PSMN3R3-80PS,127
PSMN3R3-80PS,127
    NEXPERIA(安世)
    SOT78
    MOS管 N-channel Id=120A VDS=80V SOT78
PSMN3R3-80PS,127 数据手册
PSMN3R3-80PS N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 Rev. 1 — 27 October 2011 Product data sheet 1. Product profile 1.1 General description Standard level N-channel MOSFET in TO-220 package qualified to 175C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits  High efficiency due to low switching and conduction losses  Suitable for standard level gate drive 1.3 Applications  DC-to-DC converters  Motor control  Load switch  Server power supplies 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 80 V - - 120 A - - 338 W -55 - 175 °C - 4.6 5.4 mΩ - 2.8 3.3 mΩ ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 Ptot total power dissipation Tmb = 25 °C; see Figure 2 Tj junction temperature [1] Static characteristics RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 100 °C; see Figure 12 VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 13 [2] Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge VGS = 10 V; ID = 75 A; VDS = 40 V; see Figure 14; see Figure 15 - 27 - nC - 139 - nC - - 676 mJ Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy [1] Continuous current is limited by package. [2] Measured 3 mm from package. VGS = 10 V; Tj(init) = 25 °C; ID = 120 A; Vsup ≤ 80 V; RGS = 50 Ω; unclamped PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain 3 S source mb D drain Simplified outline Graphic symbol mb D G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number PSMN3R3-80PS PSMN3R3-80PS Product data sheet Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 2 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 80 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 80 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 [1] - 120 A VGS = 10 V; Tmb = 25 °C; see Figure 1 [1] - 120 A - 830 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 338 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C - 120 A Source-drain diode [1] IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 830 A VGS = 10 V; Tj(init) = 25 °C; ID = 120 A; Vsup ≤ 80 V; RGS = 50 Ω; unclamped - 676 mJ Avalanche ruggedness non-repetitive drain-source avalanche energy EDS(AL)S [1] Continuous current is limited by package. ID (A) 003aag824 240 03aa16 120 Pder (%) 200 80 160 120 (1) 80 40 40 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 Product data sheet 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature PSMN3R3-80PS 0 Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 3 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 003aag823 103 Limit RDSon = VDS / ID ID (A) tp =10 μ s 10 2 100 μ s 10 DC 1 ms 10 ms 100 ms 1 10-1 0.1 1 10 100 1000 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 4 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - 0.22 0.44 K/W Rth(j-a) thermal resistance from junction to ambient Vertical in free air - 60 - K/W 003aaf613 1 Zth(j-mb) (K/W) 10-1 δ = 0.5 0.2 0.1 0.05 10-2 P 0.02 δ= tp T single shot t tp T -3 10 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 5 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 250 µA; VGS = 0 V; Tj = -55 °C 73 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C Static characteristics V(BR)DSS drain-source breakdown voltage 80 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10 - - 4.6 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 2 3 4 V IDSS drain leakage current VDS = 80 V; VGS = 0 V; Tj = 25 °C - 0.02 10 µA VDS = 80 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VGS = -20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 10 V; ID = 25 A; Tj = 175 °C; see Figure 12 - 6.7 7.9 mΩ VGS = 10 V; ID = 25 A; Tj = 100 °C; see Figure 12 - 4.6 5.4 mΩ - 2.8 3.3 mΩ f = 1 MHz - 0.9 - Ω RDSon drain-source on-state resistance VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 13 RG internal gate resistance (AC) [1] Dynamic characteristics QG(tot) total gate charge ID = 0 A; VDS = 0 V; VGS = 10 V - 135 - nC 139 - nC gate-source charge ID = 75 A; VDS = 40 V; VGS = 10 V; see Figure 14; see Figure 15 - QGS - 51 - nC QGS(th) pre-threshold gate-source charge - 30 - nC QGS(th-pl) post-threshold gate-source charge - 21 - nC QGD gate-drain charge - 27 - nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 40 V; see Figure 14; see Figure 15 - 5.8 - V Ciss input capacitance - 9961 - pF Coss output capacitance VDS = 40 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 - 847 - pF Crss reverse transfer capacitance - 401 - pF td(on) turn-on delay time tr rise time td(off) tf VDS = 40 V; RL = 0.53 Ω; VGS = 10 V; RG(ext) = 10 Ω; ID = 75 A - 41 - ns - 43 - ns turn-off delay time - 109 - ns fall time - 44 - ns PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 6 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit - 0.8 1.2 V - 63 - ns - 121 - nC Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17 trr reverse recovery time Qr recovered charge IS = 25 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 20 V [1] Measured 3 mm from package. 