BUK765R0-100E
N-channel TrenchMOS standard level FET
28 July 2016
Product data sheet
1. General description
Standard level N-channel MOSFET in a SOT404 package using TrenchMOS technology.
This product has been designed and qualified to AEC Q101 standard for use in high
performance automotive applications.
2. Features and benefits
AEC Q101 compliant
Repetitive avalanche rated
Suitable for thermally demanding environments due to 175 °C rating
True standard level gate with VGS(th) rating of greater than 1 V at 175 °C
3. Applications
12V, 24V and 48V Automotive systems
Electric and electro-hydraulic power steering
Motors, lamps and solenoid control
Start-Stop micro-hybrid applications
Transmission control
Ultra high performance power switching
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
100
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
120
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
349
W
VGS = 10 V; ID = 25 A; Tj = 25 °C;
3.9
5
mΩ
65
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Fig. 11
Dynamic characteristics
QGD
gate-drain charge
VGS = 10 V; ID = 25 A; VDS = 80 V;
Tj = 25 °C; Fig. 13; Fig. 14
[1]
Continuous current is limited by package.
BUK765R0-100E
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
2
1
S
3
D2PAK (SOT404)
6. Ordering information
Table 3.
Type number
Package
BUK765R0-100E
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package
(D2PAK); 3 leads (one lead cropped)
SOT404
7. Marking
Table 4.
Marking codes
Type number
Marking code
BUK765R0-100E
BUK765R0-100E
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VDGR
drain-gate voltage
RGS = 20 kΩ
100
V
VGS
gate-source voltage
Tj ≤ 175 °C; DC
-20
V
Ptot
Tmb = 25 °C; Fig. 1
349
W
ID
drain current
Tmb = 25 °C; VGS = 10 V; Fig. 2
120
A
Tmb = 100 °C; VGS = 10 V; Fig. 2
115
A
Tmb = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3
643
A
[1]
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
BUK765R0-100E
Product data sheet
All information provided in this document is subject to legal disclaimers.
28 July 2016
Nexperia B.V. 2017. All rights reserved
2 / 13
BUK765R0-100E
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
120
A
643
A
385
mJ
Source-drain diode
IS
source current
Tmb = 25 °C
ISM
peak source current
pulsed; tp ≤ 10 µs; Tmb = 25 °C
[1]
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
ID = 120 A; Vsup ≤ 100 V; RGS = 50 Ω;
[2][3]
VGS = 10 V; Tj(init) = 25 °C; unclamped;
Fig. 4
[1]
[2]
[3]
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
Refer to application note AN10273 for further information.
03aa16
120
003aaf632
200
ID
(A)
160
Pder
80
120
(1)
80
40
40
Fig. 1.
100
150
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
BUK765R0-100E
Product data sheet
Fig. 2.
150
Tmb (° C)
200
Continuous drain current as a function of
28 July 2016
50
3 / 13
BUK765R0-100E
Nexperia
ID
(A)
003aaf633
103
Limit RDSon = VDS / ID
tp = 10 us
102
100 us
10
DC
1 ms
10 ms
100 ms
1
10-1
Fig. 3.
1
102
10
VDS (V)
103
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
003aah029
103
IAL
(A)
102
(1)
10
(2)
1
(3)
10-1
10-3
Fig. 4.
10-2
10-1
1
tAL (ms)
10
Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
0.43
K/W
Rth(j-a)
thermal resistance
from junction to
ambient
minimum footprint ; mounted on a
printed-circuit board
50
K/W
BUK765R0-100E
Product data sheet
28 July 2016
4 / 13
BUK765R0-100E
Nexperia
003aaf570
1
Zth(j-mb)
(K/W)
= 0.5
0.2
10-1
0.1
0.05
tp
T
P
10-2
0.02
10-3
10-6
Fig. 5.
t
tp
single shot
10-5
10-4
10-3
10-2
T
10-1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration.
