PSMN7R5-30MLD
N-channel 30 V, 7.5 mΩ logic level MOSFET in LFPAK33
using NextPowerS3 Technology
11 August 2015
Product data sheet
1. General description
Logic level gate drive N-channel enhancement mode MOSFET in LFPAK33 package.
NextPowerS3 portfolio utilising Nexperia’s unique “SchottkyPlus” technology delivers
high efficiency, low spiking performance usually associated with MOSFETs with an
integrated Schottky or Schottky-like diode but without problematic high leakage current.
NextPowerS3 is particularly suited to high efficiency applications at high switching
frequencies.
2. Features and benefits
Ultra low QG, QGD and QOSS for high system efficiency, especially at higher switching
frequencies
Superfast switching with soft-recovery; s-factor > 1
Low spiking and ringing for low EMI designs
Unique “SchottkyPlus” technology; Schottky-like performance with < 1 µA leakage at
25 °C
Optimised for 4.5 V gate drive
Low parasitic inductance and resistance
High reliability clip bonded and solder die attach Mini Power SO8 package; no glue,
no wire bonds, qualified to 175 °C
Exposed leads for optimal visual solder inspection
3. Applications
On-board DC-to-DC solutions for server and telecommunications
Secondary-side synchronous rectification in telecommunication applications
Voltage regulator modules (VRM)
Point-of-Load (POL) modules
Power delivery for V-core, ASIC, DDR, GPU, VGA and system components
Brushed and brushless motor control
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
30
V
ID
drain current
Tmb = 25 °C; VGS = 10 V; Fig. 2
57
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
45
W
PSMN7R5-30MLD
Nexperia
N-channel 30 V, 7.5 mΩ logic level MOSFET in LFPAK33 using
Symbol
Parameter
Tj
junction temperature
Conditions
Min
Typ
Max
Unit
-55
175
°C
8.2
10.3
mΩ
6.3
7.6
mΩ
1.7
2.5
nC
5.8
8.8
nC
1.2
Static characteristics
RDSon
drain-source on-state
resistance
VGS = 4.5 V; ID = 10 A; Tj = 25 °C;
Fig. 10
VGS = 10 V; ID = 15 A; Tj = 25 °C;
Fig. 10
Dynamic characteristics
QGD
gate-drain charge
VGS = 4.5 V; ID = 15 A; VDS = 15 V;
Fig. 12; Fig. 13
QG(tot)
total gate charge
Fig. 12; Fig. 13
Source-drain diode
S
softness factor
IS = 15 A; VGS = 0 V; dIS/dt = -100 A/µs;
VDS = 15 V; Fig. 16
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
D
G
mbb076
1
2
3
S
4
LFPAK33 (SOT1210)
6. Ordering information
Table 3.
Type number
PSMN7R5-30MLD
Package
Name
Description
Version
LFPAK33
Plastic single ended surface mounted package
(LFPAK33); 8 leads
SOT1210
7. Marking
Table 4.
Marking codes
Type number
Marking code
PSMN7R5-30MLD
7D530L
PSMN7R5-30MLD
Product data sheet
All information provided in this document is subject to legal disclaimers.
11 August 2015
Nexperia B.V. 2017. All rights reserved
2 / 13
PSMN7R5-30MLD
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
30
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ
30
V
VGS
gate-source voltage
-20
V
Ptot
Tmb = 25 °C; Fig. 1
45
W
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
57
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
40
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
230
A
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
Source-drain diode
IS
source current
Tmb = 25 °C
38
A
ISM
peak source current
230
A
28.3
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
VGS = 10 V; Tj(init) = 25 °C; ID = 15 A;
[1]
Vsup ≤ 30 V; RGS = 50 Ω; unclamped;
tp = 97 µs
[1]
PSMN7R5-30MLD
Product data sheet
Protected by 100% test
11 August 2015
3 / 13
PSMN7R5-30MLD
Nexperia
03aa16
120
ID
(A)
Pder
aaa-008398
60
50
40
80
30
10
Fig. 1.