003aaf602 250 gfs (S) 003aaf603 75 ID (A) 200 50 150 100 25 Tj = 175 °C 50 0 0 0 Fig 5. 20 40 60 ID (A) 80 Forward transconductance as a function of drain current; typical values 003aag797 8 RDSon (mΩ) 0 Fig 6. 2 4 VGS (V) 003aaf606 16000 C (pF) Ciss 12000 4 8000 2 4000 0 0 4 8 12 16 Drain-source on-state resistance as a function of gate-source voltage; typical values PSMN3R3-80PS Product data sheet 0 10-1 20 VGS (V) Fig 8. 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 6 Fig 7. Tj = 25 °C Crss 1 2 VGS (V) 10 10 Input and reverse transfer capacitances as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 7 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 003aag796 80 10.0 6.0 5.0 VGS (V) = ID (A) 003aad280 5 VGS(th) (V) 4 max 60 3 typ 4.5 40 2 min 20 1 0 0 Fig 9. 0.2 0.4 0.6 0.8 VDS (V) 0 −60 1 Output characteristics; drain current as a function of drain-source voltage; typical values ID (A) 60 120 180 Tj (°C) Fig 10. Gate-source threshold voltage as a function of junction temperature 03aa35 10−1 0 003aaf608 3 a min 10−2 typ max 2.4 10−3 1.8 10−4 1.2 10−5 0.6 10−6 0 2 4 6 0 -60 0 60 120 VGS (V) Fig 11. Sub-threshold drain current as a function of gate-source voltage PSMN3R3-80PS Product data sheet Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 8 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 003aag798 12 RDSon VGS (V) = (mΩ) 10 VDS 4.5 ID 8 VGS(pl) VGS(th) 6 VGS 5.0 4 QGS1 6.0 QGS 10.0 2 QGS2 QGD QG(tot) 003aaa508 0 0 20 40 60 ID (A) 80 Fig 13. Drain-source on-state resistance as a function of drain current; typical values 003aaf609 10 VGS (V) Fig 14. Gate charge waveform definitions 003aaf610 105 C (pF) 40V 64V 104 7.5 Ciss VDS = 16V 103 5 Coss Crss 102 2.5 0 0 40 80 120 Q (nC)160 G Fig 15. Gate-source voltage as a function of gate charge; typical values PSMN3R3-80PS Product data sheet 10 10-1 1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 9 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 003aaf611 25 IS (A) 20 15 10 5 Tj = 175 °C Tj = 25 °C 0 0 0.25 0.5 0.75 VSD (V) 1 Fig 17. Source current as a function of source-drain voltage; typical values PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 10 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 18. Package outline SOT78 (TO-220AB) PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 11 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN3R3-80PS v.1 20111027 Product data sheet - - PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 12 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 9. Legal information 9.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. PSMN3R3-80PS Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 13 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PSMN3R3-80PS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 October 2011 © Nexperia B.V. 2017. All rights reserved 14 of 15 PSMN3R3-80PS Nexperia N-channel 80 V, 3.3 mΩ standard level MOSFET in TO-220 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 October 2011
PSMN3R3-80PS,127
物料型号:PSMN3R3-80PS
器件简介: - 这是一款标准水平的N沟道MOSFET,封装在TO-220中,适用于工业、通信和家用电器的广泛应用。
引脚分配: - G:栅极 - D:漏极 - S:源极
参数特性: - 漏源电压(Vps):最高80V - 漏极电流(ID):最大120A - 总功耗(Ptot):最大338W - 结温(T):范围-55°C至175°C
功能详解: - 该MOSFET具有由于低开关和导通损耗而带来的高效率。 - 适用于标准电平栅极驱动。 - 快速参考数据显示了在不同条件下的最小、典型和最大值。
应用信息: - 适用于DC-DC转换器、电机控制、负载开关和服务器电源等。
封装信息: - TO-220AB塑料单端封装;带散热器安装;1个安装孔;3引脚TO-220AB。
PSMN3R3-80PS,127 价格&库存
很抱歉,暂时无法提供与“PSMN3R3-80PS,127”相匹配的价格&库存,您可以联系我们找货
PSMN3R3-80PS,127
  • 1+48.451021+6.24627
  • 10+32.2900310+4.16281
  • 100+23.14272100+2.98355
  • 500+19.24245500+2.48073
  • 1000+18.313941000+2.36102
库存:1000
PSMN3R3-80PS,127
  • 1+48.223401+6.21700
库存:5
PSMN3R3-80PS,127
  • 77+41.7024577+5.37625
  • 100+39.56933100+5.10125
  • 500+37.54287500+4.84000
  • 1000+35.409761000+4.56500
  • 10000+33.3832910000+4.30375
库存:4000
PSMN3R3-80PS,127
库存:6750
PSMN3R3-80PS,127
  • 167+28.37620167+3.66190
  • 500+27.11510500+3.49920
  • 1000+25.538601000+3.29570
库存:2000
