PMXB56ENZ
PMXB56ENZ
    NEXPERIA(安世)
    SOT-1215
    MOSFETs 30V 400mW SMT SOT1215 3.2A N-Channel
PMXB56ENZ 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DF N1 01 0D -3 PMXB56EN 30 V, N-channel Trench MOSFET 11 January 2017 Product data sheet 1. General description N-channel enhancement mode Field-Effect Transistor (FET) in a leadless ultra small DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • • • Trench MOSFET technology Leadless ultra small and thin SMD plastic package: 1.1 × 1.0 × 0.37 mm Exposed drain pad for excellent thermal conduction Very low Drain-Source on-state resistance RDSon = 49 mΩ Very fast switching 3. Applications • • • • Low-side load switch and charging switch for portable devices Power management in battery-driven portables LED driver DC-to-DC converters 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - 30 V VGS gate-source voltage -20 - 20 V - - 3.2 A - 49 55 mΩ ID drain current VGS = 10 V; Tamb = 25 °C [1] Static characteristics RDSon [1] drain-source on-state resistance VGS = 10 V; ID = 3.2 A; Tj = 25 °C 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm . PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 S source 3 D drain 4 D drain Simplified outline Graphic symbol D 1 4 G 3 S 017aaa253 2 Transparent top view DFN1010D-3 (SOT1215) 6. Ordering information Table 3. Ordering information Type number Package PMXB56EN Name Description Version DFN1010D-3 DFN1010D-3: plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body 1.1 x 1.0 x 0.37 mm SOT1215 7. Marking Table 4. Marking codes Type number Marking code PMXB56EN 01 10 10 MARKING CODE (EXAMPLE) READING DIRECTION YEAR DATE CODE VENDOR CODE PIN 1 INDICATION MARK MARK-FREE AREA READING EXAMPLE: 11 01 10 Fig. 1. aaa-008041 DFN1010D-3 (SOT1215) binary marking code description PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 2 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - 30 V VGS gate-source voltage ID drain current IDM peak drain current Ptot -20 20 V VGS = 10 V; Tamb = 25 °C [1] - 3.2 A VGS = 10 V; Tamb = 100 °C [1] - 2.8 A Tamb = 25 °C; single pulse; tp ≤ 10 µs total power dissipation Tamb = 25 °C - 15 A [2] - 0.4 W [1] - 1.07 W - 8.33 W Tsp = 25 °C Tj junction temperature -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - 1 A Source-drain diode IS [1] [2] source current [1] Tamb = 25 °C 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm . Device mounted on an FR4 Printed Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 017aaa123 120 Pder (%) Ider (%) 80 80 40 40 0 - 75 Fig. 2. 017aaa124 120 - 25 25 75 125 Tj (°C) Normalized total power dissipation as a function of junction temperature PMXB56EN Product data sheet 0 - 75 175 Fig. 3. - 25 75 125 Tj (°C) 175 Normalized continuous drain current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 11 January 2017 25 © NXP Semiconductors N.V. 2017. All rights reserved 3 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET aaa-009040 102 lD (A) tp = 10 µs 10 tp = 100 µs 1 tp = 1 ms DC; Tamb = 25 °C; 6 cm2 tp = 10 ms DC; Tsp = 25 °C 10-1 tp = 100 ms 10-2 10-1 1 10 102 VDS (V) IDM = single pulse Fig. 4. Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) [1] [2] Conditions in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - 271 312 K/W [2] - 102 117 K/W - 10 15 K/W Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm . aaa-008918 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.5 0.25 0.75 0.33 0.1 0.2 0.05 0.02 10 0 0.01 1 10-3 10-2 10-1 1 102 10 tp (s) 103 FR4 PCB, standard footprint Fig. 5. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 4 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 103 aaa-008919 duty cycle = 1 0.75 0.5 0.33 Zth(j-a) (K/W) 102 10 0.25 0.02 0.01 0 1 10-3 0.2 0.1 0.05 10-2 10-1 FR4 PCB, mounting pad for drain 6 cm Fig. 6. 1 102 10 2 tp (s) 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 5 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V VGSth gate-source threshold voltage ID = 250 µA; VDS=VGS; Tj = 25 °C 1 1.5 2 V IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - - -100 nA VGS = 10 V; ID = 3.2 A; Tj = 25 °C - 49 55 mΩ VGS = 10 V; ID = 2.8 A; Tj = 150 °C - 77 87 mΩ VGS = 4.5 V; ID = 3.2 A; Tj = 25 °C - 56 65 mΩ RDSon drain-source on-state resistance gfs forward transconductance VDS = 10 V; ID = 3.2 A; Tj = 25 °C - 13 - S RG gate resistance Tj = 25 °C; f = 1 MHz - 2.3 - Ω VDS = 15 V; ID = 3.2 A; VGS = 10 V; Tj = 25 °C - 3.6 6.3 nC - 0.5 - nC - 0.4 - nC - 209 - pF - 50 - pF - 17 - pF - 3 - ns - 12 - ns Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 11 - ns tf fall time - 2 - ns - 0.7 1.2 V VDS = 15 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C VDS = 15 V; ID = 3.2 A; VGS = 10 V; RG(ext) = 6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage PMXB56EN Product data sheet IS = 1 A; VGS = 0 V; Tj = 25 °C All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 6 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET aaa-009041 12 5.0 V aaa-009043 10-2 3.5 V ID (A) ID (A) 10-3 3.2 V min 8 typ max 3.0 V 10-4 4 10-5 2.6 V 0 Fig. 7. 