PSMN4R5-40PS
N-channel 40 V 4.6 mΩ standard level MOSFET
Rev. 02 — 25 June 2009
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel MOSFET in TO220 package qualified to 175 °C. This product is
designed and qualified for use in a wide range of industrial, communications and domestic
equipment.
1.2 Features and benefits
High efficiency due to low switching
and conduction losses
Suitable for standard level gate drive
sources
1.3 Applications
DC-to-DC convertors
Motor control
Load switching
Server power supplies
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
40
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1
100
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
148
W
VGS = 10 V; ID = 25 A;
VDS = 20 V; see Figure 14;
see Figure 15
8.8
nC
3.9
4.6
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
[1]
drain-source
on-state resistance
Measured 3 mm from package.
Tj = 25 °C; see Figure 13;
[1]
PSMN4R5-40PS
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
S
1 2 3
SOT78
(TO-220AB; SC-46)
3. Ordering information
Table 3.
Type number
Package
Name
Description
PSMN4R5-40PS
TO-220AB;
SC-46
plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78
TO-220AB
Version
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
40
V
Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ
VDGR
drain-gate voltage
VGS
gate-source voltage
ID
drain current
40
V
-20
V
VGS = 10 V; Tmb = 100 °C; see Figure 1
96
A
VGS = 10 V; Tmb = 25 °C; see Figure 1
100
A
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
545
A
Ptot
total power dissipation
148
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
100
A
ISM
peak source current
545
A
152
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 40 V;
avalanche energy
unclamped; RGS = 50 Ω
PSMN4R5-40PS_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
PSMN4R5-40PS
Nexperia
003aad008
150
ID
(A)
03aa16
120
Pder
80
100
(1)
50
40
Fig 1.
50
100
150
Tmb (°C)
200
100
150
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
003aad297
103
Limit RDSon = VDS / ID
ID
(A)
10
10 μs
2
(1)
100 μs
10
DC
1 ms
10 ms
100 ms
1
10-1
Fig 3.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN4R5-40PS_2
Product data sheet
3 of 13
PSMN4R5-40PS
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-mb)
thermal resistance from see Figure 4
junction to mounting
base
Min
Typ
Max
Unit
0.65
1
K/W
003aad007
1
Zth(j-mb) δ = 0.5
(K/W)
0.2
10-1 0.1
0.05
0.02
10-2
δ=
P
tp
T
10-3
single shot
t
tp
T
10
Fig 4.
-4
10-6
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration; typical
values
PSMN4R5-40PS_2
Product data sheet
4 of 13
PSMN4R5-40PS
Nexperia
6. Characteristics
Table 6.
Characteristics
Tested to JEDEC standards where applicable.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = -55 °C
36
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
40
V
ID = 1 mA; VDS = VGS; Tj = -55 °C; see
Figure 11; see Figure 12
4.6
V
ID = 1 mA; VDS = VGS; Tj = 175 °C; see
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C; see
2
3
4
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
3
µA
VDS = 40 V; VGS = 0 V; Tj = 125 °C
60
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 10 V; ID = 25 A; Tj = 100 °C; see
Figure 13
6.7
mΩ
3.9
4.6
mΩ
0.97
Ω
ID = 0 A; VDS = 0 V; VGS = 10 V
35
nC
ID = 25 A; VDS = 20 V; VGS = 10 V; see
Figure 14; see Figure 15
42.3
nC
13.8
nC
7.9
nC
VGS = 10 V; ID = 25 A; Tj = 25 °C; see
Figure 13;
RG
internal gate resistance f = 1 MHz
(AC)
[1]
QG(tot)
total gate charge
QGS
gate-source charge
QGS(th)
pre-threshold
gate-source charge
QGS(th-pl)
post-threshold
gate-source charge
5.9
nC
QGD
gate-drain charge
8.8
nC
VGS(pl)
gate-source plateau
voltage
ID = 25 A; VDS = 20 V; see Figure 14
4.8
V
Ciss
input capacitance
2683
pF
Coss
output capacitance
VDS = 12 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 16
660
pF
Crss
reverse transfer
capacitance
290
pF
td(on)
turn-on delay time
19
ns
tr
rise time
23
ns
td(off)
turn-off delay time
30
ns
tf
fall time
9
ns
VDS = 12 V; RL = 0.5 Ω; VGS = 10 V;
RG(ext) = 4.7 Ω
PSMN4R5-40PS_2
Product data sheet
5 of 13
PSMN4R5-40PS
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C; see
Figure 17
0.75
1.2
V
trr
reverse recovery time
IS = 50 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V
40
ns
Qr
recovered charge
VDS = 20 V; Tj = 25 °C
33
nC
[1]
003aad020
300
ID
(A)
250
10
003aad021
10
RDSon
(mΩ)
7.5
VGS (V) = 7
6
7
VGS (V) = 6.5
8
7.5
200
6.5
6
150
6
10
100
5.5
50
4
15
5
2
Fig 5.
