PSMN9R5-100PS,127
PSMN9R5-100PS,127
    NEXPERIA(安世)
    SOT78
    MOS管 N-channel Id=89A VDS=100V SOT78
PSMN9R5-100PS,127 数据手册
PSMN9R5-100PS N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 17 October 2013 Product data sheet 1. General description Standard level N-channel MOSFET in a TO220 packages qualified to 175C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 2. Features and benefits • • High efficiency due to low switching and conduction losses Suitable for standard level gate drive 3. Applications • • • • DC-to-DC converters Load switching Motor control Server power supplies 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current Tmb = 25 °C; VGS = 10 V; Fig. 1 - - 89 A Ptot total power dissipation Tmb = 25 °C; Fig. 2 - - 211 W VGS = 10 V; ID = 15 A; Tj = 25 °C; - 8.16 9.6 mΩ Static characteristics RDSon drain-source on-state resistance Fig. 13 Dynamic characteristics QGD QG(tot) gate-drain charge VGS = 10 V; ID = 60 A; VDS = 50 V; - 23 - nC total gate charge Fig. 14; Fig. 15 - 82 - nC VGS = 10 V; Tj(init) = 25 °C; ID = 89 A; - - 177 mJ Avalanche ruggedness EDS(AL)S non-repetitive drainsource avalanche energy Vsup ≤ 100 V; unclamped; RGS = 50 Ω PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol D mb G mbb076 S 1 2 3 TO-220AB (SOT78) 6. Ordering information Table 3. Ordering information Type number Package PSMN9R5-100PS Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 7. Marking Table 4. Marking codes Type number Marking code PSMN9R5-100PS PSMN9R5-100PS 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 100 °C; Fig. 1 - 63 A VGS = 10 V; Tmb = 25 °C; Fig. 1 - 89 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 355 A IDM peak drain current PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 2 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tmb = 25 °C; Fig. 2 - 211 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 89 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 355 A VGS = 10 V; Tj(init) = 25 °C; ID = 89 A; - 177 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Vsup ≤ 100 V; unclamped; RGS = 50 Ω 003aae016 100 ID (A) 03aa16 120 Pder (%) 80 80 60 40 40 20 0 Fig. 1. 0 50 100 Continuous drain current as a function of mounting base temperature PSMN9R5-100PS Product data sheet 0 150 200 Tmb (°C) Fig. 2. 0 100 150 Tmb (°C) 200 Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 17 October 2013 50 © Nexperia B.V. 2017. All rights reserved 3 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 003aae017 103 ID (A) Limit RDSon = VDS / ID 102 tp = 10 µs 100 µs 10 DC 1 1 ms 10 ms 100 ms 10- 1 1 Fig. 3. 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 4 - 0.38 0.71 K/W 003aad142 1 Zth(j-mb) δ = 0.5 (K/W) 10- 1 0.2 0.1 0.05 0.02 10- 2 single shot P δ= tp T 10- 3 tp 10- 4 10- 6 Fig. 4. 10- 5 10- 4 10- 3 10- 2 10- 1 t T 1 tp (s) 10 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 4 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 90 - - V ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C; 1 - - V 2 3 4 V - - 4.8 V VDS = 100 V; VGS = 0 V; Tj = 125 °C - - 100 µA VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.02 4 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 15 A; Tj = 100 °C; - - 17.3 mΩ - 23.5 27.4 mΩ - 8.16 9.6 mΩ f = 1 MHz - 0.7 - Ω ID = 0 A; VDS = 0 V; VGS = 10 V; Fig. 14 - 67 - nC ID = 60 A; VDS = 50 V; VGS = 10 V; - 82 - nC Static characteristics V(BR)DSS VGS(th) Fig. 10; Fig. 11 ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 10; Fig. 11 ID = 1 mA; VDS = VGS; Tj = -55 °C; Fig. 10; Fig. 11 IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Fig. 12 VGS = 10 V; ID = 15 A; Tj = 175 °C; Fig. 12 VGS = 10 V; ID = 15 A; Tj = 25 °C; Fig. 13 RG internal gate resistance (AC) Dynamic characteristics QG(tot) total gate charge QGS gate-source charge Fig. 14; Fig. 15 - 21 - nC QGS(th) pre-threshold gatesource charge ID = 60 A; VDS = 50 V; VGS = 3 V; - 13.1 - nC Fig. 14 post-threshold gatesource charge - 7.8 - nC Fig. 14 - 23 - nC QGS(th-pl) QGD gate-drain charge ID = 60 A; VDS = 50 V; VGS = 10 V; ID = 60 A; VDS = 50 V; VGS = 10 V; Fig. 14; Fig. 15 VGS(pl) gate-source plateau voltage VDS = 50 V; Fig. 14; Fig. 15 - 4.5 - V Ciss input capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; - 4454 - pF output capacitance Tj = 25 °C; Fig. 16 - 302 - pF Coss PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 5 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 Symbol Parameter Conditions Min Typ Max