PSMN2R2-40PS,127
PSMN2R2-40PS,127
    NEXPERIA(安世)
    SOT78
    MOS管 N-channel Id=100A VDS=40V SOT78
PSMN2R2-40PS,127 数据手册
PSMN2R2-40PS N-channel 40 V 2.1 mΩ standard level MOSFET 22 February 2013 Product data sheet 1. General description Standard level N-channel MOSFET in TO220 package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 2. Features and benefits • • High efficiency due to low switching and conduction losses Suitable for standard level gate drive sources 3. Applications • • • • DC-to-DC convertors Load switching Motor control Server power supplies 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 40 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 3; Fig. 1 - - 100 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 306 W - 1.75 2.1 mΩ - 25 - nC Static characteristics RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 25 °C; [1] Fig. 12 Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 80 A; VDS = 20 V; Fig. 14; Fig. 15 [1] Measured 3 mm from package. PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain 3 S source mb D drain Simplified outline Graphic symbol D mb G mbb076 S 1 2 3 TO-220AB (SOT78) 6. Ordering information Table 3. Ordering information Type number Package PSMN2R2-40PS Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 7. Marking Table 4. Marking codes Type number Marking code PSMN2R2-40PS PSMN2R2-40PS 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 40 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 40 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 100 °C; Fig. 1 - 100 A VGS = 10 V; Tmb = 25 °C; Fig. 3; Fig. 1 - 100 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 1122 A IDM peak drain current PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 2 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 306 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 100 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 1122 A VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; - 1.24 J Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Vsup ≤ 40 V; unclamped; RGS = 50 Ω 003aak896 300 ID (A) 250 03aa16 120 Pder (%) 200 80 150 100 40 (1) 50 0 0 50 100 150 Tj (°C) (1) Capped at 100 A due to package Fig. 1. Continuous drain current as a function of mounting base temperature PSMN2R2-40PS Product data sheet 0 200 Fig. 2. 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 22 February 2013 50 © Nexperia B.V. 2017. All rights reserved 3 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 003aad316 104 ID (A) Limit RDSon = V DS / ID 103 tp = 10 µs 100 µs 102 (1) DC 10 1 ms 10 ms 100 ms 1 10-1 Fig. 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 0.25 0.5 K/W 003aad100 1 Zth (j-mb) (K/W) 10-1 δ = 0.5 0.2 0.1 -2 10 0.05 0.02 P δ= tp T 10-3 single shot 10-4 10-6 Fig. 4. tp 10-5 10-4 10-3 10-2 10-1 t T 1 tp (s) 10 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 4 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 10. Characteristics Table 7. Characteristics Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 36 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 40 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; - - 4.6 V 1 - - V 2 3 4 V VDS = 40 V; VGS = 0 V; Tj = 25 °C - - 10 µA VDS = 40 V; VGS = 0 V; Tj = 125 °C - - 200 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 25 A; Tj = 100 °C; - 2.4 2.85 mΩ - 3.25 3.9 mΩ - 1.75 2.1 mΩ f = 1 MHz - 1 - Ω total gate charge ID = 0 A; VDS = 0 V; VGS = 10 V - 110 - nC ID = 80 A; VDS = 20 V; VGS = 10 V; - 130 - nC QGS gate-source charge Fig. 14; Fig. 15 - 42 - nC QGS(th) pre-threshold gatesource charge - 24 - nC QGS(th-pl) post-threshold gatesource charge - 18 - nC QGD gate-drain charge - 25 - nC VGS(pl) gate-source plateau voltage ID = 80 A; VDS = 20 V; Fig. 14; Fig. 15 - 4.95 - V Ciss input capacitance VDS = 20 V; VGS = 0 V; f = 1 MHz; - 8423 - pF output capacitance Tj = 25 °C; Fig. 16 - 1671 - pF Static characteristics V(BR)DSS VGS(th) Fig. 10 ID = 1 mA; VDS = VGS; Tj = 175 °C; Fig. 10 ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 11; Fig. 10 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 12; Fig. 