ID
(A)
100
150
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
Fig. 2.
50
75
100
125
150 175
Tmb (°C)
200
Continuous drain current as a function of
aaa-008399
103
Limit RDSon = VDS / ID
102
tp = 10 us
100 us
10
DC
1 ms
10 ms
100 ms
1
10-1
10-1
Fig. 3.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 4
3.1
3.32
K/W
PSMN7R5-30MLD
Product data sheet
11 August 2015
4 / 13
PSMN7R5-30MLD
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-a)
thermal resistance
from junction to
ambient
Fig. 5
57
K/W
Fig. 6
178
K/W
003aaj429
10
Z th(j-mb)
(K/W)
δ = 0.5
1
0.2
0.1
0.05
10
-1
P
0.02
single shot
10
tp
-2
Fig. 4.
10-6
10-5
10-4
10-3
10-2
t
T
10-1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
aaa-008477
aaa-008476
Fig. 5.
tp
T
δ=
PCB layout for thermal resistance junction to
ambient 1" square pad; FR4 Board; 2oz copper
Fig. 6.
ambient minimum footprint; FR4 Board; 2oz
copper
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C
1.2
1.7
2.2
V
V(BR)DSS
VGS(th)
PSMN7R5-30MLD
Product data sheet
11 August 2015
5 / 13
PSMN7R5-30MLD
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ΔVGS(th)/ΔT
voltage variation with
temperature
25 °C ≤ Tj ≤ 150 °C
-3.8
mV/K
IDSS
drain leakage current
VDS = 24 V; VGS = 0 V; Tj = 25 °C
1
µA
VDS = 24 V; VGS = 0 V; Tj = 125 °C
0.26
µA
VGS = 16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
100
nA
8.2
10.3
mΩ
17
mΩ
6.3
7.6
mΩ
12.5
mΩ
f = 1 MHz
0.25
0.49
Ω
ID = 15 A; VDS = 15 V; VGS = 10 V;
11.3
17
nC
5.8
8.8
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
10.2
nC
IGSS
RDSon
gate leakage current
resistance
Fig. 10
VGS = 4.5 V; ID = 10 A; Tj = 150 °C;
Fig. 11; Fig. 10
Fig. 10
VGS = 10 V; ID = 15 A; Tj = 150 °C;
Fig. 11; Fig. 10
RG
gate resistance
QG(tot)
total gate charge
Fig. 12; Fig. 13
ID = 15 A; VDS = 15 V; VGS = 4.5 V;
Fig. 12; Fig. 13
QGS
gate-source charge
1.97
nC
QGS(th)
pre-threshold gatesource charge
Fig. 12; Fig. 13
1.14
nC
QGS(th-pl)
post-threshold gatesource charge
0.83
nC
QGD
gate-drain charge
1.7
2.5
nC
VGS(pl)
gate-source plateau
voltage
ID = 15 A; VDS = 15 V; Fig. 12; Fig. 13
2.9
V
Ciss
input capacitance
VDS = 15 V; VGS = 0 V; f = 1 MHz;
655
982
pF
Coss
output capacitance
Tj = 25 °C; Fig. 14
578
867
pF
Crss
reverse transfer
capacitance
50
75
pF
td(on)
turn-on delay time
VDS = 15 V; RL = 1 Ω; VGS = 4.5 V;
7.1
ns
tr
rise time
RG(ext) = 5 Ω
10.4
ns
td(off)
turn-off delay time
8.5
ns
tf
fall time
5.5
ns
PSMN7R5-30MLD
Product data sheet
11 August 2015
6 / 13
PSMN7R5-30MLD
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Qoss
output charge
VGS = 0 V; VDS = 15 V; f = 1 MHz;
11
nC
Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 15
0.82
1.2
V
trr
reverse recovery time
IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V;
23
46
ns
Qr
recovered charge
VDS = 15 V; Fig. 16
11
22
nC
ta
reverse recovery rise
time
10.2
ns
tb
reverse recovery fall
time
12.6
ns
S
softness factor
1.2
[1]
ID
(A)
includes capacitive recovery
aaa-008400
60
10 V
[1]
4.5 V
3.5 V
aaa-008401
30
RDSon
(mΩ)
24
45
18
VGS = 3 V
30
12
2.8 V
15
6
2.6 V
2.4 V
Fig. 7.