Unit Crss reverse transfer capacitance - 185 - pF td(on) turn-on delay time VDS = 50 V; RL = 0.8 Ω; VGS = 10 V; - 22 - ns RG(ext) = 4.7 Ω; Tj = 25 °C tr rise time - 25.2 - ns td(off) turn-off delay time - 52.2 - ns tf fall time - 22.8 - ns IS = 15 A; VGS = 0 V; Tj = 25 °C; Fig. 17 - 0.85 1.2 V Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 20 A; dIS/dt = 100 A/µs; VGS = 0 V; - 61.5 - ns recovered charge VDS = 50 V - 157 - nC Qr 003aae025 30 RDSon (mΩ) Fig. 5. C (pF) 24 600 0 18 400 0 12 200 0 6 003aae022 800 0 4 8 12 16 VGS (V) 0 20 Drain-source on-state resistance as a function of gate-source voltage; typical values. PSMN9R5-100PS Product data sheet Fig. 6. Ciss Crss 0 6 9 VGS (V) 12 Input and reverse transfer capacitances as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 17 October 2013 3 © Nexperia B.V. 2017. All rights reserved 6 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 003aae021 150 003aae019 100 ID (A) gfs (S) 5 10 5.5 75 4.8 100 4.7 50 4.5 50 25 4.3 VGS (V) = 4 0 Fig. 7. 0 20 40 60 I D (A) 0 80 Forward transconductance as a function of drain current; typical values 003aae020 80 Fig. 8. 0 0.5 1 2 03aa35 10- 1 min 10- 2 60 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values ID (A) ID (A) 1.5 typ max 10- 3 40 10- 4 20 Tj = 175 °C 0 Fig. 9. 0 2 10- 5 Tj = 25 °C 4 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical valuesvalues PSMN9R5-100PS Product data sheet 10- 6 0 2 4 VGS (V) 6 Fig. 10. Sub-threshold drain current as a function of gate-source voltage All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 7 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 003aad280 5 003aad774 3.2 VGS(th) (V) a 4 max 3 2.4 typ 1.6 2 min 0.8 1 0 - 60 0 60 120 Tj (°C) 0 -60 180 Fig. 11. Gate-source threshold voltage as a function of junction temperature 0 60 120 Tj (°C) 180 Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature 003aae024 40 VGS (V) = 4.5 RDSon (mΩ) 4.7 VDS 4.8 ID 30 VGS(pl) VGS(th) 5 20 VGS QGS1 10 5.5 10 QGS2 QGS QGD QG(tot) 003aaa508 0 0 25 50 75 I D (A) Fig. 14. Gate charge waveform definitions 100 Fig. 13. Drain-source on-state resistance as a function of drain current; typical values PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 8 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 003aae026 10 003aae023 104 C (pF) VGS (V) 8 Ciss VDS = 20 V 6 50 V 103 4 Coss 2 Crss 0 0 25 50 75 QG (nC) 102 10-1 100 1 10 VDS (V) 102 Fig. 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values Fig. 15. Gate-source voltage as a function of gate charge; typical values 003aae027 100 IS (A) 75 50 25 Tj = 175 °C 0 0 0.3 Tj = 25 °C 0.6 0.9 VSD (V) 1.2 Fig. 17. Source current as a function of source-drain voltage; typical values PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 9 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 11. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) e c e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig. 18. Package outline TO-220AB (SOT78) PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 10 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PSMN9R5-100PS Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 11 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 12 / 13 PSMN9R5-100PS Nexperia N-channel 100 V 9.6 mΩ standard level MOSFET in T0220 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 Package outline ................................................... 10 12 12.1 12.2 12.3 12.4 Legal information .................................................11 Data sheet status ............................................... 11 Definitions ...........................................................11 Disclaimers .........................................................11 Trademarks ........................................................ 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 October 2013 PSMN9R5-100PS Product data sheet All information provided in this document is subject to legal disclaimers. 17 October 2013 © Nexperia B.V. 2017. All rights reserved 13 / 13
PSMN9R5-100PS,127
物料型号:PSMN9R5-100PS 器件简介:PSMN9R5-100PS是一款由Nexperia生产的N沟道逻辑电晶体。
引脚分配:该器件采用SOP-8封装,引脚1为D(漏极),引脚2为S(源极),引脚3为空脚,引脚4为S(源极),引脚5为空脚,引脚6为G(栅极),引脚7为空脚,引脚8为S(源极)。
参数特性:VDS最大值为100V,ID最大值为4.2A,工作温度范围为-55°C至150°C。
功能详解:该器件具有低导通电阻和高速开关特性,适用于高频开关应用。
应用信息:广泛用于电源管理、电机控制和变频器等应用。
封装信息:SOP-8封装。
PSMN9R5-100PS,127 价格&库存
很抱歉,暂时无法提供与“PSMN9R5-100PS,127”相匹配的价格&库存,您可以联系我们找货
PSMN9R5-100PS,127
  • 5000+10.490755000+1.35892