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
100
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
90
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
2.4
3
4
V
1
V
4.5
V
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.1
1
µA
VDS = 100 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
3.9
5
mΩ
13.5
mΩ
V(BR)DSS
VGS(th)
Fig. 9; Fig. 10
ID = 1 mA; VDS = VGS; Tj = 175 °C;
Fig. 9
ID = 1 mA; VDS = VGS; Tj = -55 °C;
Fig. 9
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
Fig. 11
VGS = 10 V; ID = 25 A; Tj = 175 °C;
Fig. 11; Fig. 12
QG(tot)
total gate charge
ID = 25 A; VDS = 80 V; VGS = 10 V;
180
nC
QGS
gate-source charge
34
nC
QGD
gate-drain charge
65
nC
BUK765R0-100E
Product data sheet
28 July 2016
5 / 13
BUK765R0-100E
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Ciss
input capacitance
VGS = 0 V; VDS = 25 V; f = 1 MHz;
8860
11810 pF
Coss
output capacitance
Tj = 25 °C; Fig. 15
770
925
pF
Crss
reverse transfer
capacitance
546
750
pF
td(on)
turn-on delay time
VDS = 80 V; RL = 3.2 Ω; VGS = 10 V;
37
ns
tr
rise time
RG(ext) = 5 Ω
62
ns
td(off)
turn-off delay time
158
ns
tf
fall time
80
ns
LD
internal drain
inductance
from upper edge of mounting base to
centre of die
2.5
nH
LS
internal source
inductance
measured from source lead to source
bond pad; Tj = 25 °C
7.5
nH
IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 16
0.77
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
65
ns
recovered charge
VDS = 25 V
191
nC
Qr
003aaf634
200
VGS
ID
(A)
(V) = 10
6.0
5.5
003aaf639
15
5.0
RDSon
(mΩ)
150
10
100
4.5
5
50
1
1.5
VDS (V)
Tj = 25 °C; tp = 300 μs
Fig. 6.
Fig. 7.
Output characteristics: drain current as a
function of drain-source voltage; typical values
BUK765R0-100E
Product data sheet
15
VGS (V)
Drain-source on-state resistance as a function
of gate-source voltage; typical values
28 July 2016
5
6 / 13
BUK765R0-100E
Nexperia
003aaf635
400
003aah027
5
VGS(th)
(V)
ID
(A)
max
4
300
3
typ
2
min
200
100
Fig. 8.
Tj = 175 °C
1
Tj = 25 °C
4
6
VGS (V)
8
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aah028
10-1
ID
(A)
Fig. 9.
60
120
T j (°C)
180
Gate-source threshold voltage as a function of
003aaf640
10
RDSon
(mΩ)
10-2
VGS (V) = 5.0
4.5
8
min
10-3
typ
max
5.5
6
6.0
7.0
10-4
4
10-5
2
10-6
4
VGS (V)
Fig. 10. Sub-threshold drain current as a function of
gate-source voltage
BUK765R0-100E
Product data sheet
10
100
150
ID (A)
200
Tj = 25 °C; tp = 300 µs
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
28 July 2016
7 / 13
BUK765R0-100E
Nexperia
003aaj323
3
003aaf641
10
VGS
(V)
a
2.4
8
1.8
6
1.2
4
0.6
2
120
Tj (°C)
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
14 V
VDS = 80 V
100
150
200
Tj = 25 °C; ID = 25 A
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
003aaf637
105
VDS
QG (nC)
C
(pF)
ID
104
VGS(pl)
Ciss
VGS(th)
VGS
QGS2
QGS1
QGS
103
Coss
QGD
QG(tot)
Crss
003aaa508
102
10-1
Fig. 14. Gate charge waveform definitions
1
10
102
VDS (V)
103
VGS = 0 V; f = 1 MHz
Fig. 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK765R0-100E
Product data sheet
28 July 2016
8 / 13
BUK765R0-100E
Nexperia
003aaf642
200
IS
(A)
150
100
50
Tj = 175 °C
Tj = 25 °C
0.6
0.9
V SD (V)
1.2
VGS = 0 V
Fig. 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values
BUK765R0-100E
Product data sheet
28 July 2016
9 / 13
BUK765R0-100E
Nexperia
11. Package outline
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
SOT404
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
b2
c
b
e
e
Q
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
A1
b
b2
c
4.5
1.40 0.85 1.45 0.64
4.1
1.27 0.60 1.05 0.46
D
D1
E
11
1.6
10.3
1.2
9.7
e
2.54
HD
Lp
Q
15.8
2.9
2.6
14.8
2.1
2.2
sot404_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
06-03-16
13-02-25
SOT404
Fig. 17. Package outline D2PAK (SOT404)
BUK765R0-100E
Product data sheet
28 July 2016
10 / 13
BUK765R0-100E
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
12. Legal information
12.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
BUK765R0-100E
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
28 July 2016
11 / 13
BUK765R0-100E
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BUK765R0-100E
Product data sheet
28 July 2016
12 / 13
BUK765R0-100E
Nexperia
13. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
Package outline ................................................... 10
12
12.1
12.2
12.3
12.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 28 July 2016
BUK765R0-100E
Product data sheet
28 July 2016
13 / 13
很抱歉,暂时无法提供与“BUK765R0-100E,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 800+15.19443800+1.97491
- 2400+13.697142400+1.78030