13 VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 12; Fig. 13 VGS = 10 V; ID = 25 A; Tj = 25 °C; [1] Fig. 12 RG internal gate resistance (AC) Dynamic characteristics QG(tot) Coss PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 5 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET Symbol Parameter Conditions Min Typ Max Unit Crss reverse transfer capacitance - 814 - pF td(on) turn-on delay time VDS = 20 V; RL = 0.25 Ω; VGS = 10 V; - 33.2 - ns RG(ext) = 1.5 Ω tr rise time - 40.4 - ns td(off) turn-off delay time - 66.6 - ns tf fall time - 25.2 - ns IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 17 - 0.85 1.2 V IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; - 53.7 - ns - 80.75 - nC Source-drain diode VSD source-drain voltage trr reverse recovery time VDS = 20 V Qr recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 20 V; Tj = 25 °C [1] 300 ID 20 (A) 10 250 8 Measured 3 mm from package. 003aad116 6 VGS (V) = 5.5 003aad118 250 ID (A) 200 200 150 5 150 175 °C 100 25 °C 100 50 0 Fig. 5. 50 4.5 0 1 2 3 VDS (V) 0 4 Output characteristics: drain current as a Fig. 6. function of drain-source voltage; typical values PSMN2R2-40PS Product data sheet 0 3 4.5 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 22 February 2013 1.5 © Nexperia B.V. 2017. All rights reserved 6 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 003aad122 12000 C (pf) 10000 003aad123 250 gfs (S) C iss 200 8000 150 Crss 6000 100 4000 50 2000 10-1 Fig. 7. 1 VGS (V) 0 10 Input and reverse transfer capacitances as a function of gate-source voltage; typical values Fig. 8. 003aad124 30 RDS(on) (mΩ) 25 0 50 100 150 ID (A) 200 Forward transconductance as a function of drain current; typical values 003aad280 5 VGS(th) (V) 4 max 20 3 typ 15 2 min 10 1 5 0 Fig. 9. 0 5 10 15 VGS (V) 0 - 60 20 Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN2R2-40PS Product data sheet 0 60 120 Tj (°C) 180 Fig. 10. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 7 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 03aa35 10- 1 ID (A) min 10- 2 typ 003aad117 6 VGS (V) = 5 RDSon (mΩ) 5 max 10- 3 4 10- 4 3 5.5 6 10- 5 2 8 20 10- 6 0 2 4 VGS (V) 1 6 Fig. 11. Sub-threshold drain current as a function of gate-source voltage 10 0 50 100 150 200 250 300 ID (A) Fig. 12. Drain-source on-state resistance as a function of drain current; typical values 03aa27 2 VDS a ID 1.5 VGS(pl) VGS(th) 1 VGS QGS1 0.5 QGS2 QGS QGD QG(tot) 003aaa508 0 - 60 0 60 120 Tj (° C) Fig. 14. Gate charge waveform definitions 180 Fig. 13. Normalized drain-source on-state resistance factor as a function of junction temperature PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 8 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 003aad120 10 VGS (V) 8 003aad121 12000 C (pF) VDS = 10 V 6 Ciss 8000 VDS = 20V 4 4000 2 C oss 0 0 50 100 QG (nC) Crss 0 10-1 150 1 10 VDS (V) 102 Fig. 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values Fig. 15. Gate-source voltage as a function of gate charge; typical values 003aad119 100 IS (A) 80 60 40 20 0 25 °C Tj = 175 °C 0 0.2 0.4 0.6 0.8 Vsd (V) 1 Fig. 17. Source current as a function of source-drain voltage; typical values PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 9 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 11. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) e c e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig. 18. Package outline TO-220AB (SOT78) PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 10 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN2R2-40PS Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 11 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 12 / 13 PSMN2R2-40PS Nexperia N-channel 40 V 2.1 mΩ standard level MOSFET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 February 2013 PSMN2R2-40PS Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2013 © Nexperia B.V. 2017. All rights reserved 13 / 13
PSMN2R2-40PS,127 价格&库存
很抱歉,暂时无法提供与“PSMN2R2-40PS,127”相匹配的价格&库存,您可以联系我们找货
PSMN2R2-40PS,127
  • 1+38.12230
  • 10+22.74120
  • 20+15.91890
  • 50+11.37060
  • 100+10.80210
  • 500+10.00610