1
2
3
4
5
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 6.
100
150
200
ID (A)
250
Drain-source on-state resistance as a function
of drain current; typical values
PSMN4R5-40PS_2
Product data sheet
50
6 of 13
PSMN4R5-40PS
Nexperia
003aad022
100
ID
(A)
80
003aad026
4000
C
(pF)
Ciss
3000
60
Crss
2000
40
Tj = 175 °C
25 °C
Fig 7.
2
4
6 V (V) 8
GS
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aad027
100
Fig 8.
2
4
6
8
10
VGS (V)
Input and reverse transfer capacitances as a
003aad028
25
RDSon
(mΩ)
gfs
(S)
15
50
10
25
5
Fig 9.
25
50
75
ID (A) 100
Forward transconductance as a function of
15
VGS (V)
Fig 10. Drain-source on-state resistance as a function
PSMN4R5-40PS_2
Product data sheet
5
7 of 13
PSMN4R5-40PS
Nexperia
03aa35
10−1
ID
(A)
003aad280
5
VGS(th)
(V)
min
10−2
typ
max
4
10−3
3
10−4
2
10−5
1
10−6
4
6
VGS (V)
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
max
typ
min
−60
120
180
Tj (°C)
Fig 12. Gate-source threshold voltage as a function of
03aa27
2
VDS
a
ID
1.5
VGS(pl)
VGS(th)
1
VGS
QGS1
0.5
QGS2
QGS
QGD
QG(tot)
003aaa508
−60
120
Tj (°C)
180
Fig 14. Gate charge waveform definitions
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature
PSMN4R5-40PS_2
Product data sheet
8 of 13
PSMN4R5-40PS
Nexperia
003aad024
10
003aad025
104
VGS
(V)
8
Ciss
C
(pF)
VDS = 20V
Coss
6
103
4
Crss
2
102
10-1
40
50
QG (nC)
1
10
VDS (V)
102
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
Fig 15. Gate-source voltage as a function of gate
charge; typical values
003aad023
100
IS
(A)
80
60
40
175 °C
Tj = 25 °C
0.4
0.6
0.8
1
VSD (V)
Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values
PSMN4R5-40PS_2
Product data sheet
9 of 13
PSMN4R5-40PS
Nexperia
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
c
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig 18. Package outline SOT78 (TO-220AB)
PSMN4R5-40PS_2
Product data sheet
10 of 13
PSMN4R5-40PS
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN4R5-40PS_2
20090625
Product data sheet
PSMN4R5-40PS_1
Modifications:
PSMN4R5-40PS_1
Data sheet status changed from objective to product.
Various changes to content.
20090507
Objective data sheet
PSMN4R5-40PS_2
Product data sheet
11 of 13
PSMN4R5-40PS
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN4R5-40PS_2
Product data sheet
12 of 13
Nexperia
PSMN4R5-40PS
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Contact information. . . . . . . . . . . . . . . . . . . . . .12
Date of release: 25 June 2009
很抱歉,暂时无法提供与“PSMN4R5-40PS,127”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.244961+2.88150
- 10+16.7491510+2.16960
- 100+15.00445100+1.94360
- 国内价格
- 1+20.69798
- 10+15.52349
- 100+13.95437