1
1.5
2
2.5
VDS (V)
Output characteristics; drain current as a
Fig. 8.
function of drain-source voltage; typical values
PSMN7R5-30MLD
Product data sheet
6
8
10
12
14
VGS (V)
16
Drain-source on-state resistance as a function
of gate-source voltage; typical values
11 August 2015
4
7 / 13
PSMN7R5-30MLD
Nexperia
ID
(A)
aaa-008392
50
aaa-008402
48
RDSon
(mΩ)
40
2.8 V
3V
3.5 V
36
30
24
150°C
12
Tj = 25°C
4.5 V
VGS = 10 V
Fig. 9.
2
3
4
VGS (V)
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
40
50
ID (A)
60
Fig. 10. Drain-source on-state resistance as a function
of drain current; typical values
VDS
ID
10 V
1.6
VGS(pl)
1.2
VGS(th)
VGS = 4.5 V
0.8
VGS
QGS2
QGS1
0.4
10
003aal037
2
a
60
90
120 150
Tj (°C)
QGS
QGD
QG(tot)
003aaa508
Fig. 12. Gate charge waveform definitions
180
Fig. 11. Normalized drain-source on-state resistance
factor as a function of junction temperature
PSMN7R5-30MLD
Product data sheet
11 August 2015
8 / 13
PSMN7R5-30MLD
Nexperia
VGS
(V)
aaa-008394
10
aaa-008395
104
C
(pF)
8
103
6
Ciss
24 V
Coss
15 V
4
VDS = 6 V
102
Crss
2
4
6
8
10
QG (nC)
10
10-1
12
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
IS
(A)
1
10
VDS (V)
Fig. 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aal160
aaa-008396
102
102
ID
(A)
trr
10
ta
tb
0.25 IRM
150°C
10-1
Tj = 25°C
0.5
0.75
1
IRM
1.25
VSD (V)
t (s)
1.5
Fig. 15. Source current as a function of source-drain
PSMN7R5-30MLD
Product data sheet
Fig. 16. Reverse recovery timing definition
11 August 2015
9 / 13
PSMN7R5-30MLD
Nexperia
11. Package outline
Plastic single ended surface mounted package (LFPAK33); 8 leads
E
e1
L
SOT1210
A
A
c1
b1
E1
mounting
base
D1
D
H
1
4
e
b
w
X
A
A1
c
C
θ
Lp
y C
detail X
Dimensions
Unit(1)
mm
5 mm
scale
A
A1
b
b1
c
c1
D(1)
D1
E(1)
E1
e
e1
H
L
Lp
w
y
max 0.90 0.10 0.35 0.35 0.20 0.30 2.70 2.35 3.40 2.45
3.40 0.25 0.50
nom
0.65 0.65
0.20 0.10
3.20 0.13 0.30
min 0.80 0.00 0.25 0.25 0.10 0.20 2.50 1.90 3.20 2.00
θ
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1210_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
11-12-19
12-03-12
SOT1210
Fig. 17. Package outline LFPAK33 (SOT1210)
PSMN7R5-30MLD
Product data sheet
11 August 2015
10 / 13
PSMN7R5-30MLD
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
12. Legal information
12.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PSMN7R5-30MLD
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
11 August 2015
11 / 13
PSMN7R5-30MLD
Nexperia
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PSMN7R5-30MLD
Product data sheet
11 August 2015
12 / 13
PSMN7R5-30MLD
Nexperia
13. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
Package outline ................................................... 10
12
12.1
12.2
12.3
12.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 August 2015
PSMN7R5-30MLD
Product data sheet
11 August 2015
13 / 13