2.8 V VGS = 2.5 V 0 1 2.7 V 2 3 VDS (V) 10-6 4 0 1.5 2.0 2.5 VGS (V) Tj = 25 °C; VDS = 5 V Output characteristics: drain current as a Fig. 8. function of drain-source voltage; typical values Sub-threshold drain current as a function of gate-source voltage aaa-009044 2.5 V 2.8 V 3.1 V aaa-009045 300 3.5 V RDSon (mΩ) RDSon (mΩ) 200 200 4.5 V 100 Tj = 150 °C 100 Tj = 25 °C VGS = 10 V 0 4 8 ID (A) 0 12 Tj = 25 °C Fig. 9. 1.0 Tj = 25 °C 300 0 0.5 Product data sheet 2 4 6 8 10 VGS (V) ID = 3.2 A Drain-source on-state resistance as a function of drain current; typical values PMXB56EN 0 Fig. 10. Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 7 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET aaa-009046 12 aaa-009047 1.8 a ID (A) 1.5 8 1.2 Tj = 150 °C 4 0.9 Tj = 25 °C 0 0 1 2 3 4 VGS (V) 0.6 -60 5 0 60 120 Tj (°C) 180 VDS > ID × RDSon Fig. 11. Transfer characteristics: drain current as a function of gate-source voltage; typical values Fig. 12. Normalized drain-source on-state resistance as a function of junction temperature; typical values aaa-009048 3 aaa-009049 103 C (pF) VGS(th) (V) max 2 Ciss 102 Coss typ Crss min 1 0 -60 0 60 10 120 Tj (°C) 1 180 Fig. 13. Gate-source threshold voltage as a function of junction temperature Product data sheet 1 10 VDS (V) 102 f = 1 MHz; VGS = 0 V ID = 0.25 mA; VDS = VGS PMXB56EN 10-1 Fig. 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 8 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET aaa-009050 10 VDS VGS (V) ID 8 VGS(pl) 6 VGS(th) VGS 4 QGS1 2 0 QGS2 0 1 2 3 QG (nC) QGS QGD QG(tot) 003aaa508 Fig. 16. MOSFET transistor: Gate charge waveform definitions 4 ID = 3.2 A; VDS = 15 V; Tamb = 25 °C Fig. 15. Gate-source voltage as a function of gate charge; typical values aaa-009052 4 IS (A) 3 Tj = 150 °C 2 Tj = 25 °C 1 0 0 0.4 0.8 VSD (V) 1.2 VGS = 0 V Fig. 17. Source current as a function of source-drain voltage; typical values 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 18. Duty cycle definition PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 9 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 12. Package outline DFN1010D-3: plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body: 1.1 x 1.0 x 0.37 mm SOT1215 visible depend upon used manufacturing technology (2x) solderable lead end, protrusion max. 0.02 mm (3x) pin 1 index area visible depend upon used manufacturing technology (4x) e b (2x) 1 2 L (2x) E E1 e1 L1 D A1 3 b1 A D1 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b b1 D D1 E E1 e e1 min 0.34 0.22 0.245 1.05 0.87 0.95 0.16 nom 0.37 0.25 0.275 1.10 0.90 1.00 0.19 0.75 max 0.40 0.04 0.30 0.325 1.15 0.95 1.05 0.24 0.1 L L1 0.17 0.195 0.20 0.225 0.25 0.275 Note 1. Dimension A is including plating thickness. Outline version sot1215_po References IEC JEDEC JEITA European projection Issue date 13-03-05 13-03-06 SOT1215 Fig. 19. Package outline DFN1010D-3 (SOT1215) PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 10 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 13. Soldering Footprint information for reflow soldering of DFN1010D-3 package SOT1215 1.2 0.45 (2x) 0.3 1.1 0.35 (2x) 0.4 0.25 (2x) 0.75 0.3 0.5 1.5 1.4 0.4 0.5 0.4 0.3 0.5 1.3 0.4 0.3 0.4 0.5 1.3 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 12-11-23 13-03-06 sot1215_fr Fig. 20. Reflow soldering footprint for DFN1010D-3 (SOT1215) PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 11 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMXB56EN v.3 20170111 Product data sheet - PMXB56EN v.2 Modification: • Section 10. Characteristics: values for forward transconductance and gate resistance changed PMXB56EN v.2 20140430 Product data sheet - PMXB56EN v.1 PMXB56EN v.1 20130925 Product data sheet - - PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 12 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. 15. Legal information Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document [1] [2] status Product [3] status Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PMXB56EN Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 13 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE, MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP Semiconductors N.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 14 / 15 PMXB56EN NXP Semiconductors 30 V, N-channel Trench MOSFET 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 6 11. Test information......................................................... 9 12. Package outline........................................................ 10 13. Soldering................................................................... 11 14. Revision history........................................................12 15. Legal information..................................................... 13 © NXP Semiconductors N.V. 2017. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 January 2017 PMXB56EN Product data sheet All information provided in this document is subject to legal disclaimers. 11 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 15 / 15
PMXB56ENZ 价格&库存
很抱歉,暂时无法提供与“PMXB56ENZ”相匹配的价格&库存,您可以联系我们找货
