 175 °C Tj = 25 °C 0 0 0.25 0.5 0.75 V SD(V) 1 Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN034-100PS_2 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 10 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 18. Package outline SOT78 (TO-220AB) PSMN034-100PS_2 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 11 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN034-100PS_2 20100301 Objective data sheet - PSMN034-100PS_1 - - Modifications: PSMN034-100PS_1 PSMN034-100PS_2 Objective data sheet • Various changes to content. 20100218 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 12 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PSMN034-100PS_2 Objective data sheet Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 13 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PSMN034-100PS_2 Objective data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 1 March 2010 © Nexperia B.V. 2017. All rights reserved 14 of 15 PSMN034-100PS Nexperia N-channel 100 V 34.5 mΩ standard level MOSFET in TO220. 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 01 March 2010
PSMN034-100PS,127 价格&库存
很抱歉,暂时无法提供与“PSMN034-100PS,127”相匹配的价格&库存,您可以联系我们找货
